Nissan Maxima
1128129131133134174
  • kyleknickskyleknicks Member Posts: 433
    Tires - personally, i would rather go for the well known brands.... bridgestone, dunlop, toyo etc.. but that's just me.
    GAS - i've only used 93 octane in my maxima for the last 36k miles mainly based on the assumption that it is cleaner than regular... therefore less chance of clogging my injectors... plus i just feel better giving my maxima the better stuff... now, if i was a mechanic, and can service my own injectors/engine etc, then i might go with 89octane.
  • kp40mkp40m Member Posts: 19
    Where does it state that we should use premium gas (91 or 93 octane) in our Maximas? I just bought a 2003 GLE and the owners manual mentions that 87 is fine as long as there is no knocking.
    I don't mind paying for 91/93 IF its worth it.
  • obiwankenobi1obiwankenobi1 Member Posts: 290
    I had been putting 89 in my 02 SE when the gas prices were way up. I just switched back to 91 on Monday. I filled the tank completely with 91, added a fuel injector cleaner and octane boost to the tank. The thing is a rocket now!
    HOWEVER...It still is knocking a bit which is odd. I wonder if it takes a few tanks of premium to get all the knocks back out?
    Obi
  • mirthmirth Member Posts: 1,212
    My '02 manual just says it recommends premium. My policy is to use whatever fuel the manufacturer recommends. They know their engine.
  • habitat1habitat1 Member Posts: 4,282
    "It is STILL knocking a bit.."
    Obi: Not to pick on you in particular, but you mean to say that you were continuing to use 89 octane even after you heard knocking? I really question the prudence of saving 10-15 cents a gallon on a $25k car and risking engine damage in the process. Reread gg2k2se's post if you need a second opinion.
    For everyone: I tried to be diplomatic before, but for the clearer record: I think it is just plain dumb not to put premium gas in a Maxima. Over the course of 10 years and 150k miles you couldn't save more than $1,000 using regular gas, even if your mileage didn't suffer. You won't save a damn cent if your mileage drops 2 mpg. And, in exchange, you are going to risk the likelihood that you won't get to 150k miles without costly engine repairs??
    Of all the penny wise and pound foolish analogies, this pretty much takes the cake.
    P.S. For the record, when I bought my 1995 SE, I was on a tight budget and had to think long and hard about spending an extra $3k over a Camry LE or Accord LX (both 4-cylinders) at the time. I stretched for the Maxima because, among other things, I valued the exceptional V6 compared to the other two. The only option I could afford was ABS ($1,000). No sunroof, no Bose, no leather package, no other options. But never, in the intervening 8 years in 136k miles, did I skimp on premium gas. If I could do it, anyone getting a Maxima could and should.
    i sorta agree with habitat... but i'm sure there are people out there that lives beyond their means and end up with a loaded max or similar and saving $3 a fillup makes sense to them since it gets you from point A to point B just the same.
    For me, i would rather put in 93 octane and ease off the petal...
    Almost seems like the "good" fillups where i get maximum mileage is when i fill up at Exxon. I get sucky mileage when i go to HESS.
  • nismoguynismoguy Member Posts: 7
    finally, someone else understands, lower octane burns faster then premium, in turn you use more, making the cost savings nill. not to mention the damage your engine gets for being cheap....
  • norbert444norbert444 Member Posts: 195
    Is there any good way to carry a bicycle (short of installing a permanent rack) on the 00 GLE? This would be just for a one-time vacation use. Thanks.
  • p100p100 Member Posts: 1,116
    I have been using premium fuel in the 98 SE 5 speed since new. I get consistently 26-27 MPG in combined driving with the A/C on almost all the time (I live in Florida). The car seems to like Mobil premium the best.
    I have been using premium fuel in the 95 SE 5 speed since new. I get consistently 26-27 MPG in combined driving with the A/C on almost all the time (I live in Florida). The car seems to like Mobil premium the best.
  • giant56giant56 Member Posts: 9
    I came across a CD hard drive made by Kenwood at Best Buy. I am told that it mounts just like a CD changer in the trunk or under the passenger seat. It can store up to 10 hours of music and it reads several formats (WAV, MP3, etc.). Has anyone had any experience with this item. I own a 03 SE and am considering it as an addition, but I am VERY CONCERNED about my warranty..
