M
I cannot post the US website address here, but I am sure a little google would get you there.
Honda Develops World’s First Super Handling All-Wheel-Drive Available this fall in the Acura RL (North America) and the Legend (Japan)
TOKYO - April 1, 2004 --- Honda Motor Co., Ltd. today announced the development of a new Super Handling All-Wheel-Drive system, called SH-AWD, that provides cornering performance that responds faithfully to driver input, and outstanding vehicle stability. A world’s first, the SH-AWD system combines front-rear torque distribution control with independently regulated torque distribution to the left and right rear wheels to freely distribute the optimum amount of torque to all four wheels in accordance with driving conditions. The new system will be available this fall in the Acura RL (North America) and the Legend (Japan).
By monitoring driver input and driving conditions, the SH-AWD system determines the optimum front-rear and lateral (left-right) torque distribution. This information is then conveyed to the rear differential, where direct electromagnetic clutches continuously regulate and vary front-rear torque distribution between ratios of 30:70 and 70:30, and lateral torque distribution in the rear wheels between ratios of 100:0 and 0:100. Torque is used not only for propulsion, but for cornering as well, resulting in a significant enhancement in vehicle maneuverability.
The SH-AWD system is composed of sensors to detect steering angle, lateral g, and other vehicle information; an ECU; and the rear differential. The direct electromagnetic clutches inside the rear differential, another world’s first, employ electromagnets to obtain precise control over the multi-plate clutches. Built-in search coils monitor the gaps between the electromagnets and the magnetic body to achieve precise, continuously variable torque regulation.
The rear differential is also equipped with a built-in acceleration device, yet another world’s first. During cornering, the track of the outside rear wheel normally falls outside the average of the tracks of the front wheels. The outside rear wheel does not rotate fast enough to keep up with the front wheels, preventing efficient transmission of torque. To counteract this problem, the SH-AWD acceleration device alters the gearing to speed up the outside rear wheel’s rotation relative to the front wheels. This reduces torque transmission losses and significantly improves vehicle maneuverability.
At Honda, driving pleasure is regarded as one of the most important factors in vehicle development. The new SH-AWD system features “feed-forward” control, which utilizes the degree of driver input to determine appropriate torque distribution. This results in a super-neutral steering feel that responds with optimal faithfulness to the driver’s handling of the steering wheel, realizing outstanding driving comfort and stability.
http://www.honda.co.jp/HDTV/news/2004-4040401a/
This is the long-overdue Legend!
Who needs V8?! This is coming from a guy who drives '98 BMW 540iA everyday. The new RL is rumored to have 3.5L i-VTEC rated at 300hp (torque around 280lb-ft) More info on April 7 when New York autoshow starts. Stay tuned.
P.S. the test vehicle is NOT new RL. It is Inspire (Japanese version of US Accord. Their Accord is our Acura TSX.. I am sure you probably know that already)
Uh-oh they're at it again...the little engine (company) that could!
M
BTW, now even edmunds pre-NYC autoshow write up talks about a potential Acura RL preview...
Can't wait for the auto show anyways
ksso
I expect they could use a few billion to create a new platform for the RL and sell 70K units here in the US. But I think they rather spend the same cash and sell an extra 200K units of the cars they've already developed, but in new markets.
Merc1 - As far as the way it functions, yes, SH-AWD is similar to ATTS. It distributes power to the outside wheels in a corner. But it manages the shift in power differently.
SH-AWD is very much like VTM-4 (from the Pilot and MDX), except that SH-AWD can vary torque between the left and right rear wheels. And it can also operate with power going to both the front and rear axles all of the time.
The Inspire has a different front end than our Accord, but those taillights do look different. Plus, the steering wheel was on the left. Could this mean that we might be getting a SH-AWD Accord with different taillights for 05???
I do think the use of the Accord tells us quite a bit about the RL, though. The RL may be of a similar weight, wheelbase, and general dimensions. I expect it will be somewhat heavier, luxury equipment and 200 lbs of AWD will do that. But probably not more than 3,800 lbs.
As for changes to the Accord, half of the taillights were covered with black masking, but otherwise unchanged. The test mule wore a decklid spoiler, which kinda made the back end look a little different, but it's a stock item. The only new item I noticed was a strip of chrome above the license plate. Someone else noted that the car had a sportshift transmission, but that might be part of what they were testing along with the rest of the drivetrain.
