Visitor Agreement.
Wittb
MSRP $29702
Quoted Price $27250 ($200 over dealer invoice
$500 over KBB's
Dealer's invoice $27050
KBB had it at $26683
Is KBB accurate in invoice pricing? This still seems like a good deal even with the dealer's invoice. Anyone got better quotes?
I promise this is the last post i'll have re: pricing. Thanks.
The thing was, i was offered the same price on both vehicles, though they were identically equiped. I would never ever pay 27 grand for that altima, but would probably pay 35 for the max(hope nissan is not listining). anyways, just my two cents.
If anyone has seen one would you let me know if it is a stark white or is it toned down.
Also how do you like it?
I am waiting for one to come in and, believe it or not, if the colour is not acceptable to my wife and I we are going to get a VW Passat in Fresco Green.
Any help appreciated.
gsd@canada.com
I bought a base Maxima SE with only a sunroof and BOY is it swell! Geez! Do yourself a favor.....
BUY THE MAX!!
I tried a Maxima SE, automatic, cloth and no sunroof. It has the side airbags and would be fine for me (I like leather but it is not absolutely necessary). My only problem is the sport tuned suspension. I really liked the softer suspension of the GLE and find this one too harsh for my taste (I don't drive sportly as you can guess).
Is there an inexpensive way to "detune" this suspension so that it is more like the GLE? Do you have to replace both the springs and the shocks? Would that have a negative effect on the handling (I mean worse than the GLE)?
Does the Max SE have LSD as well as traction control?
My other option is to buy a used 2000 Toyota Avalon (11,000Km). It has everything I want with leather, sunroof (I fit), traction control and skid control. It would cost a few thousand more and maintenance would likely be more expensive... I am not sure about the reliability of the car either, lots of complaints on the Toyota Avalon board...
Suggestions are welcome!
Pat.
You might also consider an adjustible shock. KYB and Tokico both make them. You can then make them softer.
As one other suggestion, you could try putting on smaller wheels and higher profile tires on the SE. 16" wheels with 60-series tires would probably soften the ride a little. A lot less radical of a "fix" than the suspension.
Try getting Infiniti I30 with sunroof delete option and you might get what you want.
Check out the I30 board for current prices etc. Also consider the cost of Insurance. ..
We were looking at Maxima and I30 last year. I30 was about $2000 (USD) more then MAX SE...but was $500 per year less to insure. (with out driving records and in Scottsdale, AZ area)
If you are planning to keep the car for five or more year Max and I30 are same....
Just my humble opinion.
Humble Rex
Just wanted to add to your post above. Even though insurance may be cheaper for the I30, depreciation for the I30 is very bad, whereas the Maxima is about average. pdubois, I'm not sure how depreciation is in Canada for the I30, but here in Atl, GA it's pretty bad. Just my .02
I am replacing the original tires, Toyo's 215/55/16, this Sat with Michelin Pilot XGT V4 225/50/16. Should be a much better handling tire. SInce I am doing this, and really wished I had the SE, but wife didnt like the firmer susp. I am also replacing the springs/struts as well. (Quietly) heehee...putting Eibach springs/Tokico struts front and rear. Am told it will drop front by 1.3" and 1". I hate the big gap in the front fenderwell.
Sorry for the long post.
Has anyone else attempted this? BTW..car has 27K on it..wore the Toyo's out pretty good. Wish I had an SE...
Pat.
WIll let you know.
I have a 95 GLE which came with 15" alloy wheels back in late 1994 and I've always had the same issue with the looks of the car as you, the wheel wells were way too big for the 15" tires!!
Last fall I added a set of 16" painted 5 spoke wheels and 16" low profile tires and the car finally looks pretty decent (IMHO). (Came from TireRack.com)
I used the 15" alloys for a set of snow tires on my 00 SE which has the 17" wheels and tires.
0-60mph
quarter mile in ___ seconds
speed at end of quater mile
Obi
I have noticed weird rattle noisy when I drove under 15 MPH. It just happened few days ago, and I couldn't duplicate same problem at dealer. I only have 46K miles on my 97.
