2013 and Earlier - Toyota Sienna Prices Paid and Buying Experience
16869717374236
  • weedshastaweedshasta Member Posts: 85
    Thanks for all the info, nickles. The XLE AWD with the run flat tires does not have any spare. The brochure states that a "temporary spare" is a dealer installed option on the AWD. I guess this would be hanging down underneath as there is no spare well compartment. My question is, if I eventually go with regular tires and get rid of the run flats, I will need a spare. (I guess I would have to buy another rim?) I would like to be able to have a conventional sized spare and not one of those little temporary ones. I am wondering if it is possible to install a spare tire holder underneath the car that will hold a regular sized spare? Is there enough room under the car?
        What a dumb thing for them to do! Who can afford a $200 each tire? You should at least have the option of whether to go with the run flat or the regular tires.
  • nicklesnickles Member Posts: 41
    What ? that seems crazy!
    oh i see what they are up to.
    'Why should you need a spare, when you have runflat tires???'
    gee, what marketing geniuses.. You can definatley see the influence the OEM relationshiip has on future consumer goods....
    sounds like you can get the temp spare as an option. (it's the same spare as all the other Sienna models). the spare well 'should' be in the same place in the Sienna as the other non-AWD models.. you wouldn't want to mess with getting a full size rim - then you'd need to make modifications to the underbody to rig it up there.
    You could certainly get a wheel that matches the bolt pattern of the Sienna, and get a regular tire (much smaller in size) to mount on that rim.. but you would have to be sure it's overall dimension woudl allow it to fit in the spare well...
    My advise is to wear these out with normal use.
    If you get a flat or are in need of replacing one prematurely, then dump them all and get a whole new set. Then get the dealer to install your temp spare.
  • danogdanog Member Posts: 318
    Seems to me the location of the spare on the other models (CE,LE and XLE) would make it impossible for the spare to be located in the same location on the AWD, hence it would be relocated elsewhere and not installed at the factory.
    Not sure where they'd put it but if you drive as much as you mentioned I'd rather not take the chance of being stranded without a spare.
  • heywood1heywood1 Member Posts: 851
    According to the owner's manual for my XLE AWD Sienna, the 'dealer-installed' spare is to be kept in the well area into which the 3rd row seat is supposed to fold. I will admit this seems ridiculous, especially considering that the disappearing seat is one of the van's most touted features.
    My guess would be that Toyota assumes that if you can afford $35,000+ for an AWD minivan, then you can afford a couple of hundred bucks to replace a tire (See my previous message #3605).
    Rants like Weedshasta's confirm my belief that most people are driving expensive vehicles they can barely afford to buy (lease?), let alone maintain (hello all you dime-a-dozen BMW owners!). To that end, I expect most AWD Sienna owners will replace the OEM's with non-run-flats when the time comes.
    If "most AWD Sienna owners will replace the OEMs with non-run-flats when the time comes," then don't you think this was a real bad idea on the part of Toyota? As to my "rant," you have absolutely no idea what I can and can't afford. As a retired person, I do have to pinch pennies on day to day expenses. But reliability is very important to me and that is why I went with the Sienna, the #1 rated minivan in Consumer Reports. That's why I tracked down the best deal I could find (through this forum) on the extended warranty. I also wanted AWD because I live in snow country, and what other minivan has AWD? And I paid cash for the car.
  • nimmy4nimmy4 Member Posts: 4
    Ordered a new XLE FWd Artic Frost with pkg #16(GJ) with floormat pkg CF, hitch setup, and hood protector?
    List Price was $36,285. Price was $34198 + $98 doc fee. Probably not the best price available, about $2087 off list, but dealers in our area are not negotiating much since Siennas only last a few days on their lots or are sold before they get them. I Have a few questions if anyone would like to respond.
