RJS - thanks for the simple tip about placing old rags under the opening of the throttle body because some cleaner does dribble out.
Question - Why does the varnish like stuff and crap accumulate entirely on the throttle plate side of things? When driving, I imagine the plate is open to some degree and I would expect the debris to collect upstream of the throttle body as well - but none does.
Another question - does the cleaner that goes past the throttle body also help clean the rest of the intake and manifold??
Driving it daily I left the cover on for about 4 days and then took it off. AND IT RUINED THE PAINT ON THE HOOD. Where the cover went over the hood the paint under the clearcoat is now "foggy" and dull. The detailing shop I took it to said it was from the heat. The dealership body shop said in 30 years they have only seen one car do this and they don't know why. The paint guy said he thought it's from moister getting under the clearcoat(?) on the aluminum hood and would clear up in a couple of days. Well, it's been 10 days in Florida heat and it's just getting worse. And, of course, neither the dealership or Oldsmobile is taking any responsibility and I'm stuck having to pay for a paint job.
ANYBODY WANT TO BUY A FACTORY BRA FOR A CLASSIC - CHEAP?
Now that I've ranted.... If I'm going to have to paint the hood, then I'm going to have to paint the front bumper as well to match it. If I'm going to do that.... The Razzi ground effects are looking pretty good! (gotta be a way to make lemonade out of all of this). My '95 is the exact color (champaign)of their model aurora and for 7 years old, the paint really is in pretty good shape. I'm thinking I could add the ground effects without having to paint the rest of the car.
800watt, what don't you like about the front air dam? and what do you mean about the black line between body and kit? I don't see any from the pics (zinc's razzi pics 1 and 2). Did you get an estimate for installing / painting the kit? and finally, what is "GFX"?
Larry
In fact, during a high-speed (85-95 MPH) run from Miami to Tampa last Friday I got to thinking of ground effects and the corsa exhaust. We'll see.
Hope you enjoy yours as much as I've enjoyed mine.
Larry
My throttle plate only got dirty on one side - the engine side. The other side stays completely clean. There's no crap in the MAF either (on the classic is screws directly to the throttle body). Is that weird?
I'd say you are getting outstanding mileage. I think the K&N adds a little on the highway. Maybe 1 mpg. That would be hard to prove though. I'm always amazed at the mileage my autobahn gets on the highway.
You have to admit the Aurora gives an incredible combination of Luxury, performance, economy and price. Where else can you get a solid true luxury 3800 lb (or 3900+ for the classic) ride with a silky smooth V8, great acceleration (despite the weight), and it's still possible to get upper 20's highway mpg - and it's not 40+k? The Lincoln LS is the only other car I can think of off hand.
You're right, the Aurora is awesome. The LS is nice, but it doesn't seem as luxurious, and the exterior certainly isn't as memorable.
GFX is easier to type than ground effects every time. You should go for the razzi kit, I'll be gelous. Find a high quality repair shop to paint/install. They will re-paint your hood, front bumper, and Razzi nose piece they same, and paint the rest of the gfx to match your 7 year faded paint. I went to body shop for a quote, that worked on my mothers car, 99 monte Z34, It got caught in a hail storm, rolled away with +60 dents, on every panel. Car was only 8 months old. They did a great job. They said they would paint each piece of the gfx to match the neighbor panel, blending everything perfect to match. They will also re-paint for nothing if it doesn't look right. They quoted me on the high end because I didn't have instructions or picture
Front $225
Rear $225
Rockers $300 per side
TOTAL $1050 for ground effects only.
spoiler $350 +/- spoilers vary greatly on install, show actual instructions for real $$
Grand Total $1,400 for paint and install at Top-quality 100% customer satisfaction shop.
The lowest I found Razzi's kit was around $550 with free delivery. I like the spoilers4less
spoiler and that cost $189 also with free shipping
TOTAL COST= $1,700 w/ spoiler =$2,200. Probably be little less, I rounded high.
About the white line. On these picts of white Aurora's there's a line from between the kit piece and body (only front & rear)
< a href="http://members.fortunecity.com/zincster/images/99whtfx.jpg" >displayed-text< /a >
< a href="http://members.fortunecity.com/zincster/images/97whitecustom.jpg" >displayed-text< /a >
It's not on any of the 5 razzi picts, only picts from zincs site on white cars like mine.
800wattAURORA
displayed-text< /a>
displayed-text
Weird noise-dlcleav-My 96 Aurora started making a clicking sound in the cabin. It would click at random. Never happened in front of the dealer, figures. Turns out to be a Selonid (?), from under the dash. Told my Olds dealer and they said that they knew just what that sound was, the Selonid. After a while the contacts get worn, and start making a clicking noise.
"It's normal" they tell me. Not bad for the car, just annoying to the driver. Replace noisey Selonid $85, just to have it make that noise again. It comes and it goes.
-800wattAurora-
BTW, I had to make a hard stop the other day (stupid UGLY PT cruiser pulled out in front of me) and now my CD changer doesn't work. I haven't had time to investigate it, but my head unit isn't recognizing that there is a CD changer there. Does anyone know if there is a separate CD changer fuse?
