First of all, I want to say that it is GREAT to find a Trooper forum running around out there. This forum was quite difficult to find. It’s a great pleasure to meet you all!
6 months ago, I purchased a 1991 Isuzu Trooper 4x4 5 speed manual Trans with a 2.8 litter 6 cylinder. The truck it in excellent condition! It’s the beautiful color of red with nearly perfect interior with no dents or scratches. When I first purchased it, I went out of my way to have a bunch of stuff done it to make sure everything was up to par. I changed all fluids. I.e.: oil, manual trans fluids, flush and fill coolant, engine flush, fuel system flush, break fluid, AC, etc I also had the breaks done all around, new tires, new ac compressor end dryer, shocks, and tune-up with new plugs/wires/roter/distributer cap. I look at all of this as to be preventive medicine. Always better to be safe then sorry.
I do have one problem though that maybe you all can help me resolve. I live here in Denver Colorado. And being in the mountains, there are its challenges when running up and down in the hills. The problem I have is horse power. Not to long ago, I brought my children up in the mountains to go camping. We had a blast! It was the first time I was able to run my truck in four wheel drive! It went everywhere anyone else could go and much more! I was really amazed by its performance! The unfortunate problem I have it when the truck is running high end. When I shoot up into the mountains via the highway, I’ll hit around 65 mph. Once I start to hit any kind incline (and the incline doesn’t have to be much), my truck starts to bog down. I will be going 65 mph in fifth gear, and then I will have to work down into fourth, and so forth. My truck holds up great in first thru third gear. It is nice, but I find myself holding traffic back because I am not able to increase my truck speed up “any hill” at fourth or fifth gear. I am boggled by this. Could it be a sensor of some sort? Oxygen or Map sensor? Everyone tells me that my truck is just old, and I will just have to deal with it. I do try to keep that in mind, but when I’m running up any kind of incline or inner city hill, and see a U-go (however you spell it), or an old Datson passing me bye, I have to wonder if there is maybe a problem here. If there is anyone out there who can help me in anyway with this, It would be GREATLY appreciated . Oh, and by the way, I have so many people come up and ask me about my truck. They've never seen one in such great condition! There doesn't seem to be any nice ones running around out there these day! It's to bad, I love my Trooper!
Maddy :sick:
One owners opinion. Good luck.
Does anybody know how/where I can get replacement parts for this - used is fine? Has anybody had a similar problem? This seems very odd to me... Any comment is welcomed!
The light comes on about 10-15 minutes into the first drive in the morning. If I stop for coffee for five minutes witht he engine turned off I get back in and there is no check engine light. But as I begin to travel down the road a few minutes later it will come back on.
Thoughts --- by the way I am not a mechanic so advice in laymens terms would be appreciated.
I too, have the same trans. light issue. Mostly, this winter
when it's colder. Coming to a stop I generally can hear a faint click, the light wil come on flashing, and the trans remains in high gear. after turning off and restarting, the gears return to normal. I have taken the truck in and have had 0 luck with diagnostics in the past. Have you had any success finding out the problem / and solution. Please let me know.
Thanks Mike
Did you ever figure out a way to get the front turning assembly out on an Isuzu Troooper 98-2002? I am afraid if I pull any harder, I will break it. I did take out the screw on top. I read the answers to your message that there is a plastic stud in the back of the assembly going into the fender. Did you find a special tool to use? I tried a plastic spoon to pry it out and the spoon broke! I am considering taking the Trooper in to the Isuzu dealer as I don't see any alternative. Seems silly to have the dealer change a lightbulb.
Gary
I used a local garage since they quoted about $300 less than the dealer ($850 for both water pump and timing belt at dealer, about $550 at the local garage.) I consider this garage to be reasonable, not rock bottom, just reasonable. But I'm satisfied with their work and comfortable with their work.
I think you got a real reasonable price considering what has to be done just to get to the belt assembly. It took me the best part of 6 hours to do it myself, start to finish.
I have now replaced the alternator, battery, starter along with the above, but I still like the vehicle. The engine is noisy though. I had hoped it would quiet down a little with the belt change, but no joy there.
I like the Acadia/Outlook for a 7-8 passenger alternative, but don't think I need to replace the Trooper with that and have 2 high end vehicles...so, I might get a pretty basic Envoy (have seen them advertised for $22K) and look at the Acadia/Outlook when it is time to replace the Envoy XL. Not ready to jump on anything right now.
The Auto show is going on here in Michigan now, and there are some really nice deals out there right now.
Thanks for the info on your trupr.
