None of the above will protect from too low a downshift, however -- just constant throttle within a given gear. If, for example, you try to downshift to 2nd at 80mph, physics and gear ratios win: the engine would have to be spinning at about 8,000rpm (unless the gears become unmeshed or the clutch slips or the engine blows a connecting rod, etc.). The engine control system can't override physics -- just like DSC can only protect so far. Once physics takes over, well, Sir Newton can tell you the rest...
I have pushed my old 323is to teh red line and the power just shuts off - I didnt time it - and hence dont know how long it was before I got power back...
In any case in the 3 years I have had i have come to realise (unfortunately
And I just got my new 325ci in yesterday - Silver, blk, sport, premium, everything except for the HK sound system. Felt great but was surprised that the M facia comes only with the 330... ah well - guess I can live with that.
Many thanks!
Yeah, there's no protection for rpm junkies downshifting into the redline. But it's great to know that if you hit the redline during straight acceleration you will be fine. I guess it sounds a little like racing cars entering the pits - you know how they hit the button that limits their top speed to 50 mph or whatever in the pits. That's a good approach from BMW.
I was fortunate to order a 325I while in "112" status! Only had a day or two to choose my options. Ordered on April 30. Went to 150 status 2 days later! Chose blk/blk lth/CD/roof/xenon. Ordered in Lafayette, La.
Are you able to find any current info on this vehicle? My salesman is away at a car show all week, otherwise I would ask him. Thanks!
FYI, I came REAL close to ordering from your dealership. Very competitive and helpful. I just couldn't justify the expense in getting it from Cali to Houston, Tex!
Hey, what is it - Al or W? What are you, a double agent or something? Get your story straight, buddy
I'm in NJ and my dealer reserved a slot on 3/28 - I actually placed my final order on 4/7 for which dealer used the 3/28 slot by making changes per my specs. Dealer told me that by doing that we saved at least a week and the vehicle should be at the dealership in ~7 weeks. Which means by end of May I should recieve my 330xi.
I called BMW-NA on 4/10 and they told me that the order was already accepted and my status was 111. Guess what, it's been over a month now and my status is still "On-Order"! Which leads me to believe there's no way I can have my car before the long weekend...
This week I called BMWNA almost everyday and my dealer on Monday and accoding to both of them my production should've started this week. BMWNA is unsure as to what caused that delay but it may because of that change on 4/7 - but even than it's taking longer than evryone else.
Please Guru HELP! I can't take this anymore - I'm going crazy. Could you pleeeeeeeeeease let me know what you think the real situation is???
Thx!
Z-man
PS It's Steel Blue with Black Leather(ette)
the engine will cut power (not shut off) until you drop your revs.
Pretty scary if you're not expecting it.
Now, this proceedure does take a few minutes and I am now at work (I wasn't, until an hour ago).
I'd be delighted to keep you all up to date on your vehicles status, but it might be tough now until I get home (7pm PST).
Electronics mean that we can make a cheap RWD platform with lousey / low-tech suspension with-out the negatives associated with such systems (like the ones GM recently ditched - Caprice/Fleetwood). Remember - RWD for domestics meant (with a few exceptions like the T-Bird) a solid rear axle (like a pick-up truck), BMW / Mercedes have had no solid axle for nearly 50 years, so poor is the resultant handling characteristic.
Yes, in the Altezza, as well as the TL, CL-S, the automanual is truly more auto than manual, as it will upshift for you...found this out in test-driving as well, and it's not just at the redline...makes me question the logic of having a manual mode at all...
I don't know about 2002 Type-S though as I never drove that...
-Z
All things being equal, which scenario has the better balance: 1) FWD where the fronts provide both steering AND motivation, while the rears jnust trrack, or 2) RWD where the burden is shared: fronts steer only, and rears motivate only. Combine that with 50/50 weight distribution (BMW does that the best), and BALANCE is truly attained!
Maybe this also helps to explain why BMW doesn't recommend rotating tires (can't on SP anyway). The front and back tires probably wear at about the same rate, due to the shared load, equal weight distribution, etc. There is some science behind the magic...
Thanks for your words of wisdom though!
Anyways, it was a small price to pay for the piece of mind I have now. My experience with the service dept. was excellent/top notch. They kept me informed daily as to the status and actually completed the repair 1 day earlier than expected.
This ultimate driving experience is really all encompassing from sales to driving to service. I'm loving it.
guru - Can't rationalize with kids, esp. the troll type.
Sorry for the long post with all these questions, but I have just sold my favorite car and can't wait for my new baby.
Anyone care to explain what the processing center do?
Thinking of buying a new BMW 325i. Any suggestions? What do you guys think as compare to Acura 3.2 TL? Any recommendations where to buy?
Shahid
Looks like we stirred up a hornet's nest here as far as status requests go!!
Well, thanks for your input on my status earlier today. You said it was in 112 status but the BMW website still shows it as "on order"! Is that possible?
And, why are we even responding to V_tech posts anymore? I thought we agreed we were going to ignore him!
Veekay1(325xi/sapphire/gray/week22)
I would honestly urge other meatheads like me, who might be sitting on the fence between the 325 and the 330, to seriously consider that if you get the 330, you'll never have to look at another car and say, "yeah, that's the same as my car, except with 41 extra horses."
All that said, Japanese cars are boring, auto tranny crap. How can ANYONE consider a car to be a performance car with an automatic transmission??? The very notion is communist! If it doesn't come with a manual, it's just a "point and go" car. Period.
Additionally, A Lexus, in particular, is nothing but a Toyota with gold trim. I laugh in scorn and derision.
veekay - STOP PANICING!! "112" is still "on order", it just means that the car is too close to production for the dealer to change its spec (unless they do it with in a day or so of it going 112). So basically, it is on order, but by the end of next week, it should be "150" - sheduled for production.
That's just not that much more than a loaded 325xi, which would cost about $35K.
As far as being a meathead... some people want power, some want quality. A 325i is hardly slow, but the people on this board are probably enthusiasts who generally need the big engine !! (Like mine!)
I just left my salesman a message. Here's where being a litigator by profession comes in handy.
