Nissan Maxima
1139140142144145174
  • cduongcduong Member Posts: 70
    Thanks for your input about'95-99 Maxima. I will look into it. My friend at work has a '96 Maxima with 225,000 miles and still going strong
  • brymilbrymil Member Posts: 18
    jg28--I agree with you that the trip computer is very inaccurate. I never get gas mileage anywhere near what the computer say I am getting. I drive my Max mainly to work which consists of about 18 miles of open highway, 12 miles of moderate stop and go, and 10 miles of the type of traffic Chicago is known for...stop and go. With this type of mix I am consistantly getting between 23-24. Just last night it took 12.67 gal for 304 miles of driving equating to 23.99 mpg. I have got as much as 27 mpg on the highway. Since I am cheap I have calculated how much money in gas I would save if I traded the Max in for a hybrid and it is only about $700/year. It would take a much bigger savings than that to give up my Max.
  • vanbo57vanbo57 Member Posts: 46
    Thanks all for your input on the Pilot Sports A/S tires. I will probably go for those. Re the noise - I usualy have the stereo up pretty loud so that should not be much of a factor. Re the ride - Well, the car is stiff now and ride may become more "harsh" with the Pilots but I suppose that is a sacrifice that I'll have to make if I want the wet / dry / snow performance that I have read is the best I'm going to get in that size, (225 50 17). Re the price - if you want the best performer, ya gotta pay. Any tire that size is going to be expensive. I have read that the tire wear is rated higher than the RE92s and I'll get 30,000 out of those,I'm at 28,400 now.
    Drive safe.
  • cheerioboy26cheerioboy26 Member Posts: 412
    I changed to the Pilots at 38K on my 00 Max (have about 42K now). Definitely better wet traction, although I don't drive the car much now - it's my wife's. They are a bit louder than the Potenzas.
  • eksterekster Member Posts: 22
    This board has had numerous posters discussing their satisfaction with the '95-'99 max. While I accept the comments on the superiority of the 4th gen max, I've been very pleased with my 2000 with 68,000 miles. Are their any owners of 2000+ maximas with high mileage (over 100,000) that can relate how their 5th gen max is doing?
  • ccermakccermak Member Posts: 260
    I have 2000 SE 55K miles with no probs other than an O2 sensor a couple weeks ago. Cost = $330 at dealer in MN. Replaced Toyos with Dunlop SPA2 at 40K. The tranny seems confused a lot when driving really aggressive, besides that car is still solid. I plan on going 100K+ before selling.
  • emf213emf213 Member Posts: 2
    Had my new '04 Max for two months. It's a Black SE w/Frost leather, Driver Preferred Pkg. and Moonroof. Here's my gripe...Nissan cheaped out on the driving lights; they are not Xenon like the headlights (cheezy move to save a few bucks if you ask me). Anyway, is there a way to replace the standard bulbs with the Xenon?? I believe Nissan/Infinity uses the same size Xenons (driving) in other car models. Thanks.
  • bowke28bowke28 Member Posts: 2,185
    xenon lamps can be put in if you can find them...and its not a matter of a few bucks...its a matter of about $700-$1000 for a pair. also, VERY FEW cars with xenon lamps have xenon fog lamps as well...actually, i cant think of any...can you?
  • dklaneckydklanecky Member Posts: 559
    I've got a loaded Silver Mist SE automatic that has 135,xxx miles on it. It has had no significant (other than normal maintenance)issues with the exception of the ignition coils were replaced at 120,000 miles at dealer expense.
    I had taken the car in for it's 120k service (it was running perfectly) when I dropped it off. I picked it up the next day, and drove away, about 3 miles later, all the warning lights came on and it went into "limp home" mode.
    Took it back to the dealer and he the ignition coils were bad and had to be replaced at a cost of ~$700.
    I had them replace them and then asked what could have caused them to go bad all of a sudden when the car was running perfectly when I dropped it off.
    His admitted that the coils become somewhat fragile after a long life a lot of miles and the technician probably damaged them when they removed them to replace the spark plugs.
    They agreed to cover the repair and I bought a new Murano from the same dealer about a year earlier.
    There are some good Nissan dealers out there!
