-June 2024 Special Lease Deals-
Tim
'02 TB LTZ
OK, I checked it more thoroughly this time. It isn't glued to the panels, but clamped onto the hinge. I haven't noticed any wind noise, though. Are you sure it's supposed to be glued? It looks like it was meant to just hang there and act as insulation.
After the second time the dealer installed a"transmission control module" After the third time dealer could not "duplicate the problem." Has anyone else had this problem?
The vehicle will be going in next week to have have front axle seals replaced.
Key to air bag replacement is stay away from the dealer.
Parts are available, and the job is easy even if you have trouble with doing oil changes.
Usually, any 1000 dollar job at the dealer can be done for 200 at home, parts included.
http://www.bagmasterair.com/air.html
Loved my Lincoln Mark VIII.
WichitaGreg
tim
no tranny expert
http://www.tyguy.net/gmc_2004tb_tt.htm
-- Jim
will spin and leave its' mark on the pavement (at very slow speed). Either the computer is engaging
the transfer case or the positraction is activating (doubtful). It doesn't seem to do this
after I drive a little. Anyone else experience this?
Also, the brake pedal will slowly sink at a stop.
If you press hard, it WILL go to the floor. Anyone experience this? Well, at least I went 1000 miles before my first problem!
Just got back from a 300 mile trip on the freeway.
The computer said I got 22 mpg @ 70 mph. I will do an actual mileage check when I fill up.
GAM2
I was working in the yard near the car this afternoon. The sun was beating down on the back of the car and I could actually hear the license plate bracket popping against the tailgate as it expanded. I may try loosening the bracket as others have proscribed. I will definitely go for the dealer gasket fix, but I'll wait a while on that.
No other problems or concerns to date.
One complaint is the paint job on this car is not that great to me. Somehow my driver side door has a bad scratch down to the sheet metal on the leading edge . The paint job should not be this thin. The cause of the scratch was opening the door and it rub against my garage wall.
Just finished 350 mile trip. 80% highway in Northern Michigan. 70 mph avg. DIC (computer) say 19.2 mpg. Also calculated by hand and it was 19 mpg. Close enough for me.
Envoy SLT 4x4 w/ 4.10 rear end. Nice smooth ride.
Mike
miles, shut down completely on the interstate going 70 mph, thank God we were in the right-hand lane and was able to get off the road. Again was able to start it, brake lights on, no gauges working. Took it back to service, called customer service and received a case number. They came back and said they weren't going to buy back the car they were going to fix it. After 2 weeks they have put in a new computer and that is the "fix" they have for it. They didn't think it would work the first time and it didn't. Service manager has made calls for us to corp. We have made calls to Executive office. They act like we are crazy for thinking this is an unsafe vehicle. Don't know what else to do.
FRANK
IExplore2000@aol.com
restarted, abs light stayed on, was able to drive under one mile to dealer with car stuck in first gear and engine revving like an sob. (all of the above with approx 690 miles on the car). dealer
reprogrammed tcm and pcm as per 01-0604-052.(hope this nbr helps someone else who is having problems). also, my experience with the dealership's service folks has always been great. car seems fine now, but only time will tell. thank goodness this did not happen on the hwy! pretty scary event. keeping my fingers crossed that this will not reoccur.
When I make turns, like when I'm trying to park and the wheel turns more than an certain amount, my Bravada starts to vibrate and seems to lose power and stop. At this point, when I give it gas, I have to give it a LOT of gas to get it to move! This happens in forward and reverse.
I'm going away this week, so I can't have a dealer look at it untill I get back.
Check out the warranty section on http://www.carbuyingtips.com/
Regarding the engine shut-down issue, I too had the service engine soon light come on. I hit the On-Star button and had them run a diagnostic which came up clean. Did those of you that had the problem call On-Star when the light came on? My light has been coming on and off for the past few days and I hope I'm not a candidate for a shut-down.
Good Luck
you are experiencing the same problem I am. I'm guessing the Smart-trak (Dumb-trak?) is locking the transfer case when it doesn't have to. This causes binding in the driveline because the wheels want to turn at differnt speeds but Smart-trak won't let them. Make a sharp 180 degree turn next time this happens and see if you leave a skid mark where the rear wheels traveled. Mine only does this after I start it up (maybe there is a time delay?) and only ocassionally. I have not taken it to the dealer yet. My guess is it is a computer programming problem, not a transfer case problem. Anyone else venture a guess?
GAM2
