I have become rather obsessive with checking the level in our 98 Trooper (3.5L), and my wife thinks I'm nuts. But I would rather check too often than not often enough.
We had a 96 Trooper (3.2L) and it consumed a fair amount of oil. I don't remember off-hand, but believe it was quite a bit more than 1 qt/3000 miles. My impression was that the 92-97 Troopers (3.2L V6) did have oil consumption 'issues' in addition to the ticking/valve lifter/etc. problems.
However isn't the TSB (assuming there is one) only going to note the symptoms, state to replace the gasket, and give the new gasket part number? It is not going to list the replacement steps is it? My limited understanding is that the only way a TSB would list any maintenance manual steps is if the original maintenance procedures are wrong and they are being updated.
Where do you think a good place on-line would be? I went through a quite a few, and none of them had just the lens (some had the entire assembly).
Sam
www.car-parts.com
What is the impact of this coming loose? Dirt, water, salt, etc. can get on the plunger. Are these boots "nice" but not entirely required, or should expect to have some shock issues down the line?
On a related note...can you jack the truck up (using a shop jack) by the rear differential if I want both rear wheels off the ground? Or do I have to go side by side and use jack stands?
Does any one know what that code is. BTQ, the error disappeared now, but, it is too early to say.
Sam
I would have the transmission fluid checked/service replaced at this point.
Good Luck.
I hate that code
John
Don't know if it works on our Troopers, check it out.
http://www.davisnet.com/drive/products/carchip.asp
I'm worried about the old plugs not coming out easily, breaking off, etc.
Is there anything I can do to increase the chances that the technician is able to remove the old plugs easily? I was planning to discuss my concerns with the manager, in hopes that he tells the tech to make sure he/she is careful. Is there any lubricant I can spray down the wells to help loosen the plugs? When would I do this - right before dropping it off, a couple days before, etc.
Sam
Didn't talk to the tech, but the advisor said the tech didn't mention having any problems doing the job.
Unfortunately, I didn't get the Champion double platinums installed as I wanted. The shop uses Bosch and I didn't feel like explaining to the guy that I wanted something different, and why. Plus that surely would have cost me more since they would have had to pick them up somewhere. I made sure they did NOT use the Platinum +4 since folks have had trouble with those in the newer Trooper. He said they'd use the "twos" or "plus twos" or something like that.
Total was only $87.12, including tax and shop supplies. Seemed pretty reasonable, especially since his phone quote the other day was $100-110 and a Honda dealer quoted about $170.
http://www.directhits.com They have a custom fit kit for the Trooper and it is important to use low resistance wires with it, included in the kit.
My 1995 Trooper went from 9.9MPG and having a hard time (the engine sounded strained) pulling a 4000# trailer to 11.2MPG and it pulls smoother(the engine sounds confident with power to spare) and can stay in a higher gear. The MPG wera tested on multiple trips so it was definately the DirectHits. Around town my Trooper is a little more peppy.
I too have heard that the Bosch+4s are very problematic in Isuzu service. I don't know about the Platinum2s. However I remain very skeptical about any multiple electrode plugs. My personal theory, FWIW, is that what you want igniting the fuel is 1 very good spark not several ok ones. Just my $.02.
It might be worth checking to make sure the shop actually installed the Bosch plugs specified in the Bosch catalog. Just call a local parts store that stocks Bosch. Make sure the part number they tell you matches what the shop says they used. I know this sounds like super overkill, but given your recent luck with maintenance jobs it may not be.
I tried to get Bosch spark plug part number info on AutoZone's web site but it wasn't there. Maybe I'll give them a call. The paperwork I received has a 6 or 7 digit number, but I'm not sure if it's meaningful (i.e. Bosch part #) or meaningless (internal Firestone part reference #).
I haven't noticed our Trooper smoking from the exhaust but probably should look closer.
The repair manual shows the rear diff to be a "lifting point" and even a drawing of a rolling floor jack with a large lifting head placed there. For safety reasons I certainly wouldn't use a small headed jack (e.g. the Isuzu jack or a cheap low capacity floor jack) there. It would be too easy for the jack head to slip off.
I have a good hydraulic floor jack, next time I need to I will try using the differential. Though it scares me to even climb under and put a jack-stand underneath when it is jacked up. Something I guess I need to get used to. But it doesn't hurt to be safe.
