Up here in Canada (I am in Toronto - comparable to Michigan, NY state Ohio etc)) they suggest 8,000 km/5000 miles between oil changes and do not suggest changing the first one before that interval due to the special break in oil. I have not heard of the 10,000 mile one - perhaps it is different in the part of the US where you live.
dave210: The mileage you are getting on your auto matches my experience on the 5speed I have. The autos lose 1 mpg as rated up here. I have found highway milage to drop off quite a lot by driving at 120 (75 mpg) km/h versus around 100-100 km/hr (60 mph. The difference is 4-5 mpg!
From post # 2617, my average mileage is : 27-33 Combined (US gallon) with over 60% city. Best on highway is 39.
I use the "severe" sched - lots of short hop and enthusiastic driving coupled with intent to keep the car a long time.
Now one thing I am skeptical about, rotating tires every ten thousand miles. I've always done it every five to six thousand miles...
FUEL ECONOMY is UP. Took a trip this past weekend and cleared 39 mpg at 75 MPH. Not bad! One thing I noticed while driving my dad's Civic, his car settles in around 3200 rpms @ 75 MPH and mine settles in around 3700 rpms @ 75 MPH. I would have thought Honda would want the car to have lower rpms in fifth gear?
Any positive news in Honda land?
jjpcat - Read on another thread that FW drive cars really do need the rotations. Something about rear suspension harmonics causing cupping. Given the very reasonable seeming maintenance sched on other issues, I'd go with the sched in the manual.
That's what I thought about my '93 tires.
Ain't Edmund's great!
Anybody just ignoring Honda and running 5-30 or 10-30 (or heavier) oils in their cars?
From what I have heard, there are no tolerance etc. changes in the current Hondas, and Honda even claims the new oil is backward compatible with earlier generation Hondas.
vocus: Thanks for the vote of confidence... :-)
micweb: Sure hope you're right! If this had happened to a three or four year old car, I wouldn't get it fixed. BUT, the car is eight weeks old!
I am entering my 9th week of ownership and am clearing about 4 mpg better than five weeks ago (keeping a detailed log).
I have had my car since late last year, about five months, and the odometer says 8000 km/5000 miles.
My mileage has been good since day one but it was very cold when I bought it so mileage has probably gone up due to ambient temperature as well as a broken in engine. The first highway trip I got 43 imperial /36 US mpg but was also driving at between 115-140 kph /72-88 mph, which does lower mileage.
While this is good, my 2001 Saturn SL with the lower hp engine and a 5 speed could get 55 imperial/46 US mpg on the same trip and driving conditions. My 1992 Saturn got only 1 mpg less than this.
I have noticed variations in mileage due to oil viscoscity. The Golf called for 5-40 oil, which isn't available outside of Europe so far as I know. 5-50 (Castrol Syntec) seemed to give 1-2 mpg less than 5-30 (Mobil 1), which I attribute to the viscosity difference at operating temperatures. (I have recently read that Mobil 1 5-30 is at the "low end" of the permitted viscosity variation for 30 oil, which might have something to do with it as well; FYI, I have also heard that "high mileage car oil" is supposed to be at the higher range of its stated viscosity range; before this, I didn't know there was much variation permitted in the specs.)
The viscosity variation was tracked in a relatively short time frame, when I had an oil change done, so is probablyl accurate. The increase in gas mileage over time may be due to other factors, mainly learning to drive the car more smoothly and perhaps more efficiently - although I am usually nervous with new cars and take it easy, and drive harder once the car is broken in (which may be counterbalanced by a subconscious desire to drive faster and harder on a new, exciting car).
On a positive note, driving back I did achieve around 39.5 mpg.
We had a great weekend here in Toronto but my car continues to emit all kinds of annoying buzzes in the dash board, vents, and driver door area. Back to the dealership I guess.
Buzzing and rattling?!?!?! Odd. I'm not having anything of the such on my Canadian built Civic. Do you have rough pavement up there?
My car is quiet on smooth roads which are few and far between these days.
Actually the engine is so quiet on a warm day when idling it is eerie - like an electric car. While my 2002 Corolla is quieter as a car, the engine in the Honda is quieter than one in the Toyota.
~alpha
trigred- I've only gotten up to 80, no higher.
Sameejudge- Depends upon where you live. "Severe" conditions such as bumper to bumper traffic, high or very low heat environments, heavy dust environments, etc... require oil changes every 5000 miles.
