Toyota Solara
1151618202177
  • bwiebebwiebe Member Posts: 27
    I had heated seats installed in Dec and its the best money I have spent. When you slide into those leather seats at -35 it can be quite a shock. At least with the heated seats your posterior is toasty in a few minutes. I had them installed at an automotive upholstery shop and it looks as good as factory.
  • radracerradracer Member Posts: 96
    The Cougar is a nice car and when bought used, can be had for almost twice as less as a Solara. The Cougar v6 is kind of slow, even with the sticky 5 speed, so I'd recommend getting the Type S with the 194hp SVT Duratec. It handles very well and also has a great turning radius thanks to a passive 4 wheel steering system. One thing I don't like about my Solara is its size. It's seriously about 1" too wide for me. The Cougar is a much smaller car so it's more manueverable, but I do enjoy the size of my Solara on long road trips.
  • jabeck8925jabeck8925 Member Posts: 3
    Does anyone have a bug deflector for their Solara similar to those made by GTS? If so, where did you get it and how much did it cost?
  • scsolarascsolara Member Posts: 47
    My car does the same thing. With EVERYTHING on the panel off, a light breeze still comes out the vent. I think it is normal. It has to be the outside air because the compressor is not on. It is not the A/C or anything, I believe the system is just still a little open to the outside and the force of driving is pushing it through the vents?
    I finally put on my side markers! It took a while to get the nerve to put a gaping hole in the side of my car! Take a look.. The blue really stands out at night. It is a lot brighter than I expected. They are on with my parking lights and blink opposite my blinker.
    http://users.ev1.net/~gunpilot/misc/
  • cunnrcunnr Member Posts: 9
    I have noticed the same thing regarding the vent air. You can adjust the temperature of the vent air so that it matches the outside air temperature (therefore no heat) by turning the thermostat down (to the point where the thermostat is below the reading for the outside air temperature) before turning off the AC. I know this seems strange but it seems to work, and I also think it is in the users manual but not very clearly explained. In other words, the vent air can be heated (but not cooled) based on the thermostat setting before the system is turned off. I think my old Corolla did the same thing but the air system was manual not digital.
    Hope this works.
    Rob
  • fastdriverfastdriver Member Posts: 2,273
    scsolara-
    Looks nice. Several people in the 300M forum are doing the same thing by getting "underground" side marker lights like the ones that are put on the European 300M.
    fastdriver
  • haveagold2000haveagold2000 Member Posts: 1
    Hi. I have a 2000 SLE with about 5,500 miles and no problems whatsoever. I have a question, though. When I had the oil changed, the guy said he got oil on my engine due to the way the oil filter is mounted. Anyone else have that "problem"? Can it be avoided by telling them to drain it more before unscrewing the filter? Thanks.
  • hud116222hud116222 Member Posts: 46
    After 7 weeks, lots of haggling, etc. It finally got here. Red Flame Metallic SE- V-6- with all the options. EXCEPT- Cambridge, Ontario left out the VIP security system I ordered. My dealer is making it right for me- free. Drove it to work today- 35 miles- and it was awesome! P.S.: It pulls SLIGHTLY to the left.
  • phatnastycatphatnastycat Member Posts: 73
    You have yourself a great car. The pulling to the left is a natural phenomenon with the Solara. Mine pulled to the left for over 2 years and never could get fixed. However, I took mine in for a 30K mile service, and the left pull has mysteriously disappeared. Hopefully you will have better luck. Replacing the tires may help. I have heard some have had luck with this.
    If you take it to the dealership for help, be sure and keep all documentation in case they can't fix it.
    Otherwise, enjoy the car, and crank up that JBL
  • 99solara99solara Member Posts: 51
    Congrats on the new car and you will enjoy it. I have '99 SE V6 5 speed with left pull. Do you have the infamous Bridgestone tires? I have found that when rotating my tires the problem comes and goes with each rotation. I will be dumping the Bridgestones any day now. Phatnastycat may have lost the pull at the 30K mile service because the dealer rotated his tires.
  • cliffy1cliffy1 Member Posts: 3,581
    I've watched our guys do oil changes and they keep several cans of brake cleaner handy. They go through about a quarter of a can per oil change. After they are done, they soak the engine around the oil filter to wash off all the spilled oil. Make sure it drips into a container for recycling.
    Mine came with Michelins. I made sure they rode with me before I signed for the car so they could feel the pull. Hopefully, that will make it easier when I start bugging them about it.
    I have one on my car. It's a genuine Toyota product, but only sold in Canada.
