Visitor Agreement.
And, I won a pair of very nice IPF driving lights at the raffle (donated by ARB, thanks guys), which will find a home on top of my nudge bar (as soon as I figure out the directions, which are all in Japanese)!
-mike
I have noticed tha the dash gets so hot you cant touch it. So does the detachable face on the CD/tuner. Other than a windshield reflector, what are you guys using to keep the heat off the dash and your head units.
-mike
I just installed Ventshades brand visors. I went to their web-site, ventshades.com(?), and I believe I ordered them right there. They were about 55.00 with shipping, all 4 windows. They look great.You do have to loosen the outside cover where the side mirror is to get the front edge under it. This involves popping the inside cover, where the tiny speaker is, to get to the screws. No big deal...30-60 minute install.
Con
Cheers,
Con
similar to this one(for passport/rodeo)
http://www.manik.com/products/isuzu.asp
I saw the posts before but just want to see what everyone has.
I think I am leaning towards the Lund Interceptor cause it appears to use the factory bolt holes(no drill) plus it sits off of the hood so you can get under it to clean it and wax it. I checked a couple of sites but all of them did not have the Trooper model listed.
Did everyone get Smoked as I am thinking about the clear one. Anyone use a clear one before?
Con
P.S. Funny thing is that Weather tech sells them too but unlike their side vents, their bug guards are tape mounted. Strange.
I have seen those steps that mount to the body and they look great. I might off-road a little so I want frame mounted ones. I called manik once for a question on my Sidekick and they had terrible salesperson that turned me off of them. I think their bars are better than WAAG but because of that, I won't deal with them. When I bought bars for my Mom's Explorer, I bought WAAG(Waag is cheaper too).
You have good customer service, I will buy.
Cheers,
Con
-mike
Con
-Sue
-mike
It's gonna be a blast. So far we have about 5 trucks from the NE coming.
-mike
Lots of trouble-free Ventshades out there, but the tape thing was holding me back!
Also, getting the rear door, quarter, and rear door windows tinted soon. I was quoted $240 locally. Sound fair?
Rick
Harrisburg, Pa
I guess it depends on the area. In FL, I could get a SUV tinted for around $100 bucks. In NY, around $180(plus tip) or so. $240 sounds high but if they do a good job, well worth it. Look at how good they do with other cars(older the better to check quality). I like tinters who can tint all the way to the ends of the window as some only tint to the frame so when you roll the window down you see the tint line. Also get one who can hide the tint cut lines in the rear defroster line so it looks factory. Good Luck.
Cheers,
Con
-mike
For more info goto http://www.pureisuzu.com/nurf_bars2.htm
new steel bumper as well
-mike
Cheers,
Jack
-mike
-mike
Jack
I just ordered a Hidden Hitch from JCWhitney.com for $119 for my 2001 Trooper and the light kit was about $27 also. HH seems to be a good hitch. For more money, the Uhaul ones seem nice and they have the round tube ones for your Rodeo(I think HH has them too) The advantage of the HH hitch is that they try to hide the hitch in most aplications(Trooper is hidden) but the Rodeo with the under floor spare makes the hitch more exposed. So if I had a Rodeo, I would look for a round "look" hitch.
I just received mine today so I will try to take some pics of the install and post them.
Cheers,
Con
Thanks for the info. I do have the Rodeo with the spare underneath. Hopefully that will not cause too much of a hassle. Should I go for Class II or III?
Cheers,
Jack
You might as well go for the Class III hitch as the cost is about the same, and you never know when you might need the extra capacity.
-mike
-mike
Plus the Uhaul is round tube which looks good. Go for the Class III too.
Con
Just installed my hitch with the help of my neighbor. It took us about 10 minutes to install. you have to take the tow hook off on the pass. side and the "shipping" ring/hook off of the driver side. No drilling on my 2001 Trooper. Two bolts on the driver and three on the passenger side.
Only reason you need two people is to help line up the bolts. If you have a jack, that would probably make it a one person job.
I cleaned up the bolts and frame with WD40 and used LockTite to make sure the bolts don't backout but since it did have lock washers, overkill. I took some 35mm pics so I will post them when I get them scanned.
Con
-mike
Just an update. The HH harness came in the mail today. It is made by Hoppy and rebadged as HH I guess as the intructions say Hoppy. It was a 2minute job as the hardest thing was figuring out where to zip tie it. So easy and only 27 bucks from JCW.
Pics coming soon.
Cheers,
Con
Does anyone remember the discussion awhile back where someone installed some manual locking front hubs for the Trooper? I'd like to know the brand and where to call for them.
Also, if you don't have a helper, it's possible to install this hitch by yourself. Just lay on your back and press it up into place against the frame. You can hold the opposite end up with your knee while you're putting a bolt in the side closest to you. Once you have one bolt started you can move to the other side and start the next one. Not really too difficult to do.
On the http://isuzu-suvs.com/howto/index.html Bike-rack section there is a good shot of the HH on a newer trooper. I really need to get myself a digital camera one of these days.
-mike
