Pontiac Bonneville
I also think your ready for the three twenty five and a cold air induction , even bigger fun !
Ezrapon, I ran a 3.50 pulley and a slip in K.&N before going to the 3.25 and modified CAI and it made more of a diff. in perf. from the 3.50 to the 3.25 - CAI then stock to 3.50 - slip in did. I'm sure your 3.40 is slightly better then my 3.50 was but no way is it going to run with a 3.25 , you will notice the diff. but you should do the CAI at the same time , the 3.25 needs AIR! And you own the install tool so you could easily get $100 or more for your old pulley installed on someones GTP,SSEi or Regal GS .
But after 2 attemts too make contact with phildo I have yet to hear back from him . Smfran , was there an earthquake out your way and Road Island fell in the sea , I haven't watched CNN lately so I may have missed it . Come on back guys !
I'm still getting a "springing" noise coming from under my console when it is below 30 outside. It seems that it is tied to the transmission as I can make it happen by pushing and releasing the gas pedal quickly. When it's very cold it will happen when shifting. The dealer has tried to eliminate it by adding insulation between the cables running underneath and the body. This hasn't helped. Has anyone else experienced this or have any ideas? Bonnie goes back in the shop next Friday.
The 3.25 and the modified Thrasher Cold Air Induction kit is more like 60 HP with even less lag in start of acceleration from the time you floor it. And it will accelerate! My shifts seem much better with this level of mod. The car is more difficult to bring out of the hole , use as much gas as you can without spinning front wheel till your above 20mph in hot weather and above 30 in cold , then go WOT , but after that pure fun !
This mod requires a shorter Supercharger belt and should have a 180 deg. thermostat , no big deal . Belt is off any way for pulley change and thermostat is 2 screws , about 10-15 minutes max. 3 of us SSEi'rs have gone from 3.50 pulleys to the 3.25's and none have gone back , many thousand miles on these three cars with the 3.25's and all are running great! I highly recommend this level mod. if you enjoy performance cars and thought that was what you were buying in the SSEi
One tip that I posted during the summer when I installed my CA . When I removed the stock air box I made a discovery , there is a foam donut that acts as a air duct from the hole in radiator support wall and the opening in factory air box , but on my car it was folded over and blocking some of the opening into air box , not good . So anyone running a stock air box should check this.
Ed
My car has blown out its second amp for the sub, must be a nasty impedence mismatch or voltage problem... get a system in, slap on the pulley and exhaust and fill me in.
The seat doesn't seem to go down as far as my older '93 bonneville. I had to adjust it for a tilt going back to avoid hitting the ceiling which was not the greatest position driving.
I own a 93 without a sunroof and have plenty of headroom. For 30k+, i don't get it. My only other complaint on this car is that it resembles somewhat a Grand Prix on the exterior, in fact, it's hard to tell the difference from a distance.
Any comments or insight on this please of owners of the 2000 or 2001 sunroof owners. By the way, i'm 5'10", so i'm know giant.
Mark
marlae - You definitely gain headroom without the sunroof. I've owned 5 Bonnevilles; the first two with sunroof. My 2000 gives me ample headroom but not as much as I had in my '97.
ABOUT PERFORMANCE MOD, SMALL IA. BLOWER PULLEYS, I&N AIR FILTERS AND SUCH. I NEED TO KNOW WHAT YOU GUYS ARE TALKING ABOUT IN LAY MAN'S TERMS.
DOES MY 2400 MILE 2001 Sri HAVE ROOM FOR IMPROVEMENT? THANKS
YES IT IS AN SSEi, 2001 WITH 2400 MILES ON IT.
CAN YOU GIVE ME SPECIFICS?
THANKS, BERNIE
Has anyone changed the rear bar to a larger size with urethane bushing? Is it worth the time and dollars? Thanks.
Second level of mod was a 3.25 diameter pulley ( stock is 3.80) , 1 " shorter S.C. drive belt , a Thrasher Cold Air Induction (CAI) Kit modified to fit the SSEi and a 180 degree thermostat (stock is 195) . This level of mod is good for about 60-65 HP and much less lag time and a very noticeable performance improvement.
Any pulley change will void your warranty if they find out . Go to www.thrasher-ep.com for purchase info on pulley and install tool and CAI kit (meant for Grand Prix)
Any other ?
Preliminary results for my first two runs: 0 - 60 mph: 6.41 and 6.34 seconds. This is with outside air at 30 degrees Fahrenheit.
If my math is good, this puts the car around 14.9 - 15.0 in the quarter mile. What do you guys think?