    1. How long does it typically take to get a factory ordered Sienna?
    2. What would be a fair price for Toyota Extended warranty? - (preferably 100,000 mile warranty)
    3. Has anyone purchased the Toyota Dual Port System -the cargo carrier that attaches to hitch? How much is it? And any opinions
    4. Does anyone know what going interest rate is from dealership or opinions on Internet financing.
    Thanks in advance
    Considering that the AWD setup takes up the space for the temporary spare, I don't see that Toyota had much choice but to offer run-flats. It's a compromise.
    And I don't think many owners will notice, as most people remedy a flat tire by dialing the auto club from their cell phones--whether they have a spare or not.
    If you paid cash for the car, Weedshasta, I'm still not sure what the big deal is about a $200 tire. Sounds like my brother, who paid $42,000 (cash) for a new BMW 735i back in 1987, and still complains about the cost of the TRX tires it requires--($250 each and made only by Michelin).
    And Nissan Quest is available with AWD.
    I can't comment on all your questions but you should do some research here and on the web. I paid less for a XLE Limited than your #16 although I didn't get many of the options you listed. I can however add them if the need arises.
    You probably could still work a deal with another dealer.
    Seems the 7yr/100k warranty can be had for ~$800.
    As for interest rates, check with the credit bureaus (www.equifax.com) and see what your beacon score is. If you score 700+ you should qualify for the best rates available. Compare rates using www.bankrate.com. Your local banks will not compete with the low rates for individuals so allow your dealer to check on your behalf. They write 50-100 loans a month giving them more leverage with the local banks.
    I've used Internet financing www.capitalone.com and would recommend it to anyone unless your dealer can beat the rate.
    There just happens to be a handy link on the left :-)
  • virgochampvirgochamp Member Posts: 3
    Firstly, thank you to all the wise ones on this board for all the excellent information and tips. Here is what we ordered (Silver color):
    2004 Toyota Sienna XLE FWD (carsdirect.com prices)
    >>>>>>>>>>>>>>>>&- gt;> MSRP >>>>>>>>>> Invoice
    Base ............. 28260 ......... 26367
    Pkg 16 (GJ) ....... 6545 .......... 5274
    CF (carpet mats)... 196 ............ 119
    WH (xtra headsets).. 82 ............. 66
    AW (all weather mats)98 ............. 70
    WL (wheel locks).... 59 ............. 37
    Dest Charge ....... 540 ............ 540
    TOTAL ............ 35780 ......... 32473
    Invoice .......... 32473
    + Dealer profit .... 120
    + Documentation fee . 50
    + Sales tax (7%) .. 2285
    + Tags/Title ........ 25
    TOTAL OTD ........ 34950
    The vehicle is on the dealers inbound allocation and should be here in 14-21 days.
    Thanks again to everybody for the inspiration and guidance. We had to go to this local dealer about 3 times along with a fax attack to dealers in a 5 state area to get there. Me and my family have owned 5 Nissans and 2 Toyotas over the last 30 or so years. Our last 3 vehicles have been Nissans and we have loved them all. But, the driving feel of the Sienna tipped us over vs. the Nissan Quest.
  • kwtradingkwtrading Member Posts: 19
    i agree with heywood1,
    toyota obviously designed the AWD Sienna with runflat tires in mind knowing full well they had no place to put the spare with the drivetrain underneath.
    so it sounds like toyota salesmen are more likely to spout "this vehicle has runflat tires! you'll never need a spare!" than the more truthful "this vehicle has runflat tires and with them you will never need a spare! however, keep in mind that there is no spot for a spare tire in the AWD Sienna so you will continue to need runflat tires in the future."
    i think any AWD owner has the right to be a little angry over this regardless of how much the vehicle costs or how wealthy they are or are not. the fact of the matter is they are obviously average or even below average performing tires from what those of you who have them are reporting. some people are reporting theirs wearing out at a pathetic 15,000 miles!
    i know i'd feel taken if i did...
    My point here is everyone considering the purchase of an AWD Sienna needs to be aware that the vehicle has no spare, and replacement tires (if you choose run-flats in the future) are really expensive.
