Isuzu Modifications/Aftermarket/Accessories
17810121340
  • duktrooperduktrooper Member Posts: 78
    I noticed my handling(in and out of curves) suffered a little after adding OME springs and cranking torsions. It seemed as if raising the vehicle's center of gravity definitely had some effect. I definitely noticed it which makes me wonder if one upgrade always leads to another(ie, Calmini sway bars or Sway a Ways).
    Anyway, I'm still real happy with OME lift and all other ride characteristics it provides.
    Hi Mike-
    like a few others, am anxiously looking forward to arrival of ECB nudge bar. Will they be providing an installation guide of any sort or can you help offer some details(ie, ECB for Dummies) on that? I want to be ready when that thing shows up. Thanks.John
    When you upgrade to the OMEs it will raise up the height which will lead to slightly more instability w/o adding the calmini sway bars. You really don't need to worry about having softer front torsen bars compared to the OME springs because the OME springs are progressive rate springs, which means that they only stiffen up as the load is increased, for example, if you put nothing in the back of your truck, they will not be any stiffer, but if you load it up with stuff as the back moves down, it will become stiffer causing less sag.
    I will likely go for the calmini sway bars eventually.
    Tonight I cranked up the Ranchos from 3/3 to 5/5 for a ride. 5 is way too stiff for on-road stuff, although I may try 4/4 just for the heck of it. 3/3 is nearly perfect though.
    -mike
    I just got word today that Tony over at ECB has the orders for the 98-01 Trooper bars ready and they shipped out yesterday, which means that you should see em in a week. The 92-97 bars will go out next week cause he needed to fabricate them and prepare em, whereas the current model ones he has on the shelf.
    Installation is easy, and the directions are near perfect. The hardest part I found was getting a good sledge hammer and cold chisel to get the weld-nuts off the frame. The second one I installed was much easier than the 1st time.
    Basically you un-bolt one of the bolt holding the front sway bar bracket in place and knock off the weld nut on the frame, then you bolt on the bracket for the nudge-bar. Once the brackets are in place but not tightened up completely, you bolt on the bar, level it, and then tighten up all the bolts. Should take someone who is a non-gearhead like myself about 1.5hrs from start to finish.
    -mike
  • sahara111sahara111 Member Posts: 51
    Tom,
    You're absolutely right - the last thing you want is a mushy set of taller springs or taller torsion bar. If you're going to lift, even just a bit it is worth considering going for a firmer, safer torsion bar up front to go with the OME coils in back. The OME coils and orignal torsion bar, in my opinion, are NOT well matched to each other. But then again, it was obvious the original torsion bar was too weak the first time I had an emergency stop from about 30 mph - the whole front end dove WAY down - enough to scare me.
    My '99 Troop now has WAY less body roll, sway, etc compared to original equipment. It now corners like a champ - even though it now sits about 1 and 1/2" taller than before. In fact, I had originally considered doing the sway-bar thing too - but this is no longer necessary with the equipment I have now. This is due to superior, more robust equipment. There is no magic here.
    The only thing I may consider - once the issue of "squeaking" is cleared up - is maybe doing the bushings as some of you have. But again, my vehicle now corners, handles hard acceleration, hard braking, and high speeds so well now that I'm in no hurry.
    Good luck on your decsions.
  • sdc2sdc2 Member Posts: 780
    Refresh my memory - you have the Sway Away torsion bars? Or are they Calmini? Can't remember...
    I did notice more body lean after I put the OME springs on, but that's simple physics after raising the center of gravity 1.5".
    Now I am contemplating Calmini sway bars, but you have me interested in new torsion bars instead...what do you think?
  • lovingpclovingpc Member Posts: 34
    I wish it were easier to "view all" posts and I could search for roof rack discussions, but I can't. Anybody have a positive experience with aftermarket racks for 2000+ troopers (with sunroof)?
    I'm not crazy about the Yakima/Thule looking racks that bolt on the frame, and would like a "stock looking" rack that sits on the back half of the roof. My primary use would be cargo hauling, probably one of those aerodynamic luggage tops.
