But my problem NOW is a rattling coming from the windshield when I hit the slightest bump. Taking it to the dealer this week.
Also, anybody else find the headrest leans forward a bit too much? I pulled mine out and put it back in backwards.
Value is comprised of more than just features for the upfront money. -soothsayer4
I have a 2002 RAV 4 with every option except leather and ABS.I have sprayed silicone in a few places where plastic meets plastic - and have no heard another thing.(it's been 3 months since I sprayed between pillars, and around base of windshield area)I also coated all of my rubber door gaskets with silicone spray, to help preserve and extend life.
Here is a question.Where should I look for the net
that goes across the mid-region of vehicle to prevent stuff(or my dog from coming forward?)Is it stored in back /underneath ? Thanks
are best ?
I also wonder if there are any TSB for rattle sound from the sunroof when it is in the tilt position. I hear it in low speeds as I mostly drive it off the highway, and last tiem I asked at the dealership they said it was just wind noise and that I should buy a spoiler or shield and put in front of it.
Finally, I wonder how the hell the hard tire cover is constructed, when it can come off even if it is locked using the hinge on the underside of the tire. It happened to me at a manual carwash, and the cover got all scratched as it completely fell off. I couldn't for the world figure out how the hell it could have come off with the higne intact, when it was locked? I took it to the dealer, and he helped me put it on. Only thing we could see what that the latch thing at the 1 o'clock position had not attached to the cover, so the cover was 'loose' for about 7-8 inches at that area. Anyone else having had this problem?
Thanks...
You might be interested in the Are SUVers Unpatriotic? discussion! :-)
In the last gen. CR-V, the rear passengers get "pull out" cupholders from the doors. I would like to see something like that on the RAV4.
The 2003 RAV4s have $1000 factory rebate on some L and S packages.
Below is the link to my dealing on the purchase of my RAV4.
http://www.ravworld.com/board/viewthread.php?tid=312
Had the rattle from day one on a 2001 (bought Nov 00) Rav. The first time, dealer said that other Ravs had the rattle and they would call the Toyota Tech line to find out what the fix was. They did the first fix, but the rattle eventually came back (not as bad, but still annoying). Then, I took it back (about Nov. 01), and the dealer said that Toyota had a new fix for the problem. They put on a new cowl and did some other things with the cowl area per a new TSB (Technical Service Bulletin) from Toyota. It has been PERFECT ever since. I would ask them to call Toyota tech line to get the latest TSB, and make sure they do it. Otherwise, go to a different dealer, because some dealerships are not just no good. This can be fixed. It could be something else rattling, I guess, but just "turn up the heat" on your dealer or go to another.
Good luck!
My RAV-4 PROBLEM : on S.F. Bay area, there is Hywy-24 from Oakland to Walnet Creek& IT has some section of VERY rough surface freeway with speed above 70-75 mph : Very Bounpy (Up & down motion on freeway speed on rough surface & on bad bumps : it seemed like no shock absorber that impact force to those bad bumps is like crash impact + floating motions *, all these add up to made the RAV-4 VERY UNSTABLE & Unsafe & feel like riding the horse.
I have driven cars for 30 years, and I have driven the same Hywy 24 everyday to commute to work (95 miles per day) for 9 years. My other cars like 93 Honda Accord, 94 Acura Intergra, my former cars : 84 Maxima & 83 Civic + 74 VW Beetle had all driven on Hywy 24, and I never feel such horrible bounpy experience.
Any one can tell me how to fight to get dealer to solve that problerm & complaint to the
consumer protection agency for lemon car ?? What is the website for those consumer affair/ protection group ? I had visit the City Toyota- (DALY CITY)dealer servie dept 3 times & wait there for hours & got turn back for that is normal, "just got use to it "!!
It won't take you any time at all to get used to - take one for a test drive. Gas mileage - 25.3 mpg winter gas, 70% highway miles. As for the so called "bouncy" ride - I have no complaints - slightly more bouncy than a sedan, but it is a small SUV. I test drove it a lot before I bought it, and thought it was fine. Tire pressure may be too high? Other than that, it is normal!
If you are not satisfied with the dealer and you find yourself out Walnut Creek way on a daily basis, try using Walnut Creek Toyota - their service department is the best in the Bay, bar none. Plus they are open until midnight in the week. But you may find that your vehicle is truly operating in the manner it is supposed to.
RAV4 tops the list for Small Sport Utility Vehicles in the most-recent Consumer Reports listing, edging into the excellent column on the bar graph (the only one of the 13 compared to do so).
It is a paid-subscription site, and I don't want to try to link it, but the magazine can often be found in local libraries. I'm not sure what month's issue it is, but they are pretty well-indexed for preceding months in the back of each issue.
You could even (gulp) buy a copy.
There are a lot of people here on this site that berate CR, but they haven't come up with any better source for such info. So, you guys, please hold your fire. Thank you and god bless.