Living in the darkest ghettos of the Big Apple, I guess I'll see 1st hand how serious ACura will be with the better-very-late-than-never RL. Looks like the TL in the drawing. I hope this new "Performance sedan" comes with a "performing" tranny! Everything else Acura has does.
I couldn't imagine a van and SUV that are EIGHT INCHES wider and several inches longer would come off the Accord platform, but it maybe possible.
DrFill
M
It's like houses. My house is a cape. So is my neighbor's. But he's got an extra 1,000 sq ft, another bath, and two more bedrooms.
http://www.autospies.com/article/index.asp?articleId=2792&cat- egoryId=1
I would say that Infiniti will have a tougher time with the new M45 than Acura will have with the RL. No large Infiniti sedan has ever done well here, ever. The current M is a disaster, V8 and RWD or not. Also, if Nissan really wants the next M to be able to take on the GS and RL, they have got to improve their materials quality. I've driven the G35 Coupe, its a great car, but the interior is barely enough to qualify for a Nissan Sentra. Lexus shoppers will be much more likely to cross town shop with Acura than Infiniti, since Acura appears to be matching them on Interior details lately. I think Lexus\Acura shoppers will be less likely to consider the german brands, and BMW\M-B\Audi shoppers will be even less likely to consider a car from Japan. I dont think either will consider an STS. I dont know anyone that actually likes the look of that thing.
I think you focused too much on interior quality. Ask any BMW guys who buy BMW for the interior?! People buy BMW for the driving dynamics. The closest things from Japanese brands are from Honda(Acura) and Nissan(Infiniti) (maybe Lexus GS). There are only BMW and Honda (own Acura before) in my house. I drive '98 540iA now, and I am very interested in the new RL. BMWs are great cars, but reliability is far from Honda.
Acura may never have the brand cache of the german competition. That's true enough. But, if this RL fixes the problems with the old one, I think they are sitting as pretty as can be expected.
http://www2.autospies.com/article/index.asp?articleId=2792&ca- tegoryId=8
Buyers like myself who are more interested in the Mark Levinson audio system, vast stretches of rosewood, etc, arent really all that concerned about lateral G forces, so I think its very likely that traditional Lexus ES\GS shoppers could consider an RL. Infiniti needs to figure out which side it wants to be on. The FX45 points in the German direction, but at least the current Q45 tries to be a copy of an LS430, and has failed. If Infiniti wants to challenge a GS\RL, they need to majorly improve their interiors. If they want to challenge BMW or Audi, they need to figure out how BMW works such magic with a lowly strut suspension, and copy it.
Fearless (and possibly foolish) Prediction #1: so long as the car has acceptable tires, the RL will outcorner / out-skidpad every sport sedan on the market, including the lofty E55, M5 and and their brethern. It won't be able to power out of curves like those muscle sedans, but it'll hang with them going in.
That's my level of confidence if Honda's really applying the active differential from the Prelude SH to both axles. Remember, the FWD Prelude SH was capable of 0.9g on a skidpad. That may not sound like much until you realize that the Prelude SH shipped with 205-series Potenza RE92 tires, possibly the worst performance tires ever made. Prelude SH had phenomenal handling limits given its FWD layout. There aren't many bona fide RWD sports cars that could hang with it if you put, say, Potenza S02s on the Prelude. The RL would be substantially better.
Here's the problem: the cornering forces such an active differential setup can enable won't be realized safely (by a driver) if you don't squash body roll. That's easily done with a sports car suspension, but you can't put a sports car suspension on an Acura RL. Therefore, I will fearlessly predict (#2) that there's a suspension story to this car that we don't yet know about. You don't put this kind of differential on a car that hasn't been tuned for 10/10ths driving. Either the RL features some truly interesting suspension setup (think Cadillac XLR here) or the new RL is biased far closer to, say, a 5-series with big rims and a sport suspension, than it is to, say, a GS300 or E320. I don't see a paradigm shift in suspension design philosophies at Honda, so I'm betting that the new RL targets the sport-suspension 5-series squarely and ignores the rest of the market. This car will not have a Lexus ride.
Fearless Prediction #3: the most important statistic to be on the lookout for is the approximate weight penalty of the SH-AWD system. If it is palatable, this may provide a mechanical basis for AWD systems on Honda performance cars going forward (i.e. enhanced TL, next NSX, future 6-series / G35c / SC300 competitor), at least until hybrid drivetrains obviate the need.
