Any advice??
I had an old Honda accord 1990 and the radio was from Alpine too!
So..my question is....anybody else here have installed a cd changer to a 2001 Honda civic lx?
Pat
Sedans and Women's Auto Center Message Boards
thanks!
EVERY MORNING, I ALWAYS HEAR A CREAKING SOUND WHEN I BREAK SLOWLY. THE SOUND IS NOT NOTICEABLE DURING THE COURSE OF THE DAY. IS THIS NORMAL?
I WENT TO THE DEALER AND THEY WERE UNABLE TO DIAGNOSE. THEY TOLD ME THAT THIS IS NORMAL. BUT THE CAR DIDN'T HAVE THIS NOISE BEFORE.
DOES ANYBODY KNOW WHAT THE PROBLEM IS? PLEASE HELP.
THANKS.
As for those worried that the engine would be harmed by using a different viscosity oil, that's utter hogwash. The recommended oil for our 92 Accord was 10W-30. My dad always used straight 30W oil, except during the 2 coldest winter months, during which he used 10W-30 for less strain on the starter. The engine ran beautifully up until just last week when it was totalled. It had 186,400 miles. It never leaked, nor did it ever burn a drop of oil. Anyway, the moral of this post is to let those who are not informed know that 10W-30 is a perfectly fine weight of oil that will not harm your Civic. Before having a heart-attack over a dealer putting that into your engine, at least understand what the numbers mean and look closely at the oil viscosity charts. And in the case of those who live in hot climates, I suggest making sure the dealer uses 10W-30 instead of the 5W-20.
still not sure why he pulled out.....hopefully he is thinking long and hard about it as well. he could not speak ANY English, and had only had a license for about a year. the cop was not pleased with him at all. glad i don't have to go to court...;)
1) The owners manual states 5w-20 only, there is no temperature chart.
2) It further states 5w-30 may be used when the recomended oil is not available but should be replaced with 5w-20 at next oil change.
Why use the correct oil?
Penzoil told me of several new cars that use 5w-20 for maximum fuel economy and lower polution and if you are saving receipts for possible warranty verification of correct maintenance, you have a problem, you did not do what they plainly recomend in print. For example the owners manual said use only 87 octane gas in my truck. You might not see harm in putting 92 in untill the mechanic tells you that you burned out the oxygen sensor for $300 and since I confessed to useing a proscribed octane gas they would not pay for it, next time. This is why I am concerned about it. I thought that 92 octane would be ok but it was not. Now I read the book and do just what it says before some engineer tells me why I have screwed up his vehicle.
I know you can easilly pull 80 MPH in third gear without getting near redline.
If my dealer put anything different than what is recommended in my owner's manual, I'd have them drain and fill it with the proper oil. Then if at any point there is a problem with the engine that can be attributed to motor oil, your [non-permissible content removed] is covered by doing it by the book.
The point is, the manual states to use a certain oil for a reason. Granted it may be because of fuel efficiency mainly but it may also be for other reasons as well. If you have data that would show the manual to be incorrect or just general information for the owner, then show it otherwise your opinion is invalid. Mechanics, Dealers, Want to be experts on these boards, Owners who think they know everything, they all want to claim that 3,000 miles or 3 months with 10W-40 is best, blah blah. Not until you show me the proof will I deviate from the manual. The manual is written by engineers, all other advice comes from mechanics and the like. Who do you think I should trust? I already know.
Also, the manual is not written by engineers. An Engineering Release would consist of data provided by the Engineering group, is approved by the Sales and Marketing team, and is scrutinized for publication by the Legal department. Each of these entities have their own agendas. Do you think this process would allow that two different spec oils may be used between winter and summer?
Lastly, no, I have no proof.
http://www.honda.co.uk/civic.html
As far as your comment on changing to 5W-30 when the temperature rises above 95 degrees (another baseless opinion), I've provided a link to show you flash points of different oil viscosities from Pennzoil. See for yourself, the 5W-20 actually had a higher flash point than 5W-30. 5W-20 can take a lot of abuse and when people claim it is not enough for the summer, blah blah, it makes me want to puke. I'm tired of the opinions.
http://www.pennzoil.com/TechData/pdsheet/domesticmarketing/engineoils/pdf/Multigrade.pdf
So there you go, some evidence, of which you have none.
Remember that your Terms of Use (see link on left sidebar) requires that no profanity (masked or otherwise) be posted, and that you have agreed to disagree with opinions of other posters in a civil manner.