  • msamuels1msamuels1 Member Posts: 1
    I have a 2000 SLE V6 convertable with 13,000 miles. I have noted, since day one, that there is more air noise at speeds of 50mph than I would expect. There is also some flapping. The dealer can't seem to fix the problem, Is this an isolated case or have others had the same problem? This is not my first convertable. Thanks
    check out the Camry Solara Convertible message board in this forum. Someone there should be able to answer your question.
  • pbcpbc Member Posts: 44
    AirFlow
    There are two airflow buttons, one that let's air circulate within the car, and another that depicts air coming in from the outside. If you press the circulation one I believe that will minimize if not eliminate the slight air coming in when the system is off?
    Seat Heaters
    Bwiebe -- what was the name of the Upholstery place you got the seat heaters installed? I've been looking around in Toronto to no avail. Also, what was the cost and does it affect the warranty in any way?
    Speakers
    I've posted this a couple of times with no response. Are the front JBL tweeters and speakers not the greatest? I'm convinced my right fronts are damaged in some way since anything with a low low base (e.g. Stern Show, certain rock songs) result in a cracking sound coming from the speaker. The dealer told me this is normal (gee big surprise there) and said to keep the bass level on -2. I think that is ridiculous since I don't here it on the left side and I can't believe JBL speakers can't handle a little base (I normally keep it at 3). Anyone else have this problem? Anyone think the dealer just doesn't want to replace the speakers????
  • automophileautomophile Member Posts: 780
    pbc -
    Your initial thoughts are correct - There is a problem with the amp or speakers. The crackling that you hear can be the amp clipping, or it can be a bad driver.
    I have cranked my system to the max with no clipping. I have the bass on +2 normally. Stop by a good autosound shop and let one of the techs have a quick listen before you go back to the dealer.
    The JBL system is NOT the greatest, but it is OK. My biggest gripe is that the sound is not well balanced, frequency-wise, until it is TOO loud, about 1-2 O'clock position of the volume knob. At lower levels the sound is very muddy and indistinct. Also- It REALLY needs a subwoofer. Also the tweeters are too small, so the crossover is right in the critical voice frequencies - an audio no-no.
    I ordered my sidemarkers and bulbs from autotoys.com. Their install guide was amazing and easy to follow! You can take a look at:
    http://www.autotoys.com/New_Tech/DIY_2000/Side_marker_lights/side_marker_lights.htm
  • cheme74cheme74 Member Posts: 5
    I got the wood grain accessory kit. It really looks nice. The guy who put it on for me suggested that I don't use Armor-All to clean the dash as it may weaken the adhesive.
    Can anyone suggest a cleaner that I can use to clean the dash?
    Also what is a good cleaner for the Ivory leather interior?
    Lastly, after applying the Zaino products must I hand wash in the Zaino car wash, or can I quickly run it through a local car wash from time to time?
    Thanks in advance.
  • eyemd1eyemd1 Member Posts: 5
    I enjoyed reading hunfreds of your posts. I am in the process of buying the SLE V6. I wanted to share with you my experience with my Z3 2.8 that for over a year now pulls to the left. BMW unable to really fix it despite alignments, tire and alloy ckecks/rotations etc. I think its disturbing that the Solara also can have this "pull", though has a much more comfortable and luxurious highway ride compared to the Accord EX. Any more thoughts on Solare SLE V6 versus Accord EX V6 from the experts here? I appreciate your input.
    cheme74 -
    Your friend was right - do NOT use Armor All on any part of your car. For the interior, use Lemon Pledge on almost everything - vinly, leather, plastic, wood and chrome. I have been using it for over 20 years with great results! Spray a little on a soft cloth, rub it on, buff it off. It has a great look and is self-cleaning. It will not build up and collect dirt like some other products. If you have leather seats, use Lexol twice a year on them to keep them soft.
    SC Solara - Thanks for the info on the lights!
    Left Pull - I pumped up my tires to 34 PSI in the front and the pull or drift is nearly gone. I believe it is the tires.
  • wskbearwskbear Member Posts: 4
    After an unfortunate incident with a traffic barrel, I am in need of a replacement right side power mirror. Can anyone recommend a good site for after market or EM parts?
    Will
  • reticent1reticent1 Member Posts: 70
    try newtoyotaparts.com and eMail Steve (gonzo4u@earthlink.net) because he does ship UPS for free and if you are not in CA, there is no sales tax. That's a big money saver for a large/costly part.
    Sorry about the traffic barrel incident! Yikes. Bummer!
