If done right, an engine replacement is not something to fear, especially if the exact same engine is put in (i.e. no custom motor mounts, etc.) Everything can be reconnected just like new.
Also, there were some issues raised earlier about "rebuilt" engines. Again, correctly done, they are just as good as new.
I look at cases like these all day. If you want me to explain the reman engine issue, from an apprasiers perspective, I surely can.
st1100 - "Again, correctly done, they are just as good as new."
Unfortunately, not true. In most cases, there is no idea of how many miles an engine block had on it prior to being used for a rebuild, and only components that are "out of spec" (and the specs are BROAD) are replaced.
My 2 cents
I've got almost 20K on my Envoy XL SLT, its almost a year old (end of May) and is in like new condition. I broke the engine in according to the manual and it sounds and feels like the day I bought it, the transmission has done some learning and either it's adjusted or I've adjusted.
Would still like to hear from more happy owners.
Chris
Some options:
1. Find another dealer? Waiting for parts for two weeks is unacceptable.
2. Sell.
3. Fix. Preferably at another dealer.
I don't know your entire vehicle history but we once purchased a Chevy Corsica from a friend who had nothing but trouble with it. It was still under warranty and he gave us a great deal so we said what the heck lets buy it. Well, we never had a problem with it after we took delivery! I bet he had 10 or 15 trips back to dealer with all sorts of complaints. We bought with about 15K miles on it and sold it 9 years later with 160K on it in good condition. Yes, we had some regular maintenance on it but nothing much else. Your story could be similar, my point, there's always hope.
Chris
1) Wind noise which the dealer is going to try and minimize for me; foam stripping is on order.
2) 6 CD changer makes rubbing noises while playing CDs. The unit has been replaced but still does it. I'm told they all do it. I've tried all in his lot and it is true. Does anyone on this board also experience this?
I'll bet there are many (thousands)of people from coast to coast who are on the outside looking in. Come on people, share a "happy owners" story with us this weekend. Lets get all the average Joes like you and me with a story.
I want to know how many garbage cans your trucks can take out in reverse, who pulled the dock out of the lake and some good off road story to boot!
Tech guys please stay on board, be patient and don't laugh to hard (just this weekend), we need you and your expert advise very much.
No get up and go when hot. Suffer smell some times
and spits back when shut down hot some times. Stomp
accelerator to floor in park slowly climbs to 3000 rpm temp goes up, smoke comes out of dash and suffer
smell. Vacuum 20" at idle 15" at 3000 rpms. No codes. Dealer said
nothing wrong. I think exhaust is restricted. Help
GAM
Thanks in advance,
Todd
Radio: To change the radio to the Bose, in these vehicles the Bose uses a seperate power amp located in the right-rear behind the inner rear quarter area ahead of the rear wheel well. Plus if you did get all the hardware, wiring harnesses, dash tweeters, etc., you would have to reconfigure the BCM computer to the modified vehicle configuration and program the anti-theft feature of radio to the vehicle. Everything talks to each other via the Class2 serial data bus.
I knew the dark eye on a two year old truck was bad news. Being the holiday and all, I just ran down and popped in a battery not even bothering with the dealer and potential warranties.
Oh well. Enjoy the holiday weekend!
That would mean a 20% increase going from a 3.42 to a 4.10 ratio. It takes a given amount of horsepower to drive the vehicle a certain speed. As slow as these engines turn on the highway, the difference is probably 2-3% between ratios, otherwise GM would have to reflect that difference in the window sticker. BTW, I got 22.2 mpg in my Bravada (3.73's) on a trip from the Twin Cities to Milwaukee.
GAM
thanks......
Trust me, you picked the right one for you.
PCM - TSB
I am not sure of the right meaning of the abreviation but in plain english a PCM is an update to a program in one of the computer of your vehicle done by your dealer. A TSB is the announcement that something can be done to fix a common problem. Its not a recall, but it provides information to the dealers on how to fix something that has been noticed in many vehicles. For example, if Veh X has problem Y, then there is a TSB stipulating that a PCM will fix it.
Cheers.
