Visitor Agreement.
Germany Northwest Map #415
Germany Northeast Map #416
Germany Midwest Map #417
Germany Mideast Map #418
Germany Southwest Map #419
Germany Southeast Map #420
Germany Overview Map #984
All six of the regional maps (415-420) can be had for around $9.00 all over the internet, the Overview can be had for about $11.00.
Good luck, have fun.
Best Regards,
Shipo
As for the fans, BMW got a bad batch of fans from Seimens last year, that problem has been worked out.
On the subject of noise and rattles, I am just about to turn in my 1999 328i (early production E46), the car has 37,000 miles of driving in and around NYC, and so far, not a single unscheduled noise, squeak or rattle.
Best Regards,
Shipo
1) Loosen the five wheel bolts on a single wheel a half turn each, then roll the car a couple of feet to make sure that the wheel is easy to remove.
2) Jack up the car and remove the wheel (make sure to chock the wheels at the other end of the car).
3) Loosen the two 16mm caliper bolts behind the caliper bracket, and remove the bottom bolt.
4) Stack 14" of newspapers (preferable bound with twine or some such) to the rear of the wheel well.
5) Remove the top caliper bolt, and rest the caliper on the stack of papers.
6) Remove the single rotor retaining bolt with an Allen key and slide the rotor off the hub.
7) Remove the spring clip between the caliper bracket and the caliper.
8) Remove the brake pads from the caliper and slide the caliper bracket off of the caliper (these are floating calipers so the bracket should slide smoothly off to the rear).
9) Put the brake pads back into the caliper and slide a thin hammer handle between the brake pads and twist the hammerhead so that the oval of the handle gently presses the piston back into the caliper.
10) Repeat #9 with a larger hammer handle until the piston is pushed all of the way in.
11) Remove the old pads.
12) Wash the new rotor in a good concentration of dish soap, rinse and mount the new rotor and secure with the retaining bolt, tighten with the Allen key.
13) Slide the bracket back on the caliper.
14) Insert the new brake pads in the caliper.
15) Re-attach the spring clip between the caliper and the caliper bracket.
16) Slide the caliper over the new rotor, and thread the top caliper bolt.
17) Remove the stack of papers, insert the bottom bolt and tighten both bolts to about 100 ft/lbs.
18) (Left front only) Snap the sensor in place on the inside brake pad ("bump" toward rotor), and connect the sensor to the "Box" in the wheel well thus replacing the old one.
19) Mount the wheel, and screw in the wheel bolts finger tight.
20) Lower the car to the ground and tighten the wheel bolts to 72 ft/lbs in a "Star" pattern.
21) Repeat for the other wheel.
It really is that easy. ;-)
Best Regards,
Shipo
shipo - wow, who would have thought changing pads and rotors on a BMW was so easy. These cars seem so complicated that most people here are afraid to change their own oil! lol You are an inspiration to all of us!
An alternative to a stack of newspapers is to bend an old wire hanger into a hook and hang the caliper from a convenient suspension component. When I'm just changing pads, I don't even bother with that, I just hold the caliper in one hand.
Put a little anti-seize on the hub before you put the new rotor on. Also a dab on the rotor retaining screw. It'll make the job much easier next time.
I'd also suggest not using soap and water to clean the cosmoline off the new rotor, instead use spray-type brake cleaner. Hold the rotor vertically by sticking your fingers through the hole, and all that gunk'll flow right off. You don't have to wipe the rotor afterward, but make sure your garage is well ventilated.
Oh yeah, if you want to cut down on brake squeal, spray some anti-squeal on the *back* of each pad and allow to dry before putting 'em in the caliper.
Best Regards,
Shipo
Just curious why you chose the 5.
I used Goop to clean my hands, it took all of 2 easy minutes, followed by a quick wash with Dawn. The end result was almost perfect.
I thought about the hanger wire, however, 1) I was already dirty, so, I did not want to go back into the house, and 2) with the plastic fender liner, there are few (if any) places to hang the caliper other than the spring.
I have very sensitive sinuses, and the "Spray Stuff" bugs me, soap and water in a big bucket works pretty well. That said, the "Spray Stuff" is decidedly faster.
