I, for one, like the new '04 Impala SS but I think it is 3 years too late to market. The '04 SS would have been a killer car for Chevy to offer back in late '99/ early '00 because at the time Ford had just axed the '99 Taurus SHO sedan. A 240HP Supercharged Impala would have given the late Taurus SHO a complete run for the money. Today that is questionnable because even a '03 Accord with a normal aspirated V6 engine with 240HP can keep up with it and may be outrun it.
Chevy missed a golden opportunity by delaying the SS for so long. They had the hardware back then to make it possible....why hesitate so much?
I think the 5.7L V8 FWD Impala SS prototype was interesting but the torque steer and production costs issues put it in the back burner. How much is the '04 SS going to be?? $30K??? Insane!!
GM knows that the secret to its long term market success in the car arena is to go back to RWD platforms, so I hope that by 2006/07 the Impala goes back to RWD and offer optional V8 engines.
The current Impala is a terrific car, but GM in their wisdom, have not done much of anything to keep it fresh and appealing year after year. A 2003 Impala looks essentially the same as a 2000 Impala...see the problem??
As long as Chevrolet retains the Corvette and leadership in auto racing they will have a performance image, and IMO they will never satisfy the die-hard performance fans who want RWD and lots of hp because of the pressure on oil prices, gov't regulations and the cost to redesign their vehicles in an uncertain market. Remember when Chrysler almost went out of business selling RWD cars? Just my opinion.
Bob Lutz has recognize the need for GM to recapture their role in the car performance arena and as a last minute resort they are importing the Australian Golden Monaro V8 Coupe and reselling it here as the '04 Pontiac GTO. The car is controversial but it is the move in the right direction IMO.
GM should capitalize in the utter market failure of the current Mercury Marauder and speed up the development of viable and superior RWD car platforms. The Marauder doesn't have the balls to live up to its name. Those 94-96 Impala SS continue to fetch very good resale values.
I am drooling over that sweet and sexy Chevy SS concept presented last month at the International Detroit Auto Show. GM can do it and they are showing willingness to go in that direction.
Furthermore, let the new '04 Chevy Malibu do the fight against its immediate FWD competition (Accord/Camry/Altima/Passat). The Impala is in a whole different class and GM should capita;ize on the success of the current FWD to bring back a "gotta have" RWD Impala sedan in the future.
Lutz, are you listening?
I wonder how many ISS lube kits have been performed when it wasn't that at all?
Brakes - Rattling Noise
File In Section: 05 - Brakes
Bulletin No.: 01-05-23-O11A
Date: February, 2002
TECHNICAL
Subject:
Rattle Type Noise Coming from Front of Vehicle
(Install Front Brake Caliper Service Kit)
Models:
2000-01 Buick Century, Regal
2000-01 Chevrolet Impala, Monte Carlo, Venture
2000-01 Oldsmobile Intrigue, Silhouette
2000-01 Pontiac Grand Prix, Montana
This bulletin is being revised to remove Chevrolet Lumina from the Models
section and to update the condition information. Please discard Corporate
Bulletin Number 01-05-23-11 (Section 05 - Brakes).
Built Prior to the VIN Breakpoints shown.
Condition
Some customers may comment about a rattle type noise coming from the front of
the vehicle. This noise usually occurs at vehicle speeds under 48 km/h (30 mph)
and while driving over bumps. The noise can usually be eliminated by a light
application of the brake pedal.
Cause
This condition may be caused by too much clearance between the front brake
caliper bracket and the caliper pins in the bottom of the bracket bores.
Correction
Install front brake caliper service kits to both sides of the vehicle using the
following service procedure. Each kit contains 2 pins, 2 boots, and 2 packets of
grease.
Service Procedure
1.Raise and suitably support the vehicle. Refer to Lifting and Jacking the
Vehicle in General Information.
2.Remove both the front tire and wheel assemblies.
3.Hand tighten 2 wheel nuts to retain the rotor to the hub.
4.Install a large C-clamp (2) over the top of the brake caliper and
against the back of the outboard brake pad.
5.Tighten the C-clamp until the caliper piston is pushed into the caliper
bore enough to slide the caliper off the rotor.
6.Remove the C-clamp from the caliper.
7.Remove the caliper pin bolts (3) and discard. New bolts are supplied
with the service kit.
8.Remove the caliper (1) from the caliper bracket (2) and support the
caliper with heavy mechanic's wire, or equivalent.
9.Using a flat bladed tool or punch, carefully tap the caliper pin boots
from the brake caliper bracket and discard.
10.Remove and discard the bushings from the brake caliper bracket bores.
Carefully insert a small screwdriver into the brake caliper bracket bore,
then rotate and pull the bushing outward to remove.