    While your salesperson may trumpet the fact that the vehicle has run-flats, he or she may not mention--or even know--how much these tires cost.
    The drive shaft obviously requires part of the space where the Sienna's spare resides.
    The alternative locations could be mounted inside the rear cargo area. Mounting it on the rear door wouldn't make sense so there really isn't many options left.
    Think about where other makes mount their spares and consider what options you would loose if the Sienna was to match their locations.
    Heywood1 is right, make sure you consider the price of replacing the run flats when shopping the AWD model.
    I suspect the price will moderate some; after all, Toyota is selling lots of Siennas, and many of those are AWD models.
    I also suspect that we'll start seeing space saver spares mounted on the roof racks of '04 model AWD Siennas in about 3 years :-).
  • jb_shinjb_shin Member Posts: 357
    Also, it seems like more manufacturers are choosing the runflats for various reasons. MB E-class, BMW 5-series, and the new Mini are all equipped with runflats. It is purely my guess, but the price will go down as more cars are equipped with these. By how much?, your guess is as good as mine.
    Having said that, I would carry a fullsize spare on any trip more than an hour outside of my area, and sacrifice a bit of room and flexibility.
    Please indulge me, as I believe this observation is relevant to 'prices paid:'
    Yesterday was our neighborhood's annual Easter Egg Hunt for all the kiddos. A couple about our age (36) pulled up in their brand new '04 Phantom Gray Sequoia. Although it was beautiful (I must admit), I am more pleased than ever with my decision to buy a new XLE AWD Sienna. For $10,000 less (even considering real-world street prices for both models), my Sienna has:
    much better seats
    more luxurious interior
    more cargo room
    better MPG
    power lift gate
    better handling
    & cheaper insurance
    To be fair, though, the Sequoia seems to be the vehicle of a Rhodes Scholar, as compared to the antiquated Land Cruiser that another friend of mine just bought (smaller, six-year-old design, and yet even more expensive). Seems people drive the LC only to demonstrate how much they spent, not how much they know.
    My advice: If you don't need the towing ability of a V-8 (most people don't)--buy an AWD Sienna, don't worry about the Jones's, and use the $10-20K you save as a down payment on a condo at the beach.
  • wildredwildred Member Posts: 43
    according to the manual, RFTs are not repairable!!! when they go flat, you have to replace them!!! the only advantage having them is to be able to drive another 100 miles at 55mph afterwards.
    if people in the know were right, then it will cost $800 for all 4 tires!!! it's not safe to just replace one while the other three had, say, 15,000 miles on them. it's like having different tires on 4 wheels.
  • chitownmomchitownmom Member Posts: 2
    just want to check it out with the folks on this board to see...I've learned so much by reading all these posts!
    Sienna XLE Artic Frost/Fawn Pkg #14...$31,500, $33,858 out the door. Dealer has allocation for vehicle, has to change the color for us. Should have it in 3 to 4 weeks.
    I checked Costco pricing, Carmax pricing (I live close enough to Kenosha), and larger dealers in my area (Chicago suburbs). Two dealers quoted this pricing for me, and it's very close to the Carmax pricing. Carmax can't get me the color I want. One dealer, the one closest to me would only come $500 off MSRP (about $34K)!
    Is this too good to be true, should I keep trying for a lower price, or should I take it before it's gone? We'll probably finalize our decision tomorrow.
    Don't know where you're getting your info, Wildred.
    The Dunlop brochure that was included with my XLE AWD clearly states: "Like any other Dunlop speed-rated high performance tire, the Dunlop SP Sport 4000 DSST tire may be repaired to correct a nail-hole puncture in the tread, but proper materials and procedures must be used...."