Edmunds.com Used Car Appraiser and True Market Value on our host site and
Real-World Trade-In Values, the discussion rivertown mentions.
Hope this helps!
Pretty consistently over the past 15 years, car manufacturers have had "optimistic" and "realistic" numbers. The optimistic numbers are based on their mandate to not waste oil. The realistic numbers are based on their desire for consumers to have good engine life.
Honda and VW have some of the longest oil change intervals - 10,000 miles. VW at least has a 5 quart crankcase - Honda only has 3.5. Ford has reduced its optimal rating from the previous industry standard 7,500 miles, to 5,000 mile regular, 3,000 miles severe.
Chevy Impalas have an "oil monitor" that calculates when an oil change is due based on driving patterns - it doesn't actually check the oil. Their lights tend to come on between 6,000 and 7,000 miles. BMW packs their Mini's with full synthetic, and their dealers told me that the oil change lights come on much earlier, for most drivers, than the "manual" requires - at around 7,000 - 8,000 miles.
I think the most I'd go is 5,000 miles on full synthetic, and 3,000-4,000 on regular oil. Look at it this way - would you like to put my 3,000 mile oil in your car and drive another 7,000 miles on it? Sounds crazy, huh, but that's what you are doing to your car when you leave the same oil in your car for that mileage.
Check with your dealer - my dealer recommends 3,000 mile oil changes, max 5,000. I don't think the dealer wants customer complaints, especially after Toyota's well publicized sludge problems. Also consider that here in America, no one is willing to put "good" oil in their car - in Europe, their is a special "eurospec" oil which is 5-40, full synthetic - Pennzoil and Castrol list it on the USA website for European cars - they are much less fanatical than we are about engine protection vs. gas mileage.
That's why I always follow the oil change interval recommended by the manufacturers. So far, I haven't bumped into any engine problems with any of the 8 cars I have owned.
I would like to see independent/un-biased research results. But I haven't seen anything. The only one closed enough was published by Honda in the 90s. At that time, people were also amazed by the long oil change interval that Honda recommended. So, Honda did a lengthy test in NY/NJ areas and found no damage to the engine by following their own recommendation.
As for the engine problem reported against Toyota 3.0L V6 engines, it's because those people didn't change oil for 20k or even 30k miles (at least that's what Toyota said). I have owned 3 cars with that engine and I didn't have a single problem with the engines by following Toyota's recommendation.
This place is getting to be like the Civic's new commercials up here in Canada. It just shows people driving the cars talking about nothing in particular. The closing voiceover says something like: with a car as reliable as a Civic what will you think about?
I am enjoying my 2003 Galapagos Green Civic sedan which I have had now for 7 months with 10,000 km/6200 miles. The little rattle in the dash was repaired by the local dealer and with summer coming,I plan on doing lots of driving.
It ain't perfect but, man I like driving this car!
I'm still considering the Civic, but price is a factor, so it would be a Civic LX versus the Elantra GT, I think. If the Civic was available in a hatch, I would consider it more....is there ANY chance of them bringing it back?
The lousy resale values of a Hyundai continue.
Four door hatchback? Maybe someday but I've heard nothing.
Great car and really happy!!
First Honda and third new car. Prior had a Cavalier and a Venture. GM quality sucks!
Looking forward to many many years of good driving.
Sorry you had trouble with your GM stuff.
I was a happy GM owner for more than 20 years with no major problems. They all served us well. But their designs have gotten tired and their fit and finish is absolutely the worst in the industry. Interiors are pretty bad as well - not to mention squeaks and rattles.
My last two GM products were Saturns which very good cars but I did not like the new Ion's appearance, interior, shifter or the fact that it got a lot worse fuel econ than my old cars. Here in the Toronto area at the time I bought my car, an Ion cost about the same as a Civic, although with the latest rebates the Ion is cheaper.
Now what do I do with my GM Visa card?
Are you sure all the world views GM products that way? That's a big research study to have done...
Personally I've found them well-built and dependable. I've maintained them with frequent oil changes and they've lasted just fine.
They are big, cheap to buy, cheap to keep on the road,reliable, pleasant looking (interior quality aside)and overall decent value. Despite the fact that the interiors rattle a lot, I have always liked the basic value these cars represent. However the small Saturns were always better cars if you wanted to buy GM.