  • p100p100 Member Posts: 1,116
    The fact that they told you that the coil replacement was $ 700 proves to me that this is a not an honest dealer. The retail cost of these coils is about $ 75 times six which is $ 450. Their cost is about $ 40 a piece, so $ 240 total. Are you telling me that charging somebody $ 460 for half an hour worth of work is OK and sign of an honest dealership?
    They replaced them free of charge because you bought a vehicle from them recently and your repeat business is worth $ 240 to them. They may even have a way of claiming these under warranty for all we know.
    Man, your really down on Nissan dealers aren't you?
    My typing mistake on the timing of the events.
    The Murano was bought a year later July 26, 2003.
    The coil repair was in July 2002. The two events are not linked, except that I went back to the dealer and bought another vehicle from them
    FYI, Most dealers actually charge the retail price to their customers, not their cost price.
    i went to our service dept. to check on your #s...each coil retail cost is $89.95. times 6=$539.70 plus tax (usually 6%)=$572.08. each coil carries a quarter hour of labor at $90. thats $22.50 for each coil times 6=135. add that to the parts cost and you have $707.08. dealer cost doesnt matter, since they quoted a retail repair. for one, they WERE honest, and for 2, even if they used your numbers, it doesnt make 1/2 hour labor $460...it would make it $260. use a calculator next time, and have some faith that some of us in the car business enjoy an honest living.
    According to my local Nissan dealer parts department the retail price for one ignition coil for a 2000 model Maxima is $ 69.46. I asked the service department for a quote for replacing the spark plugs for the same car. The answer was $ 84, or one hour labor. This is interesting, and puts a big dent into the above honesty claim. To replace the spark plugs, you must first remove the coils! They said that replacing the plugs takes about an hour - a half hour to remove and reinstall the coils, and roughly the same amount of time to remove and reinstall the spark plugs.
    So according to the other dealer's quote, it takes 1.5 hours just to remove and replace the coils. This means that replacing the spark plugs should be twice that - or 3 hours. At $ 90 an hour, this is $ 270 labor to replace 6 spark plugs. The retail cost of platimum OEM spark plugs for my 98 SE is $ 13.20, or $ 79.20 for a set of six. Assuming the cost of the plugs for the 2000 model is the same, the total cost of replacing six spark plugs is $ 359.20, plus applicable county sales tax.
    I do not know about you, but I bet that most people who read this forum would consider $ 360 charge to replace 6 spark plugs in a Maxima unreasonable. If so, why is it reasonable to expect 1.5 hours of labor charge to replace six coils? In my original post I was trying to illustrate the dealer profit for what I believe is at most 1/2 hour of work. Keep in mind that the 15 minute estimate for each coil replacement most likely includes the time required to get the car into the service bay, getting the right tools, disconnecting the battery, removing coil cover, etc. This is done just once, not all over again for each coil. So I would say that our local Nissan dealer is more honest.
    sorry...i had 1 mistake. the 1.5 hour labor was for coils AND plugs...1 hour for coils and 0.5 for plugs. i just didnt add the plugs cost.
    I replaced the plugs on my 98 SE this morning. This was the first time I did this on a Maxima. Took me exactly one hour at a comfortable pace. I disconnected the negative battery terminal before starting the work, used compressed air to blow out the dirt from each plug well after removing each coil. I stand behind my former claim: 1/2 hour to replace the coils and 1/2 hour to replace the plugs, for a total of one hour should be a conservative estimate for a Nissan dealership.
    Some advice when replacing the spark plugs:
    Remove one coil and plug at a time. This way you do not have to label the coils for correct reinstallation. When removing the coil electrical connectors, fully press in the locking tab to avoid breaking the connector. Each coil is held in place with two machine screws with an 8 mm hex head. I used an 8 mm nutdriver to loosen the screws, then used a magnetic Phillips screwdriver to remove them. Using a magnetic screwdriver is especially important for the rear coil screws because you can drop a screw and it may be difficult to retrieve it.
    Take care when removing coils after removing the mounting screws. The coils have a long plug boot and must be lifted gently to avoid damaging them. Rear coils were easier to remove for some reason.
