Quote
It appears that you would have to replace your steering column as well as the steering wheel
Quote
cluster can not be reprogrammed so you might also be looking at buying a new cluster
Quote
dealer would have to re-program ... the body control computer
Here's a link to the discussion. Fully functioning DIC???
But when I run my VIN through the Calibration site I don't get the same updates as the TB.. and I noticed the 2002 TB's have a TSB regarding the calibrations, but the 03 TB's and 03 Envoy's don't. Is the re-calibration only for the 2002's?
Mine is going into the shop Monday for these issues and for the intermittant "shutter" at idle that at first we thought was an engine miss (3rd time in for this issue).
Just a note, getting my driver side weather-stripping replaced under warranty as it was not adhering well to the door opening. It's not hanging down or anything just a slight sag in it that got my attention. This is the first warranty work I've had done. Truck now has 18K, '02 Envoy XL SLT build date 5/02. Interestingly, I've been following manufacturers recommendation and lubricating lightly with a silicon sprayed clean cloth. Also, I don't have wind noise that I would consider bothersome nor have I ever experienced any leaks.
Still love my truck. Happy motoring to all.
Chris
GM Has Recalled the 2003 Trailblazer, Envoy and Bravada
The National Highway Traffic Safety Administration (NHTSA) has released the following information.
Make : CHEVROLET Model : TRAILBLAZER Year : 2003
Make : GMC Model : ENVOY Year : 2003
Make : OLDSMOBILE Model : BRAVADA Year : 2003
NHTSA CAMPAIGN ID Number : 03V151000
Component: SERVICE BRAKES, HYDRAULIC:FOUNDATION COMPONENTS:HOSES, LINES/PIPING, AND FITTINGS
Potential Number Of Units Affected : 44653
Summary:
CERTAIN SPORT UTILITY VEHICLES WERE BUILT WITH A LEFT-FRONT BRAKE PIPE WITH A CIRCUMFERENTIAL SCORE AT A RANDOM LOCATION ALONG THE LENGTH OF THE PIPE AS THE RESULT OF THE MANUFACTURING PROCESS. IF THE BRAKE PIPE AT THE SCORING LOCATION CORRODED TO THE POINT THAT THE BRAKE PIPE WALL BECAME VERY THIN, AND APPLICATION OF THE BRAKE DEVELOPED ENOUGH PRESSURE TO PARTIALLY OR FULLY FRACTURE THE BRAKE PIPE, BRAKE PEDAL TRAVEL WOULD IMMEDIATELY INCREASE AND FRONT BRAKE PERFORMANCE WOULD BE REDUCED. OR, IF THE BRAKE PIPE WALL AT THE SCORING LOCATION PARTIALLY OR FULLY FRACTURED DUE TO A COMBINATION OF PRESSURE, VIBRATION, OR TEMPERATURE INDUCED FATIGUE, THE BRAKE PEDAL TRAVEL WOULD IMMEDIATELY INCREASE AND FRONT BRAKE PERFORMANCE WOULD BE REDUCED. IN THESE INSTANCES, BRAKING WOULD BE LIMITED TO THAT AVAILABLE WITH THE REMAINING HALF SYSTEM (REAR BRAKES).
Consequence:
IF THIS OCCURS WHEN STOPPING DISTANCE IS LIMITED, A CRASH COULD OCCUR.
Remedy:
DEALERS WILL REPLACE THE LEFT-FRONT BRAKE PIPE. GM HAS NOT YET PROVIDED AN OWNER NOTIFICATION SCHEDULE. OWNERS WHO TAKE THEIR VEHICLES TO AN AUTHORIZED DEALER ON AN AGREED UPON SERVICE DATE AND DO NOT RECEIVE THE FREE REMEDY WITHIN A REASONABLE TIME SHOULD CONTACT CHEVROLET AT 1-800-222-1020, GMC AT 1-800-462-8782, OR OLDSMOBILE AT 1-800-442-8006.
Frank
Frank
Anyone ever have a data recorder hooked up to their triplet? Dealer can't figure out the "stutter" or miss that our 2003 Envoy is doing at idle so after pressuring them to do something they hooked up a data recorder. I hope it can give them some clues.
And unlike the 2002 TB's there wasn't a PCM update for sluggish 1-2 upshift when cold.
I'm pretty disappointed in the customer service at our local GMC dealer. Anyone in the Minneapolis/St. Paul area have a GMC dealer that they've had good service at?
When you get the "Service Satisfaction Survey" from GM be sure to fill it out accurately and quote what that so-called "service advisor" said. Amazing how some of these characters seem so put out when asked about TSBs or recalls, even though that's their JOB!! GM actually does seem to be interested in customer feedback. The 3 times my TB has been in for service in the past 15 months, each time within a couple of weeks I have received a questionnaire and a followup "reminder to fill it out" card a week later.
