Oldsmobile Aurora
199100102104105112
  • 95mushroom95mushroom Member Posts: 230
    Either keep the name or change it to: Every1s'NV
  • rjs200240rjs200240 Member Posts: 1,277
    Looks like Shelby will sell remaining Series 1's as a kit car. The car never really sold properly as it had a very difficult time meeting legal requirements. They only sold about 250, and have complete parts to build about another 250. So now as a kit car, it doesn't have to meet any requirements. The 4.0 engine will be sold by some 2nd company for installation into the Series 1. I guess if any of you want a S/C 4.0 to stick in your Aurora, you can give them a call... ;)
    Man, the weather today was amazing! It was about 65F this morning, so the wife and I took the Aurora out for a run. It was fun, driving through the Shenendoah's. We need to find some slower, windier roads, though. I was punching it up just about every hill... :) What a great car!
  • sls002sls002 Member Posts: 2,788
    highway 1 on the west coast is winding. Just got back.
  • HenryHenry Member Posts: 1,106
    Well I decided to give aROARa a rest for this trip. I went up to Syracuse, NY from Newark, NJ, about a 240 trip each way. I took the 84 convertible Riviera.
    Nice ride but the car overheated twice, once going up and once coming back. There appeared to be no reason for it over heating. I noticed the car throws off a lot of heat. Must be that big OLDSMOBILE 307 iron engine. I think I will have my mechanic drain, flush and refill the cooling system. The car is 20 years and 107K miles old.
    I am thinking that will fix the problem. Any other thoughts from you "Classic" car guys?
    You could also check the thermostat, and make sure the fan engages. And you can make sure the engine is clean, and not crusted up with 20 years of oil and road grime. Some heat does leave the block via the external surfaces. Just thoughts.
  • 53rocket53rocket Member Posts: 65
    My father's '84 Riv had no issues with overheating. His car had the Oldsmobile derived 307 (5.0 L) engine also. You do need to be careful of the thermostat bypass house that is about 6 inches long and goes from the thermostat to the intake manifold. Traditionally, these are a problem area. Additionally, I would do a good cooling system flush and replace the 195 degree thermostat with a 180 (assuming you're not looking for a lot of winter heat).
    I forgot to mention that I got some interesing milage readings on the trip. The float in the gas tank does not work on this car so I have been resetting the trip odometer after every fill-up.
    Using the "how much gas does it take to fill-up the car" approach for estimating milage, I got the following results:
    around town driving = 9 - 13 mpg
    highway no A/C = 23.5 mpg
    highway with A/C = 16 mpg
    I find the mileage differences to be dramatic. The idea that the car would double its milage on the highway verses around town is NEWS TO ME.
    Because this reading was taken on the way up to Syracuse, I dont know what effect, if any, the topograghy of the land had on the numbers. I went through mountains (Poconos)and the 23.5 is based on the trip up. I have yet to fill the tank to get the no A/C numbers for the trip down. The 16 mpg is based on the trip back.
    WINTER HEAT - This is not really a concern of mine. I dont drive the convertible during the winter (except to cirulate the fluids and maintain the tires).
  • autobahn95autobahn95 Member Posts: 62
    Hello Everyone...
    I just thought I'd let the board know that my Aurora has finally flipped the odometer past the hundred-thousand mile mark. I've had my '95 Autobahn black/black for almost 4 years now and have put 22,000 miles on it in that time. I have enjoyed every minute of owning this vehicle.
    Here's a list of what I've done:
    KYB GR2 struts up front
    New AC-Delco air shocks in the rear
    Cross-Drilled and vented rotors on all 4 corners
    Both front wheel bearing assemblies
    Lower control arm bushings on both sides
    Fuel Pressure Regulator
    Re charged the A/C
    Serpentine belt tensioner pulley
    Next on my list is to change the spark plugs and wires along with the O2 sensors.
    At the rate I drive this car, it will take me around 20 years to rack up another 100,000 miles!
