Pulled a flat deck with a Camaro on board from from Dallas to Winnipeg. 3rd gear, 70 - 75 mph, 10 mpg, never struggled on hills. Gas stop every 150 miles
The power and tourque are great, as it has had all the latest PCM updates.
Dean
With the load I would expect it to hold the lower gears much longer than under normal driving conditions.
When I said "when it should" I meant that on level ground, it should eventually shift into 2nd and then 3rd as the engine vacuum increases to a certain level. Normally, this can be induced by slightly reducing pressure on the throttle by "tricking" the drivetrtain into thinking that the load is reduced a little and it's OK to shift to the next higher gear. Mine does this fine for about the first 10 miles or so of towing (3-4000 lbs). But after that, it will stay in 1st if I hold the throttle constant and she's singing along at 4500rpm steady speed, long after it should have shifted into 2nd. It does the same thing on the 2nd-3rd shift to the point where I nearly have to remove my right foot to get it to upshift. Then the truck slows too much to hold in third gear and it soon has to downshift back into 2nd. If I don't lift my foot, the truck will keep cruising at 4000 rpm, neither slowing down nor speeding up, it just doesn't want to shift up into 3rd. If I lightly lift my right foot, the rpm will drop and the truck will slow down, but still not shift into 3rd. I would think that this action should cause an immediate upshift.
Keep in mind this is in the level flatlands of NW Ohio.
Dean
thanks.
Walter
BTW: my TB, however, only had about 1,800 miles on it when this problem showed up.
*AND*......before you jokers give me a bunch of grief (like my neighbors do) about the TB sitting in the garage, let me say that my '92 Accord has over 207,000 miles on it, and I *know* it's just a matter of time before it decides to take a dump. So when it does puke on me, at least I'll have the TB ready (paid for?) to be pressed into daily service and not have to rush out to buy a new set of wheels.
No way is it normal. Lots of us take vacations of 1 or 2 weeks at a time. Surely we can't be expected to worry about batteries dying in that time.
Don't monkey around with disconnecting batteries and hooking up chargers. You'll be treating the symptoms without fixing the problem.
If you want to track down the problem yourself, get one of those test lights, pull a fuse and bridge the circuit with the light. If the light comes on for something it shouldn't, there's a short there.
I hate electrical problems.
Some amount of parasitic drain is normal. If the battery is not charged fully when you park the vehicle for a couple of weeks, you can wind up with a discharged battery. Check out the April '02 Techlink article.
Another interesting note: The driver side mirror has gone out again. I think I may have a theory on the cause. I took the truck to a car wash recently and they folded in the side mirrors. When they pulled them out, the guy knocked the the mirror out of alignment. After that, I started to notice it vibrating from wind buffeting at high speeds. Then the mirror started to drift out of place when using the key fob. My bet is that the supports inside the mirror are flimsy, they get broken or damaged and then the sensors or adjusters start to go out of whack. This will be my 4th driver side mirror!
I hope they don't do that recall on the emergency release. I had to use that to roll the truck out of the garage a bit to jump it when the batt died!
BTW, My 2 cents: 30K+ miles, getting around 17mpg mixed driving. 4:10 rear gears. I6 standard length SLT. Decent accel from stop. Good accel at freeway speeds. Very smooth ride (air susp). Very low road noise (even compared to my A4).
The mirrors should darken when more light is available.
What's the red-line for I6 TB?
I guess they figured it's not necessary to point it out because it's rev limited.
I wouldn't trust the rev limit, it's also supposed to stop at 4k in first gear (doesn't)...
It's not supposed to stop at 4000 in first gear. Where'd you hear that? That would make no sense.
but there was some discussion of it back in the day:
posts 3448,3449, and 3455
Yesterday, I drove from my first home in Michigan back to my second home in Ohio with my Envoy loaded to the ceiling with "stuff." Unfortunately I had so much junk in the SUV that I could barely see out of the back window! With only 3k on the odometer, the ride, handling and performance was top notch! I was able to pass others on the road without any effort at all. I definitely appreciate the power of the V-8 in the extended models, especially after my recent trip from Michigan to Nebraska in my aunt's TB LT EXT (6 Cylinder). The Bose system along with the multi-adjustable seats kept me content along the way.
This trip, I had the opportunity to put the "pedal to the metal" and boy was I surprised! Excellent passing power, even with the A/C on and the heavy cargo. Additionally, I averaged 19.4 MPG the entire trip! Not bad for a V-8 eh?
I wish you the best with your new vehicle and last but not least, any particular mods or accessories that you are planning to install on your new SUV? Thus far, I have not done anything major to my Envoy with the exception of the SUV door guards that I installed two days ago. Also, I am still exhausted from applying the Zaino Brothers wax system to my vehicle this past Tuesday! The process pretty much took a full 10 hours (including an exterior hand wash and de-tarring from the roads), but was well worth it.
I am contemplating on purchasing a set of mud guards (if I can find a set that requires no drilling) and maybe the rear bumper step that Tim Lauro had installed on his Trail Blazer. Other than that, maybe an extra set of wireless headphones for the 3rd row passengers to listen to the DVD unit. Why are they not included in the Extended models? Geesh! Out of all the lousy ways to save a buck! Ha, ha :-)
Happy Motoring!
IExplore2000
Here's a link to the spec sheet I saved. Shows trans upshift at 6100 and Rev limit at 6300.
4.2L Spec Sheet
Why mess around with removing and re-installing the "chip" when you can use timed runs between certian RPMs or MPH, or get on a dyno? I've literally done what seems like a hundred such timed runs in my Ford Taurus SHO gauging the effects of mods before getting on a dyno. Timed runs do not lie like the butt dyno does as long as you do direct before and after runs wiht the same temp, Bar, Humidity...
Don McKinnon
2003 TB EXT
Had 2 coils go in 1 day--was really ugly trying to get to the dealer. Had about 40,000 mi. or so when they went. 65,000 plus miles now and ---knock on wood!! But ---the muffler went about a week ago. $466 and change from the Dealer!! for just the part--Went to Mineke and all is well.
The 2002 wheels are tinted gold and are supposed to look that way. They are not fading, discolored or anything else.
GM changed this for 2003.
1) Borla Dual Exhaust: You can get the stock exhaust system out in one piece, but to do so you need to drop the rear end and take the driver's side coil spring out. Not to hard to do, if you have the right tools and access to a lift." Sorry about that Tblazed. Why they don't supply those bolts, you got me, we had those bolts in stock at our shop when my brother did the install on my 2002 Envoy, so I never knew they weren't provided.
2) Envoy rims: They had a gold tint in 2002 that was dropped and changed to clear coat in 2003. I can send you the change list if you don't believe me. So the service writer doesn't know what he is talking about, or is confusing your question with another issue.
3)Hypertech: My contact there has been telling me that they are working on the 4.2 and have been for some time. I too am getting tired of waiting, but I already own a programmer, form my '97 Jimmy that they said they can convert for me for a fee. But I think if I can find someone to buy it from me I might dump it. How much longer can this take? Or is the problem just that they can't get anything else out of this motor, which I find hard to believe.
Just my 0.02.
This site is awesome! Keep up th good work everyone. We will master GM pretty soon!!
tb4me: If your numbers are correct, your new tires are considerably taller than stock (11%). How far off is your speedo?
GAM
Thanks Ken