Looks like my total parts cost will be ~ $1,700. Add in tax, shipping, and a little labor, and I'm right at $2,000.
I sure hope to see some major gains after spending this much on a custom setup...
I'm still getting that "springy" noise from under the front of the console. The dealer just can't isolate it. They've insulated all the cables underneath which seems to have helped a bit; but it still makes the noise when cold out (below 30F). The noise happens when lifting up on the accelerator and when the transmission shifts. Any ideas?
Anyways, now that I have some spare time I was able to assemble an Excel spreadsheet listing all of us, the mods we've made, etc.
I think there are at least seven of us with pulleys now.
If any of you want to peruse the spreadsheet, and help me fill in the blanks, just let me know and I'll email it right out.
My address is AdvGauging@aol.com.
Suggestions anyone? (other then don't go back to the "Mumbo Jumbo" dealership). Does anyone know what the GMS price is as a function (%) of the MSRP for the SLE?
I am also leaning towards a Oldmobile Intrigue GLS or even possibly an Aurora.
BTW First time here and posting.
I also looked at SLE and Aurora V8 , but went with SSEi . I'm am sooo glad I did cause doing the mods and the performance gains make the car very special
$2000 you say , wow! $850 for the headers, $300 for mufflers , maybe a 100 for some straight pipe for the resonator and the MIA cat . What am I missing ? I so want those headers on my exhaust setup , but I'll have to come up with some more "untraceable cash" or little Queenie is goina give me "THE LOOK"
The snow is melting (December set a record here in Madison, WI) and it has been hard keeping the black machine clean (but it has been kept clean!).
As you may know, the mods on my machine have been limited to painting the exhaust tips and rubber floor mats for the winter
However... knowing you guys... here is a site you might like. http://www.84to96.net/kaleco/
Bill
$ 21 Manifold Gaskets
$ 750 Headers
$ 39 Crossover Wrap Kit
$ 50 Rear O2 Sensor Simulator
$ 240 Stainless Steel Tubing (3" and 2 1/2")
$ 200 Mufflers
$ 244 Tips
$ 47 Clamps
$ 28 Hangers
______
$1,619
All these prices were without tax and shipping. Still need to add some labor for welding and expanding some of the pipes.
This is going to be fun project!
He had a few mods a while back, and then seemingly disappeared...
I just noticed that the Kaleco site changed its format... The site was brand new three days ago and I thought it was very funny. The format changed last night, it is still amusing but now looks too much like it is trying to be serious for my taste. Hope any of you who looked at it understood that I thought it was funny and that I was not poking fun at anyone.
Smfran- I've been here all the time, the new format didn't scare me off, I just didn't have anything to offer. As far as mods for the SSEi... I already get the "look" for mods on the Vette. So I think the Bonnie is gonna stay stock. Besides one car that only gets 30,000 miles on a set of tires is 'enuf
Also, ay gotta understand, Carolyn's idea of a car is a grey 4 cylinder GranAm with crankup windows (that is her car, thank goodness). So, it is politic to behave myself with the SSEi.
Have fun everyone... and I will keep reading.
Bill
By the way, Superchips offers a chip for your car. They claim 20 horsepower and 27 foot-pounds of torque with application #2995025. They can be found at http://www.superchips.com/domestic.htm.
Good luck with your new Bonneville!
My questions: How is the reliability of the newer Bonnevilles, say from 1997-99 and the 2000 models everyone has already? Also, what fuel economy does everyone get? I drive alot of highway, and usually get 20-22 mpg, which is better on 89 octane than 87 for some reason. Love all the "toys" in the SSE, but wish it was SCed.
BTW, how much do you all think trade-in value would be on my 1993? I estimate something like $5000 or so.
Oh, and how does everyone's 2000 models compare to their older ones? I read here awhile back, and know at least one person replaced a 1996 model with a 2000, so please advise. Thanks again.
When I was 19 I had a '75 Buick Electra Limited with a 455 4-barrel carburetor. Talk about luxury with attitude! Unfortunately, I went broke filling the tank and traded it for a '80 Toyota Celica.
I find them really useful for getting things apart and back together without breaking anything (haven't had to use 'em yet on the Bonneville... but have used similar manuals a lot on my other/past cars).
Anyway, if any of you have a question about how to get something apart... or would like to see a diagnostic table (could be lots of pages) for a particular problem... drop me a note and I'll scan some stuff and EMail it back.
My normal EMail address is WEShelton@home.com. Home.com's servers have been having problems of late, so a copy to WEShelton@aol.com might be a good safety measure.
Have fun,
Bill