  • dklaneckydklanecky Member Posts: 559
    Yalima makes a real nice setup. I fit two adult and two teenagers biles up on the roof of my 2000 SE with no problems. (It does however really penalize your gas mileage.)
    It was kind of pricey (about $450) when I bought mine in late 1999 but it still works great and you can customize the setup to match your needs.
    The price is directly porportional to the amount of bikes you're going to carry.
    For example I bought the crossbars and 4 trays with a product called I think lock jaws which allow me to very securely clamp and lock the bikes up on the roof.
    The original installation, getting everything set just right took the better part of 1/2 a Saturday but now I can get the whole thing set up (or taken down) in about 20 minutes.
  • ramped1ramped1 Member Posts: 159
    on the 93/91 or 89/87 octane debate. I've put every grade in my '92 SE over the past decade.
    Based on my experience, everyone who has posted recently is right. The higher the octane, the higher the gas mileage, all other factors being equal. But, on the other hand, my car has never knocked on 87 octane.
    I have primarily used 89 octane and have had no injector problems over 111K.
    What is overlooked in this debate are the outside factors. My car always gets better gas mileage in cooler weather, no matter what octane I'm using. So, in the cooler months (rare) here in Florida, I'm more likely to use the lower octane. When it cooks in the summer (pretty often here), I usually use the 89 or, occasionally, the 91.
    The 87 octane is not going to hurt this engine, or Nissan would certainly make 91/93 octane mandatory under warranty coverage. You can far more effectively regulate your MPG by using a light foot on starts and driving conservatively (hard to do in a Max!) than by buying higher grades of gas.
    By the way, I'm not a big fan of the the '04. Don't like the grill even a little bit. What about you?
    i went to the car show this past friday...and wanted to see the maxima in person and take some pictures.... well, the only thing i can say is, the rear end looks better than my 00 with the dual exhaust, but that's about it.
    that new sunroof they have it in sure is weird looking...if anything, they should make it panaromic like the mercedes... all it does is let some sunlight in, that's about it... i dont care for the car that much... if i had to choose on a 03 vs an 04 at the same price, no doubt i would pick the 03. i would even take an Altima or an Audi A4 before i would choose the maxima...
    funny thing was, at the car show, one guy said "man, this things is over 300hp".. i'm thinking to myself "u dope, no it doesn't"..and another guy said.. "that roof opens sideways!" again, i thought, wait till u buy it and it doesn't open! LOL
    can we make fun of the first person that comes into this board that bought a 04? LOL..
  • niteswmer2niteswmer2 Member Posts: 20
    Hi everyone. Love the board. I'm looking to be a new (well, used) Maxima owner. I'm currently looking at an '00 SE with a lot (87,000) miles on it. Interested in hearing anyone's thoughts/concerns about purchasing a car with so many miles on it.....
  • rswaglerswagle Member Posts: 27
    Don't! It's not worth it. The 00's had many TSB's with unresolved coil pack problems and rotor warpage. I speak from experience. However the 03's may be a better option for you if it is economically viable. With the interest rates so low, it may make sense to go that route. Just my .02
    regards
    I own a 2000 Maxima SE and have not had any problems with "many TSB's with unresolved coil pack problems and rotor warpage".
    I have 125,xxx miles on mine now and will tell you that IMO a lot depends on the original owner and how the car was driven and serviced.
    Can you check the service records on the vehicle at the Nissan dealer or is on another dealer's lot? It may be that some of the issues that the previous poster identified have already been dealt with or never existed.
    The deals on the remaining 2003's are pretty incredible right now with $4,000 off MSRP pretty common now.
    If there's any way to afford it, the 2003's are the better way to go with more horsepower and a significantly higher level of standard equipement that what's even possibly on the 2000 SE your looking at.
  • bcohenbcohen Member Posts: 58
    I don't imagine that niteswmer2 is going to be able to make the stretch cost-wise from a maybe $10k car to a $23k car just because their a good deal right now. I don't think that's fair advice. I'll be looking at used Max's too shortly in the $11k neighborhood. I would love to make the leap to a 2003, but I can't afford the difference.