    Any thoughts/reccomendations?
    Andy
    on http://isuzu-suvs.com if someone on here gets ahold of some good info on roof racks. The only ones I've found are either basket types or the Thule types. The OEM ones I've found are all from UK, Aus, or Japan.
    -mike
    I'm wondering the same thing.....which will be the best for improving lean and handling, especially in cornering situations. I'm also using the OME springs and while I love the lift effects, I want to offset some of the added lean I gained with the lift.
    Sahara, did you add front and rear Sway a Ways or just front?
    I should have a good rec. on roof racks to post tonight for those who like the Landcruiser style. I put one on a month ago....sharp looking...just can't remember brand, model#.
    Also don't forget tonight @ 10-11pm EST Owner's Chat!!!!
    -mike
  • gpm5gpm5 Member Posts: 785
    The seats on the '99 trooper S do not provide much more in the area of lumbar support (i.e. nothing adjustable). I have not taken my trooper on trips of more than 2 hr so far but the seats have not bothered my back for that length of time.
    I recall someone posted once a while back about the Proline racks. These guys are in CT and apparently will replicate any stock rack at no extra charge. Their racks are between $100 and $150 and seem like good deals.
    see them at:
    http://www.prolineracks.com/roofpermanent.html
    Okay, one more time:
    I bought and had installed new Sway-A-Way brand Torsion Bars - which are only used on the front. The current Trooper uses torsion bars up front (not coils, not leafs, etc...). Torsion bars may be an "old" design - but it has the clear advantage of being able to quickly raise/lower the front end as needed, including compensating for more weight. I also put on the OME progressive coils for about a 1.5" lift. Along with these I have installed the OME shocks, part numbers N15 rear, N65 front.
    I spoke with 2 different tech reps before deciding on the N65 front - which is the firmer option - and they both told me I would be much happier with the more controlled, firmer ride even though I do NOT currently have a heavier front end (bull bar, winch, etc...). And they were right - the truck feels VERY sporting now and certainly corners fast enough for any sane person. This, after all, is NOT a sports car.
    This combination - firmer shocks and a stiffer torsion bar - has overcome any body roll, sway, nose diving, left/right back-n-forth mushiness problems of the original equipment - in spite of being about 1.5" taller than normal.
    I personally did not want to mess with replacing the sway bars - and now I don't need to. Remember, sway bars won't do pee for you when it comes to hitting bad bumps, holes, carrying lots of extra weight, off-roading, etc. It won't help one bit.
    However, if your number one priority is "cornering" - in a 4500 lb SUV - then I strongly suggest you have the vehicle LOWERED (via shorter, custom springs in back) and ALSO have the new Calmini sway bars, and bushings, installed. Also, you'll really want to also do a wheel and tire upgrade. After all this, you may have a serious "cornering" SUV.
    Again, I would do everything again just as I have - except skip the Edelbrock shocks!!
    SDC2 and duktrooper - which shocks do you have on now?
    I recently invested alot of time in looking at roof racks both online and at truck\accessory stores. I stumbled across a local dealer who told me he had put on a "landcruiser" style rack on a Trooper and it came out really nice on mine. I am calling dealer back tomorrow to get brand name but here's what I can tell you.
    Price was 189, pls 60 to install. Model # is ASB 4460 and I think the brand name is Dynstar or Dynostar. Anyway, the quality of material and look is vast superior to any of the Perrycraft brands most places sell. It is an extremely lightweight but strong aluminum frame(no plastic) with four stancions(sp?)on the corners. Wgt.limit is 150 lbs. The closest thing online I've seen, though not nearly as nice is the "winnmaster" under the roof rack section at the "prolineracks" website. My model has thicker dimension runners and cross bars, like that on a Landcruiser, for a more rugged, beefier look.
    One of these days I'm going to figure out how to get pics of my vehicle posted...hate too admit it, but I don't know how. I'll post more on this once I get the other details. Net/net...this is by far the best looking rack I've seen of the 12-15 styles I looked at. HTH. John
    How does it mount? I guess it would be too much to ask to have it bolt into the existing threaded holes under the rubber strips...
