NOW you tell me! You replied in an email when I asked you how you did it, all you removed was
one cross link. The guys I had helping me wanted to take a spring out but I kept insisting it wasn't necessary according to what I had been told. Then after messing with it for an hour, time was becoming an issue, so I said cut it in two. No major biggie, the stock system will probably never get used again, but sure would like to have had valid information.
I have been very impressed with the professionalism of my dealer and parts department. They are ordering two different grille inserts for me to see which one I like and have even said if I am repulsed after it's installed they'll take it off at no charge. Dealer is Lemay Pontiac-Buick-GMC in Kenosha Wisconsin.
Happy Motoring
Chris
The Tekonsha Voyager gives me the green led when connected. Both turns signal circuits are working as well as brake lights. When headlight swith is turned on, all lights on trailer light, but so do the backup lights on the trailer, Trailer backups do light when truck is in reverse, Of most concern is that when I depress the brake, the green led dims, but does not turn red as it should. No matter what I do to the level and gain controls, no difference.I do not have the extra accessory circuit connected at the truck battery, but did not think I would need that.
Anyone have a suggestion?
http://www.gmgoodwrench.com/gmgoodwrenchjsp/accessories/home.jsp
Additionally, I like to shop at StylinConcepts.com for accessories. They are pretty good in my opinion. Also, good luck on the "Service 4WD" issue. Mine has 3K on it and has done a few "wierd" things, but I am playing it by ear before I let the techs get ahold of my new baby. Who knows, maybe it was just a quick glitch that corrected itself?
IExplore2000
I've been asked on several occasions, "Wow.. that's a V-8!"
Hot and Nuetral were easy, which left only two others to connect. One was heavy guage which I choose for the brake leaving one that I assume runs all the lights
Should have been simple!!!
My controller is likely 10 yrs old now and although it worked last summer in my previous vehicle, I am wondering if it is the problem.
I just left a message similar to my first post with the good folks at Tekonsha.
I hope they are responsive
Assuming the same setup as the Envoy...
Color coding was:
Heavy dark blue goes to trailer brakes
Black (small)= ground
Small blue was labelled CHMSL (center high mounted stop light) this wire is for the brake light switch
Heavy orange was lablel AUX (as I recall) This is +12v.
I believe you can download a set of installation instruction in pdf form from Tekonsha's site to get the corresponding color code on your controller.
http://www.hitchmen.com/tekon/tekcat/voyager_install.html
Thanks for the help.
Jay
You are correct, all you need is the 7 to 4 pin converter unless of course U-Haul has some type of proprietary wiring system to get you to spend some money. It may depend on the size trailer you are renting.
quickdtoo : Thanks, outstanding link. I do have my manual from the Controller and it matches with what the link shows, and I did hook it up this way.
N7DON: Yeah you are right... I had a brainfart.
In fact the tech at my Chevy dealer explained to me how the wiring for the harness is somewhat redundant in fusing so that a short on the trailer will not take out the truck wiring. There are separate fuses.
I am thinking I have 3 options to pursue.
Perhaps the pigtail I am using that converts the std round 7 pin to a rectangle 7 pin for my Starcraft has a problem. May explain why the trailer reverse light comes on with the headlight switch, or perhaps I have a bad ground on the trailer for the brakes, or perhaps the controller is shot.
Damn: I know I should have chosen Electrical when getting my Engineering degree.
Anyone have a suggestion how to troubleshoot this?
One thing I would like to comment on is problems with other vehicles, Honda Pilot, Toyota etc... Take a look at their discussion boards, they have the same problems as us, and an often comment is that their quality is not what it use to be!! Toyota especially, seems they have problems with hard shifting trannies, comments are head snapping!!! Its been pretty quite here as far as major problems, little things yes, but it seems the foreign makes have their share of problems to. So take it for what its worth!!!
