thanks,kyle
-Cj :confuse:
struts would be different on the GLE." ((
I realize I'm late to the party with a comment on maximafan's post, but the McPherson naming convention is in reference to the Scottish-born Ford of England engineer who devised the simplified coil-over-strut style suspension system that uses only a lower control arm to locate the wheel hub laterally and longitudinally. It's not a brand name. Neither Ford nor Mr. McPherson patented the design, so it's in general use worldwide. Though the componentry is always basically similar, it's never intentionally interchangeable from one automaker to another. The struts, themselves - essentially shock absorbers - would probably be internally valved differently in the Maxima than the Altima even though they might be physically similar enough to be interchanged. There're also unnamed variants of the McPherson concept in wide use that add an upper control arm to the mix.
does anyone know if i could put 205-55-16's on my maxima?
and is there a need to adjust the alignment for the rear wheels on a 2000 maxima that has the Multi-Link Beam suspension in the back... thanks!
Rear wheels do not need to be aligned on 2000 Maxima.
is this true for you??
What kind of Brake Pads are you using?
by the way... I'm using OEM brake pads i bought from advance auto parts.... they're not special pads
1. do both 2001 & 2002 require premium gas?
2. in real world, how does mpg compare between the two engines both with auto (would love the 5sp but wife is does want to mess with clutch)?
any info helpful...
2. For my '01 I get 27 mpg highway, 23-24 city -- down to 22 in the winter.
The '01 is so smooth and powerful, I can't imagine why one would need even more!
it was totalled in a wreck back in July. I
have definitely mourned this car, it was such
a nice car. The issue with the Xenon lights
depends on what City or area you live in.
I live in the Tampa Bay area and there have
been no reports of HID thefts on 2002-2003
Maximas. I have heard some reports of HID thefts in the Miami area and particularly the
New York/New Jersey area. Oh, and possibly
in the State of Texas also. So if you don't
happen to live in any of these cities or states, I think you should be all right!
Good luck shopping for your Maxima. I don't
think you can go wrong with either model year.
what is the price difference btw a 2001 and a 2002??
Let me guess, in queens there is dealership which shares floor for Nissan and Volvo. Is this where you got it?
Do you mind tell me how often time wise(?monthes) that you change oil for 10K change intervals? Do you have to stick with 3 month peroid? 10k for 3 month is a lot of driving.
I thought that was a characteristic of Toyota/Lexus transmissions, but after hearing that you're experiencing the same thing in the
Maxima, I'm not so sure now why these cars drive like this!
P.S. I have the 5-speed automatic, no CVT tranny.
Engine starts and run fine for about 30-45 minutes.
Once the car gets a little warm, it starts making sputtering sounds as if it's going to cut off. Sometimes it does cut off, and sometimes it doesn't.
One thing for sure is once you cut the car off, it will not crank back up for about an hour or two. When you turn the ignition it sounds like it wants to crank up, but it won't.It actually sounds like it's being flooded. I have spent $900 bucks taking it to a shop; yet they still cannot fix the problem.
Anyone has any ideas what it maybe?.
I honestly dont believe the Maxima has that many problems as soooo many people say on the internet. In fact, I stopped believing the whole CRAPPY VW thing when the new jetta/rabbit only have 1recall and 4tsbs. My accord has about 75tsbs.
-Cj
fyi - i have a 2k maxima