    My advice to niteswmer2 is to just look at the price/value comparison. I would think you would be able to get a 50-60k mile 2000 Max for $11ish right now based on my research. That means you should be able to get a 2000 Max with 87k miles for say $9k. You have to ask yourself, "will you have $2k worth of repairs while you own the car?", "how long are you going to keep the car...will you get hit with a depreciation also?". The Max should be good for another 80K+ miles, so it may be worth it if the price is right. What is the price, by the way?
    It may look a little different but once you get in and drive, forgetabout... This car flies.. This is one thing that keeps your mind off the other aspects of this design.
    With respect for the guy who thought it was over 300 hp its 265hp, but behind the wheel it sure feels like alot more. The reaction in the dealerships is mixed about 50/50 between the two model years. And with 03's getting hard to come by, if you want one you should act now or get comfortable with the look of the new and improved beast.
  • gerapaugerapau Member Posts: 211
    While I agree that alot depends on the original owner and how they service and maintain their car, the 2000 Max's did have numerous TSBs associated with them. The good news is that most of these problems have probably already shown themselves on a 2000 car and have been repaired.
    By the way, I am meticulous when it comes to servicing and maintaining my cars and have had my 2000 SE 5-speed in the shop way too many times over the last 3 1/2 years (all work was done under warranty but I did have to rent replacements cars on many occasions). I am on a first name basis with everyone at the service department of my dealer. I count myself as one of the unlucky "Friday car" owners and do think that the fun-to-drive side of this car has more than made up for the many trips to the dealer. I have however decided to cut short my current Max lease (my tranny is starting to act up for the 5th time) and have leased a Murano (I looked at the '04 Max but didn't like the styling). Hopefully this Nissan will be more reliable than my last.
    We're in the same boat on the Murano as the next vehicle. Mine (SE AWD) was ordered 2/15 and delivery is expected early May.
    I also am on the dealerships "Christmas Card List" as a regular customer and well known to all the service staff. Virtually all of my contact on the 00 was for preventive maintenance or the TSB's. (None of which seemed to apply to my car.)
    The 2000 Max is now going to be my wife's car and the 95 Max she's driving now will go to my 19 year old son (assuming he gets a parking permit at college next fall).
    Isn't it interesting the way that the same model of car can have such a wide variety of owner experiences? Was yours an early (bought fall 1999 like mine) model year or a little later?
    I bought it in September '99. Great car to drive but it frustrated the hell out of me. A few of the problems I had were:
    - Coils replaced (5 trips to the dealer before this was fixed)
    - Front rotors replaced (they lasted about 5000 miles before they warped)
    - Power drivers seat switch
    - Heated driver seat switch
    - Rear bumper painted due to misalligned trunk lid
    - Transmission problems (started at about 5000 miles and has be repaired 3 times and rebuilt twice. It is starting to act up again)
    - Altinator died (this left we without a car for 1 week while on vacation last summer)
    - Numerous fit and finish problems
    - A few other small problems
    This has by far been the most unreliable car I have ever owned. I do however work with at least 5 other people that have 2000 Max's and none of them have had the problems that I have.
    Wanted to say thanks to all of the responses to my post #6753 (and quick)! Lots of good advice. While I'd LOVE an '03, and could afford one if it came down to it, my goal is to get a good, fun to drive car and save some money (hoping to be able to allow the wife to "retire" to take care of the kids).
    Bottom line it's going to come down to a personal cost/value decision (not to mention the fun to drive aspect, which is important to me). I'm fortunate enough to work from home, so I won't be putting a lot of miles on the car. I'm going to insist the dealer allow me to take it to an independent mechanic to evaluate it (and if he doesn't let me, then I suspect there's something to hide).
    BCohen, the dealer is asking 11.5 - Edmunds TMV for dealer retail is 14K, and private party 12K.
  • sct75sct75 Member Posts: 19
    I have a 00GLE, so far only did a rotor surfacing and a gas/oil sensor change (under warranty). I wonder if anyone of you would be kind to answer any one of my following questions regarding to 00 Maxima TSBs:
    1) where could I find the list of TSBs on 00Maxima you mentioned in previous messages, including their details?
    2) if the described problem(s) have not happened to my car, should I bring it to dealership to check/fix it or wait until it breaks?
    3) in case the same problem occurs, should I bring the proof of TSB(s) to dealership to explicitly ask for fix and warranty coverage or would it be taken care of automatically? Any experience would be highly appreciated.
