using transmission for cleanout of old engine
I have been advised from time to time by Grizzled Mechanics that one may clean up an old engine by putting in some transmission fluid (recommendations range from one cup to the entire amount) and driving about for s short distance before an oil and filter change. I have been told that the stuff stuck in the engine will "fly out" and jam in the filter.
I have an 85 Nissan maxima and a 94 Saturn both with essentially 250K miles.
Is this adviseable?
And PS having read the section on oil till I'm sick of it, what oil recs, given that I plan to keep both, the Saturn uses a quart about every 1500 (less if I cruse at 85 for any length of time, longer if I don't) the Nissan uses very little between 3K changes.
Thanks to all
58VW
Is this adviseable?
Thanks to all
58VW
At 250K each on those cars, why not use whatever has gotten them to that mileage? Apparently it works well.(:oÞ
I do not recommend going 3000 miles on this mixture, but have never seen anything on how far to run it. this is a light petroleum solvent that is probably equal to Marvel Mystery Oil and a number of other fine old nostrums that have been around a lot longer than cars themselves.
much newer and safer are the purge pump systems at mechanics shops that run solvent under pressure through your engine.
again, though, unless there is evidence of serious crud buildup, I don't know about doing any of this. it's possible to kick a gob of crud loose that will stick in a lifter galley or worse, and can cause real issues if that happens.
Don't disturb whatever is going on in your old engines. Do not poke a sleeping snake with a stick to find out what might happen.
And stay away from Grizzled mechanics. This is 2002, and cars are way different than they were in 1972. If the Grizzly Guy is keeping up on his technical training, great, but if he drives a 1966 Dodge pickup with bullet holes in it, don't take advice on a 2002 car from him.
At 250K Mr. Sludge is probably your friend or at worst a benign companion.
Just keep changing your oil and filter, drive sanely and be happy.
\Nos"trum\ (-tr[u^]m), n.; pl. Nostrums (-tr[u^]mz). [Neut. sing. of L. noster ours, fr. nos we. See Us.]
1. A medicine, the ingredients of which are kept secret for the purpose of restricting the profits of sale to the inventor or proprietor; a quack medicine.
2. Any scheme or device proposed by a quack
Guess I should patch them bullet holes in mah Dodge.
http://www.auto-rx.com
Usually all of it ends up in the pan.
Now, if any of you have seen how low the oil pickup screen rides in the pan, you would know that it takes very little to plug up the screen.
A plug screen means oil starvation and an engine that is toast in little time.
Don't fall prey to the claims that are made about flushes and chemicals. Unless they chemically break down the sludge into a soluble mixture in the oil and is completely drained out, you are much better to leave it alone.
The ONLY proper way to flush an engine is to flush and then drop the pan and thoroughly clean the pan and oil pump pickup tube. Any other way is asking for trouble.
Now, I know that many are going to say that I am wrong, they have flushed their engines with no problems and all, but in the last 2 years, I have dropped the pans on 7 vehicles that had the engine flush done on it with in 30 days of an oil starvation problem. The only other one I have seen in the last 2 years with an oil starvation problem was one that had just had the timing chain replaced and the shop that did the work let the gasket material drop into the pan, where it promptly plugged the oil pump pickup tube.
well respected by oil enthusiasts and smart folks in the petroleum biz
Now why does that statement scare me?
coming soon to an emailbox near you...
I have no professional affiliation with anyone in any automotive industry but I would hope that people who are interested in this type of product would do their own independent research and come to their own conclusions.
Alcan is a member of a group of us who lend our expertise in the automotive industry to DIYers.
If you would like, you are more than welcome to click on my profile and go to the site listed and ask the folks there about my credentials.
To be honest, I don't care for credentials, nor do I care for having to defend myself.
We spend our time to educate the DIYer/consumer and to protect them. If there is a new product, then we would like to hear of it, but we will remain skeptical. We have seen the results of these great products and it ain't been pretty.
You don't care for having to defend yourself? Well, neither do I. Especially when my original post was simply to add to the level of information and research available for those who are interested in these kinds of products. You made the conscious decision to use my words to make yourself look good and to drive home a personal opinion. So who is attacking whom?