    You need a 5/8 inch(or 16 mm) spark plug socket with a good rubber boot, a 12 inch extension, and a ratchet to remove and install the plugs. To avoid crossthreading, I always screw in new plugs by turning the extension by hand until the new plug seats. Only then I will tighten it with a ratchet. To get a specfiied torque, you need a small 3/8 drive torque wrench. The specified tightening torque is 14-22 ft-lbs. Make sure your plug socket rubber boot is strong enough to hold the plug in place vertically because the plug wells are very deep.
    For the rear coils, you need to loosen and move out of the way several small engine components to have enough clearance to remove the coils and plugs.
    I hope this helps. I used the OEM replacement spark plugs. They are not cheap and even sparkplugs.com wants almost $ 11 a piece for them (plus postage). Nissan dealer retail price is about $ 13 a piece. After 68k miles, there was visible wear on the center electrodes of the plugs.
  • kennyg5kennyg5 Member Posts: 360
    It is good to learn that someone (like p100)on this Board is mechanically adapt in fixing cars, particularly the Max, such that we can obtain advice about various problems and the reasonable costs for fixing the problems. I know little about cars even though I have been driving for the past 20 years.
    P100, I thought the OEM plugs (platinum?) for the Max are good for 100k miles. Why did you change yours at 68k miles? Do you know if there is a TSB for the coils for the 95-99 and/or later model Maximas?
    I have a 97 and 03 Max, and several years ago I received a notice from Nissan (I think it was from the dealer rather than the manufacturer) indicating that the "check engine light" in the 97 Max needed to be replaced (probably something about the oxygen sensor). Since I never had trouble with the light, I ignored the notice. My philosophy is to keep up maintenance according to recommended schedules and not to fix something which isn't broken. So far I have been lucky ;-) Knock on wood.
  • aristotlearistotle Member Posts: 123
    I had to replace my ignition coils at 39000 miles. Nissan America picked up the labor costs of replacing the coil and paid about 40% of the cost of parts. After that the car has been driving VERY smoothly. I have about 48000 miles on it.
    How is the 2003 Maxima? Any known major problems?
    I see 2003 GXE Automatic cars advertised for about $17k with about 13k miles on them. If I can get the price lowered to $16.4K will that be a good deal?
    Both my Max are loaded GLEs and I don't really know the price of GXEs, but I suppose they may be $3k cheaper. Right now, I don't think you can get a new 03 anymore.
    As to my 2003, which I have owned for 11 months and now has 5k miles, the car has been trouble free. The only "complaint" I have is that it hesitates for a split-second when you accelerate hard from a full stop. Since I am not an aggressive driver, this doesn't really bother me. The one place where I think the 03 is inferior is the "premium" Bose system. The 97 has amplified Bose speakers, but I don't think the 03 has them, though it comes with a bass heavy subwoofer. The 03 has very user friendly steering wheel mounted buttons which control all audio functions, including changing CD discs on the dash-mounted changer.
    My main concern about the 03 is the super bright HIDs, which are magnets for thieves (depending on where you live). I was told that they can be stolen in less than 5 minutes and it costs over $3k to replace them and the damage to the hood.
    the 105k mile interval is on 2002 and newer, and back to 2000 on the SE models.
    Sorry for repeating my question. Does $16.2 K sound reasonable for a clean car ( 2003 GXE Auto ) with about 13k+mile on it?
    This is an out-of-town dealer and I need to make up my mind on this real soon.
    Thanks in advance for any suggestions / advice. I intend to do a CARFAX report before going there.
    According to the owners manual the replacement interval is 60K miles. I personally think that 100K miles is way too long for any spark plug. As the center electrodes wear down, the gap increases and the energy required to produce a spark goes up. This icreases the load on the coils.
  • habitat1habitat1 Member Posts: 4,282
    I'd like to share and get comments on the following:
    My 1995 Maxima SE 5-speed (placed into service September 1994) now has 143,500 miles. Overall, I have been very pleased with it's performance and how it's held up. However, the past 12-18 months have required several expensive repairs, suggesting it may be prudent to consider a replacement:
    Miles 0 - 50,0000 (3yrs,7months): Total routine service = $928.96 Repairs = $0
    Miles 50,000 - 100,000 (2yrs,8mo.): routine maintenance = $1,750.16. Repairs = $0.
