Here I am complaining about having to take in my Trailblazer for the shift lock release lever and IPC reprogram recalls. Got an "IMPORTANT" reminder notice Sat that I haven't had those done yet. Had planned to get those done if/when it needed some other warranty work. So far hasn't needed anything else done.
Mine does somethiing different on one f the 4 FM stations sending out RDS data here in D-FW, "The EDGE- KDGE" continuously switches back-and-forth every few seconds from "The Edge" to "KDGE". Pretty annoying- that display constantly switching. Fortunately I don't listen to that station. Of the other 3, only one has additional "info" that consists of the song title (usually) and I have to press the INFO button to see that. Don't see any way to turn off or change the RDS display.
Frank
My 02 Envoy has same issue, complete with all of the corrosion. I called the dealer. He mentioned "we have had this problem with these batteries for years". I am under warranty, so they will replace and check for corrosion problems.
Love the truck, dissapointing that they would continue to use batteries with a known defect. Especially to use with the battery "cooling" case that hides leaks until they cause a problem.
Took it in and the service advisor said they would replace the battery, neutralize the spillage inside the engine bay, and they would even repaint the inside of the fender!
I got it back with a new battery, but no repaint, and no neutralizer on the spillage. The service ticket said they "cleaned the battery tray."
I'm not going to mess with it anymore...
I figure it's my destiny to ride off the side of a steep mountain incline with my TB and it's failing brakes because of battery acid brake line corrosion. But it's OK, since I won't see anything because the faulty windshield wipers won't wipe the rain off the windshield, and the rear-view mirrors will have adjusted themselves to face Mecca.
I hope we don't get subjected to scrolling banner ads running on our radios if this RDS catches on with more broadcasters.
Frank
By that rationale, you must be too busy watching the road to pay attention to your speedometer. Do you get lots of tickets?
Allen
There's alot of whack jobs on here complaining that the sky isn't green, but I'm in love with mine. I read back to page 100, before finally posting and the only thing I worry about, because I care for all of you, is the Bose stereo upgraders.
I was a tweeker, had 5k worth of equipment in a 87 rx-7, I won IASCA competitions, and no it didn't go BOOM! The dash speaker is obviously not a real tweeter, it is a mid tweeter, or a small mid-range. The only reason it seems to produce highs on a fairly flat drop off is through equalization. This is what Bose does on all of their stuff. So their is a massive treble boost in either the amp or the head unit, if you put in real tweeters your not only losing the mid range of the Bose speaker,your also going to have a massive high end boost. Use the driver eq 3, which is how it's supposed to sound by the way, and all the mid-range shift used in this setting will be lost. If you start getting headaches or bleeding from the ears, just kidding, don't say I didn't warn you!
From the service manager: "The a/c compressor can cause the idle to go up and cause the car to lurch forward, as if you had your foot on the brake and pressed the accelerator. Does not happen all the time as the compressor does not run continuously." To which I said, "so you're telling me this is expected behavior" and he said, "uhm, yes".
Let the comments begin........ :-)
Of the 4 stations here sending RDS ID data, only one seems to send the clock data so it is not consistant.
Also, regarding comments of the usefulness of RDS to scan for station types, that would be nice, but more than 4 stations out of 25-30 in the area need to send RDS data for that to work effectively. Seems like RDS isn't exactly catching on with the broadcasters. One station here used to send RDS ID data and they turned it off over a year ago. Of the 4 left doing it, only one is a commercial station, the other 3 are down below 92 mHz in the nonprofit-public broadcasting part of the FM band. 3 religious stations and one heavy-metal commercial station here use RDS.
With all the rebates, year end sales and low interest rates you could pick up a NEW one for a few bucks more.
~Ken
When was the last time you had any PCM-BCM reprogramming done? There were a couple of programming updates issued addressing unstable idle in August '03.
No. If you drive fast enough, you see the cops before they see you!
So tell us, is the sky really green in your mind? And if it is, are you really in love with your sky?
Since you just bought your new love, I would refer to your feeling as infatuation rather than love. Wait till the tweeters lose their clarity, the midrange bulges and the bass rubs the ground, then see if you still call it love.
BTW I bought a new 2002 in 2001 with a sunroof for $29K.
Frank
2 ways oughta be fine in the dash, just not a single tweeter. Did you guys RTA that setup, it ought to be awfully bright.
My left headlight is pointing too high. Do you need to pull the battery out? The dealer said they adjusted it, but everyone flashes their lights at me so I believe it is still wrong.
I have the XL V-8 Envoy and on several occasions, mine has done the exact same thing mentioned on this board. I can be at a complete stop and about 10 seconds later... BUMP! It's kinda of hard to describe, but I can best describe it as if something hits the underside of the vehicle. I also had a 99 Jeep Grand Cherokee V-8 Limited that did the exact same thing, except that it would force the vehicle ahead by a few feet! Talk about dangerous! As a matter of fact, this was an ongoing problem with the "Slip Yokes" and something that had to do with the Dana rear end on Jeeps new body design (1999 to present)? I can remember the Jeep dealership "lubing" the slip yoke to which the problem would disappear for a few days and then return. They also rebuilt the rear end on the vehicle in addition to several other items, to which NONE corrected the problem at hand.
Unfortunately Jeep (or Daimler-Chrysler) had a bunch of dissatisfied JGC V-8 Quadra-Drive owners and found themselves in a fairly big dilemma relating buybacks. Not only did Jeep buy back my 1999 Cherokee, but they bought back my father's 1999 JGC and my best friends 2000 JGC as well.
