I avoid the "lag" by revving to about 2000 or so before engaging the clutch. Smooth, brisk takeoffs.
-Craig
I have a 2002 Passat with 5067 miles on it. I was going to take it to the dealer for the first service. They were going to charge $35 for what seems to be a simple oil change. He also said they use castrol GTX. I was thinking for $35 I could do it myself (and use a synthetic)! I notice it has a audi filter on it. Anybody change their own oil or have advice WRT this?
thx!
thx!
the alternate oil weight is 5w30.
Under a pull-down(VW,etc.) scroll down to Service & Parts
Oil Change for $22.95:
http://www.vw.com/SP/gif/sstp2_enusd_oc.jpg
Note that this is for the 4 cylinder (1.8T). The V6 is going to be more (uses more oil).
My dealer accept this coupon. They use Valvoline 5w-30, which is against VW's own recommended oil weight of 5w-40. Their excuse? "Oh, 5w-30 is fine for the Northeast." It doesn't say anything about the Northeast in the book...
One more way the dealership screws us (no offense Pete).
-Craig
Read your post about changing tires / suspension on your 99 Passat. Also have a '99 (V6, 5spd) and put a set of Dunlop SP Sport 5000 Asymmetrical 205/55-16s on just about 1 year ago. (Replaced wheels at same time.)
Have been very happy with these tires; they are better in all respects than stock Michelin Energys with possible exception of gas mileage. Was running 26 - 28mpg, daily driving; am now at 25 - 26 mpg - but Fun Factor is way up & am driving a bit more 'aggressively' as a result: the Michelin's did not like to be pushed very hard, whereas I have a lot of fun with the Dunlops. (Actually don't Speed much - goal is more Not to slow down for curves/on-ramps; normal corners are taken "spiritedly," but not so much as to draw attention - from police or anyone else. The goal is not to be reckless, but to 'safely explore the capabilities of the machine.')
The Dunlops have been great in the rain, and did well with the little bit of snow they got exposed to last year. Have about 10 - 12,000 miles on them, and expect they will need replacing next fall (at current projection expect concern to be snow-worthiness for 3rd winter). They are also Perhaps a bit noiser than Michelins on some road surfaces, but only marginally, and have been pleasantly surprised at ride quality. There have been some complaints that the SP 5000s are a bit "soft," but then so is the stock suspension. (Haven't dealt with that yet - the tires alone made enough of a difference that it was almost like getting a new car, esp with new wheels at same time - visual change - and I figure I can enjoy the same experience all over again by waiting another year to replace the suspension. Hey, that 'new car thrill' every two years without actually buying a new car... Great!) The Dunlops seem an excellent compromise for what is still a 'family sedan with Real sporting pretensions.'
-->OTOH, my son has a set of 5000 Symmetricals (NOT "Asym..."; in size 195/50 - 16s; a special OEM version) on his fancy Protege: that car handles fantastically on dry pavement, but he reports poor wet road handling (as against my report of excellent wet handling/braking; maybe I'm just old enough to tone it down a bit more when roads are wet...). He did ok in snow - but again, we did not have a lot of that last year - but has picked up about 3 nails (I have picked up one; presumably due to soft tread compound used to improve 'Stickiness').
There are lot of good tires available - and a lot of Apparent changes in tire technology, what with new materials and composite construction techniques; so the question comes down to what compromises you wish to make - including cost - which hopefully will depend in part on weather & road conditions where you live, as well as driving habits.
So, there you have 2-cents worth (or maybe 5-cents worth...), always remembering that it is nothing more than one opinion, based solely upon my experience... (And since I absolutely enjoy my '99 Passat, it appears from the overall tone here that I simply Must be daft!)
Have fun shopping!
GWG - RK
As for gas mileage. That's probably right. The 1.8T gets about 32 or so on the highway.
-Craig
I am wondering if there is any objective comparative performance data for the 1.8T and V6 engines in the Passat with a manual transmission. I read lots of opinions without a clear majority for either. Would appreciate any information any of you have. I do enjoy performance driving when I can drive my wife's 2002 BMW or 1997 Integra (yeah, she has both; both are coupes).
Has anyone heard about this? I feel stupid but this is the first car I've had with low-profile tires. Finally, does anyone have suggestions about replacement tires? We're planning a LONG trip over Xmas and I am really considering replacing these tires for the sake of my sanity.
Thanks in advance
I don't mind the extra road noise. I like to know my tires are attached to the road
Thanks again
Couple questions:
~ He's asking $16,900 -- too much? It's cheaper than the used used cars at my local VW dealer, but theirs are certified with 24 mo warranty.