Thanks for the response.
Glad to hear you use stands to support your vehicle instead of just relying on the jack.
This would tend to support the EGR link to high oil consumption. Namely as the EGR plugs off the flow of recycled exhaust is restricted. This causes higher combustion temperatures and in turn more carbon formation.
Those of you that have done the EGR cleaning may have only addressed part of the problem. The oil rings may still be at least partially carboned. You might consider a bottle or two of Techron cleaner to see if that helps reduce your oil consumption.
Just my HTH $.02.
The Deuler's have been really good around town, traction and ride. The highway is decent, very quiet, however I expected them to perform the same as the stockers if not better based on reviews. The have a little vibration at highway speeds...50-60, above 60 it isn't really noticable. The tread is agressive and everything I read about A/T tires pointed to this, however some reviews rated them better than the H/T's for highway ride.
-mike
255/70R16 weigh 33lb. tread depth 13/32
245/75R16 weigh 40lb. tread depth 15/32
265/75R16 weigh 48lb. tread depth 16/32
285/75/16 are heavier tread depth 17/32
tire sizes
http://www.bridgestonetire.com/dpp/sizespecs.asp?passproductid=10- 55
tire description
http://www.bridgestonetire.com/dpp/glamourindex2.asp?passProductI- D=1055
Technology tutorial
http://www.bridgestonetire.com/tech/index.asp?id=tech_unitAQII
-mike
I went with an LT to help counter the occasional off-road abuse. I drive 80% highway and do not mind the stiff ride. Most of the changes in driving characteristics are minor. My wife cannot tell a difference when she drives the Trooper. Well she does have to "hop" into the truck now, but that's another story.
Lee
I chose the P series deulers due to price, most of my driving is onroad, and most of my offroad is sand/dirt oriented.
-mike
I was also contemplating between Michelin LTX M/S, Dueler AT, and some low price Firestones. The Firestones might have been the real deal at $84/tire and the tire saleman said they were a much better tire than $84 but were priced at that level because of consumers resistance and perceptions of what happened with the Ford Explorer.
The Michelins were almost $70 higher/set and the Bridgestone Dueler AT's were $2 cheaper/tire. It was a tough choice between the 2 Bridgestones and the Michelin and I ended up with the Dueler H/L's.
I went one tire size larger - 255/70/16 and had the white lettering side showing. This tire is a little bit taller and a little bit wider than stock really looks good on my Trooper.
I drove my Trooper into the tire shop with practically worn out Bridgstone 684's that had some vibration due to my neglience to rotate the tires often enough. All 4 tires were worn down below the wear bars and the inside edges on all four were badly worn well into the rubber. The front-end was slightly out of align with a small amount of toe in. But, I had been out in the snow and ice with them in TOD and did not have any problems, but I knew I was taking a chance on sliding out of control or having a blowout so I was especially careful. (But, it was fun doing 360's in deserted parking lots during the snow :-) )
Upon taking my Trooper out for its first spin with its "new shoes", there was a NOTICEABLE difference. The larger tires did have a 'heavy feel' steering and the ride was noticeable smoother, and acceleration seemed noticeably sluggish but not a problem. There is still some road noise from the tires on an asphalt road going home but not as much as the 684's.
For those of you looking for tires for your Trooper, you might want to consider a larger size. I now wonder what a Trooper with 265/70/16's would be like. Paisan has the 275's - and those must really be awsome.
Looks wise, the 255/70/16's is all positive. Handling seems better but a little 'heavy' but I like that feel. Could it be that the 255's are a much heavier tire? Like I mentioned, acceleration seems slightly sluggish than before. When I first got in my Trooper, believe it or not, but I immediately sensed that I was sitting a little taller in the saddle - just a fraction of an inch is very noticable.
MB1 oil change (I supplied the filter - Isuzu)
Front/Rear disc overhaul (I supplied Isuzu pads)
Tire rotation
flush & fill brake fluid
price paid w/ NJ 6% tax - $233.68
The beautiful thing was that I did not need to have the rotors turned/cut or replaced. I have never had any brakes last this long on any auto I have owned. I feel a little lucky. Cheers to all!