Did you people know that if you buy an import, Toyota, Kia, Honda etc... It does nothing for this countries GDP gross domestic product. That is correct!!! So when you buy a foreign vehicle Edmunds should define and recognize that it does nothing for GDP!!!! That is a measure of the overall economy! So even though Toyota and Nissan have people working in the USA the Sale of the vehicle does nothing for GDP, ask any CPA, or go do your own investigating. So Steve the Host, this should be Edmunds understanding, foreighn brands go to foreighn economies!! No good for outlook of GDP!!!
GAM
I recently turned in a Mitsubishi Diamante after a 4 year lease. The car was in the service dept. one time for a horn. I wish I could say that about my 2002 TB. I believe other countries have qualified workers too.
Frank
We're here to discuss the vehicles and we leave the political discussions to other venues.
This is BS from a vehicle that is meticulously maintained at such a low mileage.
Because I have the small (18.7 gal) gas tank I used to stop more frequently than I really wanted to. This time I decided to put my faith in the DIC. I was not disappointed. The first time I really tested it was on a 350 mile route across Montana. Before starting this leg of the trip, with a full tank the DIC said my range was about 375mi. All the way across the state it consistently showed 25 to 35 miles more range than I had to go to reach my destination. As I pulled into the station at the end of the 350 miles the DIC still said about 25 miles range remaining. Just as I stopped, the low fuel light came on. It took 16.5 gallons to fill. Now, I rely on the range reading rather than fillup with 5 or 6 gallons to spare. I guess I don't need that 22 gal tank after all.
Frank
BTW, the service manager checked and said the new 22 gallon tank WOULD work. Bad thing is the tank retails for $700+!!! More details when I know them.
-- brad barber
peace.love.track.
I just try not to rest my knees there, but it almost drives me nuts when a passenger puts their knees there.
I haven't investigated what it would take to stop the squeak.
Replace D4440 Compressor Assembly
Replace 3033879 Orifice
Replace 2724578 Seal Washer
They aslo tried again to fix my damn mirror's Alzheimer's disease. I'm on my second set of mirror actuators. Grrrr....
brad barber
peace.love.track.
I wired the new set as specified, hooked up the trailer and viola, brakes now work.
BTW: I e-mailed Teknosha with my problem on Sunday night and still no reply. Inexcusable!!!!
Try the NHTSA board. They will investigate.
GAM
Anyway, the new AC acts like the old one. It cools weakly at first even with the windows half open for a while. After it cools some, it works fine. I've been VERY disappointed in the climate system's inability to keep up with Houston's tropical heat. I have my best results by leaving it on 'AUTO'. In this day and time, an AC system shouldn't need babysitting to operate quickly or to 'protect' the compressor. This seems to be a case of 'lowest cost supplier'.
Could you please tell me more about this? How and to where did you re-route the hose? Where exactly should I look to find the hose in the first place?
Thanks....
It has been over a year since I did this, so this is from an admittedly foggy memory. <g>
Jack up the truck on the passenger side, put a couple of jack stands under the frame for safety. Crawl under the truck (having the hood open helps) and look for the hose coming down from the [passenger side of the firewall. It should be just hanging loose. You can probably follow the water stains if you've had your TB for very long. :-)
Anyway, I used a plastic hose connector and another piece of heater hose I had from my race car shop to lengthen the drain hose about 6" so it didn't drain onto the exhaust and frame. I just used a couple of tie wraps to secure the connection. It is pretty obvious what to do if you look under there and all the parts you need are available at any Pep Boys/Auto Zone.
Hope that helps,
brad barber
peace.love.track.
Is there any way to through-bolt the flaps to the sheetmetal instead of using sheetmetal screws (I am assuming this is what they give you)? I want the flaps but I am not too keen on using sheetmetal screws on my new TB. At the very least I would at least look into getting stainless steel sheetmetal screws to help with corrosion. If anyone else has the molded mod guards and cares to comment, please do. I am looking for any and all opinions.
Elevatorguy
The molded mud flaps uses existing screws and holes for 2 of the 3 attachments. The other hole is drilled into the plastic from below. You probably would not notice the hole if the flaps were off.
GAM
