A reporter would like to speak with you about your experience; please reach out to PR@Edmunds.com by 7/25 for details.
Subaru Impreza WRX
Bob
I would never own another unless it drove from an enclosed garage to another.
-juice
have fun,
Eric
Has anyone seen this before?
Dan
http://www.turnfast.com/tech_driving/driving_heeltoe.lasso
The way I do it is more like pressing the brake pedal with the ball of my foot and then rolling the right side of my foot over the gas pedal to blip the throttle.
-mike
Such a close pedal spacing was the cause of the mysterious Audi acceleration problem which was really just american drivers expecting a 10"-wide inverted-T brake pedal like on old automatics with 4 wheel drum brakes which required you to stomp the brake with both feet while bracing yourself and pulling up with both hands on the steering while. We've come a long way, baby.
-mike
One warning about the shifter - the SPT shifter is not rubber-insulated like the stock one (at least the stock shift lever on my Forester), so you will feel more vibes in the driveline through the shift lever. I certainly do, but IMO it's worth the trade off for the shorter throw and less rubbery feel.
-juice
Next week I will be in Las Vegas, is there one close to Vegas ?
Check this site for info on that and other schools: http://www.racingschools.com/rally.shtml
Dennis
Eric
http://www.gorally.com/
Any good skier knows what this move with the foot feels like - its the same thing you do to tip the ski up on edge when initiating a turn. It uses the muscle that runs up the outside of the lower leg from the "ankle bone" to the little round bone that sticks out on the side just below the knee.
Pat
Sedans Message Board
* The left handgrip lever is the clutch.
• The right handgrip lever is the front brake, and the throttle is the right hand grip which you rotate backwards to give gas.
• The gear shift is operated by your left foot (unless you own an early Harley or Brit bike [mid '60s or older], which uses the right foot).
• The rear brake is operated by the right foot (again, just the opposite with early Harleys/Brit bikes).
In any event, when downshifting, you pull in the clutch with your left hand, and using two fingers of your right hand and your right foot you brake, and at the same time you rotate the throttle slightly to *blip* the engine, and downshift with your left foot at the same time—thus syncronizing the the engine with the transmission.
The next time you hear a motorcyclist downshifting, and you hear a blip between the shifts, that's exactly what he (or she) is doing.
Bob
Bob
Of the eight tires listed on the Tirerack site in that category, none of them have any kind of mileage warranty--probably because the manufacturers might be a little suspicious of the kind of punishment guys like us are going to put them through.
The survey results give the SP5000 a tread-wear rating of 7.4 which really isn't bad--the average for the eight tires is about 7.0, with 7.9 the best and a low of 6.4. My ball-park guess is you can probably count on at least 25k or so out of them-- unless your WRX doubles at night as the Batmobile
--RA
-mike
Also, on another note..I'm _not_ Batman, guess Mike is..(better for the role then Clooney, but who isn't?)..so I want to buy tires (after wearing out the RE92s somewhat) that will perform pretty well and go for at least 40-50K if I'm not using my car to fight crime and score points with pedestrians.
Eric
-mike
-B
It's nice having this kind of exclusiveness in a car that only costs 24k--especially one that's already made C&Ds 10 Best list. Maybe we'll be the only ones on the block for another year or two.
When it comes to 3/4 worn tires, better safe than sorry is my motto too. Just pay the price and get 'em off of there! Flying off the road backwards into some hedges on a rainy day might be fun the first time around--but that gets expensive after a while.
--RA
--RA
-Dennis
-juice
$30 k 260 hp, couldn't afford it.
Evo? Tommi M. traded his in on a WRX (HEH,HEH)
I'm happy.
twrx
hehe
Oh yeah, you already did.
The EVO looks sweet and even if it was out when I bought my WRX, I would have still chosen the WRX. Subarus are more reliable and the EVO is considerably more expensive (It looks like it will only come with 250HP...what's up with that?). Anyway, since Subaru is likely going to counter with the STi, I would rather have an STi if I wanted to spend that much anyway. That big wing on the EVO7 (although functional at insane speeds) has got to go...there are too many tasteless Civics running around here with similar looking wings.
Stephen
Although it hardly seems worth the trouble these 4-banger FWD folks spend to get their times, compared to cheap power like RWD muscle cars.
The SRT4 Neon looks like every boy racer's wet dream...outrageous body kit and screaming fast motor. Having actually driven a Neon for 5 months, you couldn't get me to go near one even if it ran 12 second quarters.
Besides, not ready to stick a roll cage into a WRX yet. Cringing at the cost of 16" stickies versus 14"... Ugh
You can get an EVO clone now, no waiting. Rhys Millen, son of Rod Millen of Pike's Peak record fame, sells a Rhys edition Lancer with more (some) power.
Stephen
Well, I suppose so, since many of the Neon autocrossers I talked to practically consider their car to be disposable. Replacing parts after every track even is "normal" for them. I guess the cheapness of the parts makes that less painful.
However, as a car that I also rely on to get me to work and back, there is little to recommend. Anybody who thinks the WRX paint is thin hasn't lived with a Neon through the winter. Not to mention all the other problems I had (binding brakes, failed window mechanisms, engine defect). Sorry, this former owner's opinion of the (first gen) Neon is pretty low.
