Recently i notice a tick tick noise from the rear of my car when i start the engine. Also after i stop the car and come out i hear this noise for sometime.
Is it normal or needs checking?
Im still under the maintenance package so will they be checking and replacing anything required under the package??
Thanks for your help...
Rob
Am I about to be deluged by a tsunami of repairs by virtue of 'things need to be replaced'? Looking for some sage advice...thanks.
If you are asking, will repairs increase as mileage increases, in ever increasing proportion to value of the car, the answer is certainly "yes".
On the other hand, cars are like bank accounts. If you've been making deposits, you won't go bankrupt for a long time, but if it has been mostly withdrawals (of the car's mechanical and cosmetic wealth), then you will go bust sooner.
Question:
1. can I do without computer resetting
2. What equipment should I buy to change oil myself (extruction pump?)
Thank you in advans. Lehrer
Good Luck!!
Pirelli tires are ok. interior and body clean. front spoiler/ground effect is damaged.
does an 85 m3 have ground effects front, mid and rear? this one has them front and
mid but no rear. can't find another 85 m3 on ebay or autotrader.
And, like you said, there is no '85 M3.
Methinks the seller has a 318. Either that or it has had an engine swap.
you made my day! The link you posted is wonderful and I apresiate your advice.
The remaining question is: should computer be resetted or not.?
Best regards. Lehrer
Your instructions are a masterpiece.
Best regards, Lehrer1
Good luck
Lehrer
- This is the work the prior owner had completed.
- At 66.9k Front Control Arm Bushings Replaced as well as Pullys and Belts
- At 65.4k The 60k Major Service and Inspection, as well as Oil Service, Front Brake Disc, Pads and Sensors.
- At 57k Oil Service and Inspection
- At 51k Oil Service and Inspection
- At 45k Oil Service
- Any help would be much apreciated.
Somebody tell me that BMW will apologize and pay to repaint the damage.
My 06 330xi auto is 72k miles now.
Also, sports package or no?
K
So you should have the damage inspected by a dealer, it might be covered under the warranty.
Yep, got the sports and premium package! Oh yeah remember people say to change the tires every 10-15K. However, mine still look okay at 18K. Thread is good, but I know passengers have mentioned a rough ride lately so maybe I do need to change the RFT.
I am planing to finally get my first BMW and I just came to live to Miami so I would really appreciate advice and feedback from you dear experts about the average annual maintenance fees and normal repairs so I can inlcude it on my yearly budget.
The car will definitely be a convertible model from around year 2004. My first option is a 330 because I've been told that is the best one for reselling. Any suggestions?
I plan to use it as my daily driver so I consider average 10 - 12000 miles per year.
Please be so kind to help me with this info before I go car hunting. Any buying recommendation will be highly appreciated too!!
Given that my current car is a 2001 model with only 57k miles on it I am expecting to put a similar amount of miles on this car in that time frame. It will not be taken to a race track, just used for a short daily commute and some occasional longer trips (say 40 minute drives)
So... is it fair to assume my maintenance/repair costs will be low on this vehicle? Right now the main concern I have with a BMW is reliability. Any resources anyone can recommend on what to expect from them?
If so, the first four years will have very, very low maintenance costs.. Probably only a set of tires at the end of four years... BMW covers all of your maintenance, outside of tires, for the length of the warranty.
After that, I'd say your costs could be fairly low... if you find a good independent BMW tech/repair shop.. Even routine maintenance at a BMW dealer can get expensive.
On the plus side... at 7500 miles/yr, your BMW will only need one service per year...
That's it for maintenance.... from a reliability standpoint, we've always had very good luck with our BMWs... Unscheduled visits to the service department have been very rare.
The plan would be to keep the car for at least 5 or 6 years, probably more. Looking at it that way it's 2 years or so of maintenance I'd have to pay for after the warranty. Normal maintenance though I have no problem with.