Also, I get all sort of feedback from gas pedal. For example, I can feel gas pedal shakes long enough to feel shifting gear on my Auto Tranny. Also, higher RPM it goes, more shakes/feedback I am getting. Is this normal? I never got any feedback from my pedal on my 240SX.
Rear Brakes($215)
Rear Brake cable($400)
45000 Mile Service($300)
Wheel Alignment($80)
Belts ($80)
I told him, I have got a rear brakes service 7 month ago(9000 miles ago), and I got wheel alignment then. But what he told me was, previous dealer didn't ADJUST rear brakes correctly and it wore off and this causes bad brake cable. (I was like WTF..) It didn't make sense to me, because I though Brakes works by hydraulic system not by cable. He said, I have cut in my cable hose, and in winter, salty water can cause rust whole thing, and cause failure.
So I just left dealer, and went back to old dealer whom I got my brake service before. They noticed, both brake cable were bended, and it seems like they didn't adjust lifter when they lift up my car. That's how those hose got cracked in same place for both sides. I tightly overwrapped the 1" crack with black electrical tapes several times. Do you think I need to replace brake cable?
By best I mean best price, honest, and easiest to deal with.
Much obliged.
Well I have to say it looks MUCH better. I needed tires anyway for the NH winter, so I splurged. Here's what I did:
Orig. tires 215/55/16 Toyo Proxes
replaced with 225/55/16 Michelin XGT Z4
Replaced orig. struts and springs with am Eibach Pro Kit, Tokico struts all four corners. The Eibach drop it about 1.4" in the front, 1" in the rear. This made a huge diff. in appearance, along with the wider tires, they now fill up the wheelwell. I'll post a link when I get back to work with pics. Forgot to take some pics before change, but since most here probably have not done this, will have an idea of the car before.
The ride is much firmer, been a long time since I test drove the SE, but I think this is at least that ride if not a tad more. The drop was not low enough to cause a camber prob with the front or rear tires, (tops leaning in), and looks awesome.
Let me know what you think once you see the pics.
Enjoy the ride...I will a little more since I commute in this puppy 120mi each day.
Next thing I am doing is a front and rear strut tower brace. Gotta raise a few $$ first though.
In case you wanted to know the total cost...
Tires were roughly $800 installed, total bill for all $1901.
Not cheap, but the look is worth it for me.
The Olds has cost us over $7200.00 for maintenance and repairs for the 55,000 miles we owned it. I'm hoping that the Max will be MUCH less expensive to operate.
sysadmin1 - I'm wondering what kind of gas mileage you get on the 120 mile commute. My commute is 104 a day and while the Max is the wife's car, I may get to drive it sometimes
I consider my driving style to be "sporting" and so far I'm very happy with the way the Max drives. Maybe the GLE model has a softer suspension than the GXE? If it had been my car it would have had to have been an SE with a manual, but my wife won't put up with a stick in NJ traffic.
I just purchased a 96 Maxima GLE in Ohio for 7950 + Tax. It has 65,500 miles on it. This was from a Nissan dealer.
My Q is
Is this a good price?.
What maitainence / problem should I be aware of?.
Thanks, in advance..
Ban
I have the same problem with my '01 SE. Terrible grinding/squeaking noise coming from left rear brake in slow city driving. Never at highway speeds. Especially loud and terrible when just leaving the garage (first brake application after startup). Very noticeable driving around town. Local Nissan techs are confused and can't find the problem. Initially...they tightened some loose bolts on the brake caliper...but that has not done the trick. Taking it back in this week. Good luck!!!! (Anyone else having this problem?)
I can say there the best I have found. I have purchased 4 Nissan's from them and they beat others dealers prices each time.
The service dept was as good as my old Lexus dealer. Get the invoice price and fax it to him.
Good rule of thumb, no matter who you end up dealing with keep your guard up and be ready to walk.
Thanks for the tip on the Chicago Nissan dealer.
So if you find any good deals (price wise/dealer service/ etc.) please let me know
They do not have the new max on their site and I bought one today. No brochures available. Salespeople are not at all knowledgeable. The only reason I bought one is that I've had one since 1989 and it has been an excellent car.
Should I have bought the 02 Passat??????
