But, I think you are definitely right about other factors being involved. I don't think that .5 mpg increase on one trip compared to another can be chalked up to the K&N. Rocket3_50, that's pretty good mileage, though (same with your 30+ fjk). My best so far was about 24.5 or so. But on long trips, I tend to go about 80 mph. Although, I'd also imagine the V6 gets better cruising mileage than the V8 does.
Since "wwilfert" bought new ones from ebay, you would have to program them first at the Dealer, so your Aurora can read them in the computer system. Hope that helps.
I had to do the same when I got my 1999 Aurora, the dealer were I bought my Aurora gave me another Aurora's remotes (I know that sounds ghetto), they told me to take them to any GM/Olds dealer and they would be able to program them to my car.
At the end it was all useless since I went with an aftermarket Clifford alarm, I just did not want to be keyless for a couple days before I decided to get the Clifford alarm, the Clifford alarm came with it's own remotes. Also the dealer paid me for taking the remotes to my local dealer which was around $45 dollars. Good luck and keep us posted. Peace.
http://www.cardomain.com/id/javidogg
I am noticing a number of Classics without the center piece of the wheel. I asked two people abot it and they both said that they came off while driving. One guy said he hit a bump on a turn and loss the cap. The other person, a woman, just said she lost it while down south.
My mechanic did say that mine came off a little too easy when I took one off for him.
I am saying this to say that maybe as the car ages, whatever GM did to hold on the cap get weak. It looks like they are held on by a wire. Maybe the wire may need to be tightened due to slack that comes into it over time. For those Classic owners, maybe its time to check the caps to make sure they don't "fall off".
However, I still think mine had a little help "falling off."
Henri
Maybe I was lucky, but before I got the 2001 wheels, I was getting centers for the original wheels from a wheel (junk) dealer for $20 each. Just call around. Regular junk yards may have them. Look for wheel places.
wwilfert: Does this sound like the procedure you used for your '98?
i noticed something today that seems a little unusual to me about my wipers. I was driving in a very slight mist of a rain (not even enough to turn the wipers on even at the slowest delay). What i was doing, is pushing the wiper control arm up, for the "mist" function whenever needed.
The unusual thing that i noticed is that most times i would get one cycle of the wipers (as expected), and about once every 4 or 5 times it would do a "double" and i would get two cycles of the wipers. It didn't seem to be related to how long i held the wiper lever or related to how often i held the lever up either.
Has anyone else noticed anything like this on their Aurora?? Mines's a black/black '95 with Autobahn by the way.
just curious.
If this was Oldsmobile's idea of product placement, no wonder the company is closing down. Who notices the traffic cars in the background? (Besides the Auroraholics on this board.)
Henri
Henri must have a very cooperative dealer. It typically costs about $40 to get them programmed, more if the dealer insists on charging a minimum of 1 hour labor.
Chris
Does anyone have info on this?
Back in the day, I drove a car without power brakes. The Aurora brakes feel a lot like the brakes in that car did.
Eventually, I'd like to drive another Aurora to be compare. In the meantime, let me know what you think.
Yeap something big did fall off the truck at the Aurora. I don't remeber if the car ran over it or not.
As far as programming the remote for free. When you spend over $9,000 at your dealer's service department, I bet they will throw in a free remote programming also. (Let's hear it for after market warranties.)
As far as hard pedals and steering, I found the 1999 'Roara that I test-drove had about the same pedal feel. However, the steering was quite a bit lighter. What sort of cars are you used to Mariposarosada? I mean, if you used to drive 80's Cadillacs or Oldsmobiles, then yes, the steering will probably seem heavy. Otherwise, I don't think I'd describe the car I drove as being "heavy".
I have noticed the steering seems to "tighten up" at weird times. I don't think the '95s use Magnasteer, but some earlier variable power assist. I can appreciate that Olds increased the effort somewhat to give it a semblance of road feel. However, mine does sometime seem to increase the effort at inopportune times -- like entering a pretty good curve at cruising speeds -- certainly gets my attention, anyway.
As far as the gas or brake pedals, I haven't noticed any difference between them or my wife's 2002 Impala LS. EXCEPT that every once and a while at very slow speeds, especially if I'm just pulling off and then have to hit the brakes, they don't stop very well at all (I hit a panic stop and the car just slows down to a stop). I suspect there's some sort of vacuum deficiency under those certain conditions keeping it from a hard/fast stop.
Larry
Javs
I'll get out the lube and have some fun tonight.
"I'll get out the lube and have some fun tonight."
I noticed an interesting comment in C&D regarding their test of the G35 coupe. They didn't do instrumented acceleration, but rather tested it at Sears Point International Raceway as a preview. Here is what was interesting: (some crap about how the car was designed by some engineer who worked on Nissan's LeMans effort) "So we were confident the car would feel at home on a racetrack. Apparently, the Japanese engineers wanted to be sure and added oil coolers to the cars we drove, as well as conducting extensive brake tests beforehand."
So apparently it isn't like C&D doesn't realize that they are getting ringers, it's just that they don't care. I'm sure they will in later articles mention how durable and composed the G35 was at Sears Point without bothering to mention how the car was specially prepared for the track. Not to mention, if the engineers bother to make changes to the car prior to a magazine testing it, who's to say those changes are limited to what they mentioned? The most insulting part is how this same issue contains an in-depth article on how they test cars, in which they conclude: "Although our numbers may not always be the fastest, at least you can be confident they are an honest and consistent representation of a vehicle's performance." Yeah, it's just to bad the vehicle they are testing bears only a resemblance to the one you are buying...
