Mine: 1995 318ti Club Sport-2020 C43-2021 Sahara 4xe-1996 Speed Triple Challenge Cup Replica
Wife's: 2015 X1 xDrive28i
What causes the plugs to foul is starting the car, letting it idle for a few minutes, and shutting it off. If the ignition system is good the problem should not reappear as long as the car is driven long enough to let it reach operating temperature.
Rob
Please I need your opinion on what to buy. This economic turn got the best of me.Thanks
the price is retail, this model is "okay" in terms of reliability, but 25K a year is 500 miles a week, to say nothing of your pleasure use. This means you'd have to keep the car tip-top, and really almost a bit of overkill for maintenance. This might prove to be more than you wish to spend.
It would be a nice car for all that driving, though.
Best regards,
Shipo
Thank You!
On an E46 some services are determined by time, some by mileage, and some by the on-board Service Interval(SI) system(which calculates service based on driving conditions).
The time based services are: Brake Fluid(every 2 years) and Coolant(every 3 years)
The mileage based services are: Spark Plugs, ATF, and Oxygen Sensors(every 100K miles for all three).
The SI system has 3 levels of service: Oil Service, Inspection I, and Inspection II. An Oil Service is called for at 15K intervals(or every year, whichever comes first). It is just an oil change. It costs $80-$125
The Inspection I rolls up at 30K; it is an oil change, a cabin air filter change, and a comprehensive inspection of the car. Figure $250-$300
Inspection II occurs around 60K and is essentially an Inspection I + an engine air filter change. Costs average $400-$500
If you are planning on flipping the car in a couple of years I'd just follow the BMW schedule. However if you're going to hang on to it for a while I'd advise changing the transmission fluid(slushbox OR manual) every 60K at least. Ditto for the final drive oil. If you take your 3er to the track I'd reduce those mileage intervals by 50%. I change the engine oil on my 3er at 7.5K intervals due to the fact that it sees the track every so often and my wife's X3 chews up its oil in less than 9K miles(based on used oil analysis). Some people go 15K without any problem but I'm not one of them.
As for an extendeed warranty, I just don't think it's worth it. Stick whatever you were going to pay for it in a money market account and just self insure.
thanks,
Rob
Can any of you guys recommend an internet site that I can purchase parts for my BMW e46 body? I'm actually looking for a radiator assembly and an auxilliary fan.
Thanks much
2004 325 xi, manual trans, with a low frequency rumbling noise that I hear at idle. At times it seems to be transmitted from front to back along the driver's side under the cabin. Dealer checked it out, replaced two pulleys and belts, but no effect. Noise stops the instant the engine is turned off, but does not change with increased revs. On occasion the car will go a while without making the noise.
Thanks in advance for any ideas.
-jaj
I've heard Pelican is good also - just have never used them personally.
If I need something that's not really BMW specific, I've been using Rock Auto a lot.
I don't really see how this would be worth it, but I am hoping to gather some empirical evidence as to annual routine maintenance costs from e90 3-series. I love to do maintenance on my own vehicles, but I find I don't really have time any more.
I'm not real impressed with the techs in the dealerships. Tried three different dealers and convinced that none of their maintenance staff can do anything without the computer telling them what to do. Logic, common sense and experience don't seem to be a part of the picture. Computer diags are great, but the computer only sees what it's programming and sensors tell it.
Roseville BMW - Messed up everything they touched and failed to fix extremely simple problems. Did things like tried the same fix three times even when the first attempt didn't fix the problem. Purchased with 100,000 mile maintenance agreement because I got lazy (1st mistake). They didn't even inform me that all four tires were wearing on the inside edge and I trusted them to at least get the simple stuff like that right (2nd mistake), they didn't even though my wife took the car in to complain about the tire pressure warning coming up frequently. Turns out the warning was apparently happening because the tires were worn down to the belts on the inside edge. They never mentioned this and they had the car in their shop more than a dozen times.
Concord BMW, service writer tried to tell me the inside tire wear was the tradeoff you make for better performance.
Niello BMW performed alignment to fix the inside wear, subsequently wore on the outside tread. Wondering if they screwed up the alignment. Just got new tires (not run-flats). We'll see how they wear. Took the car to Niello for the passenger air bag recall, still get the airbag warning and Niello says it's because the SAS is messed up. Incidentally, that (SAS, steering attitude sensor) was one of the things Roseville was supposed to have fixed. Also, I don't see why the SAS would prevent the airbag warning from resetting if the recall was done properly.
If they serviced the car at a BMW dealer after the maintenance plan expired, they'll have those records, as well.
If the Inspection II was completed at the dealer (60K service), then you won't have much to do... But, you'll need to find that out, first.
However it is common for p/s fluid to leak from hoses connected to the reservoir tank. For this you will need to replace the hose that is leaking. One hose is going to P/S pump and that one does not need special tool to unscrew from pump. The other is connected to the radiator. But it is not simple you will need a special tool. Special tool is for disconnecting one of the hose that is going to radiator and other to the reservoir tank.
I recommend letting a professional repair shop that works on BMWs handle this so they do not damage the hose or the radiator.
Special tool is not expensive but many do not know about it and may damage your radiator.
Good luck -
It is a good preventive maintenance to get the p/s fluid flushed every 30k miles. Though, BMW does not promote this service, it would be a inexpensive service ($50-$75) to get done and save you leakage issues in future. New fluid will have conditioners and detergents built in to provide you with long life with minimal expense.
And changing o-ring is nice but not required. Unless you notice leakage from the cap area.
Are you still having the same issue or have it checked out by the dealer ?
Has anyone had this problem ? Not sure if the remote fob needs to be programmed accordingly.
HELP !!!!!
Good Luck
I think I follow your instructions. This is what I understand:
A) With the first key, turn on the car, adjust the seat position, save settings to memory button 1, then turn off car.
With the second key, repeat step A, and save settings to memory button 2.
C) Make sure both keys are in car - that means that one key will be in the ignition while the second key is comfortably resting on the seat : )
D) Access computer commands on turn signal lever, go to appropriate key icon, set to unlock with 4 doors and driver's door open.
I did step A and D thinking that it was paired, then changed the seating position, exited the car, locked, open again and voila ... scratched my head when nothing happened.
The instruction manual makes no mention of pairing the keys to the memory settings before activating the computer. My MDX key fob pairing to the power seat settings is simple and logical.
Just wondering, if I happen to wait in the car while the wife is shopping and move the seat back to take a nap while the key is in the ignition (pretend is summer and AC is running), will the seat memory settings update automatically ?
I will try it tomorrow if I get a chance. Thanks for your help.
If so, with who, how much was the plan ??
If you had to make a claim, did you experience any issues ??
I just bought a 2007 335xi with original waranty expiring in 2011.