The pads that I bought already has a layer of stuff on them, and so far, they have perfectly quiet, however, I may be singing a different tune after a few hundred miles. In the past (25 years ago) I used to use a good high quality Duct Tape (3M) and back the pads with that stuff, it never failed to prevent all noise associated with "Them new fangled disk brakes." ;-)
Best Regards,
Shipo
I decided to upgrade to the 5-Series for what is probably the most basic illogical reason of all, I wanted it. ;-) The only decision was what options and color.
Given that I may want to keep this car until 2011 when my son comes of driving age (he wants to drive a stick, and he is only 8), I felt that the lack of cylinder liners on the 540i might represent a potential maintenance issue once the car hits the “Century” mark. That combined with the extra $8,300 for the 540i 6-Speed (all else being), and I simply could not justify going for the bigger motor.
Best Regards,
Shipo
My $.02.
Ken
Is this normal? It isn't bad, just kind of wierd feeling. I thought I remember seeing posts about this a while back. Of course, my wife says that she didn't notice - but then she never has it to the floor (but I do).
Thanks for your input.
I picked up our new 325i on Monday as well, our cars have the same "birthday" :-)
I haven't noticed the notchy gas pedal myself since I'm trying to follow the break in period which I believe advises against full throttle during the first 1200 miles. Personally, I can't wait to do some driving without dropping below 4500 rpm's! I'll get back to you then.
-Murray
This will normally force the car to shift to a lower gear for passing etc.
If car is new you should not be flooring it. Read your manual... there is a breakin period (1200 miles)
CNorthrup
anyone with the same problem and/or solution.
stg
330xi
Enjoy weekend
Good luck with your new 325 !!
Heh heh, wait till I tell the others !!!
Alan F
Best Regards,
Shipo
-nobee
-nobee
On MACO, I wish someone could shed some light on this for ED. Just like you said it could depend on locality which I think it is legit. However, an unscrupulous dealer may try to use that as an excuse for making more profit when in fact MACO is not applicable for ED. I wonder if anyone or millerro3 can share his wisdom on this.
MILLERRO3, if you have information on ED MACO please tell us so we know how to deal with this in the future.
-Murray
I have got a lot of advice over at the
"Store Bought Waxes Part II (No Zaino Posts)" in Town Hall-Maintenance & Repair.
CNorthrup
Check out the link below as proof, you could also do a search on that website under 'sticky pedal' and you will find many responses.
BTW my 330Ci does not have this problem. It is smooth sailing all the way !!
http://beemerfest.com/forums/showthread.php?s=&threadid=3512&highlight=sticky+pedal
http://www.bmwusa.com/welcome.cfm?code=Home
Then click on "Virtual Center" and then click on "European Delivery".
-nobee
One of the questions you'll need to ask about this device is how you choose a song or playlist using the in-dash head. One major disappointment I have with our DVD player (which can play mp3s) is that I cannot choose either playlist or song -- the player starts with the first song on the CD and ends with the last.
Kenwood licensed the technology and renamed it MusicKeg, so hopefully there will be wider availability and a nice price drop in the next 6-12 months. In the meantime, I have no idea where you can buy one of these...
derprofi, I found the MusicKeg in a Crutchfield catalog!
-nobee
I'm still checking into adapting the CD changer input on the head unit to accept RCA inputs. Crutchfield has a P-bus adapter that may work. This would allow me to plug in my iPod giving me 50 hours (5 gig) of music that I could take between cars, jogging, etc.
BTW, I can load the entire 5 gig in about 10 minutes through Firewire.
-Murray
They had to pry me away from the Topaz(?) Blue Z8. Beautiful curves!
There was also a nice blue Z3 that I could see myself in
I HATE the rear end of the new 7. It's like some monstrous Victorian bustle/train contraption - really hideous.
On a side note: I was talking to a guy that dropped off his 528 because the speakers were hissing. I seem to remember hearing about this a couple of months ago...anyone care to spare me the agony of searching several thousand posts? Was there a TSB, or a posted fix?