Honestly, what you said about "Unscheduled visits to the service department have been very rare." is all I really care about. The nightmare is: oh, electrical problem. next month the AC wont work, next month the engine light goes on, same electrical problem crops up again etc etc. Even if that's covered I dont want to deal with that. Far worse if it's not covered of course
I think I just need reassurance that hey, first 60k miles on this car should be smooth, statistically speaking, assuming I take proper care of it.
I just assumed a lease on a 2007 335i Sedan with Comfort Access. The steering wheel has a button for handsfree, but I cannot find any documentation in the manual to setup/pair phones or how to use this feature. This may be a stupid question, but does the 335i come standard with this feature or is this an add-on?. I suspect it is an add-on, but can someone provide some guidance on whether this can be purchased or whether it is a factory option and what type of $$ I can expect to pay for this. I live in Toronto Canada.
Many thanks in advance
Do you drive it daily? Maybe if it goes longer stretches it's harder on battery life I'm not sure. Good luck with the 328ix! It's a gorgeous car I'm very strongly leaning towards getting it.
I have recently aquired a BMW 330D SE tourer and I am having starter problem. I take the car for quick drive, say 5 mins and leave car for about 1 hour. the car then wont start, engine turns over OK and there are No warning lights, sounds like it wants to start initially but then wont start, Just wont fire up. Starts first time about 12 hours later. Very intermittant problem. Computer diagnostics show all clear, (BMW dealer). My guess is fuel problem, fuel pump seems OK, Is there a sensor that could stop start up? I've seen that cam sensor could cause problem. Been with BMW garage 4 days but It wont repeat the problem, so I know that if I pick car up it will let me down. ANYONE had similar or suggest remedy? regards Paddy
I've decided to ride out this economic uncertainty in a 2010 Mustang GT (V8) with 5 speed manual. I got it with a 3.73 rear axle package option that comes with upgraded brakes. Besides that, it's bone stock. Power and Torque on this Stang comes from a blasty V8 power plant and the manual's engagement feels good and solid. Exhaust note is impressive and a joy to listen to. Handling however is reminiscent of my dad's Econoline. Compared to a 3, it's van'esque. I'm thinking of getting Ford's FR3 handling package which I hope will bring her a little closer to BMW handling. I know..a Mustang can never handle as well especially due to its live rear axle. For the next two years however, she'll have to do. I look forward to the next generation 3s.
I'll tell you one thing, in the past week, I've gotten more looks for this Stang than 10 months with a 335 and 3 years with an 06 330 combined. No one so much as raised an eyebrow for my 335. The Stang is plenny fun too. If I can significantly improve its handling, she might be a keepper! :shades:
Joseph
San Diego
I know BMW doesn't recommend towing a BMW on all 4 wheels. However, that doesn't mean it can't be done, its just not recommended.
I have a 1998 323ci with manual transmission. Is there anything that should be done to it in order to tow it behind a motorhome? I've heard where some vehicles need some sort of transmission pump to keep fluid flowing while being towed. Who is best to do this kind of work, a dealer or transmission place?
Anyone know of someone who hauls a BMW 3-Series with a manual tranny behind a motorhome and all is okay? Thanks.
Chris Olympia, WA
Recently drove my 328xi (2008) to Orlando. After driving about 800 miles (in a day) when I started the vehicle it had rough idle for about 2 minutes but then was fine. While in Orlando no rough idling.
Return trip no rough idling, but when I started the car this morning once again rough idle for about 2 minutes.
Any ideas.
Help would be appreciated.
Furthermore, your car doesn't run all day off the battery---your alternator should be putting out more than enough juice to keep the car running happily.
Any 15 year old car with 200k miles is going to have issues, but am I just asking for trouble here?
Any opinions would be appreciated. I've always thought the E36 had a good reputation for engine/transmission reliability.
Reputation? Not all that good if you include the cooling system as part of "engine".
Price is okay, but plan on spending money on it, at least to re-hab the cooling system straight way, and be sure to check the control arm bushings, the driveshaft coupler, and all the electronic gizmos.