    -Ret
  • vunder1vunder1 Member Posts: 1
    Has anyone found a cood source for a tonneau cover to protect the rear seat when the top is down? dougvunder@aol.com
  • xweilixweili Member Posts: 1
    the brake on my 2000 solara SE makes a loud "clanking" sound the first time i press it hard after I park my car for more than half a day. anyone of you have the same experience? my dealer said it's ok, but I think he's lazy.
    my solara brakes also make a light but high pitch sound when I press my brake to slow down and let go of it right before the car goes to a complete stop. anyone have the same experience?
    thanks. I had this car for almost a year. runs great.
  • norcalmikenorcalmike Member Posts: 25
    The oil filter is directly above an engine mount. The mount is molded in a "V" under the filter with a round hole about the size of a pencil at the base. If you unscrew the oil filter ever so slightly, the oil will start to drain SLOWLY onto the motor mount, through the hole, and into an oil pan placed directly below the filter on the ground. Works OK but the Toyota filters have an anti drain feature and it still gets a little sloppy when removing the filter. The initial slow drain does cuts way down on the mess. After installing my new filter, I spray the area with Simple Green and let that drain into the pan. Simple Green will get rid of 95% of the oil. I wipe the frame after that and it's good as new.
    cheme74,
    IMHO - Anyone that runs a car through a car wash is looking for big trouble and will get it. The brushes / flaps will rub your paint off eventually, and certainly rub the dirt from the previous filthy car right into your paint, making permant swirls and scratches. The detergent is ultra strong, stripping any wax right off, maybe even Zaino. The "touchless" car washes have been known to damage door and window seals with the high-pressure sprays. Car washes are ultra-harsh because they need to get the car clean in one pass, regardless of how dirty it is.
    If you try wash your car every weekend, it only takes a few minutes, because the car is not very dirty. To rinse, wash, rinse and dry should not take more than 10-15 minutes at the MOST, including scrubbing the wheels. If it takes any longer than this you are doing it wrong or are driving a van. It takes only another 15 minutes to vacuum the interior, Pledge the vinyl and Windex the windows. Again, this surmises that the car is NOT filthy. Do it regular, and it is no big deal.
    Isn't your beautiful new car worth it?
  • rubicon52rubicon52 Member Posts: 191
    Regarding your brake noise problem. Do you back out of your parking space or driveway? If so, you may hear a noise the first time you use your brakes after driving away. It's the brake adjusters. My Camry does it almost every time at the first stop sign after I back out of my driveway.
    The noise is typical of the "floating" caliper design used on the Solara. This has been a common "problem" reported by people. Your dealer was telling you the truth.....go figure.
    I live in Winnipeg and had the heated seats installed at Ron's Custom Upholstery at a cost of $600. including taxes. Didn't check on the impact to the warranty. You might want to check with a Toyota Dealer on where they have their work done. At Ron's he does lots of warranty work for various dealerships, including Toyota. The Dealer may be able to put you intouch with someone.
    Paint Quality. Just finished putting my first coat of Zaino Z5 on and noticed a number of small paint chips. A bit surprised by this as I only bought the car in Dec. Hope this isn't a paint problem. Any comments??
  • Apparently automakers now have to use environmentally-friendly paint whose finish hardens more slowly, so it tends to chip more readily. Even the Mercedes C-Class board has complaints about this problem, as well as a number of earlier posts on this one.
    My SLE is three weeks old (black/ivory/~900 mi.) and has a tiny ding near the front of the hood, but nothing worse yet (touch wood).
    Some people have responded by using invisible bras, though others have complained that they can trap dirt and cause scratches as the tradeoff for ding prevention. I'm trying to use the Klasse polymer finish products as a protectant, but the Zaino might work as well or better. Good luck!
    Anyone know of any "miracle" polish to fill in deep scratches? I rubbed a high curb with my rear bumper this weekend, and it looks like crap. The scratches are on the bumper (plastic) and the rear panel (metal) My paint color is black. Any suggestions are appreciated. Thanks.
  • bgerwebgerwe Member Posts: 10
    just thought i would share my secret for cleaning the inside,
    I use the "pledge grab it" wipe things, it takes just one wipe to do the whole car and you can use on the instrument gages with no worry of scratching. My car usually doesnt't get very dirty though, just the typical dust from driving with windows down. Also, it saves time because you use just one cloth and you don't have to worry about accidentally getting some spray on the windows or other crap like that.
