I have mine to 110 and it still had plenty to go. I doubt I'll ever run it to the max. There's really no need to.
The 1.8T and the VR6, however will go faster than 135, but I think they are governed at about 140 if I remember right. Either way, that's plenty fast for a consumer car.
This past weekend I went to my dealer and test drove a Wolfsburg Edition. Very sweet machine. I was a bit disappointed with off the line takeoff torque as it was initially undiscernible for the 2.0, but the 1.8T (expectedly) kept it's high-torque pull through the power band much better than the 2.0. Not to mention that the engine is worlds quieter, though I don't mind the 2.0's infamous growl.
I drove a 5-speed model as one of our members was complaining of a 'notchy' gearbox. The WE I drove had a very smooth gearbox. I was quite impressed.
-Jim
http://www.JettaOwnersClub.org
http://www.BlueLagoonJetta.com
Thinking of buying a 5 speed. Any advice? THANKS!
-Jim
Jazz - I don't care what car you buy, NEVER pay for that dumb paint sealant, undercoating, or interior protection packages. It's a waste of money. You'll get the same results with a good quality wax for the paint. Buy a few cans of 3M Scotch Guard for the carpets/cloth seats. As for undercoating, it's unnecessary on today's cars. If they salt the roads where you live, wash your car frequently at aplace that has a chasis wash feature. Besides, the rust through warranty is long for a reason.
The great thing about this engine is for a few hundred bucks you can chip it out (see wetterauer and upsolute sites) and get 120 HP and 200 ft-lbs torque, still with nearly the same mileage. The 2.0 is definitely outmatched after this.
The only drawback I have seen with my TDI is the cold-weather starts, which are slightly rougher than normal.
PS Please do not suggest Bob Lewis, their service is something else!
BTW, there are currently Special Financing on manual Jettas, I got 5.4% for 36 mos. Let me know how it goes.
I am counting the days until I go and buy my new jetta. Not going to get into details. But my question is some places I read state that the 5spd standard on the GLS 2.0L is an OD system. I was just wondering how you get an OD on a standard tranny, and what RPM the cars running at when your going about 70mph.
Thanks for the help.
David
OD is a bit of a misnomer, I believe anytime that you have a gear that allows the tailshaft RPM to exceed the engine RPM, (the gear ratio is less than 1) you can consider it an overdrive gear. 5th is probably a ratio just under 1.00 (.95??) RPM's on the highway depend much on this, and in a RWD car it has a lot to do with the rear-end ratio as well. (Not the case for Jettas of course.) With a little plotting on a graph (preferably a log plot), you can chart your car's RPM's vs speed, and by finding the peak HP curve (RPM's with the max HP) you can estimate pretty close what top speed would be for your car at that peak HP RPM, asked in an earlier post by blackjetta and bluejetta. (You must deduct some for high wind resistance)
I really want the black leather interior. Problem is, one of my friends *warned* me that this would be *very* hot in the summer and said that he would not purchase black on black again. Another car on the lot is silver outside with a black leather interior. I prefer the black on black but am a bit concerned given my friend's comments.
Can anyone with a black or dark blue exterior and a black leather interior comment on this. I live in Ottawa Canada and believe it or not, we hit the high 80's and 90's in the summer (with a lot of humidity). Your feedback would be greatly appreciated and will influence my decision.
Thanks in advance.
Good luck with your Jetta
This is just a great car.
As turbeaux said, the leather wheel will stay cooler and the sun-blocker tinted windows would also help, but I, personally, wouldn't go with the black interior if it were up to me. I realize that my older Maxima would not have been as well insulated as some of the cars might be today, but this dicision is one you'll have to live with. It not easy to change the interior.
Keep in mind this is only MY opinion, but Yours is the one that really matters.
Good luck making your decision.
I have come up with another question for you all about the 2k1 jetta. Again I am planning on getting a 2k1.5 jetta during the summer, it's going to be a GLS 2.0, lux, monsoon, indash CD, and cold weather. For the windows they work from the door with the key, which I can see myself using alot!!
My mom just got a Lexus RX300 2k1 model. It has the same window feature where it will open and close all windows and sunroof from the drivers door with the key. But it will also do it from the remote for the car. If you hold the lock button everything will close, and if you hold unlock everything will open. Does the jetta do the same thing? I wanted to test this when I test drove, but the dealer uses the valet key not the real thing "it's to expensive to replace if lost or damage" was their reason. And the guy didn't know to much so I didn't even bother asking my question.
Thanks for the help. Also, how is the Galactic Blue, and Baltic Green holding up with paint chips? Those are my two leading choices for outside color right now.
David
I can say that regardless of octane, once I got to highway speed evrything is silky smooth.
In any case, congrats on your decision. Repeat after me, I will get the 1.8T...
Also my grandfathers old benz had a similar key to the VW/Audi key where you press the button and it flipps out on his 94-96 model, I don't remeber the year exactly. But now the key no longer flips, so if you close it you have press and hold the button then sorta pry it loose. Anybody notice this happening with their keys?