    LOL
  • woodranch1woodranch1 Member Posts: 35
    I have a 1998 classic (original owner) with about 140,000 miles. At highway speeds, over rough patches of road, the car experiences a bodyroll or floating sensation, that feels like a momentary disconnect from front wheels. A bit scary, like a temporary loss of control.
    I just had struts replaced but did not solve problem. Any ideas?
  • mrdubyamrdubya Member Posts: 200
    well, i bought a new car...the aurora's highmiles were getting the best of it, and it STILL has a suspension problem, new control arm bushings, struts, strut mounts, balljoints, blah blah.......car is currently in the shop
    anyways, i got a dk blue 2001 alero gls, 3.4v6, leather, moonroof, monsoon soundsystem, chrome rims. there alot nicer inside than i thought it would be. you can definatly tell its a step down in overall quality/features over my 95 aurora, but i like the layout more...the stereo is really good in it too... the rears 6x9
    s are setup as 2ohm subs, so its got some good bass, much nicer than the stock setup in the aurora. v6 has alot of power down low, but not TO much up top, but like the aurora it has its sweet spots. they make headers for them, which are supposed to help ALOT, but anyways.....im staying with olds at least! ill check back from time to time
  • hammen2hammen2 Member Posts: 1,284
    ...couldn't resist the incentives (especially GMS) and purchased a 2004 Pontiac GTO. I looked and looked for low-mileage '02-'03 Auroras, but they were still commanding $22+K, and finance rates on used cars were significantly higher than new (got low finance rates AND cash on the GTO). Wife is driving the Aurora now, while we sell her GTP, but I'll be the driving the Aurora again when the snow flies (and the GTO goes into storage). The stock GTO sounds even better than the Corsa on the Aurora, and, let me tell you, this thing's fast (have 600 miles on it and haven't really pushed it hard yet) and can really handle. Interior is really very nice - IMHO, best current GM interior, except maybe the new STS - and the Aussies could teach UAW folks how to put them together. For a car with the "sleeper" tag, I sure get tons of looks/stares/"hey can I look at your car?" queries. I've got one of the 600 or so Cosmos Purple Metallic cars (automatic - drive to/through Chicago too many times to hassle with a stick).
    I'm still not ever getting rid of the Classic, though... :-)
    --Robert
    I just looked at a 95 Aurora with 60k on it. It is the same car as mine except it has a sunroof and sftermarket alarm system. I have 99k on my 95. I was debating whether it was worth trading cars since aside from the milage and the sunroof, its the same car down to the color and the swirls in the paint job. And, it does have the wrong "s" rated tires on it though it does have the autobahn package.
    Would you guys do the trade, and if yes, how much would you be willing to pay in additioanl cash with the trade in?
    The work already done on my exisitng 95.
    1) performance chipped the car
    2) thicker sway bars
    3) rebuilt transmission
    I just dont know if I am losing 40k miles just to make the same repairs all over again on this car as I put the 40k miles back on the "new" car.
  • blk97aurorablk97aurora Member Posts: 573
    Henry,
    Knowing what you and I know about '95 Classics, I would not consider trading a known '95 (yours) for an unknown '95 unless it had less than 10,000 miles and cost nothing additional.
    If you want to trade, go for a '98 or '99.
    Les
    Have your dealer pull the service history (think they can only get warranty history, unless the car was serviced at that dealership) of the vehicle you're considering. If the issues like shift solenoids, et. al. have been addressed, fine, otherwise consider how much extra $$$ it's going to cost you to get the car AND for the maintenance and repair.
    Might just be better off keeping what you've got and saving your $$$ for a later-model '98 or '99.
    I had an Alero rental, and they are nice little cars. Very solid, handled nicely, and rode well. I'd have gone with the Ecotech and a 5-speed, but I'm sure you'll enjoy it a lot. They are a lot of car for the money.