~ Will I be able to add a CD player? Can I find an in-dash player, or only trunk mount?
~ Would an extended warranty be worth it? I'm thinking about $900 for 5 years/75,000 miles.
Hope you can help with any/all of these questions. Very anxious to join this Passat community!
THANKS!
Does anyone know what the correct gap is for a 2000 1.8T with U.S. specs? The plugs came with a 10 mm (.039 inch) gap setting.
Anyway, I believe the gap settings are pre set at the factory. I just bought the Bosch Plat +4 for $5.77 each, and I was told they are already set, plus it says that on the box. Besides, I don't know how one could get a gap setter in the space with 3 or more tips. I think the single tip plugs are the only ones that may need adjusting, but I could be wrong.
The CD player can be added adfermarket, for around $400 or so from the VW dealer.
You can get an aftermarket extended warranty for the car if you buy it from the neighbor.
Does anyone know what gap VWA specifies?
It's the only problem I've found with the car!!
Just be sure to note which direction the notch on the lamp socket faces. It will only fit one way. The left side is easier to do because there is nothing obstructing access. To change the bulbs on the right side you have to remove the plastic air conduit, an easy but somewhat dirty job.
If you look behind the small fuses, you'll see big, blocky relays. Look for the one labeled "173". Pull the relay out (towards the rear of the car). The DRLs are now disabled.
Now, to replace your own headlights:
http://web.njit.edu/~rxp0835/b5/
Click "Info Base"
Click "Procedures for replacing headlight bulbs"
I also recommend getting better bulbs:
http://www.autolamps-online.com/products/orderform.htm
The bulbs (both low and high) for the 2001.5+ (newer style) Passats are H7, 12 volt, 55 watt. I recommend the H7 VisionPlus (H7 12972VP). They're whiter and brighter than stock.
Good luck,
-Craig
I have an '02 passat, and my infant is ready for a child-seat upgrade. She previously had a graco model with a base unit that stayed in the car and was anchored by the middle seat belt.
The new child seat suggests using the "LATCH" system which typically consists of utilizing ubolts installed in the crevice between the backrest and the seat in the rear seats. I was suprised to find the passat didn't have these, but it seems like the dealer can put them in. Does anybody have any experience with this?
thx!
I still can't figure out why they aren't installed at the factory. The part itself probably costs 50 cents (in the bulk that VW would buy it in), and would take about 30 seconds on a technicians time to screw them in.
Doesn't sound like cost savings to me (50 cents + 30 seconds of labor vs. 50 cents + 2 hours of labor).
Maybe they figure that most buyers won't install them? Considering the Passat is a "family" car, I doubt that would be true, either.
-Craig
We tried to reproduce this again, but it only happens in a cold start.
Is it normal for the Passat to do this?
But mine is a 5 speed manual.
-Craig
It's almost imperceptible now, but it you can hear it if you listen closely. I assume since yours has been problem free for all these years, I can tell my friend to sleep easy!
Thanks, Hoverdrive!
I got a service price sheet from my dealer.
It seems way more expensive than for the 1996
Nissan Maxima I owned previously. I wonder if
it's just this dealership or this kind of gauging
happens every where.
For 160.95, they do the following:
Oil & Filter change.
Check & Top Fluids.
Check & Adjust Tire Pressures.
Multi-Point Inspection.
OBD-Check DTC Memory.
Road Test.
Maybe I should go to JiffyLube or learn to change
oil myself.
Good luck
I know what you mean though. Goodyear charged me an "upcharge" for the filter on my car, $10. That's why I go to the dealer now and get the service done. More professional and I also get a loaner while it's in there.
Getting the skid pan off (underside front of car) involves releasing the fasteners (for which you need a short handled wide flat blade screwdriver) there is a total of 9 of these fasteners (two in each wheel well, 2 in the front, and 3 across the back) plus one (small) nylock hex nut in the front. The fasteners are released by rotating counterclockwise 90 degrees, and once rotated you want to carefully wiggle them to get them out. There is also 2 fasteners out of the 3 across the back that are a little tricky due to some rubber grommets. Just release them and pull them trough the rubber and they will be O.K.
I decided to change my oil myself because when I took it to the dealer for the 5000K change some bonehead cracked my oil cap. The dealer got me a new cap and all, but it really bugged me the service tech broke it and did'nt say anything.
I did have to go to the dealer for the filter though, ($12.00) I could not find any for the 2002 Passat V6. Fram lists the XG-2 filter but I could not get one in my area (CO).
Craig, thanks for the tip about the DRL relay # 173.
Gatorsnap