11.Remove the brake pads from the brake caliper bracket.
12.Thoroughly clean the brake caliper bracket bores of all lubricant.
13.Install the brake pads to the brake caliper bracket.
14.Lubricate the brake caliper bracket bores. Divide the large packet of
grease, P/N 18046532; put one-half packet into each bore.
15.Lubricate the new caliper pin boots. Use the small packet of grease,
P/N 18046645, only on the bottom internal threads (2).
16.Install the new caliper pin boots into the caliper pin bores (3) on the
bracket. Carefully tap boots into bores using a deep well socket or
equivalent.
17.Install the caliper over the rotor and onto the caliper bracket. Ensure
that the caliper pin boots are not pinched.
Important :The leading caliper pin, or top pin, has a bushing as part of the
assembly. The trailing caliper pin, or bottom pin, is a solid design.
18.Install the new caliper pin bolts (1). It is important to note which
caliper pin is designed for the correct bore. The leading caliper pin, or
top pin, has a bushing as part of the assembly. The trailing caliper pin,
or bottom pin, is a solid design. Ensure that the bolt boots fit securely
in the groove of the pin bolts. Be sure not to pinch or tear the boots. If
the boots are damaged, they must be replaced.
Tighten
Tighten the bolts to 95 N.m (70 lb ft).
19.Remove the 2 wheel nuts retaining the rotor to the hub.
20.Repeat the above steps for the other side.
21.Install both the front tire and wheel assemblies. Tighten the wheel
nuts using the J 39544 kit.
22.Lower the vehicle.
Parts Information
Parts are currently available from GMSPO.
Warranty Information
For vehicles repaired under warranty, use the table.
b4z--I just had this work done on my 2000. No More rattling. (Ken)
Most of the truck based SUVs will have to be redesigned to meet new safety regs and because fewer people will buy them with gas selling above $2. That will take lots of retooling. If GM and DC go to RWD they will essentially cede the sedan market to the asian manufacturers, leaving them to duel it out with the euros for a minor share, not a likely senario. You can believe Lutz is listening to the cash register.
1. How can it take until summer for this model to be available when the supercharger has been out forever in the Bonny and Regal not to mention the upcoming GP. And they made essentially no cosmetics changes. Explain this to me Mr. Lutz
2. No major cosmetic changes. Not even HID lights to change the look from the LS. No three spoke steering wheel. Only the usual embroided logos and larger wheels.
3. Price - how can they expect to charge $3000 more for the SS. C'mon $32K for this package is a joke.
The sad part is that I still want because I love the Imapala look. However, you can add a dual exhaust tip and the 17" wheels to an 02 or 03 LS and walk away just as happy for a lot less. Or buy a used 1996 SS.
Just my 2-cents worth.
I have a rattle that developed about 1000km ago. I feel it in the steering, particularly when driving in the city. Sounds suspiciously like what you've described. I too thought it was the ISS needing another lube kit. Maybe I'm wrong?
Brad
The date will be shown in MM/YY, for example 4/01 for made in April 2001 and so forth. The sticker also tells you were the car was made. All Impalas are currently manufactured in Oshawa, Ontario Canada only.
If the sticker is missing from that location, reject the car as there is a possibility the car is salvaged or has severe accident repair.
I hope you didn't buy that overpriced Impala with accident damage.
E-mail me if you have any further questions.
You can purchase your GM Major Guard warranty until the car has either 3 years or 36,000 miles, whichever comes first. The warranty can be purchased at your local GM dealership or from reputable extended warranty sellers found in the Internet.
I do not recommend aftermaket warranty contracts based on previous experiences (Hassle to get reimbursed or approved for covered repairs, denied coverage, etc).
At least with the GM warranty you have assurance that your covered repair will be approved on the spot and hassle free.
Also, if you decide to sell your Impala before the extended warranty expires, it can transfered to a second owner for a small fee (Typically $35.00), thus increasing the resale value and appeal of your car to prospect buyers.
Before purchasing an extended warranty consider for how many more years or mileage are you planning to keep your car to avoid either buying too long or too short coverage.
The Impala is a car that has to be kept under warranty, period. Items such as the Intermediate Steering Shaft (ISS) and engine plastic manifold typically tend to fail outside of the 3 year new car warranty and are costly to repair/replace. I personally would not keep an Impala without a good and comprehensive extended warranty contract past the 3 year/36,000 mile mark.
Just my $0.02 worth.
In my caes, I got NO extended warranty, and now have 113,000 miles on my 2000. An extended warranty would have been a near total waste of money. The only repair I have had came right about 100,000 miles, and that was for a headlight switch.