    Hammen, I'd love to hear more thoughts on the GTO, so feel free to express them here, especially any things you prefer in the Aurora or in the GTO, etc. :)
    Henri, I wouldn't do it. Hold out for a black 97-99 like you wanted. Miles don't hurt as long as the car is kept up, so who cares about 30k fewer miles. :)
    Quick thoughts:
    Ride preference is definitely the Aurora. The GTO is a real sports car, and so you feel just about every bump (concrete roads/expansion joints can be a killer). Of course, this is a little better now that I lowered the tire pressure from 60 lbs psi (!) to 35 - evidently they ship them from Australia that way, and it's not on the dealer's PDI checklist to inspect tire pressure, so they don't.
    For acceleration, handling, and (stock) exhaust note, definitely the GTO. The GTO interior is very nice - but the Aurora holds up extremely well here (my '98 is now 7 years old, and I've been driving it for 3 1/2 years, and the only rattle is when the cupholders are extended). The GTO seats feel like gloves, wrapping around you so that you don't slide around in hard cornering (something the Aurora seats don't do - can slide around a little bit). The Aurora seats are more plush, but I'd rate overall seat comfort for long drives to be equal. The GTO seats are color-coded to the outside of the car (yes, I have plum-colored seats and gauges to go with my Cosmos Purple car).
    Braking performance on the GTO is pretty good, too. The GTO is no light car (about 3800 pounds, close to the Aurora), but the handling is superb. Of course, the GTO's lack of 2 doors and small trunk (that's where the gas tank is) give the space/room edge to the Aurora. If I had the option, I would have purchased the Holden Commodore (4-door version), but, since Lutz didn't succeed in having that brought over as a Buick...
    The Blaupunkt stereo is decent (6 disc in dash) but I still like the "cleaner" sound of the Bose in my Aurora (12 discs in trunk, not nearly as useful as the 6 in the dash). There's no factory sunroof for the GTO, but you can get one from Webasto for about $1500 (Holden sells 'em that way in Australia). The GTO does have a DIC (I keep it on displaying the current speed under the gauges, like a pseudo-HUD), but I wish I could more easily display the mileage/average speed/range in the secondary displays, rather than having to scroll through.
    Car is extremely composed at speed (haven't had it over 90 yet, kept it under 4k rpms). This would make a good Autobahn vehicle. Low-beam headlights need adjustment, high-beams are the best I've had on any car. Getting used to the huge key/fob (all one unit - key and fob. The key can be removed if it breaks, but the fob is sealed. The fob's battery is trickle-charged by a contact on the fob, and a metal ring around the ignition switch. This supposedly works well in Oz).
    Back seat room in the GTO is surprisingly good (it's a 2+2, and I've had 6' tall adults in back). Getting in and out is the pain (world's slowest seat motor to slide the driver/passenger seats forward).
    Gas mileage is superior on the Aurora (average 22-24 per tankful with non-reformulated gas, versus 18-19 on the GTO with reformulated gas).
    I miss the chrome wheels on the Aurora. Way down the road, probably will get the standard rims polished or chromed, rather than buy different ones.
    The GTO lists for "around" $33,500. They're not moving (about 5400 sold, not sure how many north of 10k were produced out of the 18k they could have produced), and, with the '05's coming out in December/January with the 400 hp LS2, hood scoops, and bigger brakes, dealers are trying to move them NOW. There's presently $3500 in rebates PLUS 0.9 (36 mos), 1.9 (48 mo), and 2.9 (60 mo) financing. Throw in the GMS discount (which many dealers are giving even if you don't have a GM employee in the family - how they're doing this, I don't know), the extra $1k in GMS incentive, and GM card dollars, and you have the performance bargain of the year. I went with the Cosmos Purple because a) I like the color, b) I'm sick of black, and c) the color is the rarest of them all, and won't be available next year.
    There's an extremely health aftermarket for the LS1 as well (since the engine is used on the C5 'Vette and later Z-28's and Firebirds). Lots of chip/ECM upgrades, headers, exhaust, pulleys, a supercharger (!), et. al.