I have no reason to question your experience or knowledge but when it comes down to the bottom line, all you are offering is your opinion. That's it. And your opinions are just as valid as everyone else's.
I have no horse in this race as I have no need for any kind of flush/cleaning product for my car. I'm not defending or speaking for a product, company, self-interest, career, or any individual except for myself.
I appreciate the time and effort you guys spend in educating Town Hall members. I'm sure many people have benefited from it. But you two aren't the only experts in All Things Automotive and I (again) encourage others to do their own research and decide what is best for them and their cars.
I thought I knew a bunch about cars and the old transmission fluid flush is something I've done on all my older vehicles. I usually pop off a vacuum line and let the suction suck the fluid into the motor. I feel really dumb that I never gave a thought to all the crud that could be plugging the oil pump screen.
Luckily, I've never had an engine seize, but I'll change my methods from here on out.
Like they say, "You learn something new every day".
In my opinion, at least you SHOULD be willing to learn something new every day.
[quote]who are you gonna trust? Unknown and unaccountable persons who post tales of doom and gloom on the internet,,,,,,,[endquote]
So tell me, how is a person supposed to take that?
If no one should take that personal, then why did you post it? You clearly had a point to make?
No one used your words against you, they were pretty clear to read.
Ha ha, Alcan and I never said we were the only "experts", But we are offering experience over opinions.
Have fun, I'm done with this one.
So tell me, how is a person supposed to take that? If no one should take that personal, then why did you post it? You clearly had a point to make?
Yes, I had a point to make and I made it. My point was in the second paragraph. Did you read that far? Everyone who read that post of mine should take it for what it's worth to them. You decided to take it personally eventhough it was not directed at you. I can't help that and I'm not going to.
Then why not just let the words stand as is? Your defensive follow up posts were unwarranted if my words were truly clear to read.
No you're not. You are offering your OPINIONS based on your EXPERIENCE. Since your EXPERIENCE is not proven fact and are not independently verifiable, all they are is a collection of personal anecdotes until they are proven FACT. I'll restate it for you: Your EXPERIENCES are only OPINIONS until they are independently proven as FACT. Postulate all the theories you want but that's all they are.
The wisest thing you've said yet.
I got bashed to death over my opinions, which is funny, because I really do get paid to render opinions, to quote:
"Within a reasonable degree of certainly in automotive appraisal, automotive repair and maintenance, and dealership sales and service policy".
0patience does a similar job as mine, so his opinions ARE worth more than the "guy down the street". As arrogant as I am, I can honestly say I've learned something here.
But I don't care to be used as a doormat while others engage in self-aggrandizement at my expense.
There are lots of places online to learn and lots of smart people to learn from. Doesn't take much effort to find them.
If that's pointed at me, I don't accept it since I have no need to "make myself greater" or whatever. I have a great position in the court system and have already proved all I need to prove to whomever I needed to prove it to. I have absolutely nothing to prove to anyone here at Edmunds except that I'm here to help anyone I can in whatever way I can.
No matter.....
Consider the source. Life goes on.
Anyway - I only know of a handful of people who get paid (very well, by the way) for their opinions. The average guy on the street doesn't get paid for his opinion.
For this matter, I'm required to do a bunch more research then the average guy in order to give a true, educated opinion. My opinions are also subject to cross-examination and get scrutinized heavily, picked apart and second-guessed.
You can either understand that I may have more experience in certain areas than the average guy and by that, I'm required to step higher for a basis for my opinion than merely a guess based on reading a magazine article or taking a poll at the local diner.
You can either accept the opinions of true, certified and qualified experts in the various fields of automotive qualifications, or not. Your loss, I figure. Many of us hang out here and compare notes. You can either benefit from our pool of information or continue throwing stones.
I've had stones thrown at me by $300,000 defense attorneys for several major automotive manufacturers - surely a fellow poster on Edmunds can't push my buttons. Have a great day.