As far as we can tell, Honda is not applying anything to the front axle. The front diff appears to be open. Only the rear will have active torque management.
I doubt there will be anything special (technologically) with the RL's suspension. Good ole double wishbones with proper tuning should be enough to get the job done. Especially with the SH-AWD pushing the outside wheels around the corner.
But I do agree with you on the ride. I expect it'll be firm with a bias toward sport. Acura should be going after the BMW 5 series and GS cars from Lexus.
As for weight, the VTM-4 system weighs in at about 212 lbs. Depending on what SH-AWD is made of (magnesium housing?), I'm thinking it should be no more than 20 lbs heavier. The two systems are quite similar. For reference, Infiniti's G35 AWD sedan is about 300 lbs heavier than the same base model without AWD. Though the AWD version also has a full size spare, rather than a donut, so I can't tell exactly what the real weight should be.
Anyway... it's very possible that the SH-AWD system could end up in something like a TL type S in 2007. I don't think the TSX's 2.4 engine can handle much more weight, so I doubt we'll see in small cars like that. Nor would I expect to see it in a rear-engined, RWD vehicle like the NSX.
My predictions?
The mags will record best in class numbers for handling, but still complain about it not having the right "feel". Then they'll complain about the lack of a V8. They'll conclude that the car is great, but ask, "what took so long?" It'll land second place to the 5 series in every comparo.
Here is what I got from owning '98 BMW 540iA since new. Remind you that I know cars, and I took care of mine very well.
Moonroof(twice), cat converter(twice), trunk actuator, fog light switch, wiper relay, missing dash pixels, broken dash LED backlight, radiator, coolant hose, coolant reservoir, fan belt, water pump, thermostat(twice).
tear & wear: omitted here.
I still love my 540iA, but mag guys don't tell you that and don't care when they rank cars.
M
Would anyone expect a base price more than $10k over the TL?
DrFill
Car is fantastic.. White with Quartz, CLEAN!!!! and gets looks from people at traffic lights!
I need to get the PIN number changed on the Nav so I can put my home addr in the system, but both users (1 & 2) are taken. Dealer sent me to Acura Cust Care who sent me back to dealer. Any idea on how to reset a Navigation Pin???
He also noted very little change in price.
Just rumors.
When will these bad boys hit the showrooms? Anyone know, or care to hazard a prediction?
The TL is a fantastic car though, its only negative is that mashing the pedal from 0 will cause some torque steer, though it certainly is no 93 Viggen or anything like that. There is perhaps one other thing, if you dont spring for the manual, you get carry over brakes from the previous TL...which werent all that good. They are beefed up a bit on the automatic A-Spec package, but only the MT car gets the real binders.
Thank you for the specs and images.
I am definetely looking forward to the NY motor show! I sense it will be difficult to wait to get our hands on one of these wonderful cars!
What about the 600lb. weight difference?
The Evo is a no-compromise sport set-up. The RL won't be anwhere near that hardcore! I'd expect .86/.87 on the skidpad and 66-67 through a slalom, nothing more. Weight is a major factor in pure handling tests. The TL is over 3500lbs! Add 300 (at least) for a larger car with more features and AWD.
DrFill
MODERATOR /ADMINISTRATOR
Review your vehicle
I wasnt comparing the performance of the RL directly to the Lancer Evo, just making a point that you can turn an ordinary humdrum Lancer into a race car with a hp injection and AWD. With proper balance, big sticky tires and AWD the new RL could be capable of great things.
It was in for some other work and of course they could find nothing. I want to get it figured out before warranty goes. I have about 2500 miles to go...
Anyone have a similar experience? If so have a fix?
thanks in advance...
I test drove a 2004 RL yesterday for the very first time. In the end, I felt it drove like an Accord.
It was nothing like a Lexus LS.
It wasn't even as smooth, quiet, comfortable as a Lexus GX SUV.
Aren't luxury sedans suppose to be smoother, quieter, more comfortable than SUVs?
How come the 7" NAV screen is so dim even when I set the brightness to MAX and Daytime setting?
The Lexus 7" NAV screen is so much brighter, clearer, with deeper, richer colors.
They offered me $7,000 off MSRP.
I would rather pay more money and get the LS.
I don't like it.
NOTE: this is still the prototype