    Miles 100,000 - 143,500 (2yrs,7months): routine maintenance = $2,095.61. Repairs = $2,173.91
    The repairs consist of: engine temp coolant gage ($190), water pump ($600), starter ($440), front axle boots ($600) and miscellaneous other items. All of these repairs have occurred in the last 20,000 miles (123,500+). Note - the above figures do not include self performaed oil changes at every 4,000 +/- miles. I also put tires and brakes into "routine".
    What do you think? Time for the bone yard? I still like the car, but I'm wondering what the nest 20,000 miles have in store.
  • sgrd0qsgrd0q Member Posts: 398
    aristotle - there is a topic called "Real-World Trade In Values" under the "Smart Shopper" section of this board. There's a guy there called rroyce10 and he will be able to answer your quesion.
  • stickguystickguy Member Posts: 54,912
    By my criteria, time for the new car. Not just from a strcitly dollars and cents POV, but reliability and convenience. Since you put a lot of miles on it (what, 18K/year?), who knows if the next failure leaves you stranded at rush hour on the beltway. Plus the hassle of taking it in for continual visits to the shop.
    Besides, any $ you put into it at this point won't come back out. If it is a 2K car, another 1.5K in repairs and it is still a 2K car.
    Move it on to a new owner, and get the 5 series you really want (good deals now on left over '03s!).
    I agree with stickguy. Looks like it is about time to part with your old faithful, trade it in or sell it to a third party, and get a new car.
    I know you love the BMW 530i, which you may still be able to get great deals on (I heard $3k below invoice). Had BMW offered this kind of discount when I was shopping last year, I would have bought one myself. My concern is that BMWs tend to be less reliable than the Max, and the repair cost can be quite expensive.
    The G35 is also a good choice, but it is rear wheel drive, and you have to pay close to MSRP. Since the G35 shares Max's engine, one should expect great performance and reliability. If you want a Max clone, get the I35, although we don't know if Infiniti is going to keep that car, and if so, for how long.
    The TL-S may also be a good candidate, but I am leery about the transmission problem that some TL owners have been complaining about. The 04 TL looks good, is more powerful and luxurious, but you may have to deal with fresh design bugs and pay MSRP (at least for the first 6 months).
    allthose choices, and you didnt mention the most obvious replacement...an '04 maxima.
    I did not mention the 04 Max because I think Habitat would not consider that car as one of his choices. I do not and cannot speak on behalf of Habitat, but I believe he is not too keen about buying U.S. made Japanese cars, particularly those first generation U.S. made cars, such as the 04 Max, unless it is offered at a price that is highly attractive (and definitely not MSRP). I sort of share Habitat's belief and that was why I bought the 03 Max. Until the 04 Max proves that it is as reliable as its predecessors, I will not want to be treated as a "guinea pig" :-)
    Thanks for your comments & suggestions.
    Part of me has wanted to keep the Maxima as long as possible, just to see how high I can get the odometer up to. Fortunately, the car still looks good, so it's not as though I'm embarassing myself driving to a business meeting in an old Crown Victoria. However, another part of me recalls that when my old Acura Integra started to go, it went downhill very fast and took me for $5,000 in repairs in it's last year and a half. And, as stickguy points out, when I finally handed the keys to charity, my deductable donation wasn't any greater than it would have been before dishing out that $5,000.
    Although $2,000+ in repairs in the last 12-18 months isn't cheap, that's still about half of the depreciation that would occur driving a new 530i off the showroom floor. And, in fairness, that needs to be balanced out with $0 in repairs for the first 7+ years and 120k miles. I suspect some of these items might have gone earlier, if I did more stop and go city driving. We had to replace the starter in our Trooper at 5 years and 50k miles.
    As far as possible replacements go, the former 530i would have been at the top of my wish list, had I been able to get one equiped the way I want at $2-3k under invoice. What's left here are non-sport automatics. The G35 sedan looks still rub me the wrong way. I should probably drive one with a 6-speed before ruling it out. Forget the I35. I would never have paid for an overpriced, undersuspensioned Maxima in 1995 and I sure wouldn't now. The Acura TL also doesn't do it for me, although I should probably withhold final judgement until seeing and driving the 2004 6 speed in person. I just don't see much of a "premium" in a gussied up FWD Accord made in Ohio. The other option might be a 330i 6-speed with the upgarded sport "performance package". I need to determine whether the smaller size will work, given that I prefer having a car alternative to the Trooper for shorter family trips.