    Thanks to all.
    niteswmer2 - You should go ask Terry in the "Real World Trade-in Values" thread under Smart Shopper what the "real" price is for that '00 Max.
    u sure sound like you sell nissan's
    Two sources that I am aware of:
    http://www.alldatadiy.com/
    They will allow you to look at summary information for free but no detail unless you pay for a subscription. (About $20 for a year or something like that. Might be worth it on a $25k car?)
    Also:
    http://www-odi.nhtsa.dot.gov/cars/problems/tsb/tsbsearch.cfm
    I wouldn't just take it in to the dealer unless you see a symptom in your car (if you want the dealer to take you seriously).
    That said, once you read about all the things that people have noticed, you'll start to think your seeing some of the same things!
    dklanecky - thanks for the bike rack tip. Unfortunately for me, I only wanted a rack or something for one vacation. What you describe seems to require more money than buying a (plain) bike at a couple of destinations. :-(
    Regarding the TSBs, it has been my experience that the maintenance dept first denies the existence of a particular TSB but when pressed by me, armed with a paper copy of one, they follow the procedure quite meticulously.
    Regarding the 00 Max experience, mine is very pleasant. The two problems I had experienced have to do with paint (black) that is vulnerable and then warped rotors (see the thread here in mid-February). The latter is covered under warranty.
    I use whatever gas is most economical because my engine does not knock on any of them. Yesterday, it was 91-Octane at Costco in Van Nuys, CA. I record the gas economy occasionally to keep my decision data up-to-date. I buy mostly at Costco since they are consistently the cheapest.
    For other maintenance, I do the oil changes and rotate the tires every 7.5K miles. I only had the car to the dealer for the warped rotors and tried to watch them closely because I do not trust that they will baby my car like I do.
    I know why I am in trouble. I used swear words in my last post. I did try to bleep out the part of the swear words so "youngins" wouldn't understand. Well, I guess I still screwed up. Sorry!! Better repost what I wanted to say:
    I was going to say that my 02 Maxima SE has always knocked a bit under heavy acceleration and hot weather (even with premium). So, I figured when gas prices went up, I might as well use 89 octance. It knocked a little worse, but it wasn't so bad. I am now putting premium in it again, but it still knocks every once and again. I wonder if there is any other fix for the knocking? Any suggestions??
    Obi
    It is ok if the engine knocks under heavy accelaration a bit. Weather shouldn't have anything to do with it, unless it is really extreme, perhaps. According to the Max manual, 87 Octane is OK, and even 85 is acceptable over 4000 ft elevation. (according to page 10-4 of my 2000 Manual (same engine as yours). This manual also says that you get the best fuel benefit if you hear a light knock under heavy engine load.
    If, in your opinion, the knocking is persistent, you ought to have the timing checked.
  • al57al57 Member Posts: 67
    With everything being posted about TSB bulletins on the 2000 Max it seems remarkable you are at 125,000 miles!!Reagarding sct75"s questions about alerting the dealer of knowledge about potential problems with your car,will the dealer adhere to the TSB without replicating the problem and still repair it? They still generate money from Nissan (of course not at full rate) but it keeps their people busy.BTW,only 15000 miles on my car warranty up in July and am worried about future problems which haven't occurrred yet due to low miles and all posts prior.Any suggestions? Also looked at 2003 Gle NO Meridian, spoiler, or navigation last week..wanted 25000 and 1.9%,(listed at 29255)although car is considered 1 year old already color choice is limited, lot more SE models available--Live in NY metro area..any GLE"s out there in sheer silver/black leather without navigation and spoiler only
    Well, I just had a simple response to your post and it seemed to stimulate some interesting responses. As a previous oo GLE owner, I stand by my recommendations to you re TSB's. Yes, most dealerships are not fixing the coilpack probs but are blaming octane ratings/ethanol/MTHB. If you press them thouygh they would probably do it. Re the rotor warpage, check out www.maxima.org to get a better idea how prevalent it was. Re the paint issue, Nissan has blamed the new enviro regs on decreasing lead components in paint and sealant fabrication. Re tranny prob's, i haven't heard too much about that. After all of this, I still purchased a 03 GLE. I love the max. Love the power, love the space for me and my family and love the reliability now after some "fine tuning after the first year. Yes, most issues should have been cleared by the time you want to purchase the max, but what if they weren't? Then what? You will be stuck w/ a max that is no longer warrantied unless you purchase some type of extended warranty. Again, friendly advice. But.... Follow what your heart says. In my youthful days I bought a Rx-7 w/ tons of rotary engine issues but "I had to have it"! Let me know. Good luck
    regards
    i would say you should fillup the next 4 or 5 times with 91 or better octane, and see if it still knocks.. if so, i would take it to the dealership ...
