Visitor Agreement.
You can try going to a K&N Air Filter. I've heard they can help to squeak out a mile or so per gallon, maybe even 1.5 on the highway. They're spendy, like $45-55, but over time they pay for themselves because they last FOREVER, you don't ever need to buy another $7 air filter, you just clean and re-oil them yourself. I've got one, but my 2000 SE has the 3.0 motor so it's not a fair comparison, but I can get upwards of 28-30mpg if I drive like a grandma and go 60-65mph. I even broke 30 on one trip, I got 33.4mpg going from Omaha to Minneapolis in the summer with the A/C on the whole time. Must've been a big wind or something!
I am getting rattles at 40+ mph from back of driver's side. It's at ear level or above. It's only from one side, so it must not be normal.
Squeaks:
I park my Max in Parking building. When I drive down, I get squeaks from passenger side (possibly shocks/struts). I also hear squeaks when on uneven road (Baltimore downdown has bad roads).
Have anybody had similar problems? And how do I deal with my dealer about the problems? My 03 SE Auto has only 900 miles. Should I change oil at first 1000 miles? FYI, it's my first new car. I like to baby it.
Thank you for the input on gas mileage. I'm using premium, and I'll keep eyes on it.
Thanks for the tip on the K&N Filter. I'll look into it.
Also, just to clarify, my MPG numbers were obtained using Premium Fuel.
Regarding your first oil change, the Nissan Owners Manual states: "Your engine was filled with a high quality engine oil when it was built. You do not have to change the oil before the first recommended change interval." (Section 9-5 "Engine Oil and Oil Filter Recommendation" 2002 Owners Manual). I would assume your 2003 Owners Manual reads the same.
The recommended change intervals can be found in your Service and Maintenance Guide (i.e. 3,750 interval, 7,500 interval, etc.)
Hope this helps.
Does anyone know where to find this type of pinstripe?
I always hear about changing coolant fluid every other year, but dont know if that's overkill.
-Kyle
Coolant and transmission fluid changes -- my 92 Max with 70k miles only had one fluid change, and my 97 Max with 30k miles has not had any fluid change. Both cars run fine.
I think the Max is a low maintenance car with excellent reliability. I can't say the same for my Oldsmobile and Mercury bought in the 80s which I ended up junking due to high maintenance cost.
u seem to be a different driver than most... i asked the fluid change question because i drive about 15k a year... and currently at 32k on a 2000GLE.
I had the tranny fluid changed at 20-25k (had it changed when the dealership performed the tranny slip TSB). I'm planning on having them flush the tranny every 30-40k miles.
Also, do me a favor (anyone, everyone) listen closely to the auto tranny when accelerating slowly from a stop. I hear a faint 'whine' from mine. It seems to have started at the 30k mile mark. I test drove an '03 with 5 miles on the clock and heard the same thing. It's making me a little nervous.
As for when to change your oil, the 'Service and Maintenance Guide' dictates that you should change at 3,750 or 3 months, whichever comes first. It is not necessary to change at 1,000 miles.
It is going to be larger......therefore heavier and probably slower, and they
are going to charge MORE for it. DUH !!
It appears to me , that out of all of the Maxima iterations, the '02-'03
Maxima's are the ones to have and to own. Price, power, performance,
and luxury amenities. Real classics !!!! My 2 cents.
Just want to pass the word on this 2000 Maxima brake problem. If you brake hard on high speed, it sounds like metal grind on metal.
The problem is the rotor, there is a TSB(Technical Service Bulletin) # NTB00-088 out at their dealers.
I called the dealers and they said they will not paid for it. But after several calls to Nissan directly, I was able to get them to promise to fix it for free. One time deal is what they said.
The thing is you have to be persistent and complain loud enough to get them fix it for free.
My 2K MAX has 47000 miles on it and they said they will fix it. Have not get it fixed yet, but just want to let owners of 2K MAX out there know that they can get it fix for free if they complained loud enough
Also, here is the link to a copy of the TSB:
http://apollo799.50megs.com/Maxima/Maxima.htm
If I were you, I wouldn't use the web to search for bosdy shops. I'd ask your Nissan dealer for a recommendation and check with 2-3 of your local Mercedes, BMW, Lexus dealers for their recommendations as well.
Whether or not the entire bumper will need to be repainted needs to be discussed with the body shop. I was concerned about matching my "ruby pearl" color, since the car is now 8+ years old, but the body shop (highly reputable) said that matching and blending won't be a problem. I don't know if the there would be any difference with the bumper being plastic.