    "Don't know where you're getting your info". page 465 of the "Toyota 2004 Sienna Owner's Manual".
    for your convenience, i will excerpt below;
    "Run-flat tires
    When the tire goes flat or when the tire pressure is below 100kPa(1.0kgf/cm2 or bar, 15 psi), the tire must be replaced. If you are not sure, consult your Toyota dealer. Do not use the repaired tire."
    mine is FWD, so i don't have the Dunlop thingy. i do believe what you said is true about what Dunlop said. i would think by stating that their expensive product is one use only would deter most people from buying it.
    however, it's alarming that Toyota would go against the tire manufacture by clearly stating "MUST BE REPLACED", and "DO NOT USE THE REPAIRED TIRE". don't you think?
    i tend to believe the car maker more than the tire maker. it's your call though. after all, safety is much more important than money. just my 2 cents.
  • gtahobegtahobe Member Posts: 42
    Um, I'd believe the tire maker not the car manufacture. Remember Firestone vs Ford? Ford recommended a lower pressure than Firestone on the tires used on the Explore to get that softer ride feel. Don't jump on me about that:)
    In this case, I believe that if a nail punctures the tread and you get it repaired before the tire pressure falls too low, then you can repair it and be on your merry way.
    If however, the nail punctures the tread and you loose all air pressure while driving, then the run-flats are doing their job and you are putting extra stress on the sidewalls. This extra stress on the sidewalls is then why you wouldn't want to reuse that particular tire.
    So you're both right.
  • rorrrorr Member Posts: 3,630
    "And Nissan Quest is available with AWD."
    Huh? Are you SURE about that?
    Thought I read that AWD was to be offered on the Quest--if not now, then soon. In fact, I am SURE I read it more than once....
    I never even considered a Qwest, as Nissan interiors tend to be underwhelming, quality-wise-- so I admit I don't have the brochure memorized.
    Wow, you people on this board love to play 'Gotcha.'
    I seriously doubt Dunlop printed a lie in their run-flat brochure concerning repairability, especially in the aftermath of the whole Firestone/Explorer thing.
    I have been doing a lot of reading on this subject. If you go to Town Hall/Toyota/Sienna and then where it says "search Toyota Sienna discussions" type in "run flat", you will come up with over 7 pages of conversations in various boards. Heywood1, did you get a brochure directed specifically towards your SP Sport 4000 DSST? The one they gave me is "Dunlop Original Equipment Tires - Tire Care and Maintenance Bruchure Passenger Car Tires, Lightweight Temporary Spare Tires, Light Truck Tires." I can find no mention of the run flats and am wondering if I was given the wrong brochure. Does it list the wear guarantee as 6 years?
         Also, I have the Consumer Reports 2004 Car issue, and the Nissan Quest is only listed with front wheel drive in 2004. CRs only recommended minivans in descending order are the Sienna, Odyssey, Mazda MPV, and Nissan Quest.
    Weedshasta, my Dunlop brochure was included in the black leather zippercase that contained the owners manual for the van. And, yes, it is specifically for the DSST's.
    It's gold and white, and the cover reads: "Dunlop SP Sport 4000 P225/60R17; Dunlop Self-Supporting Technology (DSST); Toyota Original Equipment Tires; Owners Manual and Limited Warranty."
    In it is the language I posted earlier regarding repairability, including a CYA disclaimer that reads, "Contact an authorized Dunlop DSST service facility for information on proper repairs." There is also a toll-free number given to find the nearest authorized Dunlop DSST service facility near you. Am I allowed to post it here?
    Anyway, To keep this board on-topic, I'll direct future run-flat chat to a more appropriate board. But I believe this info is useful to anyone considering the purchase of an AWD Sienna.
    As for Quest AWD, I really thought it was available now, or will be in the near future.
    "Wow, you people on this board love to play 'Gotcha.'"
    YES!!!!!
    .....at least, those of us who don't have a life outside of the TH....8^)
    Although I would agree that sometimes the piling on isn't really necessary.
  • anildelanildel Member Posts: 9
    I took delivery of my XLE with GH(14), FC with door sill, PC in arctic frost color for $31300 in schaumburg (northwest suburbs chicago) on March 06, 2004. Though They insisted all the time that they were giving this special price to me as I asked them to compare it with a quote from an Indiana dealership but I'm sure that they can make a deal at this price. Later I got financing thru them (chase manhattan bank) at 2.59% for 60 months which was better than my credit union's 3.99%.