    i know yours is a 02, but someone on maxima.org had his 2000 maxima pinging/knocking, couldnt figure out why it was doing it, and the dealership changed out his coil packs....it just shouldnt be making noises like that...
    Sorry if my previous post was partly responsible for getting you in trouble.
    However, regarding your re-stated problem, I have to disagree with norbert that occassional knocking is O.K. under acceleration. It is my understanding from all sources that I've talked to that any pinging or knocking is indicative of a potentially serious problem. And it should not be occurring in the Maxima, given a properly functioning engine management system. I cannot induce my Maxima to knock no matter what I do with regards to acceleration. Flooring it in 5th gear at 1,500 rpm will just produce a slow acceleration, but no knocking (I tried it last night, just to be sure).
    I agree with kylekicks and suggest you take your car to the dealer and sit on them until they find out the source of the problem. Unless you are planning on trading the car in a year or two, in which case the potential long term damage may not be your concern.
  • jdimottajdimotta Member Posts: 55
    what does TSB stand for...and what were the # posts for the warped rotors...I have a 2001 Max..Is it affected by this???...thanks...Joe D.
    Your engine/gasoline combination will not produce any knocking. To my knowledge, my 00 Maxima engine has not produced any knocking either. And I have used all kinds of gas. We have a hill near our house where my previous cars did knock like crazy - so it is a good test hill for me.
    Let me just cite from the 00 Maxima Manual that I referred to before, page 10-4:
    "... now and then you may notice light spark knock for a short time while accelerating or driving up hills. This is no cause for concern, because you get the greatest fuel benefit when there is light spark knock for a short time under heavy engine load."
    You say that ANY knocking is bad. Maybe you can cite your sources so we can all learn.
    Joe,
    2001 is affected by the Technical Service Bulletin (TSB) for warped rotors. See post #6388 on this board (and a few posts after that).
    Norbert
  • bobfeldbobfeld Member Posts: 33
    dealers here are advertising 03 max se"s for $2,300 below cost
    any recommendations on oil changes for an 03 max? is it best to take it to the dealer? the manual says the max has a "special" oil filter only made by nissan...is this true?
    id be interested in knoing what other peeps are getting gas mileage wise on their max...just bought a new 03 gle and got 19mpg on first tank..was kind of disaapointed with that...feedback would be appreciated...thanks
    I got like 18 mpg on the first tank, but have been getting around 21 since then. On long highway trips, I get 25-26.
  • aftyafty Member Posts: 499
    TSB = Technical Service Bulletin
  • aggiedogaggiedog Member Posts: 238
    I own and 02 SE and I just got the oil changed today for $22.95 + tax. $24 and change total. It's called the Schedule A Service. Unless you do the oil change yourself and lots of folks do, take it to the dealer. Most dealers now have express lube service and ususally a 14 or so point inspection. Jiffy Lube would be about 30 bucks for the same service. You can also buy the oil filter from you dealer parts dept. I don't know the price.
  • kennyg5kennyg5 Member Posts: 360
    I have always filled my 03 GLE with premium fuel except on one occasion. Last week, when I was about 200 miles from home and had only $18 in my pocket (I forgot to bring my credit card and ATM cards), I filled my Max with mid-grade 89 octane gas (but not regular 87 octane gas). I really didn't feel much difference in performance and I certainly did not sense any knocking, even though I wasn't using premium gas. Nonetheless, I agree with many posters, such as Habitat, that putting premium gas in a "high performance" car, such as the Max,is worth the nominal incremental cost.
