Many years ago cruise use to be on option, for me it is a must-have, right along with A/C.
white: that color combo sounds great. I've seen similar combo on a Mita. Boy I tell ya to me, light gray & tan interiors look terrible after a while. I take black in a heart-beat, over the lighter colors.
I'm also finding out the a black exterior is not as bad as I thought it would be.
jgriff, my Intrigue has the dark grey interior and I like it alot. It does get a little toasty in the summer, but hey thats what A/C is for. And it is MUCH easier to keep clean(i.e. it doesn't show dirt). Now the black exterior is a different story, but when she's clean she really looks good.
Ken
On another matter, recently had the 2000 GL (30k miles) into the Olds dealer in Vegas (Findlay) for a major miss of=n hard acceleration. Turns out while they found I needed an updated eprom (the car, not me, although my wife might disagree), per a TSB, they dumped the codes and saw the error for the timing sensor. A common ill as many of us know. While I was 6 months out of warrantee, they covered it all, the eprom and the sensor replacement. Runs great again.
The dealer and I talked, and they plan to take on Caddy soon to replace the Olds brand, and already have Saab. He indicated they will handle my car until it dies, and said since the engine was a Northstar derivitive, handling it will be easy as they transition to the Caddy biz. Makes me glad and secure as I plan to keep it another 5 or so years at least. Of course It'd be nice to get a CTS-V from them (!). OK, dream over. Time to pay the bills.
Am aware of history of intermediate steering shaft problem, but I don't think that it applies to me.
In post 8718 oldsman01 described a problem with a power steering pressure line, but this was a leak - mine is not leaking.
Other posters indicated that they had the power steering rack replaced but stiff steering problem was not solved until the power steering pump was replaced. So, I am thinking that the power steering pump is the likely source of the problem.
I have 38K miles on the car and the 36 month warranty has expired. No extended warranty.
I would be interested in any advice/experience that any of you might be able to offer before I take it in to the dealer. Any service bulletins on this issue?
I've always perfer the darker interior for a couple of reasons, (1) I think it is much easier to keep looking clean & hides some of the dirt. (2) darker interiors are easier on the eyes during bright sunny days, the sun will reflect off of light leathers & door panels [almost blinding at times].
I don't think that a black cloth interior is overly hot [leather is a bit of a pain]. Nothing that a window tint job won't cure.
I always used to lose 2 or 3 of them after my dealer would rotate my tires. The techs don't know how to put them on properly. I would always have to return to the dealership and get them to replace them, free of charge. So now I remove them myself before getting the tires rotated.
If they fell off after your dealership rotated your tires then they should be responsible for replacing them.
World class handling
The 3.5 is waaaay fun, invites you to open it up
Well appointed. Good interior layout.
GM screwed up by killing this car/division. They have nothing tp replace it. I will enjoy the one I have till it dies.
I considered an 04 Grand Prix prior to buying the Intrigue, but we bought a new minivan last year and 2 new car payments would be a stretch.
The car is out of warranty, but I have yet to find a single flaw on the vehicle. Given what some other folks on the board have experienced I will knock on wood.
I really appreciate the comments here. Many of you really know your stuff!
Mine always reads 20 degrees cooler than actual in the summer, once temperatures get above 80 or so. I can drive for an hour and it still reads low. I think the sensor is probably bad.
martypa, as for an Intrigue replacement, start saving your pennies and check out a Cadillac CTS in a few years. Thats what my Intrigue replacement will likely be. Someone over in the CTS thread said MT just tested an 04 CTS with the new 3.6 liter V6 and it posted a 0-60 time of 6.4 seconds. I have yet to receive the issue so I haven't read the full report, but the CTS was already one heck of a car before the new engine.
Does anyone know if both the spring and struts were modified or just one and not the other? I wonder if replacement springs & struts for '98s are the same as the originals or if they use the newer ones for every model year?
Went to get an oil change and was told the light would come on after you burn 1.5 litre of oil (intrigue takes 5.5 litre total, was told), and that 1.5 litre less would give me a dry dipstick.
It doesn't sound right, can anyone verify this?
Dealer wants to upsell me a $40 PCV valve before they can determine if there's any oil burning, there is also a possbility that they did not fill it up at my last oil change.
If talking production, I would say the older models with the firmer deCarbon suspension parts as that is what I prefer/will choose given the choice.
As for the best Intrigue???? I'd go with the OSV. I also prefer any model with the firmer suspension.
I'd like to have quieter and more comfortable tires than this Goodyear. I've been doing some research and narrowed my choices to Bridgestone Touranza, Michelin Harmony and Goodyear Aquatred. The Michelin seems to be pretty good, but is the most expensive of the pack. The Bridgestone is a little less expensive and my brother confirms its qualities. The Goodyear is the cheapest of the bunch and seems to perform well, though a notch below the other 2.
I guess I'll get either the Goodyear or the Bridgestone, whichever I can get for the best deal.
HTH
Yes, this is exactly what happened. They will replace at no charge. However, during this little event I came across some stainless steel lug nut caps on ebay. I think the shine would go nice against the dull grey of the wheels, so I ordered them.
Ken
Don't like the spoiler on the Alero though so ours does not have one.
I guess they are mostly rental cars?
Hmmm, I don't remember crimson being a MY'99 color. I'll have to go check my brochure. Maybe it was that dark navy blue that wasn't available that I'm thinking of. What year did gold get ditched, you don't see too many of those?
Old Edmunds Townhall
Dindak, yep I think the Alero is better looking without the spoiler. One thing that I see on alot of Nissans with a spoiler is you see both the LED brake light in the spoiler and then you also see the standard issue third brake light in the rear window. I like how Intrigues with the spoiler do not have the light(or even the housing for it) in the rear window.
Also the fonts are too small.
oldsman : I hate it when cars have both LEDs and the standard light. It looks sloppy IMO. GM has done a good job avoiding this in general.
vcjumper : Ahhh the good old days. ;-)
I read an article a couple of years ago in Automobile mag about their long-term Corvette buring oil. The dealer said the problem was the piston rings. They replaced them and it stopped buring oil. I wouldn't be surprised if that is the 3.5's problem. Looks like we'll just have to stock up on extra quarts of oil now that the engine has been canned.
Did anyone ever need to change a Pcv valve?
The old Edmund site is lot easier to navigate and find info, that's why i am using the msn site more often now.