You do understand that the prices of the GM extended warranty are negotiable, right? I know many people who have paid less than half the MSRP for the things.
We have only 7,800 miles on her so far. I am going to start leaving the 2002 guzzling Trailblazer home and take the 2K-LS once the nice weather hits here in the northeast. The only problem we had was the AMP replacement. We had the tick in the cradle but it went away by itself. not updated in awhile but here is is anyway
http://www.luckyjdr.homestead.com/impala.html
I am trading my 2002 Trailblazer ( gas price is killing me everytime I fill up ) for a 2003 Impala LS fully loaded in black. very sweeet looking car. Do you guys know if I should look out for anything with this car? Has it been refined enough that I can consider it worry free? Thanks for any response
However....
The Impala still has 3 teething points:
1)The Intermediate Steering Shaft (ISS) that loses lubrication prematurely and requires re-lubrication that could be expensive after the warranty expires. GM has not been forthcoming as to whether the ISS issues have been put to bed or not.
2) The plastic upper manifold intake in the 3800 V6 Impala engine tends to warp prematurely (Mine did at 18K miles) allowing an external coolant leak to develop. Dealer replaced it under warranty but if this happens outside of warranty, it is a $800+ repair.
3)Front discs seem still very prone to premature warping, but not nearly as bad as the Malibus were.
As for the rest you should be getting a pretty reliable, safe, comfortable and powerful car with excellent fuel mileage and nice looks.
I am selling my '01 Impala LS as I have fallen in love with another non-GM car. But aside from the warped plastic manifold, my Impala LS has been rock solid for nearly 20K miles. The car doesn't have a single rattle or squeak, feels solid and reassuring as the day I picked it up in April 2001 and the paint is glossy with not a single problem. The engine starts everytime..powerful, quite, vibration free a total treat. The car works like the finest piece of Swiss watch machinery. No electrical issues of any kind whatsoever.
Great car and since you are a Chevy aficionado, you should be happy with it.
I taught that you hated the Impala looks based on comments I saw from you a couple of years ago.
2002 TB's are wholesaling back-of-book by a couple grand. Unless you have a buyer or do a lot of miles me-thinks you need to re-do the math.
If it is just pure emotional love of driving a black Impala then more power to ya and enjoy the ride.
Right now the economy stinks and the few used car buyers out there are looking for outright bargains.
The constant stream of GM subsidized rebates and 0% financing deals on new Impalas, do not help the cause either.
I would say that the biggest downer about owning this car is the fact that people refuse to pay what the car is worth (Even way below used private sale retail) and they expect you to practically give it away because is "American" and is a "Chevy".
Pretty lousy stigma to contend with...
Now it is $2000. You ONLY get $3,000 IF you are entitled to the so-called loyalty bonus.
But stay tuned. Incentives change with competition. Ford is thinking about what its response will be. This may or may not change the GM deal...
Ironically, Edmunds has the correct information here on this site, wihle the Chevrolet website still has the outdated information. Let me say it again: There is NO $3000 cash incentive to customers for the Chevy Impala or most other GM cars as this is written. If you are a current owner, you can get $3000 which is $2000 plus the loyalty bonus.
But if Ford doesn't also reduce incentives, the $3000 may come back.
Both GM and Ford are SAYING they are going to reduce production and cut back on incentives but we will see.
Where did you see that $3000 continues after February 28? I'd be interested, especially since my customers would as well.
Incentives change frequently, sometimes as often as weekly. It is important to have up to date information. Also, remember, you must take delivery by the specified date, not just order or sign a contract for the car.
Otherwise the car is rock solid and is great to drive - can't help but love it.
Anyway, with the MFG warranty about up, I'm on the fence to get one. Some of the major stuff has come up on GM's dime, but I was wondering:
Is the tranny usually trouble free?
How often does that ISS issue come back?
We plan to keep the car at least 100k miles.
Any thing else I should consider or be aware of?
Also had the manifold/gasket replaced recently (at @ 46k miles); no idea how long that one will hold.
I also have the airbag light problem, but haven't been able to catch it "on" when I've got time to take it in (and computer apparently doesn't store a code for it). What did they determine was wrong with yours, and any idea what it would have cost to fix had you been outside of the warranty?
(I've had no tranny problems, BTW)
Since cars are meant to depreciate, I"m not very picky about little nuisances like the ISS or the engine hestitation. In fact, I think this car outperforms in quality and performance as compare to my brand new Accord EX V6 that I bought in 1995. It's so smooth and comfortable! I'm still loving my Impala very much. However, since I have $2500 left remaining on the car loan, I"ve been thinking about getting a MB320. That car is totally gorgeous! The only problem is that it eats premium unleaded. I don't think I can afford $2.25 a gallon for premium gas. sigh
getting the new intrument panel and brake caliper pin kit installed tomorrow. I have the rattling brake problem and the noisy tachometer.
