Visitor Agreement.
None of this crap existed before the servicing. Could they have done something wrong? Monday I will need to call my dealer again. Felt like I was doing the right thing by following the recommended Maintenance schedule. Now I'm wondering.
Any experience or ideas?
BJL
It's maybe been 5 times in 3 months so I haven't though much of it. I'd be interested to know what you find out.
Keep us posted.
Maybe I was lucky, but based on this experience (and now the above posts) I'd be hesitant to change the trans fuild in the future.
The 'Trig has the pre-sets, and I usually stick with them, but you can really fine tune the sound if you want.
Deke
If you do decide to replace the stock radio be careful of the speakers. I think the rears are only 2 ohms and not compatible with alot of aftermarket stereos. Maybe you can find a Bose on Ebay that will slip right in and not spoil your dash. Whatever you do, Good luck and let us know how you make out.
If you like the factory one and you are looking for better sound quality just replace the front speaks with a good pair. Mine are 420 dollar components but you don't have to go that nuts.
And if you really want you can get new speakers buy an amp and have in professionally installed. Its going to cost like a grand though.
I would just replace the front speakers with a 200 dollar pair. Don't worry too much about the rears cause those are a pain in the [non-permissible content removed] to take out and the sound up front is more important.
At 42,000 km, my air conditioning is running very cold. Had it recharged and seal replaced, all under warranty with no charge.
Earlier this year, my gas cap failed causing the "check engine" idiot light to go off. To get the problem diagnosed cost $92.
About 9 months ago, the brake booster failed. Total cost--$620.
Methinks I should proceed with getting rid of her... but the wife objects... sigh....
If only you could buy them like that
Hold the face down so you do not lose the placement of the push buttons.
Those switches are about 3/8 inch square and about 1/4 thick and are actuated by a platic tip sticking out from the button. Similar setup to vcr switches, if I remember. That's if you know what vcr seup looks like. hehe.
Anyway if you know someone handy, with electronics, or are brave. The most likely situation is a cold solder joint where the pins of the switch are soldered to the little board. This is common as the repetative pressure of the switch cause the solder to develop a hair like crack around the pin. I've serviced many types of boards/dashes/radios like this.
If not that then, they could probably squirt in a drop of tv tuner cleaner and rapidly activate the switch to clean the switch. Rubbing al-cool is a good backup. If the switch has broken then I've used some rigid plastic glue to hold some together, when i didn't have a matchup from and old vcr panel.
They sell you a new one for 300, send the old back in as a core , get a dufous to solder the pin, plug it into a computer to run diagnostic and resell it to the next guy.
I just mentioned it, if maybe you have a friend. Cause if it is a cold solder joint, then most likely, it will only get worse.
Cold solder joint.
A faulty solder connection due to insufficient heat while soldering. Results in improper solder flow and causes brittle joints that fail over time due to movement at the joint or heat in the circuit.
Not likely a heat thing in that circuitas it is mostly five and 12 volts in there.
cheers
Bottom line, I would not recommend a trans flush. stick with the old fashion drain & replace fluid and filter. I am sure this flush did more harm than good. I may send GM an email on this issue- not that it would do any good. At least it would be documented.
Also my A/C has done this intermittent shut off with the switch light since last summer. It seems to shut off more often when you first start the car. Or if you change the fan speed and other climate settings. We just deal with it. Glad to here your mechanic says this is what they would do as well.
Take care,
bjl
Lift up the console and there are a couple screws( 1/4 inch or 8mm) near the latch.
You then unpop the shift console bezel (The plug for traction control needs to be unplugged) The front bezel is snapped in too. . However, i think there were a couple screws near the bottom that need to go first. I found the bezel flimsy and was carefull to get underneath a heavy part of it to pop/pry it out slow and easy. I believe one of the clips at the top stuck to the dash.
cheers and sorry again for that omission
Console is a bulb under the cover. Dash lights are a lot more involved.