Good luck
Frank
.....And I'd be sure to hunt down the service advisor's supervisor and give them an earful as well. That is totally unacceptable behavior from a service rep!
Let's not blow this out of proportion. There's always 2 sides to every story. I'm not saying anybody's lying but most people don't swear at you for just asking a question.
Anyway, I get the impression dealers don't like the internet much. They don't seem to like it when you have information before them or have more information than them.
On one hand there's people who come to the dealer and want every TSB applied even though they weren't having problems. This is kind of like hypochondriacs who hear of some new ailment and immediately think "I must have that."
However, the internet isn't going away anytime soon so dealers will need to learn to use it to their advantage. A lot of times the customer has already diagnosed the problem and found a solution. Sounds simple to make them happy.
What they need to do is put MUCH more detail into the descriptions of the TSB's. Make it clear that not everyone has the problem and do better than "transmission problems" as a description.
So can someone explain to me how a recall makes GM a bad company???
We have Ford and/or Firestone to thank for these types of recalls. No automaker wants to go through another Ford/Firestone tire debacle.
This is printed on every TSB.
GM bulletins are intended for use by professional technicians, NOT a "do-it-yourselfer" They are written to inform these technicians of conditions that may occur on some vehicles, or to provide Information that could assist in the proper service of a vehicle. Properly trained technicians have the equipment, tools, safety instructions, and know-how to do a job properly and safely. If a condition is described, D0 NOT assume that the bulletin applies to your vehicle, or that your vehicle will have that condition. See your GM dealer for Information on whether your vehicle may benefit from the Information.
>a service rep!
The Service Advisor had said "well, we don't know about that recall". So when my husband said "Well could you look into it since we have the vehicle there right now?". That's when the Service Advisor swore at him and hung up.
My husband drove straight to the dealership and spoke to the Service Manager and his boss for the next 2 hours. Never did get an apology from the SA.
>seiford, does your envoy have the automatic load leveler?
Yes, it does. But I can hear when the compressor kicks in and the "stutters" don't seem to correlate with that kicking on. I've tried to find some pattern to the behavior without any luck so far. These intermittant things are pretty hard to narrow down.
Today I drove the Envoy around for about an hour with the data recorder waiting for the stutter to happen. Got one good recording.
Then on the way home the Envoy had a little "issue". A few lights came on (Service 4WD, ABS, Airbag, battery, check gages, fuel low), 4WD indicator off, radio dead, power windows/locks dead, oil/temp/battery/fuel gauges dead. I thought I'd try calling Onstar... but that was dead too.
Drove it right to the dealer and showed the drugged out Envoy to the Service Manager. At least this issue isn't intermittant. They shut it off a few times (comes up with "Unknown driver" on the DIC) with no change. Can't even get the mileage to display. He thought this was a new issue and not related to having the data recorder hooked up.
The only reason I mentioned that brake recall was in hopes they could do the fix while we had the truck there. I don't have a problem with the recall itself - I like proactive fixes!
They provided a free rental and will work on the mystery-mobile tomorrow.
Frank
1, bumping /rubbing noise
2, long scratches on all 4 windows
3, tail lights ( left turn sig. and right break light ) consistently out
4, black seal around linc. plate housing is peeling
5,third light above rear hatch seems to have water damage to it like there was a leak and it dried up all white inside.
6,black seals around rear and front windows peeling off .( unsure if this is part of the high wind noise)
is anyone else here having any of these problems ? As I am looking now to give this TB to my hubby to take back and forth to work I am looking into going back to a mini-van the Honda because I have had enough with GM and American made cars .
Surely I'd agree that there have been too many mistakes on the triplets, but this brake line issue isn't a big deal. They could have kept quiet and nobody'd ever know.
Perhaps I'm overly tolerant. Working in the software business will do that do you. Nothing ever works! I'd kill to work with a software package that's as good as the worst triplet here.
#1
Models: Chevrolet TrailBlazer/TrailBlazer EXT Year: 2002
GMC Envoy/Envoy XL Year: 2002
Oldsmobile Bravada Year: 2002
Number Potentially Involved: 314,300
Dates of Manufacture: October 2000 – March 2003
Noncompliance: Certain sport utility vehicles fail to comply with the requirements of Federal Motor Vehicle Safety Standards No. 101, “Control Location, Identification, and Illumination” and No. 208, “Occupant Crash Protection.” These vehicles have an intermittent condition during vehicle start-up in which the instrument panel cluster may not properly power up, resulting in most of the displays, telltale lights, and functions being inoperative.
Remedy: Dealers will reprogram the instrument panel cluster. The manufacturer has reported that owner notification is expected to begin during April 2003. Owners may contact Chevrolet at 1-800-222-1020, GMC at 1-800-462-8782, or Oldsmobile at 1-800-442-6537.
[NHTSA Recall No. 03V096/GM Recall No. 03013].