    With the deals out there on the '04's, and expectation that the '05 pricing will be closer to $35k, there's no reason for anyone really to wait (since there will be little aftermarket for the LS2 at first).
    I probably won't do much with the car, mod-wise, for a couple of years. Biggest thing I miss from the Aurora is the temperature/compass/auto-dimming rearview - will probably buy a Gentex one and install it on the GTO next spring (when I'll break down and buy another XM Radio kit and install it in the GTO). Probably going to wait until the end of the factory warranty before I do things like sunroof and other mods.
    --Robert
    Soooooooooooooooooooooo
    I guess there is LIFE after Aurora.
    Live long and prosper.
    Don't worry Henri, I'm not going away from here. I'll be driving the Aurora for at least the next couple of years during the winter. I don't want to call it my "beater" since it's still my baby. The GTO is just the latest toy - I call it my "mid-life crisis" car :-)
    --Robert
    Anyone have/can get, the part # for my 95 Bose stereo w/12 disc? Or is located somewhere on the radio itself?
  • pmontgomerypmontgomery Member Posts: 3
    Let me know what happens with the suspension?? I just changed the struts in my now the rear end is all messed up. It bounces like crazy. Like the rear shocks aren't even there! So I'm guess the load sensor got out of whack some how. Anyway let me know...
    http://cgi.ebay.com/ebaymotors/ws/eBayISAPI.dll?ViewItem&cate- gory=33742&item=7922389281&rd=1&ssPageName=WDVW
    I'm sure now that the sign of the end of the modern performance boom is over. Now you can't even tell if real turbos or not. :'(
  • patpat Member Posts: 10,421
    TONIGHT - 6-7pm PT/9-10pm ET
    Get LIVE feedback on your maintenance or repair problems. Join our guest experts alcan, 0patience, and mr_shiftright as they tackle your fix-it questions!
    Hey Henri, I think you'll be able to tell if it's real by how small the taillights get...
  • garnes1garnes1 Member Posts: 33
    Did you leave out the "looks" department? I still think the Aurora is one of the coolest looking rides around.
    Sorry 95mushroom, I could have sworn Henri posted about the "turbo" exhaust tip.
    The more I've seen CTS-V's and GTO's on the road, the more I think if I were inclined to get such a car, I'd go with the Goat. I like the CTS's style less each time I see it. And of course the GTO is substantially cheaper. But I think a C4 (one that sounds like 95mushroom said, but without anything in the exhaust tip) calls me and the Aurora and Regal and 200SX will have to last a while... :)
    I have to say I feel opposite of you. The more I see the V, the more I like the styling and how well the wheels (and giant rotors) fit so nicely. I now have a cool poster to stare at. Thanks Cadillac.
    BTW, the GTO is still very hot in my book.
  • stickking1stickking1 Member Posts: 247
    Stopped in to my local AutoZone today to return some unused brake pads and they had an ad in the window for Gabriel struts. Apparently, AutoZone and other chains will be offering the ready-mount assembly for purchase. I was considering doing this sort of project for my Aurora for quite sometime and was planning on just going the KYB route, but after looking at this package, I may just go with the Gabriels for the ease of installation. Using the ready-mounts would save me a couple hours on the install at least, and I was already looking at replacing the struts/springs/mounts/boots/bushings and this would save me from buying everything piecemeal.
     I'm prepared to assume that the Gabriels may not be as nice as the KYB's, but I would save a decent amount of money and a whole lot of time...and I am just concerned about getting an OEM-standard replacement at this point. The sets are $150.00 each and are lifetime guaranteed. This way the only other thing I would have to purchase is a set of lower control-arm bushings that also need replacing.
    What do you think?
    -Brian
    FYI, Monroe is offering a mail-in rebate - buy 3 shocks or struts, get one free (i.e. "Shocktober"). My '98 needs shocks and struts badly (either that or the roads have become even worse over the past couple of weeks), so I think I'm going to go this route.