    Oddly, 3 months ago I would have said no way to the 2004 Maxima. I've now seen 4-5 on the road (mostly black SE's) and they look pretty good. If I were going FWD for practicality and still looking for good performance, the Maxima might still be at the top of my list, especially at a price closer to invoice than MSRP.
    My current plan is to hang on to the Maxima through the remainder of the year and consider replacing it in 4-6 months after I better evaluate some of the newer options, including the new 5-series. That will also allow for evaluation of the new Maxima relative to whether or not it has first year bugs. I could change my mind quickly if I get stranded on the Beltway. Or I might go back to my original plan of 200k or bust if I don't!
    Thanks again for your input.
    habitat...is kenny right about your aversion to US built cars?
    kenny...FYI...the G35 and TL are both built here...your point doesnt make sense in nixing the max.
    made in Japan. My VIN starts with "JN" not "1". All Infinitis are currently made in Japan. The new QX56 (Pathfinder Armada) will be (I think) the first Infiniti built in the US.
    actually, the G35 is split, but mostly built in tennessee...just like accords are 80/20.
    Aversion is a pretty strong word regarding my opinion on U.S. built "imports". Perhaps prudently cautious would be a better description. I've heard both sides of the story. Here's my take:
    My 1995 Maxima appeared to have better fit and finish quality than the similar vintage US built Accords and Camrys. Although the Accord and Camry, having now been built in the US for a decade or more, seem to now be back up to par, the early US production ones were not.
    The BMW Z3 and Mercedes M-Class, both built in the US had horrific quality problems relative to their respective standards for German built cars. If I'm not mistaken, the M-Class was recently rated by JD Powers as the second worst vehicle in initial quality out of about 100+ vehicles tested. Coincidental or linked?
    On the other hand, I have not heard much either way about Nissan quality with respect to the Altima and may have even heard that the plant received some awards. Would I rather the Maxima be built in Japan at a plant of the same world renowned quality as my Honda S2000 was produced at? Sure. But perhaps I should give the new Maxima another 4-6 months to see how it fares.
    So I'm not anti-American, just pocket-book prudent.
    i was going to bring up the accord...from selling hondas for almost 2 years, and 2 different body styles of accords, i can say without doubt that the US accords are AT LEAST as good as the japanese built versions.
  • maxamillion1maxamillion1 Member Posts: 1,467
    Are you sure about that. I always thought it was built in Japan, just like the Pathfinder and q45.
    I know the Altima/Maxima are built in Tenn.
    Why would they build the G35 in Tenn with the Maxima and Altima. They aren't even built on the same platform.
    G35, altima, maxima, are all on the same platform. i was, however, mistaken...some are built in TN...the 80/20 is really a 90/10 in favor of japan. sorree..
    ....nor is it on the same platform as the Maxima etc.
    Built in the US on the FF-L platform: Altima, Maxima, Murano.
    Built on the FM platform (couple of variations) in Japan: 350Z, G35 sedan and coupe, FX35/45.
    how can you say the FX35/45 are on a different platform than the murano? its the same darn vehicle, man! fact is, the platforms have different nomenclature for the [non-permissible content removed]/US versions. they are ALL based on the same platform.
  • langer3langer3 Member Posts: 4
    I have 2 months and 2000 miles on my new car. I have a loud clucking noise in my front end.Anytime I go over small bumps I hear and feel the bumps. This is very disturbing for me as this is a new car.
  • deltagirldeltagirl Member Posts: 2
    Today I had finally made up my mind after much reasearch and a few test drives that I was going to purchase a Nissan Maxima. I went into a dealership in the Washington DC Area on 450 and let me tell you if this is customer/dealer service I would be looking for another car. Since I have my heart set on a Maxima I'm going to give it another shot.
    Does anyone know of any decent dealerships in the Washington, DC area were they know the meaning of customer service?