TSB - Technical Service Bulletin - a message that goes out to dealers first, to provide technicians a method of repairing a vehicle that the manufacturer believes will work (especially for unusual problems). TSBs are published in the NHTSA website:
http://www-odi.nhtsa.dot.gov/cars/problems/tsb/tsbsearch.cfm
Go to the site, follow the directions, filling in your vehicle's information - try not to get too specific, it only slows you down. There aren't that many TSBs on the triplets, so it's easy to see all that apply.
Wow.. it's great to see that since November 2002, this forum continues to hold the TOP TEN HOT TOPICS title! For those whom followed the posts prior to November 2002, I too once owned a 2002 Envoy SLT loaded to the gills with DVD, 6-Disc Bose and the 4.10 axle.
I opted to get "rid" of my Envoy due to the ongoing problems/issues/concerns that made me question the overall reliability of this vehicle. Originally, I decided to replace my 02 Envoy with a 2003 Yukon Denali but once I started thinking about it, the design is a little dated and will more than likely be refreshed soon. As opposed to purchasing a Denali right away, I decided to wait and carefully see what the competition had to offer or even wait for the new 2004 models to hit the showrooms.
Needless to say, I have had a chance to test out many of the new SUV contenders and cross-overs (incl. Infiniti's FX-45) and constantly found myself comparing the features of my Envoy to everything else on the market. Needless to say, basically NONE of the non-GM contenders offered the highly innovative features that were present in my 2002 Envoy. For instance, the 2003 Lincoln Navigator is a very nice vehicle, but the reversing mirrors are downright horrible, acceleration was terrible and the pricing was even worse! The mirror do not give you a true "curb view" when the vehicle is in reverse. When I asked the salesman about this, I was told that you could NOT fine tune the reversing setting on the mirror like I could with my Envoy!
Long story short, it seems that virtually all the vehicles that I had been somewhat interested in could not touch the Envoy's features at all! NONE offered the multi-zone heated seat option, most simply have ON/OFF -- HIGH/LOW settings. Most DIC's on the competitor vehicles were not as flexible as the triplets. Most simply contained ON/OFF settings. The Toyota 4-Runner Limited had a very claustophobic feeling and the seating position was not very comfortable at all, in addition to having NO programmable features! The Lincoln Aviator was a JOKE and does not even come with an electrochromatic rear view mirror BUT the Explorer and Mountaineer does? What gives! I could go on and on, but I think that you all understand where I am going with this.
Want to hear a funny story? I test drove a Infiniti FX-45 on a cold/snowy day here in Columbus, OH and while out on the test drive, my sales rep instructed me to turn onto an abandoned store parking lot to test out the sure-footedness of the cross-over. Well.. about 15 seconds into our excursion, we found ourselves STUCK in snow that was NOT entirely deep at all! So.. as I am flooring the gas trying to get the vehicle un-stuck, my salesman is outside in his black slacks and dress shoes standing in snow that was not quite mid-calf, attempting to push the vehicle out of the snow! At this point, I am completely disgusted at this beautiful vehicle with beautiful factory 20 inch wheels, rear back up camera, no key ignition, adaptive cruise control and a throaty/muscular V-8 engine. Luckily, the ATV/Motorcycle dealership was within viewing range. The store owner saw our dilemma and rode out on an ATV to help us get the vehicle out of the parking lot. Umm.. Yeah.. $52,000 for a vehicle that cannot handle medium-level snow? NOT!
After careful consideration (and help to the person who posted the links on this site concerning the changes for the 2004 triplets), I have decided to take the PLUNGE again (of course hoping and praying that this one will be perfect.. or almost perfect) and purchase a Pewter 2003 Envoy XL SLT with the V-8 and the 3.73 axle, DVD, 6-Disc Bose... loaded to the gills! Why wait for a 2004 when the decontenting continues! I much rather prefer my 4 way power lumbar over the power adjustable pedals, navigation system could be nice, but looks as if you lose the 6-disc changer! Also, I like the neon rear brake lamp over the new bargain basement special that they will use in the 2004 models! I hope to take delivery this upcoming Wednesday or Saturday if my time will allow for me to make a quick 170 mile trip!