    Brian
    Brian - do you apply a protectant after the "pledge grab it" or just leave the dash etc as is? Thanks!
    i usually don't use a protectant. if i have a scuff or tough dirty spot i will use a very mild and watered down soap mixture to clean it. i don't like the greasy look or feel of using specifically made cleaners(ie armor all) plus it won't reflect the dash onto the windshield, which annoys me too. my car usually doesnt get very dirty so that it needs much cleaning and not using spray cleaners avoids having to wipe off any overspray like on the glass or seats, etc.
    if you use a sunshade you really don't have to worry about damage to the dashboard, ohh and my windows have 5% tint so very little light gets in anyway.
    i think protectants are crap and unnecessary. i have lived in FL and TX and just used the above metioned method(on previous vehicle too) with the sunshade and never garaged my car. so far i've had no problems.
    plus the pledge grab it thing takes just a minute or so for the whole interior, except seats, and you don't have to worry about scratching anything. those things are great for the house too!!
    ohh, every once in a while i'll use a wet rag on the dash/doors beacuse the "grab it" really only removes dust/dirt particles.
    I have had a 2001 SE V-6 Solara for two weeks, and absolutely love it! The one thing I am wondering right now is that I have been on the highway a lot and seem to always hear rocks hit the side panels. I had a Mazda MX-6 and can't remember hearing rocks hit the car except on rare occasions. Is there something in the Solara design that creates this problem?
    bgerwe -
    I like your idea of using the Grabit on the interior. You are right - this is a very good idea. California Car Duster also makes "mini" version for car interiors that works much the same way. The tacky yarn grabs dust and dirt.
    However, I still feel that the vinyl needs a little help as it dries out. I'm still a big fan of Lemon Pledge nearly everything inside the car. It's not shiny or greasy, and is self-cleaning so it doesn't build up. Why not give it a try between dustings?
    i have tried it and like it, however if i need to clean it well, i prefer a wet rag with mild soap..
    i really dont feel like the pledge cleans as well as soap and water, do you think so?...in between, the grab is just so easy and quick i dont think i will ever do anything else...
    brian
  • black00black00 Member Posts: 48
    These grab dust cloths are great. My wife uses it at home and I was thinking of using it in the car interior. The other day, I found new ones in the supermarket in the format of mitts. It made it even easier to grab the dust off the dashboard.
    Other than that I only "wash" the dashboard twice a year.
  • scottdudescottdude Member Posts: 177
    I test drove an Accord LX coupe today and thought I'd check out Toyota to see what they have similiar. This will sound dumb, but I hadn't even considered the Solara since I don't think I've ever noticed one on the road. I've heard of them but was thinking they were more in the "Celica" class of sporty car.
    Anyhow, I now see that the Solara is the Toyota to compare against the Accord coupe so I checked out Edmunds for more info and stumbled into your fine forum.
    I'd appreciate hearing what you Solara owners think of the Accord. Especially if you test drove both, what made you go with the Solara? And about what kind of prices did you get? Did you find the Toyota dealers more willing to discount than Honda?
  • ral2167ral2167 Member Posts: 791
    i owned a 99 solara-- put 30 k miles on it...now own 2001 accord lx coupe v6... my opinion:
    areas where solara has accord beat (in no particular order)
    1) better tilt steering adjustment
    2) better audio
    3) quieter ride
    4) larger gas tank/trunk
    5) more comfortable headrest adjustment
    where accord has solara beat:
    1) more comfy center armrest
    2) better coin box/storage
    3) car seems to hold the road better
    4) fuel filler door holds fuel cap more secure when filling tank with gas
    other items..such as appearance... are subjective-- as someone who's owned both cars, i can say they each have their pros and cons compared to the other...
    as far as discounts, folks are generally getting accords for right around invoice from what i read-- and the 3.9% financing isn't bad.... not sure what solara discounts/rebates are available.
    Don't forget that the Solara also has a full-sized back seat - VERY comfortable once you get in.
    Also- The Solara is so smooth and quiet there may be some truth to the runor that it was first intended to be a Lexus - It feels and drives exactly like my ES300.
    When I was shopping for a new car, I looked at 5 different ones, including the Honda. In my estimation, the Solara was head and shoulders above all of them, and in the first 1,000 miles I have driven my new one, the Solara has proven to be incredibly smooth and quiet. There is even room for ADULTS in the back seat, a major advantage in my mind.
    I posted this before, but got no response. One thing about the Solara; it seems to "pick up" rocks which hit the side panel a lot. Has anyone else noticed this?