Here is the sequence if I remember correctly - maybe someone can correct me if I'm wrong:
1 Remove the traction control switch. There is a little notch, use a small (like for eyeglasses) screwdriver.
2 Open the front floor console compartment.
3 Remove the bolts/screws from the front floor console trim plate (2 screws near front of compartment)
4 Pull up on the front floor console trim plate to release the retainer clips (just grab the bottom near the middle of the shifter and pull straight up doesn't take a whole lot of force.)
5 Lift the front floor console trim plate up and over the transaxle shift lever.
At this point I forgot if you can access the bulb right from there or need to remove 2 or 4 screws from the shifter to get at the bulb. If you do its just another 2 minutes.
When done just reverse the steps.
Good luck!
Be careful not to snap the tabs off the bulb socket or you'll never get it to stay back in place (like I did - D'oh!).
First open the armrest and remove those two screws, pull up the piece and set aside, then you can get to the four that hold down the shifter cover....
Deke
Deke
Bad luck yesterday. While the wife was driving home from work, something quarter-sized crunched the A/C condenser and ruptured one of the lines. Looks like a trip to the A/C repair place for new condenser and, probably, $300 to $500 bill. I took a gander through the front bumper; pretty crappy design down there. Two holes (one on each side) with no protection whatsoever for the condenser (on either side of the fog lights). Anyone here with an Intrigue can get down and observe how beat-up the condenser gets from this lack of protection. I think I'm gonna rig up some plastic grill material down there after my new condenser gets installed.
Dealer of coarse says what noise. Ya just what to punch them.
Look closely toward the top of te two doors where they meet. They rubber strip stops 3/4 inch from the top. You can almost get your finger in there. This is engineered to be a whistle.
Get close to the joint and silently blow air across this, as rushing air would while driving and you can duplicate your whoosh.
Idiot engineers. Why most gm cars are wind noisy. Built in mechanical whistles.
I happen to work at a college and I noticed two Intrigues driven by students this year. So it appears they had the same idea as you.
But definitley drive one. It hik you will be surprised at its performacne esp. for he price. Good luck.
Test drive the car and I think you'll be surprised at how well it handles. Don't get me wrong, it's no Maxima, but for the money it's a nice car. As far as getting PCS, I live in upstate NY and have the traction control (standard on the GL and GLS models) and have never even come close to getting stuck in the snow. It's a great winter car.
Good luck finding a nice '01 or '02. I spent the better part of 2 months at the start of this year trying to find one and had to settle for a Buick Regal instead. Nice car but the Olds is nicer IMO.
As far as being a dog off the line, I think thats when it's compared to the GM 3.8L. It won't keep up to the Maxima at the start, but once you get to around 35 or 40 I think you'll be pleasantly surprised. It's a great trip car and cruises at 90 with no effort at all. Good luck finding one. Go for a GL or GLS if you can. Not much difference in the price from a GX but you get alot more. Let us know how you do.
You've replaced all those at 53K miles? Ouch! That's why I am considering selling mine (also has 53K miles). I just don't think the long term reliability is there. I've had my trans rebuilt (under warranty, TSB problem) and had to replace the thermostat (another TSB) and now my A/C switch is going. It's a great ride but I think one has to be prepared to spend more than average on repairs.
It was raining out so the wipers were on. I went to change lines and the turn signals simply didn't work. Everything else was fine. I pulled over, turned the car off, turned it back on, still didn't work. There is a Chevy dealer about 10 minutes up the road, so I went up there. I was told they they couldn't fix my car because they were not yet authorized to make Oldsmobile warranty repairs--I thought every GM dealer could but apparently.
Anyway, my regular dealer was about 5 miles further so I started up that way, when all of a sudden the turn signals worked again. I reversed course, headed back to work and they worked the whole way.
So apparently the problem is gone. I'm just puzzled by why they would suddenly stop working and then come back 30 minutes later. Any ideas?
