Visitor Agreement.
The question is how much will another engine cost and what's the warranty? How long do you plan to keep the car?
A quick check on E-Bay show 1999 engines (3.8 & 3.5) going for $800 - $1925. The more expensive ones have a warranty.
Personally, I would repair the head gasket if the rest of the engine was fine. Should be less money. Plus you know the engine.
My '99 drove me crazy at 80mph. sounded like a neon with all the road noise.
I woul recommend a junkyard engine rather than spend $1300. Which seems kind of high anyway.
http://market.autopartsfair.com/oldsmobile-used_engines/intrigue-catalog.html?ca- mpaign=autoguide
We have a 1998 olds intrigue, that overheated, and leaked coolant. We replaced water pump, and thought problem fixed. Well this morning coolant has leak again. Reserve is down about a 1/3. What could it be? Thanks for the help
It could be a couple of things: blown head gasket or intake manifold gasket failure. Because you mentioned that the car overheated, I'm putting my money on the head gasket failure.
car overheating loosing fluid ect. Though the leak seemed to really be coming from the mounting point of the coolant reservoir. it was 110 outside ..it took me 25 gals of water and 5 gals of coolant.and although I am against the idea of putting additives in coolant....I did.......didn't have a problem with it the rest of the summer and has been running cooler than it ever was.
my monies on the thermostat sticking
:surprise:
Bars Leak Buddy but not all of it like only 1/2 to 1/3 of the bottle
After replacing water pump there was no coolant leaking. But after running car, and then turned off, some dripping coolant from underneath car is happening near the back of engine. I would say probably a 1/3 to1/2 cup.. this happens after running it.
It appears the OP is losing coolant through a leak. Where he is seeing the leak should narrow it down.
I have a 99 Intrigue GX. I recently opened up the panels/trim around the gearshifter and the stereo/AC console, because I am going to be swapping out my stock radio/cassette stereo unit for a stock radio/cd/cassette unit from another Intrigue.
Near the gearshifter, I noticed a set of wires, leading to a small harness/plug. There were 3 wires (white, brown, black). The wires originated near the dash and gearshifter in park, and the open-ended plug went towards the armrest console.
Does anyone have any idea what that would be? I am guessing maybe an aux harness to then run wiring from that area towards the trunk, for a cd changer or something (I never had one in the car, though I am the 2nd owner--1st owner had the car for less than a year)
If that is an aux harness for the radio, would it be possible to plu something into it, and then plug an ipod into that?
Any thoughts/help would be greatly appreciated!
I can't figure out how to post a pic from my computer, so I can email you a pic if you would be willing to take a look:
A faulty ignition switch can cause many weird things to happen including what you described. Are you having any other issues like hard starting, stalling, etc.?
The air conditioning problem could be a loss of refrigerant. I'm basing this on your comment that the compressor is coming on and the blower is working. I would have a mechanic test the system and add refrigerant with the dye in it. The AC system is a closed system so you should never need to add refrigerant unless there is a leak. IF the problem is low refrigerant, you likely have a leak in the system.
I had the same problem with the fuel gauge in my 2000 Intrigue. It floated for a while and finally only showed "full" or "empty". Interestingly, the bell would go off when the fuel was low. I never bothered to get it repaired and simply relied on the trip odometer. Based on my commute I would fill up when I reached 375 miles. If i did more city driving that tank, i would fill it up earlier. More highway, it could last to 425 miles. I actually made it to 450 miles. My car cutoff as I pulled into the station and I coasted to the pump. The fuel gauge is located on top of the fuel tank which can be accessed through the floor in the trunk on the driver side. Check prices at websites like Rockauto or GMpartsdirect.com
Also get the car scanned for OBD codes. You could have other issues that tripped the check engine light.
Good luck and let us know how things work out.
have your husband read this forum and he'll understand some of the problems with the Intrigue.
I am pretty sure you are dealing with multiple, known problems with your Intrigue.
First, do you have the following dash lights on : "Service Vehicle Soon (yellow), Trac Off (yellow), Anti-Lock (yellow) and Brake (red)? If so, it is likely that your Electronic Brake and Traction Control Module (EBTCM) is bad. (sometimes they go bad intermittently). To confirm, you would need to go have a special brake scanner put on the vehicle (most Autozones don't have these) - if it has a code C0550 the most common issue is a EBTCM going bad. There are some repair places on Ebay, but you have to remove, ship and reinstall the EBTCM. Not a bad job, but you have to be careful. The car can be driven without the EBTCM (with the lights on it isn't working anyway) but you won't have any ABS or traction control. Your car might not have traction control (does it have the button on the console rearward of the shifter?) so you might not have that light.
The flickering lights when the engine is cold is likely the air pump for the air injection system - these pumps live under the front fender and fill with ice or water and die, drawing current as they try to run. Again, a known issue with the 3.5l engine (which is what I assume you have).
You might try surfing over to the Intrigue forum on automotiveforums.com. Fixes for these issues are often posted over there.
Hope this helps!
Good luck
Donp9, I haven't been able to get over about 28mpg on the highway, more like 27 ish depending on conditions and speed, have you done anything to help your gas mileage? When you say highway driving, how fast are you talking? Anyway, it's not a big deal, 27mph is fine and I love the car, just thought I'd ask.
Sounds like oversteer . Did he do an alignment? If not then get one done. Sometimes you can get it right by some fancy measurements, sometimes not.
:shades:
As kplacer stated, the turn signals double as the daytime running lights on the Olds Intrigue. If these are the lights the OP was talkng about, his vehicle is operating normally.
Also there is a law against driving with parking lights in CA and I got confused between parking lights, fog lamps and DRLs.