  • Still holding out and hoping for deeper discounts, last I read was $5200 off MSRP with over 42 Maximas in stock within 15 mile radius! ( 2 dealers).
    what i do is, go buy some mobil 1 Synetic when it's on sale, $4/quart... buy a purator filter $2.50 and bring it to my local mechanic, who charges me $10 to do the oil change. total: $28 and i change my oil once every 7500 miles... cuts the time i have to go get my oil changed in half.. and it only cost on average of $14 every 3750 miles
    That's certainly an interesting quote in the Maxima manual about "light spark knocking" not being a concern under heavy engine load.
    I admit that I do not have an authoritative answer to quote that all knocking/pinging is bad. I have been told this by a much more mechanically inclined friend (Masters in M.E. and Material Science from Duke) who has restored several high performance/exotic cars as a hobby.
    I also called my Nissan and Honda dealers and spoke with the service managers. They both explained that a noticable pinging or knocking sound is the result of metal to metal contact that can cause damage. Neither were familiar with the term "light spark knocking". Interestingly, the Nissan dealer seemed less concerned about pinging happening on a rare occassional basis, but the Honda service manager said I should bring the S2000 in immediately if I ever hear any knocking.
    Sorry if I am guilty of spreading an urban legend that all pinging and knocking is bad. I wish I had a more authoritative answer and explanation, but since it isn't happening to any of my cars, it's somewhat academic to me.
    Here is definition of preignition from the Goodheart-Willcox Automotive encyclopedia:
    "Preignition is the igniting of the fuel charge before the regular ignition spark. If the premature combustion is completed before the occurrence of the regular spark, there may be no identifying noise. However, if the regular ignition spark follows shortly ater the preignition occurs, there will be a pinging noise when the two flame fronts collide. Also, preignition can lead to detonation. These two types of abnormal combustion are closely linked and often it is difficult to distinguish between them. The main causes of the preignition include:
    1. carbon deposits that remain incandescent
    2. valves operating at higher than normal temperature
    3. hot spots caused by defects in the cooling system
    4. spark plugs that run too hot
    5. sharp edges in the combustion chamber
    6. detonation.
    Detonation is defined as rapid, uncontrolled burning in the final stage of combustion. It is caused by rapidly burning flame front compressing the unburnt part of the mixture to the point of self-ignition. This secondary wave front collides with the normal flame front and makes an audible knock or pinging sound.
    Detonation may harm an engine or hinder its performance in several ways. In extreme cases, pistons may shatter, cylinders burst, or cylinder heads crack. At times, these temperatures resulting from detonation may reach the point where the piston actually melts. The causes of detonation include:
    1. lean air-fuel mixtures
    2. fuel of too low octane rating
    3. ignition timing overadvanced
    4. lugging an engine (further depressing of accelerator does not produce any further increase in speed
    5. excessive carbon accumulations in the combustion chamber"
    The following message is my own:
    If I experience any pinging in my vehicles, I immediately check the base timing to make sure it is not advanced too far. Advancing the base ignition timing was a favorite trick of mechanics on older vehicles, because it would compensate for other engine problems and produce sensation of greater power. However, pinging would occur if they went too far. This pinging could usually be eliminated by using high octane fuel. Pinging can be also caused by heavy carbon deposits in old engines, which will glow red hot after the engine has been brought up to operating temperature. In this case, there are products, such as GM "Top engine cleaner" which will effectively remove this carbon from tops of pistons. If you do a compression check on your engine and the numbers are even, but abnormally high, such as 180 psi in an 8:1 compression ratio engine, chances are you have heavy carbon deposits on tops of pistons, which may cause pinging. This happened to my 1983 Pontiac Boneville. After using two cans (poured down the carburetor) of the GM "Top engine cleaner", the compression pressures dropped to 150 psi in all cylinders (which is normal reading for this car).
    I would not be very concerned with very occasional pinging, because it will occur when the timing advance is at its maximum, but any prolonged pinging or regularly occurring pinging is bound to be bad for the engine. Use of premium fuel will usually alleviate the problem and is the simplest solution.
    I am somewhat puzzled by the Nissan statement that the pinging "will occur under heavy load" because pinging usually occurs under light acceleration. On older cars with dual timing advance (centrifugal and vacuum)this is especially true, because the vacuum timing advance is maximum at very small throttle opening. With full throttle, the vacuum advance drops essentially to zero. However, new cars have electronic timing advance controls, and therefore may behave differently.
    Thanks. Your educational post was worthy of my printing out and saving for future reference.