    Appreciate the low down on the torsion bars. Sounds like its a more effective and economical upgrade than Calmini's. It's moved up on my list.
    I'm still using Edelbrocks.....just can't make up mind between 9000's and OME's, though I still lean towards OME's b/c I like the "matched/tuned for vehicle" story. I also realize one can't go wrong with 9000's either for adjusting, value, reliability, etc. What were the biggest differences you noticed in switching from IAS's to OME's? Thanks. John..
    Hey SDC-
    rack mounts just inside the gutter line, with 3-4 screws per stancion. Fit and finish is excellent. Width is 38" across and legnth is 50" I believe. Dlr told me rack should NEVER have problem with a leak. You can still add Thule or Yakima cross bars or adapters if you need that kind of stuff as well.
    Go on line to " prolineracks" and look at the winnmaster and you'll get an idea of style...only this version is much more of a rack with better lines and wider profile rails and bars. Have gotten many compliments on it; it really finishes off the truck nicely. I'll contact my store today to get more info. and hope to get pics posted soon.
    Thanks for the recap, I know you have described this before, but could not remember.
    Currently I have the Old Man Emu shocks and springs. I think I have the same #shocks as you do.
    I'm going to go look at torsion bars now... :-)
  • trooperbrecktrooperbreck Member Posts: 2
    So which sway bars do you have? Also, does any one have experience in Calmini lifts?
    Disregard the last post. I didn't see the previous postings, its early and I haven't had enough coffee.
    The '99 Trooper Warranty is now posted up in PDF format. http://isuzu-suvs.com
    -mike
    I confirmed today that Calmini does have sway bar sets in stock for late model Troopers. Price is $289 for front and rear(total, not each) and includes bushings.
    The site of the mfr for my roof rack is below. The series I chose was "Activa" part ASB 4460. They have some pics and diagrams. I can honestly say it looks better in person and material quality is very high. HTH.
    http://www.sportrackaccessorygroup.com/home.html
  • teacherjimteacherjim Member Posts: 52
    I got my Rancho 9000 shocks installed today!. My 2001 Trooper has 4,000 miles and it rode allright but had to much bounce over bumps and highway joints. The new shocks are wonderful!, much less bounce and a much firmer feel. I think the ride is much better than before. I set the shocks at position 3 and thats where they will stay. I bought the shocks for $55.99 each from Hot-Rod offroad, shipping was $20. This was a mod that makes the Trooper feel much more stable and I recomend it highly.
    John, when moving from IAS to the OME shocks I noticed:
    1) Physical build - OME is much beefier, has a thicker piston rod, is welded at bottom, and - looking at diagram of internals - apparently has a much nicer valving system. Keep in mind the history/background of OME and what their equipment is designed for from the get-go. There is NO comparison between these two shocks.
    My decision for OME vs. 9000 was easy. I was aware of the OME top notch reputation, and, had heard slight negatives about the 9000 - even when set at "soft" settings it was still not smooth (but opinions may vary...). Plus, it only made sense to have a spring/shock combo that was designed/matched for each other. Finally, I knew this particular application is used a LOT in Australia so the product is proven. But nothing against the 9000 - it also seems to have an overall good rep, and seems to be rugged and reliable, and is used practically everywhere.
    2) Shock reaction - In spite of the fact the IAS are advertised as being "smart", i.e., sensing when to firm or soften up - the OME seem to be even "smarter" and react just enough at just the right time. They even seem to stay softer at very slow speeds over bumps, etc, but then feel like a sports car setup when cruising the interstate at 90 mph (like today....oops!).
    3) Shock firmness - the IAS, when they go to firm mode, were probably too harsh especially in front with the new Sway-A-Way torsion bar, although I remember this effect with the original torsion bars also. On the other hand, they never did match real well with the rear coils - because they seemed to be affected by the extended length (not designed for that....) and the fact the first part of travel of the OME coils is easy/soft until it compresses just a bit. So the IAS in the rear seemed to not work well, like they got confused; I would still get a little pogo-ing (sp??) from them.