#2
Models: Chevrolet TrailBlazer/TrailBlazer EXT Year: 2002-2003
GMC Envoy/Envoy XL Year: 2002-2003
Oldsmobile Bravada Year: 2002-2003
Hummer H2 Year: 2003
Number Potentially Involved: 511,167
Dates of Manufacture: October 2000 – September 2002
Noncompliance: Certain sport utility vehicles fail to comply with the requirements of Federal Motor Vehicle Safety Standard No. 114, “Theft Protection.” These vehicles are equipped with a mechanical override that could allow the ignition key to be removed with the shift lever in a position other than PARK. In addition, these vehicles have an override that can allow the transmission to be shifted out of PARK with the ignition in the OFF position. These overrides are not permitted unless the vehicle has a locking steering column.
Remedy: Dealers will eliminate these conditions by disabling the overrides. The manufacturer has reported that owner notification is expected to begin during April 2003. Owners may contact Chevrolet at 1-800-222-1020, GMC at 1-800-462-8782, Oldsmobile at 1-800-442-6537, or Hummer at 1-866-486-6376.
[NHTSA Recall No. 03V075/GM Recall No. 03012].
This little gem saved me when my TB wouldn't start while it was sitting in the garage. These vehicles also have a solenoid that prevents the ignition from being turned to ON when the battery is dead. Had my TB not had this override, the only option that the Tow Truck operator (whom the Chevy dealer sent to pick up my TB) would've had would have been to just *drag* my truck up onto his flatbed.
Nice solution.
tblazed: a vendor may have supplied the brake lines, but GM should have inspected them BEFORE installation.
badgerpaul: I put the 80 years number out there for emphasis, not as a factual date.
My point was not to dwell on the defects, but rather the lack of precise engineering necessary to build a dependable, quality product. Any good carpenter will tell you, measure twice--cut once.
Frank
1996 GMC Jimmy and they worked great all 7 years.
I have seen the same 3M stick-on types and also
ones by EGR that "snap" in. I installed the stick-on types myself with little difficulty and once on, don't intend to ever take them off, so portability is not an issue. Has anyone comments or experience to share on pros and cons of the different types epsecially as they fit on the new TB/Envoys? Thanks!
Yeah, but did you make the entire round trip on one tank of gas?
I write...
No, what I do is fill up right before the on ramp to the Thruway, then when I get off I buy gas at the first station I see and get the mileage that way. Very scientific actually.
I have no complaints at all and would highly recommend them.
Easy install and they look good.
http://www.weathertech.com/store/prodsearch.asp?item_group_id=4
My TB with 16,500 miles is averaging 15.9 mpg for all miles driven, both downhill and uphill.
Frank
I'd estimate that 50% of the time, I put the tranny in Park and can open the tail without hitting the unlock button. The other times I go to the back and find the lock did not unlock and need to hit the button on the armrest.
I think I also have the same experience using the key fob... sometimes it takes a 3rd push to get the back to unlock
what does your DIC mileage average read for the entire period you have owned the car.
I write:
I have an SLE so no DIC. All I have is a trip odometer, a pencil, and a calculator. If you used average mileage, it would be awful. When its zero out all winter like it was here, I was getting 11 to 14 MPG no matter what the road conditions
He writes:
Now, why would you give up such a great high mileage SUV just because of a slight vibration?
I write: Because I am a hot head, thats why. I do admit I get a compliment a week on what a good looking vehicle it is. Happened at Sears yesterday. Shhh, dont tell Richard Wagoner. I wonder if he responds....I will let you know!
Frank
Unhook the base of the boot by squeezing the two sides towards each other. It's sorta spring clipped into place. Below the boot is a little red lever that you press/hold while shifting the vehicle out of park.
I'd have never known it was there, but the guy with the flatbed who came to pick up mine said he'd just had to pick up a Bravada with the same problem the day before and the owner of the Olds showed him how to do it.
If GM 100% inspected every part that is supplied by the various vendors then you could probably expect to pay several times more for the vehicle. I can only guess this brake line problem, being corrosion related, was probably found after doing long term corrosion testing of some sample brake lines. Be glad they are doing something about it. I wouldn't want to be in the way of a runaway '03 triplet!
seems to have been shoved into the opening where
the front of the door and the wheel well meet that
appears to be there for some reason, but doens't
seem attached at any place- so doesn't seem lilely
to seal against wind noise- but some say it does.
Has anyone been able to find where these moldings
should attach -or seal? You can push them back or
pull them forward but they don't seem to pop into
place or fit precisely from viewing when the door
is opened. These are pre-molded black foam strips
just sitting in there. I have wind noise that
sounds like the front windows are not closed all
the way, but are- and suspect this is the cause
when driving at freeway speeds.
Absolutely nothing. You can ignore the recall notice. I have no intention of having my override disabled. I will keep the notice and pass it on to the buyer, if and when I sell the vehicle.