    --Robert
  • kayaman420kayaman420 Member Posts: 207
    Not that Im an expert, but my only expierence with GAbriel was a bad one. Replaced some 10 year old shocks and struts on an old Monte of mine and the new Gabriels were horrible. They felt 10 times worse than the 10 year old OEMs.
    Just wnted to give you some sort of feedback.
    GTO/CTS-- IMO the new direction of Cadillac is not too impressive. Styling and looks wise I mean. Just doesnt look like Cadillac to me. Everything they make now is so jagged looking and just flat out overstyled. But thats just me.
    GTO- Performance and Engineering wise is GREAT. But GM failed bigtime on the style department. If you could create a more boring looking HIGH PERF car .....IDk... Just not fun to look at. Really just looks like a rounded off Grand Am coupe.
    GM needs to fallow Ford when they decide to go retro. The GTO doesnt resemble the classic GTO in any sense or manner. Where as Ford with the Mustangs and especially T-Bird have nicely captured the look of the old classics with technology of today.
    I don't want to discuss this too much, as this is the Aurora forum and not the GTO one, but I wanted to make a couple of points on GTO styling (since I own both a Classic Aurora and a GTO).
    First, retro sells, but only for a short period of time. Just look how sales cooled after the initial burst for the New Beetle, PT Cruiser, and Thunderbird. Retro doesn't last for long.
    Secondly, look at the GTO heritage. The GTO started life as a Tempest with a big motor. The car was a "sleeper" and, over the years, as the styling changed, it morphed into something a little less subtle.
    GM is taking the same approach with the new GTO. It is a bit "sleeper" in that it really resembles the last-generation Grand Prix (like my wife's old one - like that styling better than the current model) in the front. For '05 they've upped the HP and added hood scoops and a new rear fascia. For '06, who knows? The old GTO's didn't stand still, from either styling or performance. GM was limited in what they could do since the only RWD platform they could use was from Australia, and they couldn't make too substantial body panel changes and yet get the car here quickly (less than 24 months from green-light to delivery). The next-gen GTO in 2007/2008, built on a new RWD platform engineered in Australia and used extensively throughout GM's full-size lineup (and built somewhere in North America), will have more "traditional" muscle car styling cues, and hopefully higher sales volumes.
    I personally like the rounded look more than the slab styling of the 300C, so I don't find the GTO styling offensive. Listen to one running (awesome stock exhaust sound), sit in one of the best GM interiors you can buy, and take one for a test-drive and you'll be hooked. I'm not normally a new-car buyer, but the GTO hooked me on the first test drive - and, with the awesome incentives out on it (low finance/lease rates, plus $$$ back), it's the performance-car bargain of the year right now.
    --Robert
    ...for a car that's been criticized for its styling, heads turn when I drive by/pull in anywhere with the GTO. There was some "styling trends report" press release I read which stated that the GTO was #2 or #3, behind the 300C (don't know the other vehicle, if there was one). I just think the target market for this car doesn't usually shop at Pontiac (or even GM) dealers, and the traditional GM buyer may not be happy with the price/size/lack of features like sunroof, OnStar, heated seats, et. al.
    --Robert
  • 2k1olds2k1olds Member Posts: 98
    for an opinion. Looked at a 1997 Classic with Autobahn package today. Clean, single CD, no Bose, but all other options. 74000 miles. Brand new Michelins. Black in color, dealer pinstriped it with gold, with Flying A's on front and rear fenders, which actually looks pretty good. He's asking 7900; what would you guys offer??
    $6000 - its eight years old. He is asking top retail blue book. Suggest that the auction value is $4000 (I don't know what the aution price might be)
  • huskerfan_21huskerfan_21 Member Posts: 27
    I recently replaced the rear shocks with AC Delco OEM parts, and to me it seemed like the front was riding worse (original shocks still in front). Maybe it was just me thinking that the rear shocks are riding better because they should, but who knows.