  • jfd713jfd713 Member Posts: 2
    Hi all,
    I am in U.S. military overseas right now, and will be coming to Northern Cal. in about a month to go to grad school for awhile.
    Have done considerable research, and am pretty sure of what I want: Sienna, 8-passenger LE with option package 11 (DVD, etc--4th kid on the way; DVD now not optional....), plus mats/sill protectors and updated security. MSRP is a bit over $30K, and the 'CarsDirect' price is a little over $28K.
    Will be new to No. Cal, so have no experience with dealers there. Would appreciate any insights on who's good and who's not, so that I can see what's out there beyond the CarsDirect price (which seems pretty good).
    Thanks for reading.
    Your post was reassuring. I got a similar price quote from Schaumburg, but I got Continental in Countryside (much closer to my house) to match it. I thought I had done my homework, but you just never know with car dealers!
    Thanks for the info, Heywood1. They did not give me that brochure, so I will call them.
         jfd713, I live in N. California. Hanlees Toyota in Davis is one of the CarsDirect dealers. They are also the Costco dealer, and the Costco price beat the CarsDirect price. You have to go on the net to the Costco site if you are a Costco member. Hanlees was very good to work with and gave me the price we had agreed to on the phone. They also gave me dealer blue book for my trade in.
    you wrote:
    "...I believe that if a nail punctures the tread and you get it repaired before the tire pressure falls too low, then you can repair it and be on your merry way.
    If however, the nail punctures the tread and you loose all air pressure while driving, then the run-flats are doing their job and you are putting extra stress on the sidewalls. This extra stress on the sidewalls is then why you wouldn't want to reuse that particular tire."
    thank you for clearing up the confusion for me. so the awd owners should not run the run-flats after they got punctured. get them repaired as soon as possible, or you will face stiff penalty--shell out more money that is.
    if one can't run flat on the run-flats, make you wonder what is the use to have the run-flats at first place?
  • impact01impact01 Member Posts: 95
    When there was no space to put a spare tire, Toyota compromised by fitting RFTs. IMO, RFTs are still bleeding edge technology, as time goes on the technology will improve. IIRC, other than GM triplets, Sienna is the only other minivan in the market with AWD with Chrysler abandoning their AWD offering.
    RFTs may not be bad after all. In my 20 years of driving I've had three flats (two of them slow leaks) and with Sienna having a tire-pressure warning sensor, a total loss of pressure will likely be a very rare occurence. However, it is not like Toyota doesn't tell you about the lack of a spare. IIRC, Toyota does sell a compact spare that can be mounted in the rear seat well. However, AWD&Runflats or FWD+regular tires is a choice the buyer has to make at the present time!.
  • hansiennahansienna Member Posts: 2,312
    With 2004 Sienna AWD, the buyer does not get a spare tire nor place to mount a spare.
          With an Odyssey, the buyer has a one piece "Magic Seat".
          With a DC minivan, one does not get a 5 speed automatic transmission or Toyota reliability.
          Some people liked pre-2005 DC AWD because they could still get either a full size spare or mini-spare. However, DC minivans did not have fold-into-the floor seating.
          With a Volkswagen Eurovan, the buyer gets neither power nor fuel economy but does get the most spacious interior.
          With a Kia Sedona, the buyer gets the most gas guzzling minivan with one of the smallest interiors...however, the Sedona is appealing as it is cheap.
          The 2004 Sienna offers the fewest compromises of any minivan with more options available than any other minivan.
    We don't have time to verify phone numbers so we ask that you just refer people to the manufacturer's web site for contact info.
    There are some tire pros hanging out in the Tires, tires, tires discussion - not much about runflats though. Not yet anyway!
  • jmessjmess Member Posts: 677
    I have been bouncing back and forth between the Ody LX and the Sienna CE with pkg 3 (rear disc, trac, VSC, and etc).