We usually only haul a big load or more people on vacation to the Gulf coast. I have a 5'x12' trailer for big loads or dirt/mulch...got that when I went from an S10 to a SUV. So while I like a larger vehicle, I don't really have to have one.
-mike
Also, I'm usually pretty good at figuring out what things are used for, but can anybody tell me the purpose of the 1 inch wide, half inch high half inch deep depression on the bottom lip of the instrument cluster?
It's directly beneath the fuel gauge. The only thing I can think of is it could be a placeholder for a PTT microphone for a CB, or some other accessory that glues into the opening. Any ideas???
Not a big problem I know, but stuff like this bugs me. :confuse:
-mike
-mike
when you hit the incline -- everyone in the car needs rock back and forth -- in unison of course. the momentum should keep you moving forward.
or you could move to KS like I did...
I had an '87 back in the day and we'd go from Denver to Craig once a month and trust me getting passed by semis' was the norm..
I'm looking to answer a couple questions today while my parents' Trooper (a vehicle I owned for its first 7 years) is being evaluated at a local independent shop.
1998 Trooper with TOD, approx 130k miles, good mechanical condition.
1. Does the following sound like a transmission problem?
2. If so, what if anything can be done to fix the problem?
3. How much would YOU sink into trans work on a vehicle that is probably worth $3,000-4,000 tops? The body is in decent shape but there's a small dent above right rear taillight and some rust under the bottom of the rear window. Interior - everything still works including the 6 CD changer and the cloth upholstery is in really good shape for a 9 year old vehicle.
BACKGROUND:
Few weeks ago, Dad has Trooper transmission serviced. I'm not 100% sure, but I believe the shop did a power flush blow out old fluid using a machine, etc.) against my recommendation. Only prior trans service was a drain adn fill around 70k miles.
Past few days, Mom reports vehicle driving funny. I drove it briefly on Saturday, and there's definitely something wrong. Vehicle lurches accelerating from 20 to 40mph and at higher speeds, says Dad. Also notice a pretty loud whomping recurrent noise from rear axle/wheels. Not sure if this whole thing might be some sort of brake issue, or multiple issues (seems unlikely), or what.
Thanks in advance for the help. I really love this truck even though it isn't mine any more, and I'm hoping it can be made right without breaking the bank.
Mode switch for more details. The loud thumb could be the Slip yolk needs some grease. Slip yolk is part of the Drive Shaft assembly. Hope this helps and Good Luck
I'll wait and see if that is the only problem; shop is replacing plugs and wires today, charging my Dad only $190 for everything including the labor to investigate the problem. This seems like a really reasonable price.
I'm still concerned that the trans power flush could have caused some issues -- not sure what, if anything, can be done at this point to reduce chances of trans problems caused by the power flush.
Instead of pulling transmissions, maybe Aamco will come out with a balloon gizmo - angioplasty for your tranny. :P
-mike
what should i do
the lights come on and everything else works but the truck wont start
somebody help me please
I have felt this engine/transmission braking a number of times on a downhill slope.
I don't know if this would have anything to do with your trans. error light when towing.
Does this happen when you are towing in D (overdrive)? Many times it is recommended to tow in 3rd expecially if you are towing a 'load' nearing the capacity of the vehicle.
Trooper IIRC is rated at 5000 lbs with load distribution hitch or 3500 with a standard class III hitch. How much are you towing?
Bill
thanks in advance for any replies...
I have a 2001 Trooper with 101K miles on it. it's been running great and I just had a few 'routine' maintenance items taken care of.
spark plugs
air filter
fuel filter
pcv valve
timing belt
water pump
serpentine belt
egr valve
so, I'm driving home today and everything is fine. I have a 20 miles commute that is a mix of highway and side road. I exit the highway and have approx 1 mile left to get home and the check transmission light comes on. Also, when I press the gas pedal I heard and clicking sound coming from underneath and could no accelerate past 30 mph.
I made it home and parked it in the driveway.....
And ideas/suggestions would be greatly appreciated.
Rich
I'd still like to try and find out what is going on.
I am interested in installing a Pure Power cleanable permanent oil filter. Their web site doesn't have any trooper-compatible filters. But there is a model designed to fit the Ranger.
I believe if you use 3 instead of drive it starts in LOW, then second and tops out at 3rd but does not go into overdrive.
I've got a Hidden Hitch brand aftermarket hitch, class III. It is rated at 5000 lbs with weight distribution system, 3500 lbs without. I think I remember seeing another model that may have been rated at 5000 lbs without the weight distribution setup. I think the Trooper will handle the 5000 lb rating without a problem.
I have found the Trooper with the way the rear axle is held solidly in place makes a very stable tow vehicle.