After carefully searching GM Buypower, I was only able to find ONE Envoy SLT XL within the state of Ohio that wasn't missing any options and the color that I wanted. I went to this dealership (while in route to my hometown in Michigan) this past weekend to check out the vehicle. I must say that I was completely overwhelmed by the large/mass quantities of Envoy's this dealership had in their possession! I guess that's why the incentives (yes.. in addition to 0% for 60 months) are so good? I am looking at an additional $2K off of the GM Employee pricing! Prior to acquainting myself with anyone in sales, I had to find the vehicle on the lot first and thoroughly inspect the exterior. After driving through acres and acres of Envoy's, I finally found mine...of course, she was the VERY LAST one all the way in the rear of the dealership! Still covered in plastic, I met with my sales rep and took her for a test drive.
First Impressions: GM!! MAKE THE V-8 AN OPTION IN ALL OF THE TRIPLETS! It was wonderful! The vehicle ONLY had 3 miles on it, so I was sure not to put my foot in it! I was amazed at how easily and effortlessly the vehicle accelerated up to speed. I even rounded the corner and lightly tapped the accelerator to find the back end trying to get "loose!" How can I describe it best? GOBS OF TORQUE! I reset the DIC as we entered the freeway and over our 8 mile test drive, I averaged 19.9 mpg at 65 mph cruising speed! The engine is sooo smooth and quiet, you barely knew that the vehicle is running without glancing over at the tach! I liked my 2002 6 cylinder, but the V-8 definitely makes a difference and I feel much better whipping out into traffic or merging on the freeway with the A/C running! SIDE NOTE: Does anyone know if the V-8's utilize the "drive by wire" technology equipped in the 6 cylinder models?
CONTINUED... NEXT POSTING..
I must say that my overall impressions of the 2003's were good, but then I had to sigh when I thought of the features that I lost in my Magnetic Red 2002 Envoy SLT. I will most definitely miss the lighted glove compartment, outside dimming driver's side mirror and most importantly, the ARTICULATING HEADREST!
After carefully searching this board, I was really not able to find any postings from anyone who have successfully installed either of these things on their 2003's? IF the wiring is already in place, I would like to take a shot at installing the electrochromatic outside signaling mirror and the light in the glove box. I've already learned that I can easily install the articulating headrest with very little effort and that's a plus. Also, to ensure me continual piece of mind, I am definitely opting for an extended warranty again! Normally, I would purchase a GMPP at GM employee cost, but after a recent bout with the service department and the GMPP rep over my aunt's 2002 Trailblazer LTZ (posting 11264), I have decided to go 3rd party. It looks as if it will be between 1Source Auto or Warranty Gold and I am definitely looking at their top of the line, 10yr/100,000 warranty plans. Anyone have any information concerning these companies that they would like to share?? Good and Bad?
To all the triplet owners out there, wish me luck on my 2nd time around! Hopefully I can enjoy a higher level of trouble free motoring and any information that you all could provide concerning these upgrades would be greatly appreciated. More so than anything, I just need to find out if the connections are still present for the mirror and the light in the glove compartment. Also, my level of confidence is higher this time around because I do think that GM ironed out "most" of the annoyances that plagued the 2002 models!
Sorry for the long post, but thanks for reading!
Happy Motoring!
IExplore2000
PS: Tlauro.. I will definitely get you a pic of the 2003 beauty to post on your website next to my old 2002 gal! :-)
iexplor2000 good luck on your purchase I hope you will be more satisfied this time.....
That's why I said "5-10% better MPG on the highway". MAYBE up to a 10% better highway MPG going from 4.10 to 3.42. I did say you will see a 10% increase in engine RPMs with each higher numerical ratio.
Tim, did you buy another Delco battery? If not what did they do about the "dedicated" battery housing-case? Seems to me the way GM designed that fancy ventillated battery housing you're restricted to ONLY Delco-brand batteries. It's hard if not impossible to find a different brand that doesn't include the top terminals. I considered the Optima sprial cell battery but that would require ditching the battery housing or severely modifying it to fit the battery.
Clocked 500km (310 miles) mostly on our hiways in greater Toronto. Our city is very well serviced with many divided hiways upto 12 lanes wide and smooth as a billards table as well. The average speed in the fast lane is 130kmh (80mph). The cops may pick and choose individuals speeding but they can't pull over whole hiways.