My main complaint about the Impala is the suspension noise. Car and Driver called it a
"clip clop sound" I would concur.
I think that my next car will be a Lexus LS 400.
probably a '96-99 model. I truly believe that they are the best luxury car on the road today.
They should offer the L67 or supercharger as an option on the Impala. That would make a world of difference especially above 40mph... on the highway. The L67 only burns 1-2 mpg more then the L36. Only problem is that you need 91+ octane.. but for 2004 the GTP has been designed to run on regular 87. However to get the full performance you should still use 91+ octane. For 2004, they have added 20 horsepower to the L67... 260 now. Where as the Impala L36 3800 engine still remains at 200 hp. The funny thing is that a fully loaded Impala is about the price as a fully loaded GTP. But you are getting the supercharger with the GTP... making it the better buy !!!
I love my 02 Impala LS sport. The sport interior trim and body color rear makes a world of difference IMO.
I have not noticed any lag at 40 MPH. Are you sure it had the 3800 engine. Most rentals would be the base version.
The Impala will get the L67 in 2004. And it'll make the most difference off the line, not on the highway. It's a roots blower which means instant torque, not highway breathing. The M90's a wall!
HVAN3: A Mercedes MB320 (Pretty lousy truck in my honest opinion, but that's another topic)
B4Z: an used late 1990's Lexus LS400 (Lexus are good cars but they are far from being the best luxury cars on the road today...they are mainly isolating cushy mobiles).
COOKIE01: (Remember her?) She is going towards a new Nissan Murano
Me? I am getting a new 2004 MINI Cooper S for October '03 delivery!
So GM, the writting is clearly on the wall...you are losing customers because you have failed to keep the Impala refreshed and interesting in the face of such formidable import competition...and...the 2004 Impala SS is a nice try but TOO LATE!!!!
Why buy a 2004 Impala SS with the "old" 240HP Supercharged Series II engine, when you can get a new 2004 Pontiac Grand Prix GTP (Nicer looks, much superior interior design and materials, better handling, suspension, etc) with the 260HP Series III 3800 Supercharged engine for almost the same money???
Chevy we love ya, but you need to wake up!!!!!!!
As for me, I am looking at either a Mazda6 or a 2004 Grand Prix GTP. I am NOT considering the 04 SS AT ALL. Less hp and torque for more money than the GTP? Why?
The tachometer no longer makes noise. They set the
odometer to 35,962 miles on the new gauge cluster. so I had 600 miles magically disappear.
The pin kit has completely eliminated the rattling sound so I can now drive down the street without people on the sidewalk turning around an looking at me as I pass by.
My dealer has a large service department and this is the first caliper pin kit that they have installed.
I still have a little movement in the suspension parts on bumpy roads but no real noise.
Thanks "sunsession."
I guess GM has replaced a lot of ISS's and cradles unecessarily.
But you can't go wrong with a LS400, that's for sure. I personally find the current LS430 sedan garish and repulsive looking. the LS400 was and continues to be what Lexus is all about.
John:: So Cookie bought a Mazda 6...wow! good for her. Still this proves my point that GM fell asleep with the 'immediate' sucess of the Impala during its first years and let the car run stale with very little substantial upgrades, et al.
I am sure you will be a happy camper on either GP or Mazda 6....how about the '04 GTO? Do you have to have 4 doors?
I am also a Realtor so the type of car that I buy has to meet certain criteria.
Plus there is no one in my family under 6' tall.
There are not many vehicles out there that cover all those bases for 21K.
In fact the Impala may be the only car with the amount of passenger and trunk space that I need.
Has anyone else had this happen. The brakes work fine. I just wonder if this is a problem.
I came across a 1999 ex-opp white Lumina for 5 thousand Canadian. It has the 3800II, 4t65e transmission, recaro seats, stiff suspension, H rated tires(max speed 130mph) and the odometer says 147k km (92k miles). After taking it for a drive last week I found no apparent flaws such as pulling to one side, engine whine or rough shift points. To my surprise when I check the dipstick for the automatic transmission fluid, it is showing bright pink fluids which indicates the fluid is fairly new.
What advice would you have for this situation? The price is right and the car is in relatively good shape, I know it would be hard pressed to find a late model vehicle in the 5000 dollar (CDN) price range, and this one has the 3800II in it which is a big plus. I have always enjoy the power the 3800II outputs, and its smoothness and reliability. Anyways, I would like to take the car home next week unless somebody comes with a convincing reason for me not to.
This is my first time car shopping, I would appreciate any suggestions and comments. Thanks in advance.
Basil
