Ray
Though I'm now driving a '99 with T/C and ABS, I'll be buying 4 add'l wheels and 4 Michelin Pilot Alpins or Bridgestone Blizzak WS-50s.
I drove an '86 CV (police pkg + limited-slip differential, but no T/C or ABS) until a few months ago and had over the past several years driven a set of 4 studded Firestones, Blizzak WS-15s, and Michelin Arctic Alpins. The Studs are VERY noisy, so I'd recommend the Blizzaks, which were the best glare ice tires I've driven (they're truly amazing!). The Arctic Alpins are very good too -- I tried them after the Blizzaks wore out because the Blizzaks wear quickly and had fairly sloppy handling. The Arctic Alpins handled much better at the expense of some ice traction.
I was MUCH better off than most of the other vehicles on the road, especially when it came to stopping on icy roads. Check out tirerack.com for their reviews.
P.S. I'm in Colorado, but drive on lots of icy
roads since I'm living in the foothills.
Remember, the rear wheels only get you going. Some places this might be good enough, but not in Iowa if you're going to be doing any serious driving. Snow tires on the front are a tremendous advantage in braking, and do a much better job of keeping the car going in the direction that your wheels are turned.
Believe me-- the difference is night and day. I do alot of driving in the Pocono Mountain area of Pennsylvania and I know what good (and bad) tires can do. This goes for people in FWD and AWD too, who I frequently wind up helping since their all-seasons just don't cut it in ice and snow.
What tires to buy? Some dealers will only sell the Blizzak's and the Alpin's in sets of four, since that's what the manufacturer recommends. Both of those names have done very well, but the tread does tend to wear fast.
For my 98CV I went with a set of Nokian Hakka 1's.
Imported from Finland, they're touted as one of the best snow tires in the world. These tires and made for climates where sub-zero weather, deep snow and ice are just normal everyday winter conditions.
I thought they would be expensive, but I got a set of 225/60R16's delivered to my door for just over $100/tire. That's better than what Bridgestone and Michelein have to offer, and these Nokains are made like iron and last MUCH longer.
For a 92 GM you won't need 16" tires, so you can probably do considerably better. Let me know if you need help finding a mail-order dealer.
www.nokiantyres.com.
If you're going to try to get by on two and hope you don't have to stop on a hill, I'd recommend using a traditional studded tire such as the Firestone Winterfire. These tires tend to be readily available, affordable, and offer decent traction.
I see that many of the tire shops will only sell sets of 4 these days - is this a new law or the manufacturers joint decision to avoid potential lawsuits - anyone know? I suspect in the aftermath of "Tiregate" many of us will be investigating the track record of tire manufacturers before slapping new shoes on the family chariot.
I want to replace the wheels/tires with aftermarket alloys and speed rated tires. We drive all summer throught the Mojave desert (120 F in the shade and there ain't none).
Can the Informed recommend sources for alloys and tires? I'm having a devil of a time finding stock wheels -- in a style I like -- and tires to fit.
Phil
We get a bit of ice around here - especially on the gravel lane I live on with a little hill to deal with coming out of the driveway - those studs get me thru every time.
ugh. I don't even want to think about winter...
Other types of snow tires are studless, and they usually have some kind of rubber tread that tries to do the same thing. This would be like the Blizzak and the Alpin.
Keep in mind that steel studs only help you in the ice; they actually reduce your traction in wet weather. I'm still happy with the traction I get on my rear wheels with the steel studs, but I'd never consider putting studs on all four wheels.
I probably wouldn't know how to drive with them anyway...
Hi everyone.
I just bought a used 1999 Grand Marquis LS with 22,500 miles that is in beautiful shape. No scratches, upholstery clean, almost smells new, brakes in great shape, etc. When we test drove it we went up to a maximum of 50 mph due to roads and conditions. No problems.
Just drove the car on the freeway and was able to go up to 70. No problems with power or car ride.
However, starting about 55-60 mph there is a wind type noise that starts in the right side of the front of the car. This sound does not exist at lower speeds.
My suspicion is that it may be have one or two sources: (a)the gasket around the right side of the windshield by not be set properly and there is a slight amount of air leakage that only occurs at higher air speeds; or (b) there is something happening with air vents.
Has anyone else had the problem I described and if so, what was the solution? Are these types of problems typically handled under manufacturers warranty?
Also, would you buy the extended warranty package?
Jim Hill
Does anyone have any suggestions on how I can find what the pressure is for the fuel injection rail of a 1991 grand marquis? Also, any thoughts on where I might be able to get a picture of the timing marks on the fly wheel?
Thanks for your time
Fuel system pressure with key on, engine off: 35 to 45 psi
Fuel system pressure (at idle)
Vacuum hose attached: 30 to 45 psi
Vacuum hose detached: 40 to 50 psi
Fuel system hold pressure (after 5 minutes): 30 to 40 psi
Fuel pump pressure max: 65 psi
Fuel pump hold pressure: 50 psi
IMO I prefer the 5L to the 4.6L; but Chevy did away with their 5L too, so, who am I to say?