I'm taking my 2002 black Envoy (41,000km / 25,500m) for its regular service tomorrow. Some guy asked me if it was new. No but the lotions and potions from Maquires make it look so!
Thanks to you people I,m armed to the teeth with info from the NHTSA site, VCI info and I even copyed some of your postings describing various concerns (engine to transmission) . My service centre treats me like gold and suspect everything will be done and then some.
I did not see any postings on the radio signal turning off and on (it happens more when it is cold), ive got a reverse light full of condensation, the caulking job on the tailgate sucks, my daughter put the boots to the rear cup holder, the transmission has a problem up shifting.
Dennis.....excellant bla bla bla
Rich.......are we the only two North of the border?
Onlyagirl. It is very funny to read a post about "the hitch thingy" on this board. Most of the time, it takes me hours to figure our what people are saying! But stick to this board. Some guys really know what they are talking about and they are very helpful.
I have an 03 TrailBlazer LT with around 500 miles on it. Yesterday I was on the highway and, when I was going through a toll booth, I notices a squeaking/squealing noise from about 5 to 15 MPH. It is very hard to describe other than a squealing or squeaking noise. It is not really loud and, like I said, doesn't start until about 5 MPH and goes away at about 15 MPH. It is hard to hear unless I am next to a building or something on the drivers side, so I am assuming that it's a wheel on the drivers side. Anyone have any experience with a squeaky wheel on these TB's? I did a little more reserach and here is what I found:
-It does it in drive and reverse. Could the tranny be the culprit here? I can hear the "whine" that the tranny normaly makes when accelerating in reverse.
-It makes the noise when I shift from drive to neutral also, so I am thinking the tranny is not the cause. As I coast in neutral at the 5-15 MPH speed it still makes the squeak.
-Moving the front wheels left to right and back while the noise is being made has no effect on it.
-Applying the brakes also has no effect on it, except to stop trhe noise when the vehicle stops.
Also, I am not totally sure that the noise goes away after 15 MPH, but at least that's the speed where outside road noise keeps me from hearing it.
-Also, with the windows up, I can't hear it at all and if I am not next to something that will echo the noise (a building, etc.) I can't hear it either so that gives you an idea of how loud it is.
So, anyone have any ideas? Tranny, transfer case, front end, rear end...or maybe just a wheel bearing? Please post back and any suggestions are greatly appreciated.
Thanks in advance,
Todd
Yes it is "drive by wire".
Good Luck with your new ride.
2002 Envoy XL SLT Polo Green build date 5/02, Bose/limited slip/running boards. Added GM accessories 4 all black mud flaps/bug guard. Soon to be added accessory: WAAG front runner. I am sticking with all black accessories which compliment the paint which is awesome-- could be the extra money I dumped on the "Protector" package. I use a silicone blade to dry the truck after washing. Never been touched by a chamois.
Chris
Ok.. I've been searching the internet to find information on true HID headlamp conversion kits for the triplets. During my search, it appears that Philips has led the charge in HID systems to date and has a fairly good amount of information available via their website. Unfortunately, I have yet to find any articles related to vehicles that utilize the regular low beam as DRL (daytime running lights) and as a night time application as well. The Envoy's use the same "upper" light for the DRL's and regular illumination at night, therefore this may pose a problem if I were to purchase a HID kit. Basically, the HID lamps would remain illuminated all day, everyday which could definitely cut down on the life expectancy of the HID bulb. At any route, I did find one website that was quite often referred to on the philips.com site. If any of you are interested, check out xenondepot.com and view their pic gallery. There is a full illustration conversion of a GMC Envoy over to the HID system.
I think that I am going to e-mail the store and ask them how the HID system would work for vehicles that utilize the low beam's as DRL's? Additionally, maybe some of you might have more information regarding this? Anyone attempted to convert their lamps?
IExplore2000
I had a very similar problem or squeak when I picked up my Envoy SLT a year ago. Drove me crazy! How do you describe such a thing to the dealer with ten people standing around. At the risk of sounding like an idiot...I did. This service tech across the room pipes up and says he knows exactly whats wrong and exclaims he received some type of GM medal for finding it. Sure. Three people from the same dealership had the same problem!
