Visitor Agreement.
1) The engine makes a slight pinging noice when first started. The noice decreases as the engine warms. I change the oil loyally every 3-5000 miles and use 5w30 oil as recommended by GM.
2) The radio controls get extremely hot when the heater is in use. Have taken to the dealer many times with complaint only to receive "no problem found". I suspect that it may be a design problem.
3) Sliding door problems. I had sliding door problems from day one of ownership. Took to the dealer multiple times only to be advised that the only thing needed was to "reset" the fuse. Ended up replacing the actuator at a cost of $900+ (after the warranty expired of course) Now I received a notice of a recall. Is that for the part replaced or the new part? How should I confront the dealer?
Other than that, the van has been great.
Lastly, I read many discussions about bulb replacements. We had a minor fender bender and had to replace the left front light. Since the accident the bulb repeatedly burned out. I took it to an auto parts store and the worker recommended that you lubricate the bulbs prior to replacement. He stated that the lubrication prevented moisture from getting into the socket and would prevent shorting out. Just a little tip.
I am considering trading this van. Any advise?
My used '98 has some sort of conservative Michelin tire mounted on it, I don't know the model, but they generally wear very very well. That is the problem for me, as I told my wife I wanted to get a wheel/tire upgrade when these are worn out...and that might take a long time!
Great - I love our van and have found it to be a great design, and very well made on the powertrain. The fit and finish are very good for GM, and the interior is very comforable. We got 24.5mpg on my last tank too, beating my 2000 maxima.
Enjoy the van, I think from a financial standpoint we did a smart thing and got a nice used one, avoiding the depreciation hit and worrys about the first nick or smudge on the interior.
DD
FYI - our doors and everything have been great. I was expecting a sloppy door like on the full size domestic vans I have used, but the GM vans have a well designed door system IMHO.
FYI Some car radios do that. I almost bought a 2000 intrigue and the radio buttons on that get hot from just the normal operation from what folks say.
I have noticed a loss of coolant and will check again today to see if its the intake seal as some have suggested. I have also replaced the outer tie rods, and the rear window washer line connector was too short and had become disconnected so I had to use some vac line and fix that, but just minor stuff - pending the coolant leak.
INDRGB - I have heard that 3rd party extended warrenties have policies that sometimes are not what you would expect when you purchase the policy. Like you may have to pay up front for repairs and hope they reimburse you promptly. May not cover things the same as a MFG warrenty. Companies may fold under. Basically, I wouldn't bother. Sort of like a homeowners warrenty, people hardly ever persist enough and go through all the red tape to break even on them.
DD
We got our Olds Silhouette Premiere for the same reasons you guys did! And we didn't even know it existed when we started minivan shopping. We looked at the Honda, DC, and Ford. We almost went with the Pontiac Montana - but something just wasn't quite right style/feature-wise. Then we checked out the Premiere - no question hands down winner for price, features, style, drive, and yes, even safety. We've enjoyed our 2001 for the past seven months with only a couple of minor adjustments needed (worst was when some jack_ss stole our Thule box off the roof rack while the vehicle was at the dealer for the powerdoor recall - dealer paid for repairs and a new box).
The grand kids enjoy the entertainment center and it sure makes trips much nicer. Only wish they would have included a T.V. tuner in the package so I could watch TV while my wife shops. Anyone know of an after market tuner that will plug into the input connections?
Great van and 100% happy with the purchase.
I am now waiting on what Oldsmobile with do. Did anyone else have this problem and get it repaired?
THis was discussed recently on the Pontiac Montana list- go back 10-20 messages.
Bottom line, don't worry about it. I'm not sure if anyone has gotten rebuilds from this. The new design motors are more prone to this with shorter piston skirts and floating piston. The 3.4 otherwise is a very reliable, torquey motor with outstanding fuel economy.
However, I have in the past undone the inlet pipe at the various stages. I have concluded that the easiest one is the one to the exteme left, rather than undo the others.
This is easier to remove and re-install and it will release the tension in the hose and allow the cover to be removed. Other issue is that the bottom tabs must be properly inserted in the main part of casing.
Any support for combining the Montana/Venture/Silo lists? Hello moderator?
DD
I'm more partial to putting links up to the other discussions, but I could be persuaded.
Anyone with strong feelings about combining the triplets discussions, please post a note in the GM Triplets discussion.
Steve
Thanks in advance for any help you can give me.
A
After several months, the new owners love our our old 1999 Silhouette GL van. It has been perfect for them without a hint of trouble. Except they could hear a small sound...
The 1999 GL had better seats than the 2002 Silhouette we replaced it with. We bought another Silhouette so that we could swap our three middle row seats to make it an eight passenger. The GM discount I can get together with the longer Olds-Going-Out-Of-Business 5yr/60mo warrantee also helped us to get another Silhouette dispite the problems with the first one.
So far, except for the ususal initial quality problems / adjustments, our 2002 Silhouette has not had any troubles. By the same number of miles on the 1999 we were into the second transmission and new rear parking brakes, drivers side sliding door would not close right etc... etc... etc... etc...
We love the van we have not had any problems, it has everything as far as options as you all know and as a used van was a heck of a lot better deal then he honda or toyota. So we are a happy campers.
Thanks all
Heck, I used to ride a Honda Hurricane 1000 superbike, and two cars ago I was driving a '65 Nova with steel dash, lap belt only and 4 drum brakes. The freakin' mini van is super safe by comparison. Buying the car that crashes best is fine for some folks but its not my first concern. I have to look at drivetrain, comfort, value, etc. Safety is one of the things I look at, but in my opinion, one test does not make a unsafe vehicle.
I don't mind being wrong, but its was the resale and the crash stats that led me to say no to the Olds. I liked the features and thought is was a great compromise between the large minivans and the smaller minivans.
Can you please tell me where you saw the GMs being 1 and 2?
Kkollwitz, I'm not quite sure what you mean.
For all you daredevils out there, its your life.
They also don't give individual examples of their criteria. In addition, these are older numbers dating back to models before their redesign. As an example, these numbers include the previous version of the Odyssey , the MPV, and the Grand Caravan(and these werent very safe vehicles compared to todays models). It may have been a safe car compared to pre-redesign minivans, but it just doesnt compare anymore.
As another example to the absurdity of these numbers, the GMC Safari rates 3rd, but it received universally low numbers in crash tests. This,by itself, proves that these statistics are biased.
Then theres the fact that you know if your ever in an offset crash, you will not be as safe in the Chevy vans as you will in almost all other minivans.
These stats show that two door models of the same weight and model type do worst than the four door (2dr Accord v. 4dr Accord). Well younger (less experienced) drivers are more likely want two door cars and drive faster.
I once read a CR report that Honda owners are more likely to sweep their garage floors. These people are also more likely to change oil every 3,000 miles. Guess what??? Hondas have less oil related problems.
Good for you Montana and Olds owners on being more careful. I think being narrower helps avoid some of those accidents. Now, if you guys can help my wife keep it under 75 mph in one of those wider minivans.
Steve
When did the garage go from a place to store your car to a place to keep your kids stuff?
Steve, you change your oil once every 7,500 miles and your the Host? I thought that 5,000 miles was a bold compromise.
If I get to 100k free and clear, I'm gonna start bragging :-)
Steve