The primary point of contention I have with a couple of fellow TH'ers is the fact that they took personal umbrage at a non-targeted comment I made about unsolicited advice which they in turn twisted into a personal attack on me. I keep making my points as clear as I can but they seem to ignore or misunderstand what I'm saying. But then, that seems to be a major problem when one is trying to converse with people who think their opinions and views are more important than those from others. Kinda hard to hear someone else when you've got that old Mac Davis song playing at full blast.
I'm sure you've all noticed that I haven't posted my credentials. The reasons are because I am not positioning myself as an expert in all things automotive and I don't feel I need to impress others with what I do know. I'm not trying to build a fan club - I'm just encouraging others to be open minded about various automotive related products and listen to a variety of opinions from others.
I don't need a fan club, I have a family. I am required, by position and title, to be an "automotive expert". That's what the legal field calls someone with my kind of background who testifies in court as an expert witness. Just like a doctor who also testifies on medical matters. Please get over it - it's my job, just like you do whatever you do.
Don't make blanket comments, attacking people you don't know, who have done nothing to attack you, and you won't have several other people who are offended by your remarks responding to you. Simple as that.
The best way to avoid being offended is to not be offensive to people you don't know, like me. Simple as that.
You're angry that the rest of us don't want to play? Please give it a rest and let's get back to talking about cars.
[quote] Now, you didn't start it, But I'm gonna end it, that's for sure. [endquote]
You are? And how are you going to do that? Are you threatening someone?
I wasn't going to post to this topic again, but that sounds like a threat. Is it? If it is, why?
0patience decided to take those few words of mine and deliver a little sermon about the dangers of flush products. What I took exception to was the fact that 0patience used me PERSONALLY as a doormat to make his point. When you use my words verbatim, you use me. Nothing ticks me off more than someone using my words to further some opinionated agenda. I don't care who they are.
After 0patience and a few others "responded" I felt the need to post a general warning to readers about unknown and unaccountable advice-givers. That wasn't directed at anyone in particular but a few decided to take it personally. The thread headed downhill when Alcan decided to defend 0patience and himself from what he perceived was a personal slight. 0patience also jumped on the bandwagon, taking me to task a second time.
I'm sorry but I am NOT going to put up with that type of conduct directed at me. All 0patience had to do was apologize for using me as an example and restate his comments from a different perspective and all would have been fine by me. The fact that Zueslewis decided to jump into a fray he had no business in and throw is weight around like some self-styled big shot only made me more incensed.
I'll end this little tiff by escalating the volume to the point where the mods will delete all the posts or delete the thread entirely. As of right now that is my main goal. If the mods delete the posts up to my original one where I included that link then things will be back to "normal".
I think this should be clear now. Any questions?
bret - you did post #16, which relates directly to 0patience's post #13, where he disagreed with using transmission fluid due to some very valid reasons. You countered in your post by referring to "unknown and unaccountable" people posting "doom and gloom" on the internet, then picked the fight further by announcing that your "core skill" was as an "internet street fighter". Most of us don't come here to fight, but when blanket statements like yours are made, we tend to defend ourselves. This is not yours, or anyone's, personal "take a shot at someone" website. Relax, take a pill, whatever.
Can we PLEASE get back to talking about the pros and cons of using transmission fluid to flush out old engines?
as for all the smoke... these top cleaners don't burn real well, compared to gas. may not be nice to the catalytic, but I haven't heard of any immediate "if A, then B" cat failures, so it probably is a break-even. you reduce unburned fuel over time, and that makes up for the gut shot now.
http://www.lubegard.com/automotive/index_trans.html
They'll be marketing a product with Aamco and I was told that product will be the "latest & greatest" from them. I imagine it will be easier for consumers to find locally.
BG Products makes many different flushes and machines for a variety of jobs. See all their stuff here: http://www.bgprod.com/products.html
Trans flush products are under "Drive Line Maintenance Services"
Hopefully ol' Tony will chime in with his point of view.
I'm rebuilding my 5.0 in the spring, it has 180,000 miles on it and I need to make sure it lasts - I don't know if I should use a cleaner in it or leave it alone.
