Does any body know of a direct source of the engine noise over 4500 rpm? Intake, resonator, whole engine in general? Not that concerned, I had the exhaust resonator cut off the second day I owned it, just curious. Or would one of you guys sit under the hood while I floor it up and down the road?
http://minimopar.net/oilfilters.html
http://lighting.mbz.org/tech/bulbs/blue/bad/bad.html
If you want the HID look with whiter (slightly blue tint) there are one or two Xenon & Krypton gas bulbs on the market which have DOT approval and run at the standard 55 watts. (Which whould save the wiring harness and lens assemblies, as well as avoid tickets).
Ray
You'd be surprised at just how well a water leak can travel along the inside of a rail, door frame or anything else. My sister's Taurus kept having a wet rear foot well and the source of the water was the FRONT windshield! I'm willing to bet you have a leak at along one of the cargo rails, the seam above the window, the rear hatch or something like that and the water is running along the roof supports and then down.
Ray
GAM
I have been lucky to date, but like to add some additional protection
Have been researching these a bit and can not find a good comparison between the differt units>
Anyone have knowledge or experience with these
Traditional back-up warning system alert you of an obstacle ex. car, child, toy, etc. You still need to get out of the car to inspect and see what there may be and check clearances. You'll find in a back-up camera and monitor, that you can see everything behind you as you back-up without having to get out of your car... Makes backing up a breeze especially when backing out of parking spaces and there is a car waiting right behind you to take your space and allowing you no room to back out properly.
Any ideas???
part replaced.If you had a bad fan clutch on your trailblazer please take the time to call GM at the number listed above so they may consider recalling the part. Thanks.
I am going to do an oil change and use Mobil 1 oil. I have almost 10k on my 03 TB. What intervals do you guys recommend for the synthetic changes? I will also be using a Mobil 1 filter. Do you guys feel the synthetic is worth the extra cost? Also, are any of you using the Fram Sure Drain system? It looks good, but I am looking for some first hand experience.
Todd
Good Luck. tasso
I have been researching this for a few weeks and the information I have reviewed put the Amsoil at the top of the class
The alternative systems provide useful feedback audibly plus with LEDs if you need a visual reference
59K on an '02 seems like a lot, but that's not meant to be an excuse. I have an '02 Envoy XL SLT with 30K on it and I commute almost 80 miles a day, you must really put on the miles.
I've had good luck with taking a reimbursement issue like that to the dealer, but I also do all my business with them--vehicle purchases, oil & filter, tune-ups, check-ups, etc. My dealer came right out and said they appreciated my loyalty and for that reason shouldered most of the cost to replace the wiring harness in my wife's '98 Transport. Saved me about $400.
Chris
Frank
I'm planning on going well past 200,000 on mine and usually change the oil around 8000 miles. I basically follow the owner's manual, which states 10,000 as the maximum, but I find that after around 8,000 enough time has gone by that I don't mind doing an oil change. I've been averaging over 20,000 miles per year, so I'd be constantly chaning oil if I used 3000 mile intervals.
(Just happen to have a picture)
First time I noticed it was wet with oil, I thought I was just being sloppy when taking out the dipstick. Clean it out, and oil gradually seeps up around the two electrical pins down inside the connector. Not enough leakage to drip, just stays wet with oil all the time. Exact same leakage on my friend's TB too. 3 yrs-36,000 miles is the warranty. I plan to have mine replaced just before Jan 16, 2005, when my 3 years are up.
Frank
The Fram Sure Drain system works as advertised. There was some discussion earlier about the drain getting in the way of the inspection plate. I have not had any problem with the drain plug hitting the plate. The drain plug is narrower than the factory plug so the oil will drain a little slower than usual, but I can live with that.
As for the Mobil1 oil filter, I just did an oil change last week and sent a sample to Blackstone Labs for analysis (having used the Mobil1 filter for the first time). The tech that did the analysis remarked on the read out that there was a marked improvement in the amount of insolubles since the last change. So for me, another no brainer.
Todd
Hopefully the dealer can look at it tomorrow. We are still well within the warranty, but I still hope it is not anything major.
kind regards
There was a plastic grocery bag melted onto the muffler. That was the cause of the burning smell.
We now have 13,000 trouble free miles.
tblazed Apr 24, 2003 8:28am
Finally someone else has noticed this.That's 3 out of 700,000+ triplets so far. Not a bad failure rate (.00042% or something like that). Too bad they all can't be 100% perfect.
If it stops working completely, the cam won't advance, a DTC code will set and the SES light will come on.
BTW; Happy Thanksgiving to all triplet owners.
Frank
I filled the tank, and it worked right (showed full), until I used 1/4th of the tank. Seems it does that when gas is betlow 3/4 tank only. Very annoying.
Once below half tank (150 miles or more driven), it occasionally decides to fall on E and lights up the "Low Fuel" then immediately sprints back to Full. Hence, below 3/4th tank, I have no idea how much gas is left in the tank.
Currently it has 200 miles on trip, and range still shows 240Mi???? does that mean the DIC range is determined by gas gauge needle position?
I will appreciate any guesses, ideas, opinions etc.
thanks,
Moby
To answer you question, the 'range' function is based upon how much fuel is remaining in the tank multiplied by your average fuel mileage. If the computer cannot determine the correct amount of fuel the range is going to be off.
Ray
Mine, so far anyway, has never leaked enough to actually drip, but the outside of the electrical connector will collect oil over a fairly short time after cleaning it off with degreaser.
Possibly the oil is evaporating or getting blown back and dispersed but I don't see any evidence of an oily film anywhere else.
My friend's leak wasn't really obvious at first, just looking at it. It had what I would consider a "typical" (for a 30,000+ mile vehicle) light trace or film of oil and dust on it, especially since it is located where a drip or two could land on it when the dipstick is pulled out. When I unplugged the connector, then the oil seepage could be seen down in the connector.
Maybe that's why they have such a long recommended interval between oil changes - to let the oil get thicker and contaminated to plug the leaks!
thanks,
Moby