Ryan
did the door to your CD changer come unlocked? I had that happen in my '97. When I opened it and re-closed it it started working. You might check it, worth a try. Also check your connections if you can.
$ 2200 for the razzi kit installed? Then a new set of wheels & tires....($1500?). The corsa exhaust installed ($1000?).
My '95 is begining to become quite valuable :-/
Guess I'm gonna have to wait for the next commission check...
Musclecar97, I still have the witch. She's on life support as I attempt to drive her from lot to lot looking for a new car, and no a/c in 90 degree weather - same old same old. Probably going with a Sebring or maybe even a 300. Don't know yet - you never know, there might be a sweet '99 Aurora out there somewhere too...
Stay well guys. And keep the warranties current!
Thanks for the expalnation on the grime deposits.
REPENT
REPENT!
REPENT!!
I had what sounds like the same problem with my '97. High temps were definitely a contributing factor. Intermittent as you mention. The problem circumvented the function that is supposed to prevent lights from completely draining the battery -- so I had to hook up the battery charger several times. I finally located two fuses under the back seat which when removed prevented relays from clicking, lights from flashing, and battery from discharging. I was fortunate enough to get it to my dealer and demonstrate the problem before my warranty ended (about 300 miles left). They replaced the headlight switch in the steering column. I was not completely satisfied with their explanation, but since I wasn't paying, I didn't push it. That switch is about $400. That was 18 months ago, and so far, no reoccurences.
BUT, neither can hold a stick to the Aurora. I'd have to agree w/ musclecar97, having tasted the forbidden fruit you won't be satisfied with less.
Musclecar97 - "looks like the car is chewing on a chicklet" That's Great! Perfect picture!
Service Advisor said it might be a couple of things. Zerk fittings on the front steering need some grease or it might mean that they spray silicone on the rubber where it joins the body at. Any thoughts? Thanks, Steve
Been having some rough starts with my Aurora lately. It's a 98 with almost 70k miles on it now. After it's been sitting for more than a day (I have a pickup I drive when the weather is bad) it starts in the normal cranking time, but idles really rough and puts out a nice cloud of blue smoke upon starting. Anyone had this? Anyone know more about engines than I do and can tell me what's going on? I had a new ICM, new wires, and one new coil pack put on the car about 6 months ago to fix a surging problem. Could it be another coil? Something more mechanical? Looking for any input here.
Ryan
http://cgi.ebay.com/ebaymotors/ws/eBayISAPI.dll?ViewItem&item=1823101161
Too bad it's so ugly (not a big fan of the yellow). Anyways, I figured if anyone would like the souped up olds, it would be this group. I want mine to have the same stuff under the hood!
The trofeos handled better than the Auroras do, but they just never had enough oomph under the hood. If GM would have put the Aurora engine into those trofeos, we'd still be able to buy them cuz they would have sold like hotcakes!
I haven't gotten the service manuals yet, so I can't consult them. However, my inclination would be to go with what the owners manual says rather than the website. I will let you know what my tire rotation reveals.
I think I will go to my local dealer and actually buy the GM multi-purpose lubricant for door/hood/trunk hinges as well as the silicone grease for the weatherstripping. I've always used Armor All or equivalent on weatherstripping, but I think Armor All sucks.
Shucknet, if you peeled off all the stickers and never opened the hood in public, the car would be pretty cool. I always thought the Toronado was cool looking, sort of mysterious. It's interesting how much the runners resemble the runners on the LS-1.
C T S
As for the Homelink universal remote on your Aurora, I programmed that by going to [link]www.Homelink.com[/link] and checking out there instructions. I ran into one small problem I happen to have a rolling code garage door opener system but you have to reset your system so it can identify your Aurora transmitter, no biggie. Any way hope this sheds some light on this, Peace.
Javidogg, I hope there is more to programming the key fob than that... What's to prevent some dude from walking up to my car in a parking lot and pressing both buttons on his new key fob, thus programming it to open my car up? Perhaps when you remove the batteries from an already-programmed key fob it still has some memory/association with the car. I hope that isn't the case with a brand new key fob.
The two button press your manual talks about is only if you remove the batteries from the transmitter. That allows it to sync up with the rolling codes in the receiver, but doesn't reset its ID.
- The 2002 does not need the chassis lubed. There are no grease points, nor a place to install grease fittings. The usual pivot areas on the suspension are permanently sealed. I suppose every 2-4 rotations you could shoot some spray grease/lube into the suspension bushings to keep them rotating freely, but that is about it. I have to say I'm glad. I hate greasing, and the grease gun is always disgusting no matter how I store it. Grease just oozes out while it's on the shelf, and it gets all over my hands making it hard to grasp anything.
- The rear end has tie-rods (of sorts) so it allows for the rear alignment to be adjusted (which is good).
- The front of the car really is heavy. I was surprised by how difficult it was to jack. I've never jacked a car so heavy before.
- The front brakes are really big. They are thick as heck, too. Much thicker than my Corvette had.
- The rear pads don't seem to make full use of the rotor size. There is about 3/4" between the bottom of the pad and the center of the rotor surface.