When my Envoy started doing this, I kinda had an idea as to what the problem could be. I ran this by my advisor yesterday and he very adamantly told me that the "clunk" issue was ONLY related to the Escalades and Denalis? So.. given that it was fairly late in the evening, I didn't push the issue.
Unfortunately, this problem is sooo sporadic that it's hard to reproduce for the service advisor? Also, it seems as if the cold weather has something to do with this? Now that it's cold here in Ohio, I can feel the "clunk/bump" at least several times a week?
If anyone else out there have any information concerning a "fix" for this, please advise..
IExplore2000
On a side note, anybody who's had the obnoxious clacking/ticking that sounds like a bad lifter should definitely try changing oil! I've had the noise since the dealer performed my first complimentary oil change and switching to 10W30 Mobil1 only made matters worse. Switched to 5W30 semi-synthetic and the noise has all but subsided within about a week of the change. (Apparently these engines HATE 10W30 oil even in the heat of summer....I'm thinking the dealer used 10W30 and not 5W30 on my first change).
Ray
But, are you sure they need adjusting? The correct alignment for the LEFT/Driver side lamp is approximately 1/2 the distance of the bright focus point higher and slightly over to the right. (They are NOT supposed to be aligned perfectly level to each other).
Ray
As far as the link to the A/C compressor: My understanding is that the compressor is always running; there is no on/off cycling. There is some type of control to vary the amount of load on it.
My dealer is tired of dealing with me about this issue. Time to try another dealer.
I may just have to push the issue a little bit more with the service department just to see if they are able to find a possible solution. Since I have had my Envoy, it has ONLY been to one servicing dealership here in town and I honestly prefer to keep it that way.
Fortunatly, I do like these guys/gals that work in the service department. There seems to be a genuine interest in getting the job done right and making sure that you are 100% satisfied. Also, I think that it does some good in terms of keeping a good/consistent paper-trail? For example, my friend has an 02 Envoy and the dealers give him the run around concerning some of his issues by saying, "Dealer X worked on a similar issue prior to your visit, therefore you need to take your vehicle back over there for them to resolve the issue or else GM won't pay us." Unfortunately, It's kind of sad, but true.. he has been taking his vehicle back and forth between two dealers for the past month! Now he's to the point where he has to get the regional representative involved, especially with 37K on the odometer!
Anyhow, I may check with the dealership again should the problem continue to get worse over time. Just curious to see who else has experienced this and if there is some type of fix out there?
IExplore2000
Like others, the studder/clunk/surge happens infrequently, so I wasn't surprised to hear from the service advisor that it couldn't be duplicated. Not sure that there's a tie into cold weather; but am sure that when it's happened, it's been within the first 5 or so minutes of driving the car; idling at a stoplight - "boom" and a quick look to see if I've just been hit.
Congratulations on your "new baby"!
Replaced Michelins at 65000 miles, they still had tread but were getting slippery in the rain.
I would say it is slightly above average in wear and tear, by which I mean it is holding together above average. Never burns oil. I got lifetime free oil changes so I have been changing oil every 3000 to 4000 miles at same dealer where I purchased it. Truck has always been a little noisy when first started in the mornings, but GMC sent me the 100k warranty on the engine.
The studder/clunk didn't take long to develop. It does exactly what everyone here has posted. It's been to the dealer and guess what, can't reproduce. Our TB does not do this so I am puzzled. Wandering mirrors...got those too. Reprogrammed and the issue still exists. I am at a loss as to why GM has not found a fix for these problems.
my old post
#13218 of 13315 Front end noise again by 2k_impala_ls Nov 03, 2003 (8:53 pm)
I had the swaybar links replaced about 1500 miles ago but the noise started soon after the fix. I think it was there before. Every bump I hit I fell a clunk. It even happens after you start going from a stop and dont hit any bumps it will clunk. Seems like a tierod or steering end linkage to me. Guess I have to bring it in again. I checked it out when I rotated my tires and the ball joints and bearings felt tight.
These definitely cycle the compressor. That's what the low-side cycling switch on the dryer-accumulator does: regulates the low side pressure by cycling the compressor. Almost hard to detect the a/c compressor cycling on-off due to the nature of the scroll-type compressor design used.
If the vehicle computer is trying to compensate for the load changing from the compressor cycling, maybe the throttle motor isn't responding to the small position change like it should (or used to when newer) and the RPM drops, causing a loss in torque through the trans, also a temporary loss in trans oil pressure. My theory anyway. Doesn't do that on mine so far.
My TB did develop a little stutter-drop to 500-550 rpm then back to 600 while idling at a light, very intertmittent condition, a few months ago. A bottle of STP Concentrated fuel injector cleaner, and changing to Shell gas with their "substancially more detergent and additive than required" as they claim has corrected that problem. Solid, stable idle at 600 rpm once again. Even got me a Shell card now to get the 5% rebate on their gas, so that it's within a couple of cents of the cheaper brands like Sam's, Quiktrip, Racetrak, and the other discounters. My 5¢ worth. (inflation)
I read about 400 pages of this site before my purchase, so I knew what the issues were. I just didn't care for anything else in this class.
I wonder if this "stutter-clunk" happens mostly with 4WD, 2WD or a mix of both.
Still very satisfied with my '02 TB after almost two years.