  • will38will38 Member Posts: 30
    Have you tried the Carmax Nissan franchise in Baltimore? You can check inventory and prices online. I almost bought a 02 Maxima from the Kenosha, WI Carmax before they sold their Nissan franchise. They didn't have the color I wanted, so I went somewhere else and paid more.
  • austinman7austinman7 Member Posts: 313
    I have a question for you 2004 Maxima owners, but if it's been covered earlier, maybe someone could refer me back to those posts. This car is on my radar screen for purchase, but the way Car & Driver slammed it for torque steer has me wondering.
    In your experience, is this something you notice on a regular basis? On moderate acceleration? Mainly when cornering? Do you have to drive it "all out" as if you were a C&D test driver to notice it? I'm actually a fairly steady driver, but just like to have a decent handling car for those times when you feel like pushing it a little.
    My purchase date is still a little in the future, so I haven't driven this car yet. When the time comes, I'll drive it and see for myself. But, test drives are somewhat limited, and I would really appreciate your real world take on this issue. I did drive the previous version, the 2003, and liked it except for the lack of independent rear suspension.
    Thanks for any insights you can offer.
  • aggiedogaggiedog Member Posts: 238
    Sheehy Nissan in Annapolis down the street from Annapolis Mall. I bought an 02 SE from them. They had better prices than CarMax at the time. I'd check them out.
  • joecrashjoecrash Member Posts: 2
    Austinman7....
    Been driving mine for about 2 months now. With no problems as of yet. I haven't really pushed it around the corners like I do the police cruiser I drive, but I love the feel of it. I haven't felt the front-drive torque pull on cornering if that is what you are talking about. Guess I am afraid to really push this new baby like I do the crusier. But, I can tell its going to handle a lot better than that heavy duty crown vic.
    Torque steer is most pronounced when accelerating hard from a stop going straight ahead. If you do not hold the steering wheel firmly and stomp on the gas you can loose the control of the car momentarily. It is particularly unpleasant if you have a manual transmission car, and pop the clutch after revving up the engine. The solution is: if you do this, anticipate what will happen and hold the steering wheel firmly.
    Infiniti G35 is made only in Japan. Platform is the same as the FX35/35, also made in Japan.
    Altima and new Maxima are the same basic platform, and made in the US. Prior Max was Japan. I35 Infiniti is still on the prior Max platform, and built in Japan.
    Murano is on the Altima platform also, but I'm not sure where it is made. Murano has nothing to do with the FX, other than vaguely similar style.
    First, let me correct something I posted earlier. The Murano is based off the FF-L platform but is built in Japan, not the US.
    The FF-L platform is a front-wheel drive platform, with and AWD option on the Murano.
    The FM platform is a rear-wheel drive platform, with AWD on the FX and the G35 sedan optional.
    I'm not sure what else to say.
    http://www.infinitinews.com/infiniti/news/products/relmatt2003013- 195833.shtml
    "All FX45 models utilize an enhanced version of the FM (Front Mid-ship) platform."
    http://www.infinitinews.com/nissan/news/products/relmatt200211191- 011.shtml
    "The new Nissan Murano’s unique, modern design is made possible, in part, by the use of Nissan’s new FF-L (front engine, front-drive) platform, which it shares elements with the award-winning 2002 Altima. "
    The G35 Sedan/Coupe, 350z, and Infiniti FX35/FX45 are based on the same platform. Rear-wheel drive. AWD is optional.
    The Altima, Maxima, Quest and Murano are based ont the same platform. Front wheel drive. AWD is optional on the Murano.
    They have different platforms because, well, One platform is front wheel drive, and the other is, ummm...rear wheel drive.
    I can recommend VOB Nissan in Rockville Maryland. They offered to sell me a new Maxima at slightly ($200+/-) over invoice over the phone. I am a previous customer and have taken my 1995 Maxima back to them faithfully for service, but they have also treated my referrals very well.
  • jbadamsjbadams Member Posts: 63
    On my 04 SL, torque steer is more pronounced during a turn with hard acceleration. I have in fact accelerated straight without holding onto the steering wheel as a test and it tracked straight ahead. Left turns seem to me to show off the torque steer problem... and again, you have to accelerate hard to notice this.