    I got a quote today from a dealer for $800 over invoice on a 8 pass CE with pkg 3 and floor matts. The invoice on Edmunds shows $23263 (CE 8 pass, pkg 3, and matts); when you add $800 you get $24063.
    The salesrep told me their invoice was 23906 but couldn't explain to me what the $643 difference with the internet price was even when I hinted about a possible TDA fee. So checking with another dealer I was told the TDA in my area for the Sienna CE is $469. So 643 - 469 = $174. So I am not sure what the other $174 is. (gas + some flooring?).
    I am really having a hard time deciding between the CE with pkg 3 and the Ody LX. I find the Ody to be more of a driver's vehicle with better throttle response, handling feel, and brake feel. The Sienna is more plush with a quieter ride and better interior along with some better/newer standard features. Coming from a sporty car back ground I would like driving the Ody more on a winding road but can appreciate how comfortable the CE would be on a long freeway trip.
  • joeblowjoeblow Member Posts: 11
    I live in the Northeast and am in the market for a Red Sienna XLE AWD with options package #17 GK and CF Carpet Floor Mats/Door Sill Protector.
    Edmunds and other sites have confirmed the invoice cost at $31,005. I have received several quotes as low as "$450 over invoice", however the actual sales price of these quotes is NOT $31,505 and varies a bit from dealer to dealer. The prices can be an additional $600 to $800 per dealer. Am I missing something like Documentation Fees, Plates, and TDA? I want to know the lowest possible price and negotiate from there (compare apples to apples). Is TDA negotiable?
    The lowest price quote I received was for $32,100 and $900 for the 7/100k/0 warranty.
    Joeblow, I can understand your wanting to 'find' the difference in the invoice prices, but come on-- nearly $3,000 off MSRP for a relatively hot vehicle (AWD, hard-to-find color), and you want to do BETTER?
    If this were a Camry, grinding a dealer down to invoice minus holdback and TDA would be possible.
    But you're going to have to live with a dealer making A LITTLE money on this AWD Sienna. $32,100 is a great deal. Tell them you'll take it if they'll sell you the warranty for $800.
  • petroniopetronio Member Posts: 18
    I have a quote for a Sienna XLE AWD with options package 17 for $34,999 plus taxes, tags and registration.
    JoeBlow, what dealer gave you that quote for $32,100?
    I was told by my dealer that the TDA is built into the invoice (but not a line item) - and it varies by region.
    Lucky me, out here in Arizona, got a $741.00 TDA fee...
    I have talked with other Arizona buyers, and they too have been charged exactly 741 for TDA.
    I don't think it's a money maker for the dealer, and my dealer said it is not an option to even THINK about removing the TDA.
    As host Steve always says, focus on out the door price, not line items.
    I live in western PA, which I believe is Central Atlantic Toyota distribution. Armed with invoice prices and other 'homework,' I have negotiated some great deals on about a dozen new Toyotas from no fewer than five different dealers over the last decade. Not ONE of them has ever mentioned TDA to me. (If we DO have TDA here, it's certainly nowhere near $741). And Central doesn't have the 'Toyo-Guard problem,' like Southern States where the privately-held distributor adds worthless crap and mystery fees to every vehicle.
    I recommend that all of you unlucky enough to be living in some of these other distribution zones get some quotes from dealers around here.
    The sticker for my XLE AWD was clean, with only three factory installed options (#17, V2, WH), plus Central Atlantic destination charge of $540. Period.
    This site and this board in particular have been terrific resources in my Sienna purchasing process.
    I have one final question. I have managed a rate of 3.85% for 60 months through CapOne. Can Toyota or anyone else beat that? I live in New England, if that matters...
    Joeblow, I'm paying 3.35% through Toyota Financial. My term is 48 months, but could have chosen 36 or 60 at the same rate.
    I financed a relatively small amount compared to the price of the van, as the '03 Sienna I traded was paid for, so I'm not sure if that had anything to do with the rate.