My work is going to cost $850 (my insurance company agreed to cover it as a "uninsured motorist" accident w/ $200 deductable if the valet parking service doesn't pay). Unfortunately, in your case, it would probably either have to be reported as an at fault accident, or taken out of your cousin's hide. My guess is that you are looking at $400 +/- for repainting the entire bumper. But that's just a guess.
Had the work done at Regal Nissan in Roswell...second time they have done work on the Max (my wife closed the garage door on the rear bumper)...also we had an Altima that was repaired there after someone ran a red light. All in all, I have been satisfied with their work.
Is this really true? I am still considering to purchase 03 Maxima at the end of the year.
Do you think it will be "totalled?" Get a new one...maybe a different color, so the memories won't flash before your eyes every time you look at it.
Good luck!
ps. Black-eyed Peas, Hog Jowl, & Cabbage on Wednesday
josel1138: Dent Wizard can't help you, my friend, but at least you are O.K.. I would absolutely strive to get the car totalled, including feigning a sore neck, back and knee, if necessary. I had two cars prior to my Maxima that sustained major damage (Toyota Supra, Acura Integra) when they were less than a year old. They never were the same afterwards, cosmetically or mechanically. Even if the repair shop does a perfect job, you are still stuck with a nearly new car with a huge blemish on its record, come trade in or sale time. I hate to suggest "lawsuit" but I do think you should at least consult an attorney to make sure you get what you are fully entitiled to. A friend of mine (who happens to be an attorney) negotiated an additional $5,000 in compensation by the insurance company as an approximation in lost market value when his nearly new 5-series sustained significant, but not fatal, damage. Good luck.
I do not believe the dealer told the truth. In fact, after I replaced the OEM batteries with Diehard golds, I never had a problem even though the mileage we put on the cars has not changed. Instead, I believe the problem lies in the fact that the OEM batteries require maintenance (like adding distill water periodically)while the Diehards are completely maintenance free. I cannot believe why Nissan has failed to put in a maintenance free battery in its flagship car after all these years. To wit -- my 03 Max still uses the same old periodic maintenance battery.
Does anyone share my experience or opinion?
And a Happy New Year to you!
I don't want leather. I love the cloth Nissan uses and prefer a cloth seat. But I also love traction control (have it on my current vehicle).
Anyone out there have Trac with cloth? How'd you get it??
I think it should really be standard, because the 255hp is incredibly easy to lose control of. It scared the heck outta me the first time I hit it (in a rental), and I drive a Jetta turbo as a daily driver, so I am used to a sudden burst of power.
Why must Nissan tie perfectly important safety options to stupid things like leather seats and sunroof??? Not that I wouldn't mind having those things. But safety options should come packaged with cosmetic ones. Shoot... I really liked the Maxima.
This was the first set of dedicated snows I'd ever bought and I for one am completely sold on the idea from now on.
I used them last winter as well and haven't had to put them on yet this year (no snow in Wisconsin yet).
I think you'll be absolutely shocked at how well the car handles with the dedicated snows on.
A word of warning, keep a close eye on the air pressure in the snows, mine for some reason seem to need attention much more frequently than the 17" tires.
I check mine every couple of days and seem to have to make adjustments about once a week.
If this wasn't done correctly (and it doesn't sound like it was) I don' think it's the car's fault, it's the person who changed the battery not knowing the correct procedure!
That said, I don't think you have much choice now but to have the dealer get involved to resolve this problem.
Good Luck.
Deb
They both say however to check with your Nissan dealer for battery replacement. Now I wouldn't ever buy a battery at a Nissan dealer but when I got the last one at Sears (for the 95), I didn't have any trouble since they apparently knew what had to be done and did it automatically.
I'm still on the original battery in the 2000 at 115,000 miles.
Why did you change the battery in the first place? Were you having trouble startin g the car? Who changed your battery? Do you have any potential recourse with them?
If not, then it sounds like your stuck going to the dealer this time.
My 95 (with 195,000 miles) is only on it's second battery. Maybe you've got another problem with the starting/charging system?
I also travel a lot and certainly don't want to be stranded. That's why I drive Maxima(s).
Good Luck!
It also a couple pics of the interior (2+2 seating).
INFORMATION PROVIDED BY NISSAN
Nissan to unveil all-new Maxima
The all-new 2004 Nissan Maxima continues the formula passed down from five previous generations - an unmatched blend of performance and luxury. The sixth generation Maxima combines traditional Maxima performance with expressive sports styling and bold innovation to create a top-of-the-line sports sedan.