I heard it wasn't until '07 for the change on these cars.Hopefully 2006,I think the sooner the better for us.
Have a good evening Troy!
DD
THANKS IN ADVANCE
Until last year, I had a Grand Marq and ran Goodyear Town & Country snows in the winter. They were great. Quiet on dry roads, but had very good traction. (I also carried 100lb of rocks up over the rear axle.) Like someone else said, by driving carefully I even passed 4WD SUVs on some roads. I only wish that I had ordered a limited slip on that car.
In the early 80s I had a FWD Chrysler with the four snows, and would not have full snows on the front wheels again. It really handled poorly on dry roads.
Since last year, I've had a FWD Taurus. Not a bad car, but I really miss the GM ride and engine. I heard that the new Sable/Taurus cars are better, but are they up to the level of the GM/CVics?
Leather has a very pleasant aroma that greets you as you enter the car and makes for a nice ambiance - until it becomes cracked and worn looking over many years of use. The temperature variance is noticeable in extreme hot and cold although the leather warms to your body far more easily than the old vinyl seats of yesteryear ever did. Warm weather heats up the seats to the point that you may notice back perspiration even after the interior has cooled down with a/c. Still - it won't fry the back of your legs like that old vinyl did. In the Cr Vic/GM you may find yourself slipping from side to side in turns since the seats offer very little (read that no) latteral support. That's what the armrests are there for! But if your posterior is of typical American middle aged proportions (read that wide) you may not notice a problem here. The calorically challenged tend to slide around a bit more! Have you heard Boston's PBS Car Talk radio broadcast on the new 'Pinkwater' posterior dimension - a super show and particularly funny episode.
Cloth is very comfortable feeling in all weather, grips your pants a lot better during those highway exit turns and, with the scotchguard treatment, usually does not get stained too bad over years of service. I've had my 3 kids, now ages 8-11, growing up in the back seat of my 2 Grand Marquis ( how does one make the plural here?), a Taurus wagon and now a Suburban - all cloth upholstered without too many serious clean-ups. Now the carpeting is another story entirely! The aroma is missing (unless you count the smell of spilled coffee, coke etc on that floor)
I would enjoy the leather in a well constructed bucket seat and would try the aftermarket sheepskin covers for uncomfortable extremes. My next vehicle may be a mid-sized sedan - perhaps Accord V6, Maxima GLE or possibly Lincoln LS - all offering comfortable leather seating. If I bought another GM or Cr Vic - cloth would be my preference.
BTW - I'm the guy with the studded snows that has passed SUVs and FWDs galore in the snowy ditches of Mass, NH and Maine during my daily carpool commute. Think I'll send for a vanity plate for my GM "studpool" - what do you guys think?
Hope this was interesting/amusing reading to some of your guys, particularly Timbotimbo. Great forum - - let's keep the dialogue going.
Turnpike Ken
Maybe it's that 10w30 he uses on his hair?
the dark red cloth of my '90 Vic still looks (near) perfect. I think the darker color interiors are the best way to go. Especially if you have a garage or can tint your windows.
Its just that all the loaded CVs & GMs that I'm seeing at the dealerships have leather seats. I guess I was just trying to talk myself into them.
Now that I decided on the seats-----I think I would also like to have a moonroof(aftermarket) installed in my new CV or GM. Would that be stupid in that I would be reducing its value & asking for trouble(leaks etc.).
Nice writing style Ken!!!!
Has anyone ever experienced this before? The airbag light on my dash blinks six times, pauses, and then blinks six times again. It does not happen all the time, but occasionally when the car is started. I was wondering if this was a code for a particular problem. Any thoughts?
Thanks again
I fiddled with the switch for a few minutes, but still nothing. Finally, when I played with the stalk (high beam/flash) they turned on and everything was fine after that.
Has anyone had trouble with their headlights coming on? Once I remember driving and they turned off for a quick second. It never happened again so I didn't pay much attention to it. But now it seems like something is flakey.
Anyone else?
according to my 91 shop manual 6 flashes of your light indicates possibly 4 things at fault, either
1 the air bag itself,
2 the clock spring itself,
3 an open circuit in the diagnostic monitor -connector or harness, or
4 the diagnostic monitor itself.
I hope this helps and please do not attempt to trouble shoot this your self unless you know all of the safety precautions before working on the air bag system. the air bag could be accidentally deployed causing injury to anyone in or around the car!
Do not probe the the connectors on the air bag(s) doing so may result in air bag deploymentwich could result in personal injury.
for more info e-mail me
I would like to firm up the ride a bit -- some dips in the local highways really throw the car up into the air.
Philip Halverson