    Not so with the OME - the front is actually softer (but still firm); the rear slightly firmer - both front and rear are now very well matched and the vehicle is even more controlled now, actually very well controlled.
    4) Dampening - again, the OMEs win in this situation/setup. In most cases, I do not have any secondary bounce. On severe bumps, dips, etc, there is an occasional, small, secondary rebound from the shock. This was not the case with the IAS - I routinely had more secondary rebound than I wanted, and the rare tertiary rebound was not so rare.
    Three weeks ago I dropped a work buddy off at an appointment after a 15 mile ride. He had not been in the truck since I put everything on. He was amazed at the ride - described the feeling as being "on rails" - with no mushiness.
    The ride of my Troop is now best described as sporting, firm, controlled, and safe - it is NOT luxo-boat soft - but it is still quite compliant. I keep wanting to say it's "smart" because it seems to always do just the right thing. I think after awhile most drivers, including men and women, get tired of the overly soft, rolly-polly, lean-to-the-left, lean-to-the-right ride of most stock SUVs - not to mention the concern with rollovers. I can guarantee you I don't have any of that now.
    Finally, I like this setup so much that I am now planning to repace the Downey Offroad 3" lift coils and Bilstein shocks on my '92 Landcruiser with the OME equipment. It's that good.
    Does this help?
  • twnisbetttwnisbett Member Posts: 11
    ...for your post. Generally, if I drive for less than a couple of hours, it's not a problem. But, I often drive my '92 for 3-6 hours at a time. I've got to do something! I'm talking to a seat manufacturer to see if they can do something. I'll let you know!
    Travis
    Yes, probably having a shop take apart the seats and re-cushioning/fabricating the inside would be worthwhile investment.
  • ctnewtonctnewton Member Posts: 9
    I've pretty much decided to go with the OME spring/shock upgrade for my '99 Trooper. I do a lot of towing in the summer. Trialer gross weight is about 4500 lbs. Last summer was fine, but I was unnerved a couple of times by infamous NY potholes/poor road quality. Sometimes the truck would bounce a few times before settling. I didn't like that.
    Anyone have experience with the OME setup and towing?
    Also, I will be adding a tranny oil cooler. I'll probably get one from http://www.tpiperformance.com as they have good prices. Though coolers are extremely inexpensive where ever you go. Any experiences with oil cooler installations?
    I'll advise as to my experiences with both the OME and tranny oil cooler when I start towing again.
    Also, I've been starting to collect some of your writings to add to a website. I know others are doing the same, but I am just trying out some new discussion forum scripts and needed content. If any of you want feel free to add content related to Troopers (or other suv's). Its at http://www.suvtech.com/discus
    Pete
    The new OMEs and Rancho shocks are great in NYC. I've tested em out for the past week :) I'll also report once boat towing season starts since I'll be towing my 3500lb boat up to the adirondacks and around the mts. there.
    -mike
  • centralcentral Member Posts: 51
    Over on ITOG someone is reporting potential problems with in his new JC Whitney/Prothane bushing brackets. Those of you on this board who have made this swap may want to check this post and your bushings. If nothing else maybe you can help dispell this "problem".
    http://165.113.128.10:81/$WEBMSG.Read.ITOG-4.76
    Hey sahara111, what year Troop do you have? I just inquired about Sway-Away torsion bars and the latest application they have is 97, they said it would not work on my 99 :-(
  • raydahsraydahs Member Posts: 449
    I too inquired about these bars, $239.95 through 4 W/PARTS.
  • islander21islander21 Member Posts: 43
    Oooooooo, that would be a biggie. I checked and found nothing of the sort on mine - front or rear.
    Islander
    Try Dan at hotrod-offroad.com. He quoted me $200 for part 1549. I haven't ordered yet but sure I will in time.