They are never going to be totally honest because that would be like saying there is no Santa. People buying the new Accord V6 would love to believe it will do mid 6's with an automatic and give a mustang GT a run if you had the manual. That one was so far over the top that it did it for me. That and the WRX doing mid to high 5's but the street start was 7.4 or something (and they never bother to mention this ridiculous disparity and what that means for real driving). Anyway, advertising dollars would disappear and readers would be mad. Oh yeah, don't forget how poorly some cars perform compared to their earlier "first drive" tests when they do the muli-model comparison tests.
Oh, you will love this - I saw a bunch of BMW infomercial kind of stuff on the speed channel. They were flying around in the M3 and it had a really fat steering wheel. Somehow fat steering wheels are bad only on Auroras.
I still have to mention the one article I saw where the 350Z was doing (if you did the math) 85% at the wheels. Maybe I'm unaware of something, but that seems like a red flag to me. I've seen the vette dyno'd and it was around 75%. Big difference.
Hey - I'll let you know how the Corsa sounds in a couple of weeks. If you do this, you will be up to 270 HP (maybe more) with the K&N and the power curve will be really fat on the top end with that new Aurora, and perhaps you will be even happier with the performance.
Does everybody have this piece? Is so, let me know the year of the car. Also, does anybody know what it does??
Henri
My '97 has what you describe. It is a vent to draw interior air past a temperature sensor for the HVAC system.
NOOOOOOOOOOOOOOOOOOOOOOO WWWAAAAAYYYYYYYYYYYYYYY
I got them on my 95 two days ago and I already want them off. These things on wet roads have less grip than my 20,000 mile Z rated Toyo's.
Anybody want a set of Yokos CHEAP??
Henri
Additionally, we just had a couple of inches of snow here, and they plow right through it. Granted they're new, but the traction control didn't even come on. I'm thrilled!
Oh yeah--only 52 bucks each, too.
The Aurora platform is already used by Cadillac, Buick, and Pontiac, and the Premium V8 is shared with Cadillac and soon Pontiac. So if you meant Aurora parts, other divisions already have them.
I guess the Bonneville GXP will be the closest thing to the Aurora, but I doubt it will have an interior like the Aurora's. I really love how it is conservative yet still very sporty. I also love the wood and chrome accents. The interior is sporty yet elegant, and not overdone. The same is true of the exterior. Sporty yet elegant.
Everytime I get out of the Aurora and into the Bonneville I think I am going from a Corsica to a Caddy.
Could this ride be improved with different tires and shocks.? The tires are Goodyear Eagles and I guess the shocks are OEM.
There is a Technical Service Bulletin and this procedure generally takes less than an hour. I'm not sure if it's entirely the cause of your problems, but I'd start there.
--Robert
'98 Classic owner
My mother-in-law works for GM, and thus she can order a new loaded '03 for about the same as what they are asking for the '01. She also has old GM card dollars and wants to use them while she can (GM is ending the "double-dipping" practice next year).
She owns a pearl white '98 Classic, and it was making creaking and groaning suspension-type noises. Took it to her dealership, who heard the problem, claimed to check everything, but couldn't resolve it (still charged her $75). Took it to another dealership, they cleaned the rust off and applied lubrication to the bushings, and the car's quieter than it's ever been. Only cost her around $60. When she went to go back to the first dealership to demand her money back, they were gone - must have taken their GM buyout.
Now that her '98 is working OK (she's got the same extended warranty as I do), she's no longer thinking about trading it in and getting a new Aurora or a CTS - instead she's looking at adding a second vehicle like the Vibe or Saturn VUE (she's retiring in the spring, and wants to buy something new while she still can afford to).
I still have a couple of years before I'll retire my '98 Classic as my daily driver. Due to the family discount, I stick with GM cars (other than the AMC Javelin I learned to drive in, and a junky Dodge Omni I had while in college, that's all I've owned/drove).
I do like the CTS, but, while it is sportier, it is a drop from the Classic as far as amenities goes. I wouldn't get one with the current Opel engine. The new Bonneville GXP intrigues me - retaining the V-8, but losing the cladding and most of the overstated Pontiac styling. My wife has a 2001 Grand Prix GTP, and it's been a decent car, but the interior is terrible (I can spin the HVAC control without it clicking into place, but my local dealer says it's working as designed). Maybe I'll undergo my mid-life crisis and have to get one of the new GTO's. Other than that, I don't see anything in GM's future lineup that interests me...
--Robert
Don't forget the new STS. That should be pretty cool.
I have been very happy with the contis and will probably replace them w/ a new set. BUT, I'm also thinking of Michelin Pilots.
The Contis will run just under $500 installed. I haven't priced the Pilots.
Any of you have opinions (stupid question). What should I do?
Larry
So it seems that I have had the most problems so far, stalling from a crank sensor that had to be reprogrammed, tie rod ends going bad at 14,000 miles, steering column noise. Anything else to look out for?
By the way, this doesn't scare me enough to get rid of the car. I just convinced the wife to get an LS so I can have the Olds. Maybe if I get real lucky, I'll have my '53 Olds done as well. Yeah right! We'll be looking in the spring.