An aggressive new exterior design captures the characteristics of a performance car and a luxury sedan all in one, with a chiseled, muscular shape and pronounced character lines. Inside, the expressive design theme continues. Standard on all models is an industry-first Skyview™ Roof, which creates an open environment for front and rear passengers while maintaining a solid roof structure. An optional Elite Package 4-seat layout gives the interior a distinctive sports car-like design, further separating Maxima from its competitors.
One thing that has not changed is Maxima's legendary performance. Maxima is powered by the award-winning VQ 3.5-liter engine, increased in 2004 to 260-plus horsepower. An all-new multi-link independent rear suspension provides superior handling and increased ride comfort. The 2004 Maxima is scheduled to go on sale in March 2003 at more than 1,100 Nissan dealers nationwide. Highlights of the 2004 Maxima include:
Body
Completely new, aggressive exterior designed to bolster Maxima's sporty image
Chiseled, muscular shape with pronounced character lines and distinctive C-pillar design adds a sport coupe-like silhouette
Nissan signature styling cues have been adopted in the hood and grille
Auto on/off xenon headlights standard on 3.5 SL (optional on 3.5 SE)
18-inch aluminum-alloy wheels with V-rated 245/45R18 tires, standard on the 3.5 SE
All-new FF-L (front engine, front-wheel drive large) platform adopted for Maxima increases torsional rigidity 40%
Dual exhaust with four ports and chrome finishers
Chrome-colored accents on roof moldings
UV reducing solar glass
Eight exterior colors
Engine and Driveline
3.5-liter DOHC 24-valve V6 producing 260-plus horsepower and 250-plus lb-ft torque
Engine features include electronic throttle, silent timing chain, microfinished camshaft and crankshaft surfaces, molybdenum coated pistons, resin intake collector, digital knock control system, cross flow coolant pattern and higher capacity muffler
Platinum-tipped spark plugs with 100,000-mile maintenance intervals
6-speed close ratio manual transmission optional on 3.5 SE models
Gated 5-speed electronically controlled automatic transmission with manual shift mode standard on 3.5 SE
4-speed electronically controlled automatic transmission with gated shifter standard on 3.5 SL
Vehicle Dynamic Control (VDC) with Traction Control System (TCS) available on all A/T models
Available Helical Limited-Slip Differential (3.5 SE manual)
Suspension, Steering and Braking
Independent strut front suspension with coil springs and stabilizer bar
All-new multi-link independent rear suspension for superior handling and ride comfort
4-wheel power-assisted disc brakes, standard 4-wheel Anti-lock Braking System (ABS), Electronic Brake force Distribution (EBD) and Brake Assist (BA)
17-inch aluminum-alloy wheels - 7-spoke on 3.5 SL - with P225/55R17 tires
Standard 18-inch aluminum-alloy wheels with P245/45R18 tires on 3.5 SE
Interior Features
Five-passenger seating with luxury cloth or leather-appointed seats and 60/40 split fold-down rear bench with lock
Optional Elite Package with 4-passenger seating layout with two rear bucket seats, rear console design resembles front console, includes power rear sunshade and cargo pass-through
Standard 8-way power driver's seat (4-way power passenger seat on 3.5 SL) with entry/exit feature (A/T only)
240-watt 8-speaker audio system with AM/FM/cassette/CD with steering wheel-mounted controls on 3.5 SE
320-watt 8-speaker BoseÒ premium audio system with AM/FM/cassette/6-disc in-dash CD changer, speed-sensitive auto volume control and RDS radio function standard on 3.5 SL
Available Nissan Navigation System with 3-D Birdview™ 7.0-inch display
Heated front seats on 3.5 SL (available on 3.5 SE)
Dual zone air conditioning with automatic temperature control and rear vents
Center display that provides HVAC, audio system and trip computer functions in one central location
Safety and Security
Standard dual-stage air bags with seat belt sensors and front seat side-impact supplemental air bags and curtain side-impact supplemental air bags
Front-seat active head restraints, 3-point ALR/ELR seat belts (driver's seat ELR only) including rear center position
Front seat belts with adjustable upper anchors with pretensioners and load limiters
LATCH (Lower Anchors and Tether for CHildren) child seat anchors and tether system
Emergency inside trunk-release
Models and Manufacturing
Offered in two models: 3.5 SE and 3.5 SL
Exterior and interior designed at Nissan Technical Center (NTC) in Atsugi, Japan
Assembled for the first time in the United States at the award-winning Nissan North America Manufacturing Smyrna & Decherd Tennessee Plant