    I have a '99 Trooper, plain jane silver w/auto and TOD. My bars, when I ordered them, were listed for the Holden Jackeroo (I believe name is correct...) or whatever the Trooper is called in Australia. That's how the Sway A Way rep and I found it in his book; then, I gave that part # to 4 Wheel Parts and they ordered it for me.
    Yes, they do make it for the '99. Mine went on perfect, I watched the installer do the work.
  • mtrionfomtrionfo Member Posts: 20
    After reading the post about possible metal fatigue of the JCW swaybar bushing brackets, I checked the condition of the brackets on my 95 Trooper. I installed the JCW bushing kit in November of 2000 and they have seen approx. 8000 miles since then.
    The brackets are lightly discolored with minor surface corrosion from the past winter (NJ), but otherwise appear to be okay. The bushings are still snugly in place, so the brackets haven't stretched any noticeable amount. Some lube has been squeezed out of the sides of the bushings, but I expected that to happen since I was pretty liberal with the stuff during the install.
    Note that I also posted this over at ITOG.
    Rgds, Marty
    95 Trooper LS
    Thanks for the links and info on racks.
    Funny story: One of my co-workers has a Pathfinder (95ish, red) with no rack. He confided in me recently that his girlfriend initially questioned his masculinity because he had an SUV with no rack. She thought,"what kind of guy would own an SUV with no rack".
    He now has an aftermarket Yakima, which is sturdy, but IMO looks aftermarket. It also sits on the front of the vehicle over the four doors.
    Andy
    I had a rack on my '97 Rodeo. The # of times I actually used it amounted to about 3x in 3 years and 120K miles. So far I haven't found a need for a rack on the trooper, and I'm sure the truck is quieter thanks to no rack. But If I did need one it would be the OEM style ones, they look best IMHO.
    -mike
    I'm not really ready to drop any $$ on one, although I think it does add to the already rugged appearance of the Trooper. *If* (as my wife says) we decide to have another munchkin (we only have one), we might need one for trips. You just can't imagine the stuff you have to bring on trips when you have a baby!
    Andy
  • johnny_ringojohnny_ringo Member Posts: 30
    I rode in an Isuzu Oasis van today and noticed the third row seats. Has anyone tried to modify that seat to work in the Trooper? It appeared to be a good fit.
    I wouldn't mind having a rack on my Trooper, but given the height (after OME lift and bigger tires) I have decided that a hitch platform is the way to go most of the time, and when I really need a rack I'll throw on my Yakima clamp-on.
    I used a hitch plaform recently to haul my Honda Trail 90 bike, worked very well. The spare did not interfere like I thought it might, and I did not need an extension for the receiver either.
    Hey, if anyone sees Pirelli Scorpion ATs on sale, especially at Sears, please let me know via email or this forum...thanks!
    The Oasis is a Honda Oddessy, I doubt you could get em to work in a Trooper. Try looking for little seats on my webpage http://isuzu-suvs.com
    -mike
    Glad to hear the hitch storage works. I was thinking of using that as well.
    -mike
    Your in luck!! Sears is having a huge sale starting tommorrow. I got the flyer in the mail and the Scorpian LT265/75/16's are an incredible $89.99, plus you can use VIP coupons if you have them.
    I upgraded a month ago and the new ride is noticeably better and improved. They are also higher(about 1 ") than my Michelin XCX's, which I sold used for $70 each. In fact, I paid $98 each plus 10% off coupon...but since I bought inside of 30 days, Sears will give me a credit on the lower price difference. Now I can get that larger spare for a 5 tire match.
    It's amazing how you can always come up with a good reason for another upgrade.
    I hope to have some pics of my Trooper and her new rack up on isuzu-suvs in a few days. I doubt I'll use it more than 3-4 times a year outside of hunting season, but lots during that time. I have a 15 ft fiberglass canoe I can load on it with gunwale brackets.
    I have to admit my reason for buying was vanity just as much as function. I just felt my Trooper looked "nekid" without a rack! It now draws the looks and respect she deserves.
    OUTSTANDING PRICE! Ask and ye shall receive...another thing I can pee away money on! :-)
    to get some myself!
    -mike