And I was a little pieved about not being able to see / the real key to drive the car, but I understand their reasons. The keys cost cost over 100 to replace / repair. Before I buy I will ask to see the real key though. Plus the dealer around us is a sleaz, could tell by the way he acted when I test drove, kept trying to get me to go to the GLX model. *sigh*
Looks like I'll be buying this car from www.carsdirect.com again. That's how we bought the lexus, worked great!!! The price is only 200 over TMV. So if the dealer won't go below carsdirect I'll buy through them. Very good service!!!!!
David
I recently purchased a 2001 Jetta GLS V6. My dealer told me before I bought the car that it takes premium gas. Its also clearly stated on the inside of gas cap and in the owner's manual that premium gas should be used. I've read in posts above that some owners do mixes at fill-up, i.e., premium gas then at half tank fill with regular octane and the mix adds up to the appropriate octane percentage. Now the question is, you're thinking of buying a great car with a great engine. You know beforehand that premium gas is preferred. Therefore, you will be paying (at today's prices) an additional $2 to $3 per fill-up at empty. I personally have no problem with this and want to keep my V6 at peak performance. If this is an issue or problem before you buy the car, you may want to re-think your preference. I test drove all three available engines and definitely went for the V6, which, of course, is more expensive. My advice? Use the premium gas. Keep your car happy.
Then it warmed up with temps above freezing most of the time. Did the same grandma/speedracer test with two tanks and got about the same milage - 25. I never thought ambiant temperature had much effect, but I guess it does. And in the summer I remember getting more like 26-27. This is mostly urban driving. Anybody care to comment/share experience?
Oh, and I agree with sonyfocus 100%, if you think that paying for premium gas is too much, you're being rediculous. Just brown bag lunch twice more each month and there you are!!
I would not allow how much the changer costs to affect where you purchase the car. I know it might be incovient but it is an easy addon to the car when you find a dealer that will install it at an acceptable price.
Buy the car, and worry about the CD Changer later. It's more important you get the factory options and colors you want.
David
Let us know who you like the car!!! I can't wait to get my jetta in a few months!!!!
Yes I know what you mean, I'm only a teen but my parents have both had a 97 Gand Caravan Sport, and a 2000 Caravan Sport. Both are great cars to drive, lots of pickup and good handling cars for american cars that is. I cann't wait to dump my topaz that I have now. I got it to replace my 86 Gli which suffered a very well timed death. I was rearended then the electrical system died before repairs were started, so I took the money and donated the car.
I can't wait until July/Aug when I get to pickup my new jetta :-)
That trip will sufficient break in the engine. Check when the first oil change is, it may be overdue by the time you get back. My mom's lexus's first one was at 500mi. Just remeber no Cruise Control for 500mi.
Have fun.
I realize this is a Jetta forum, but I figure this issue is probably common to both Jettas & Passats... yes, it's an electrical problem...
I own a 2000 Passat Station wagon with the V6 engine and manual tranny. Since Xmas the "check engine light" has come ON & OFF for a few days at a time. I brought it to the dealer the first week of January and all they did was a computer reset + gave me a story about sensitive sensors & tightened government controls. Yes, they are clueless. Needless to say, a couple of days later, the light came back ON for a few days, then turned OFF for a day, and then turned ON..... When the Check engine light comes ON, it's usually accompanied by an "Emissions Workshop!" message in the middle message section of the dash. I've made an appointment with the dealer for Wednesday, but I fear that I won't get any further with them.... In case you're wondering, yes I've gone to different gas stations for gas and the gas cap has always been nice & tight. Do you have any ideas ? On pure speculation, I'm down to a faulty oxygen sensor or faulty idiot light or.... Help !
I've always owned Hondas/Toyotas and have had excellent reliability. I still like my Volks but I hope this isn't the beginning of a reliability issue....
Tom
Also, has anybody else tried to have the temp controls raised. I'd like to do radio on top, temp in the middle and CD on the bottom, does anybody know if this is possible? I won't be able to bug the dealer with this question until Sat, so I was just wondering if anybody else knows the answer.
Thanx, David
David
Any help is greatly appreciated...
jimnim
Also, a few specific questions.
If I go with the Jetta, I'm deciding between the 1.8t and the TDI diesel. Regarding the diesel, will upkeep on this engine be any more expensive/difficult? Will it be difficult to find diesel fuel in and around metro Washington, DC? and, finally, is this one of those "next generation 'clean' diesels" ?
Thanks for your help. I'm bringing the car to the dealer tomorrow so I'll ask for the code. I'll post whatever I get back.
Thanks again,
Tom
I owned 88 Jetta. Got 130,000 out of it before selling. Engine and transmission, 5 speed were solid. Other parts of the car were average to below average. As far as cost of ownership, these cars are expensive to fix when they go down. I'm comparing their repair cost to Toyotas, Nissians, Ford and comparable GM products.
Seems to be a lot of satisfied owners on the Jetty post. Keep em and fix them for awhile and then post.
Also VW is an indifferent manufacter when it comes to responding to customer complaints.
The TDI is a clean engine, but VW is coming out with even "greener" versions. It has excellent torque for a diesel, and no, you won't have trouble getting gas in DC. If you commute in the Metro, you'll love the TDI (I used to live there).
Yes, VW has had some problems here and there, but overall their quality is much improved, and I think these 99-02 cars will have a good track record. I'll also admit VWoA hasn't been good to it's customers, but all my service experiences in the dealer have been excellent. I hear the same from other VW owners with increasing regularity.