- All the rotors are held on with two little clips over the wheel bolts. They seem like they'd be a pain in the butt to remove when the rotors eventually need replacing. The brakeline flex hoses also look like a pain because they run through a metal bracket that looks like it must have been bent around the hose. Not sure how you would pull it through or thread a new hose in it...
- The parking brake pulls the caliper; it isn't a drum-in-hat type (like I assumed it was). This is too bad because the drum-in-hat type doesn't usually need the cable adjusted as much since the shoes really never wear, and the caliper is much easier to remove when changing pads since there isn't a cable attached to it.
- The wheel/tires are pretty dang heavy. They seemed a bit heavier (or I am just older) than the wheel/tires on my Corvette. This is not necessarily surprising. The Corvette had 16"x9.5" wheels with 255/50-16 tires. Don't let the 255 fool you, though. The 9.5" wide wheels stretched the tires out a bit. They were pretty darn wide (most 255/50-16 tires couldn't even be mounted on my wheels as they were too wide, which made tire selection easier...). However, the Aurora's are an inch taller wheel and are still fairly wide. Plus, they have more weight on them and might need to be a bit beefier because of it.
- The suspension is neat looking, and is aluminum which is cool.
- The wheel covers are impossible to remove without leaving some sort of little nick in the wheel. I even put a rag around the pry bar. It's not a big deal, but it is a bit annoying. Especially if it went to a shop and they gouged it.
- There aren't really any good jacking points for the rear of the car. The screwjack that comes in the trunk is great since it fits right in a groove, but this is awfully slow. A general purpose hydraulic scares me in the stock jacking points because they usually bend the body ridge, or bow out the lower body panels. Underneath there is only the rear subframe as it is a unibody car, and there aren't any real great places on it. I need to get one of those rubber jackheads so that I don't worry about scratches rusting up or anything... I need to get a second jack too. I hate using jack stands, and two jacks will work fine for rotation as I don't get under the car (or using the spare, but that's a pain). If anybody knows of any hydralic jacks or jackstands that utilize the correct jacking points, I'd love to hear about them. The GM mounting point is a pretty standard shape, so maybe there's something out there. Maybe I should just buy three more GM screwjacks...
you mentioned that there was a way to tell if the theftloc feature was on or off by a blinking light or something. Does anyone know this, or is willing to experiment with it and figure it out? I will be replacing the airbag and switches on my steering wheel and will need to disconnect the battery for safety sake on my 95 Aurora.
When the Theftlock is enabled, it will prompt you for the secret code if the power is disconnected. If the Theftlock is not enabled, then the radio will always work and will never prompt for a secret code. I believe it will blink when the car is off if the Theftlock is enabled. I'm not sure if it blinks when the car is on when it's disabled (as a reminder to set it). I wish I had more specific detail, but I only remember some of it from a family member's '95 Bonneville with it.
I do know that if you go to set it, it will display a different message if there is already a code or not. To set it (you don't actually have to set a code if you don't want to, but this will let you know if one is currently set), do the following:
- Turn the ignition to accessory or run
- Turn the radio off
- Press the 1 and 4 buttons (presets) together and hold them down.
- "---" wil display if there is no code set. At this point just don't do anything and the radio will time-out with you changing nothing. "SEC" will display if a code is set, and you'd have to enter the current code before you can change it to another one or disable it. Again, just let it time-out and you won't have changed anything.
I don't think the Classic has more issues than other performance sedans its age. Even the Lexus lot isn't in motoring heaven. And we all know Lexus is the PERFECT car (or so the delars would have you believe).
However, since Olds is dying, the car may suffer from a lack of support in future years. Ever try to find someone to give you support on Wordperfect 5.0??? The same thing will eventually happen to all Olds. My 95 will be 8 years old in December. It will be time for me to start stacking up on parts soon. I am already considering buying another air deflector for the front, just to make sure I have one.
Maybe when i get my "NEW" 99 I will think about chipping the 95, but I doubt it.
What Perforamce CAT would anyone recomend? I know we discussed this before, but isn't there a problem with expanding the exhaust too much because of the loss in back pressure and hence a SLOWER 0-60mph for the car.
What is the limit in terms of increaseing the exhaust flow on the Northstar?
I would guess an extra 1 or 2 HP from one. Nothing great. I would not worry about making things "too big" or unrestricted by just replacing the converter with a less restrictive unit. I've heard that replacing the entire exhaust system with something too large could lower exhaust exit velocity to the point where it doesn't "scavenge" the exhaust gasses from the engine as well at low rpm's. Supposedly that can hurt torque at the low end.
The trick is to remove some of the back pressure from the system without lowering velocity too much on the low end. Generally, a system on a car like the Aurora is pretty bottled up (for a quiet ride), so there is a lot of room for performance improvement without getting into trouble with the velocity.
Again - a high flow converter should be fine IMO. It should just be a simple replacement of a failed part. Also - I'd think any well designed performance exhaust system shouldn't hurt performance. I'd stick with reliable companies. Corsa's designed a system just for the caddy. When I asked them if it would be too big for the 4.0 (less exhaust per rpm than a 4.6) they said that the difference was too small to be significant.