    So my question is, with everyone seeming to be replacing front shocks, what have you all found to work the best?
    I've read KYB, Monroe, and now Gabriel? The first two I know about, but not the last. I was probably going to go with KYB, but wanted to know what you guys thought after having a few months with your new shocks.
    Thanks for all input.
    Also, how many hours did it take to swap out?
    Equipment needed?
    Greg
    '96 Aurora Autobahn
    Just bought the above mentioned 97 Aurora, ended up getting it for 6100. It has 74000 miles and is very clean, but now it's time to research extended warranties. Has anyone ever dealt with Warranty Wizard? If you have, please give me pros and cons. Thanks
    You probably also want to check out our Warranty discussions over on the Smart Shopper board while you wait to see what folks here think. Hope this helps.
    The 95 is now at 100,080 miles!
    I would like to thank my multiple long distance trips to South Carolina, Virginia and Vermont. Also, my recent trip to Rhode Island.
    Can't forget the guy at the shop. Thank you
    And, and of course, I would like to thank all the little trips that made this possible.
    Zinc1 - I Love you Man!
    Henri
    What'd you give her for her 100,000 mile b-day? My car's coming up on an anniversary too. I believe it was 10/18/2001 that we first brought her home. We went back a few days later to do all the paperwork, though, so the official stuff says 10/20.
    I'm glad to see some posts here that are not in the Problems & Solutions thread.... :)
    Actually, it was October 17, 2001 that I took delivery. So happy birthday Aurora!
    Would you count that or the date she was made? You get a whole month then. :)
    if I can still get a warranty on my 97 with 76000 that is backed by GM? I know I can go aftermarket, but I am a little leary about this. Any help?
    John
    I doubt that you can... IIRC, I couldn't get a GM warranty on the wife's GTP once it passed 36k miles. Wife also didn't want to buy tires, so we traded the car for a new Envoy SLT ($13,500 in discounts and incentives, yikes!)
    I think it's hard to get them at all once your GM warranty has expired. If your car is still under warranty, it's a lot easier to extend it. Perhaps so people don't wait until their car has some problem and then try to buy a warranty.
    95mushroom, I count the date I got the car. It's a 10/01 build date, and probably was done a week or so before I picked it up. It's been a perfect 3 years! :)
    This is the name of an aftermarket warranty company given to me by my olds dealer. Anyone ever heard/dealt with them? Olds has been using them for 20 years.
    John
    That because you had your own, those of us who adopted our own, the date we got the car doesn't really matter. :D
  • krisskriss Member Posts: 2
    My 97 Aurora has a stalling problem that started a few months back. Have had it to 2 GM dealers and one Cadillac and they do not have a clue what to fix as the car does not stall with them. It did have some codes on it but when they cleared them nothing came back. Replace EGR valve already. Here is what happens: first time it stalled I was slowing down to merge onto highway ramp and rora just quit at around 25 mph. No hesitation nothing just stalled. Then about a month later same situation turning into parking lot and just stalled. No warning no bad running nothing. Last week stalled three times in 65 miles each time on slowing down. Then drove 528 miles to Columbus and no problem at all. Monday morning stalled again about 4 miles from home. Same thing just stalls. On way home came up to stop on highway (after 63 miles with no problem)and when I came to stop sign the rpm's surged to about 2000 and stalled. It did this three or four times, start-surge-stall. Let it sit a minute and started it and rmp's were stuck high about 2000. Turned it off and restarted and it was fine. No problem for next 150 miles. Dealer says something has to either develope a pattern or quit before they can figure it out. Anyone have this problem and have a solution? HELP! I love my car. Really want to resolve the problem.
  • peekamoosepeekamoose Member Posts: 7
    When I had that exact problem on my '98, it was the Mass Airflow Sensor. My mechanic was puzzled at first by the codes, but he's good so he got her running again. Cost me about $200 IIRC.