Also remember that responding in kind to such posts will cause your post to be removed as well. It is best to either ignore flame-bait, or email one of your hosts about the issues.
Pat
Sedans and Auto Women's Center Message Boards
Check your vehicle identification number on your lower front glass shield. It is usually start with a 1 , 2 or J
Do you know something in regards to a problem from a particular factory or are you just trying to gain data from which to try to draw your own conclusion?
Is there plenty of headroom front and rear in EX models (with moon roof)?
Does the automatic transmission shift smoothly?
Is there much road/tire noise at freeway speeds?
Has anyone driven their 2001 Civic in hot weather? Is the A/C strong enough to keep you cool in 100 degree weather?
Is there still a two second delay when you set the cruise control like the older Hondas?
Does the remote keyless entry pop the trunk also?
How do the gauges light up as night? Are they back lit now or still front lit like past models Back lit gauges are not really "important," but it's kind of fun to drive a car with a dash that looks cool at night (like the glowing blue gauges in new VWs).
What kind of real world gas mileage can you expect in a Civic EX automatic sedan?
Since we have moved to our new platform, we no longer have the requirement to stop and restart discussions after the numbers of posts exceed a certain limit. Since this discussion can continue as long as anyone has anything to say about Civic Sedans there is no longer a need for the "3" that has been included in the discussion name. Down the road, that could confuse our newer members so I have removed it.
Please continue...
Pat
I have about 4 squeaks, rattles, and buzzes in my car, with all but one coming from the dash board. My car goes in on Wednesday for servicing, though, so hopefully they will all be quelled for good then.
I am 6' tall, and I can sit comfortably front and rear with no worries about head room. Even with the driver's seat fully raised, my head is nowhere near the roof. Remember that Honda used the same trick Ford and Toyota used with the Focus and Echo, respectively, in raising the roof of the car. It worked, and headroom isn't an issue.
Actually, in my opinion, the big issue at freeway speeds is not road noise, but engine noise. It's kind of buzz. It is the best in this class, but that's not saying all too much. The fact of the matter is that if you're coming from a larger, V-6 engine car, this car will seem annoyingly buzz at first. Around town, however, where engine speeds are lower, road noise is a factor.
I haven't used the A/C, but I can say that if the heater is any indication of the power of the A/C system, then I'll be just fine. The blower is pretty strong, and in my limited use of the air conditioner, it seems to be pretty powerful.
I have no experience with older Honda, so I can't comment on the new cruise control's performance compared to the old, but I can say that the new one for the most part take a short second to set. It's not a long time at all, and many would probably count the engagement as instantaneous.
The keyless entry does not control the trunk, which is a real sore spot for me.
The gauges appear to be electroluminescent at night, which is to say that they're illuminated extremely accurately. The light is pure white, with no green or blue tinges, and everything is easily deciphered. So, answering your question, yes, they are backlit.
And, as a general rule, I believe about 32 mpg is the forum average for both manual and automatic trannies.
The remote key fob that still doesn't pop the trunk is disappointing. Aftermaket electric trunk releases don't work well. It is not that big of a deal though.
Creaks and rattles are a bigger turn off, I hoped they might have fixed that problem with a new design.
Had the dash been tampered with in any way? Was an alarm system or new stereo installed that required disassembly of the dash?
The biggest turn off is buzzy engine noise at highway speeds. In the previous Civic, I thought roaring tires were the loudest noise unless the road was glass smooth. I could hardly hear the engine when the car was in high gear.
I wonder if the top gear ratios are lower in the new Civic. What kind of RPMs are going at 65 MPH in overdrive gear in a Civic EX automatic?
Since I have heard people say that the 2001 Civic stereo is still very weak, if you like good music and want to drown out the apparent engine noise and squeaks and rattles, you will need to either get an amplifier or at least get a more powerful aftermarket head unit as well as new speakers.
Unfortunately, this installation may cause additional squeaks and rattles in the dash, doors and rear deck shelf.
I wish Honda would install a better quality factory stereo system at least in the EX models that was at least as good as the best factory stereos in a Focus or Sentra so aftermarket tampering would not be needed for anyone other than those who want to shake the neighborhood or are very critical audiophiles.
My EX Coupe is at almost 3k RPM at 65mph. I don't notice too much noise, but I came from a 2000 Elanta, the king of BUZZ, so that might exlain it.
