Truck Gas Mileage
in General
What gas mileage can I expect from this truck? I am looking at one with a 5 spd and 3.73 gears.
Btw, perhaps since this gas topic has been started, other participants (other makes/models) may also be interested in posting their mpg gallon here. I'll leave this topic open for a while to see where this discussion leads... Thanks for your participation.
Pocahontas,
Edmunds.com/Pickups Host
Summer
Highway: around 17
City: around 13
Winter with 4 wheel hi on and idling in the morning to wwarm engine
all city: average 10.4
Ryan
ryan you have me beat, i am only getting 10.0 mpg, with 20 minute warmups in the morning.
15-16 (calculated only once) in 2wd mode in warm weather.
Ryan
After 2K miles city 10.2, hgwy 14.0
Oil consumption .7 quarts at 2K miles
LB truck with driver, dog, 2K lbs. cargo, tailgate up
mike b
I am curious if anyone can report gas mileage on an extended cab 2WD auto 4.3L V6 - I am tempted to trade into a new one but hate to give up good gas mileage - suspect that about 300 lbs. extra weight on the extended cab will adversely affect gas mileage.
-- Don
Low of 7.5mpg towing big trailer. High of 18 mpg running mostly 60mph on backroads.
Guessing a max of 10% better for you with different rear end.
Really happy with my truck's power and economy.....
I think your mileage will be a little better on the highway and a little less in town. 3.73 will require higher rpms to upshift in town which will burn more gas in the lower speed ranges, however on the open road your rpms will obviously be less than a 4.10. So if you do a lot of driving in town go for the 4.10 if mostly on the open road go for the 3.73. I personally would not ever go for the 3.73.
ndared1
gordo13: You test drove both and said the 373s are sluggish. Tell me more. We went w/ 373s as the gas mileage (between 12 and 15) is better and the RPMs is a 300 RPM differnce. My husband has had other 454s with and w/o 373s and never seen one that won't turn the tires. This truck stinks! Trying to decide what to do, most likely Lemon Law, but with over $5,000.00 in accessories on it, it's a hard choice.
Chris
The 8.1 I have had since November 3 and its great so far. I don't anticipate any problems with it by now have 3K miles no noise as you mentioned with the 454. I strongly recommend 4.10 gears (unsolicited advice). I have had no reason to take truck in for warranty yet. Have had it off road at my ranch and wish for bigger tires but will have to wait for more extra cash.
My truck out the door was $35516 (sticker $36785)its a 4x4 silverado HD LS xtend cab leather seats
Since you have owned it since November how is the
mileage doing by now. Do you fill it yourself so
you know it's FULL, when you check it ? What are
you getting on the highway empty now? With a heavy
load? Thanks for any info.
Carl
Keep me posted on your satisfaction.
Chris
I drove an Ex.cab 8.1/Allison 4:10's and agree it has pep....I don't know what the 3:73's are like...but would go 4:10 for sure also...
what kinda mileage are yawl getting with an 8.1/Allison/4:10 on dry loads?
ex cab or crew?
I heard some as good as 12.5 city....hell that's what I get with my 6.0 ex.cab 4:10's!...
we also have to remember how ya drive is going to effect it big time as well
- Tim
Different gas brands will have an effect on mileage.
2001 Dodge Dakota Quad Cab, 4.7l, 3.55 axle, 4x4.
I get an average of 16 mpg of mostly local driving.
On the window sticker there is the estimated fuel economy rating. 14 city 19 highway
In the fine print it suggests the mileage may vary +/- 3 mpg from the printed rating.
Damn
Last tank was 12.6 all city on my 5.3
Ryan
Harry
I thought I am the only one with lousy gas mileage with a Dakota....
I got 16 mpg, driving nicely. Much less than I expect for a V6. Other than the lousy gas mileage, everything about the truck is so far perfect.
The truck only has 1000 miles on it, so we'll see how it is after the break-in period.
/BOSI
Fast, comfortable, smooth . . . 2wd typically gets 14-18 MPG . . .
Most 4x4 drivers (including myself) get typical 13-17 MPG (17.5 Best so far)
I haven't done any towing yet, but I have read of many people towing
WITH EASE !
Look at the owners group - Dodge Dakota, or do a search on "Dakota
Mailing List" . . . you will find a HUGE amount of information !
Good Luck !
ed
I have one on order.
I currently have a 4.8L 5speed 4.10. Get about 16mpg outta it, running empty, driving fairly aggressively.
Maybe 15 mpg driving 60mph on level surface.
For general use are they adequate?
Anybody know what mileage the Duramax diesel is getting?
kev
Got a buddy with the Allison/8.1 same basic rig. He is getting a new gas tank (bigger) installed. Says he's doing good to get 10mpg. He's probably a leadfoot though.
Towing dirtbikes and travel trailer to TX in two weeks. Will run 75mph most of the way. Will report on performance. Averaged 7-9 mpg last year over same trip using 1500 4.8L 5speed truck. Guessing I'll get about the same mpg for the 2500HD as I may be able to tow in 5th gear.