Go out to the truck and try lubricating the right hinge on the hood! That worked for three Envoys that I know!
Bobbie
IExplore2000
After a year and 3 months in our 02 Trailblazer LS, we are bidding it goodbye. This has been a wonderful vehicle to my family. Unfortunately it will no longer old our expanding family and we must go larger. We have traded it in on a 2003 Chevy Tahoe for which we got an excellent deal. I must say in the last 15 months of ownership, I barely remember what it has needed.
1. A trip for a PCM reprogram for fan noise and rear license plate frame gasket.
2. A burnt bulb and a second PCM update.
Various oil changes and tire rotations.
I hear people talk about fit and finish in their expensive compettitors vehicles. I must say this our TB was done excellent.
So I must say goodby to everyone and enjoy your vehicles.
Walter
jr45 My '03 Bravada does that little stumble or hesitation when you slightly press the accelorator from an idle.
Can report that my '02 TB definitely does NOT do that. Move the accellerator the slightest less than 1mm no lag or delay at all. So, that lag or delay is likely not a characteristic of the drive-by-wire system. There IS hope with a future upgrade in the PCM programming. The most recent PCM program versions for my '02 didn't get released til early '03.
Anyways...I was intrested in replacing the headlights to a brighter light and was wondering if anyone has done so already and if so what kind of bulb? Have you noticed improvment in the light pattern.
I do a lot of driving on dark country roads and if the moon isn't full it's going to be hard to see.
Ken
PLEASE HELP!
No, I cannot but I do have the remedy for those caps (which come across as SHOUTING!).
Press the "Caps Lock" key next to your left pinky until the little green light on the right side of your keyboard is extinguished! :-)
The National Highway Traffic Safety Administration (NHTSA) has released the following information.
Models: Chevrolet TrailBlazer/TrailBlazer EXT Year: 2002
GMC Envoy/Envoy XL Year: 2002
Oldsmobile Bravada Year: 2002
Number Potentially Involved: 314,300
Dates of Manufacture: October 2000 – March 2003
Noncompliance: Certain sport utility vehicles fail to comply with the requirements of Federal Motor Vehicle Safety Standards No. 101, “Control Location, Identification, and Illumination” and No. 208, “Occupant Crash Protection.” These vehicles have an intermittent condition during vehicle start-up in which the instrument panel cluster may not properly power up, resulting in most of the displays, telltale lights, and functions being inoperative.
Remedy: Dealers will reprogram the instrument panel cluster. The manufacturer has reported that owner notification is expected to begin during April 2003. Owners may contact Chevrolet at 1-800-222-1020, GMC at 1-800-462-8782, or Oldsmobile at 1-800-442-6537.
[NHTSA Recall No. 03V096/GM Recall No. 03013].
The Dealership will check to see if the IPC needs reprograming.
If so its a simple fix.
TSB# 02-08-49-004A - (11/01/2002)
Instrument Panel Cluster (IPC) Gauges Read Zero at Times, Gauges Inoperative at Times (Reprogram IPC) #02-08-49-004A - (11/01/2002)
2002 Chevrolet TrailBlazer, TrailBlazer EXT
2002 GMC Envoy, Envoy XL
2002 Oldsmobile Bravada
Condition
Some customers may comment that at times all the IPC gauges are inoperative or read zero at times.
Cause
The IPC cluster module receives information to position the gauges when the key is turned from OFF to ON/START. Random electrical interference with this data information on the serial data line may interrupt the receipt of the information by the IPC. When the IPC data information signal is compromised, the IPC will set the gauges to zero for that complete ignition cycle. The gauges may work properly on the next ignition cycle, if the ignition was off for approximately five minutes prior to the next ignition cycle.
We tested it but there is nothing like real world experiences. If anyone is using three car seats across the middle row. Please share your opinion so that we can make an educated decision.
Thanx in advance.
Also - has anyone had any troubles with their Homelink? I had to re program it and even though I erased the old code and then put in the new one it still sends out the old code because I can open my old garage door.