    As with other manufacturers' low-rate offers, I believe your credit score, debt ratio, and payment history must be near-perfect in order to qualify.
  • familymanfamilyman Member Posts: 8
    Hello All,
    I was con'd by the Toyota Finance guy (... yes the guy you see after the salesman) when they said my credit rating wasn't good enough for 4.9% interest rate that was negotiated with the salesman beforehand. He said my credit rating was below 700 -> but when checking at www.myfico.com later that night, my credit rating was actually 718.
    In the end I went for 6.25%, it seems he added around 2 percentage point for dealer reserve. It was just a small $12K loan after my trade-in and I wasn't too upset figuring I can easily refinance at a lower rate anyway. They had the color combo that was hard to find in our area so I bit the proverbial bullet. Besides my wife next to me was really determined to go home with the new van ...
    Anyway my question is:
    I know that Finance guy made a commission from Toyota Credit Corp. on the deal with the higher interest rate of 6.25% ( his Dealer Reserve). If I refinance it now and pay off the loan with Toyota Credit Corp, does he lose his commission or is he paid all up front???
    Oh how I wish he loses it when I refinance ;-)
    PS. They have been sucking up to me via phone messages regarding the up coming new car buyer questionnaire form I will be receiving soon. I will try to use that to get some freebies if possible by threatening to give them a bad grade (... what comes around goes around...).
    How important are good ratings from that questionnaire for the dealer? Do they win a million dollars or something if they get "Excellent" in all categories???
    -Thanks in Advance
    Ratings should be fairly important unless they toss the bad ones.
    I'd recommend calling them on beacon issue. Call and ask for the GM or owner. You should receive something.
    It gets hard to maintain good credit and many who actually are fortunate to do so should be allowed the benefits. What good would this credit rating actually serve if everyone receives the same rates?
    I called the dealer because I didn't get the brochure and warranty pamphlet with my Dunlop SP4000T run flat tires for my AWD. The dealer said they did not get any and they will contact Dunlop. I called Dunlop myself and they said they "ran out" and many dealers did not get them. They are sending me one directly. She also said that Sears handles their run flats under warranty, although she does not know whether they keep any in stock. So I think I will contact various Sears auto centers in the area I frequently drive, so that if I get a slow leak I will know where to go.
    Perhaps in different parts of the country the fees are 'included' differently.
    I have read much about the 'Toyoguard' and other stuff on edmunds.com, and thats not even an OPTION to get out here.. Haven't heard it come out of one dealers mouth.
    No rustproofing, paint sealant/primer etc....
    I think if you nickel and dime these guys to death, they will feel less likely to 'earn' any future business.
    As mentioned, I negotiated a XLE LTD w/ 06 for $600.00 over invoice..
    now, granted, I added the 741 TDA fee as part of the invoice (even though that LINE ITEM is notlisted on the invoice)..
    I don't know where the logic is, but 600 + 741 is just short of $1400 bucks.. STILL in my opinion a decent deal.
    Because I treated the dealer fairly, he promised to 'toss in' some stuff from the parts dept.. (cargo net, mud flaps etc... - we'll see about that)
    You know, you would think more dealers would be on these boards... with clear explanations to all these fees, and to represent their dealership!
  • ctkandctkand Member Posts: 4
    catsoft, could you post the name of the dealer from whom you bought your van, and also the name of the dealer offering $400 over invoice? I'm buying the same van at Toyota of Durham but they are quoting $1k over invoice on an arctic frost pearl one with OTD of $37700. Thanks!
    Hello All,
    -Thanks in Advance
  • kenhall64kenhall64 Member Posts: 16
    That guy got you with one of oldest tricks - should have asked to see your score while at his desk. It will only cost you couple hundred dollars over life of loan if you keep it but I'd make them pay you somehow (free oil changes). With that score you most likely could get < 4% from internet bank. Those internet banks will send you a check that works like cash when you buy and you can still use dealer financing and have them beat the rate you already got - did that last time I bought. Good luck.
