2000 Ford Expedition won't start
1shawn_endicott1shawn_endicott Member Posts: 4
edited December 2015 in Ford
so the other day I had a fender bender at about 20 mph it dented my passenger side bumper and broke my parking light but not my headlight I was able to drive about 5-8 miles then it shut down and still wont start something was leaking pretty bad not oil possibly antifreeze and/or tranny fluid any ideas why it wont start I could really use some help here
    You might check your inertia (fuel shut off) switch, located in the passenger footwell area behind a compartment door. Look for a red button to push and reset.
    If it's not that, then you have to start a methodical diagnosis to see if you are lacking fuel to start, or spark to start.
    One quick test would be to squirt some starting fluid into the air cleaner---if it starts and runs for a few seconds, then you have a fuel delivery problem. If it still doesn't start, then you probably have an ignition problem of some sort, or no signal to your fuel injectors. In that case, buy a simple spark tester from Autozone or Amazon.com, and test for spark as you crank the engine.
    In any event, I wouldn't run this vehicle very far, if at all, until you find out the source of the leak---sounds like coolant leaking, given the location of your accident, but it could also be from a transmission cooler.
  • 1shawn_endicott1shawn_endicott Member Posts: 4
    thank you mr shiftright I will try all your sugestions in the morning once again thank you very much
    so yesterday it would only make a single click sound today I checked the fuel shutoff switch that was in the proper position so I figured I would check to see if it would start and today I hear constint clicking till I release the key from the start position I also hear a sound it sounds as if its a motor running but cant figure out what it is
    Oh I wonder if you starter motor is "motoring"--that is, it is spinning but not engaging the flywheel ring gear.
    how could I check that is there a way I'm guessing the impact could have jerked it outta place?