  • Hud,
    I was ready to move on a C240, but another poster on the C-Class sedan board said he ended up buying a Solara because of the ride quality matching an ES300. His commute characteristics are similar to mine (a mix of stop-and-go freeway, open freeway and surface streets), so that got me interested. The build quality and reliability of my wife's Sienna helped, too. I have ~1300 miles on my SLE, no rocks yet (touch wood). The ride quality certainly helps me cope with rush-hour.
    A lot of newer cars have sides that curve in, behind the tires, so they are susceptible to stones and dirt.
    Easy Solution - Put on the Toyota mud flaps, and you will not have any stone or dirt problems. I will never buy a car without them.
    p.s. - 2-1/2 years on my SLE without a single repair, only service.
  • rsblaskirsblaski Member Posts: 68
    Our new DPW/TAN/BEIGE came off the truck two days ago and this color in the sunlight is incredible when compared to other "white" cars.
    We traded in a '96 Chrysler JXI convertible which gave us excellent service until a couple of weeks ago when the ABS system and air conditioner compressor both went south in a matter of days.
    We had previously test driven both the 2001 Sebring JXI and Solara SLE V6 convertibles, and had planned to purchase the Solara next year, but after the above problems, we decided to bite the bullet and do it now, rather than drop $$$ into the Sebring.
    We found a dealer with a delivery due in a few days, and bought the car that night.
    The higher quality of the Solara as well as a couple of extras not available on the Sebring influenced our choice.
    The Solara has a more refined feel in the ride, which we believe makes it worth the higher cost. It is also more responsive in acceleration and road handling.
    The sound level and ride quality (both excellent) were comparable to the brand new four-door Camry we were given by the dealer to use until our Solara arrived.
    We were pleasantly surprised when our salesman gave us the keys to a brand new car to use for what turned out to be a week without any charge! It sure made a difference in the 100+ heat of southern Nevada.
    As noted, our Sebring was a great car for over 88,000 miles and never needed anything other than normal maintenance until now. Both the new Sebring and the Solara are superior to the '96 Sebring, but the quality and performance of the new Solara exceeds the new Sebring and convinced us to make the change.
  • das01solaradas01solara Member Posts: 9
    Scott dude,
    I think the cars are very comparable. I agree with the differences listed above and would add one more which was a deal-breaker for me: V6 available with manual in the Solara only.
    As for the change box, I gotta say I don't see the big deal. It seems to be the same design as my 89 Sentra (maybe that says something) which I never gave me any trouble. In fact, I thought the light is a nice feature.
    No left pull noticed after 1000 miles.
    dave
    2001 V6 SE 5sp leather pkg forest green
  • luphyluphy Member Posts: 31
    Okay, when I first shopped around for cars, I remember reading how Solara owners were dissatisfied with their coin box - and I could only think...geez, it's just a stupid coin box, how bad can it be?
    Well, now that I've had my Solara for almost a year, I am beginning to understand those complaints. First off, I'm complaining about them because I can't find much else to complain about! I love this car!!
    Anyways, my coin box, which I use periodically does not close completely - can't remember whether it did from day one or not, but I'm noticing now that when it's closed, the upper right corner is not flushed with the side - anyone fix this little annoyance on their own and what did you do?
    In response to scottdude - funny thing I pretty much shopped only for a Honda Accord initially also - but when the dealer refused to meet my offer, I decided screw them, let's check out other makes. Then I ran into a Solara in my apartment complex and thought to myself - hmmmmm, pretty nice interior (I focus more on the interior since that's where I spend my time).
    Then I started reading the posts here about the Accord coupe and the Solara - and my impression was, the Accord had more complaints whereas the Solara did not. The biggest reason I decided to pay more to get the Solara is because it is much smoother and quietier than the Accord, and the interior quality is a step above the Accord. I'm not a speed demon nor do I take curves to try and break the 1-g barrier, so I was more focused on ride quality, noise level, and comfort versus handling.
    I have to say I like the back design of the Accord better, and the Accord does not come with as many options so it's easier to decide.
    Oh, I do hate the fact that the Solara's passenger front seat does not go back to its previous recline position after the seatback is declined forward to allow people in the back - one of the most annoying aspects of the Solara - and the stupid dot matrix on the top back window that makes tinting it perfectly extremely difficult.
    when i owned my solara, the coinbox was fixed by reaching up inside on the top-- there's some sort of clip adjustment-- i let the dealer do this since the car was under 36000 miles.... he fixed it so good one time that not only was the door back in alignment and not loose, but the darn thing wouldn't even open... he over compensated, in other words. eventually, they replaced the whole lower panel... i sold the car before it needed another coinbox... that thing was brutal.
