Subaru Impreza WRX
Reasons for no sunroof on the 2002? Cost, mostly. Weight, you could say, but then why did the 2001 have it? Finally, there is a brace from B-pillar to B-pillar, but the Forester also has this on every model expect the Premium.
Clearly, it could be done. The most likely reason is cost.
-juice
also, my dealer said, most of wrx will have manual transmission...no offense but I think that's a no brainer...I wonder who order wrx with an automatic trans???
dtech114: u're absolutely correct..when I placed my order two weeks ago, the sale person said (after I placed my order) that they will only accept order for 2nd shipment until the end of feb (which is today)...after that customers can hope there;s still wrx left for first year allocation...:)
Not to mention I'm sure most sales will not be pre-ordered, so they just want to have some in stock. Pre-orders are pretty bold in that the buyer, at this point, hasn't even gone for a test drive! Talk about faith!
-juice
Dtech
Stephen
Dtech - that must answer your questions too.
So, if the first allocation is slated to be at dealerships on the 13th, and provided this date could be padded just a little, that means the dealer probably has invoices w/ final price and VIN by... this week?
Dan
I was wondering what the handling diff might be as well but I figured it wouldn't outweigh the advantage the wagon has in versatility. Also, the sportwagon is a much better handler than my 00' OB.
The std keyless entry is exactly that. The WRX does not come w/a std alarm system. The security upgrade gives you the alarm. I have the same thing on my OB.
BTW, I have a silver 5spd WRX wagon on order, should be here around the 15th of March.
Stephen
Just a thought,
Stephen
But look at the WRX - it's more of a 5 door hatchback, if you ask me.
Look at an Olds Custom Cruiser and then a WRX. Do you even look similar to you? Naaaah...
-juice
By the way, here's a site by British Subie Turbo fanatics comparing the new WRX with their beloved Turbos, as they were called in the U.K. before the present model:
http://www.iwoc.freeserve.co.uk/my2001.html
Be sure to check out the link to his "IWOC reviews section". It's a pretty interesting read.
I want a blue sedan... I like those big fender gulges too. Plus I already have a wagon
Who would think a girl could whoop you like that?
-juice
You think there would be a noticeable difference for everyday driving?
thx in advance!
I found out that Subaru will not put folding rear seats in their sedans anymore. So if you need to
put anything long or bulky in your car, you better switch back to the wagon.
They said it's due to future rear crash testing.
They want to look good. This makes no sense to me
at all. Volvos and Saabs have folding rear seats.
Anyway... confirm this with your dealer.
Stephen
I noted that you'd previously wished for better brakes yourself (post #181 "I'd gladly forego the fancy stereo, remote keyless entry, and probably the power windows and locks if I could have the brake setup fitted to the European WRX"). It looks like you've reconsidered. Since you seem to be pretty knowledgable about this stuff, I'll take your reassurances in good faith.
Myron: look in your local yellow pages under Automobiles - Accessories. They should list local shops that do that type of thing. I went with an ASC certified shop, which installed an ASC roof and offered a lifetime guarantee.
I sat in a WRX sedan at the Philly Auto Show, and yes there is only a pass-through. It's big, though, and there is a nice arm rest that comes down too. The wagon has no arm rest but folds flat to reveal a bigger-than-you-would-expect cargo area. The only catch is the stylish hatch is angled, so don't expect to fit tall boxes.
You can buy the 4-pot brake kit from SPT (Subaru Performance Tuning) today. It's even available for the current RS. Don't let that stop you. I imagine most autocrossers will get that upgrade, while most street drivers will not.
For the picky buyer that wants everything, I'd wait for the inevitable STi version. I'm sure that'll have the brakes, suspension, more power, everything your heart desires. For a *lot* more money, though.
-juice
Dtech
I'll try to open up the intake and exhaust first, because these upgrades definitely won't require replacing any internal parts. Maybe I'll begin by adding another airbox in parallel with the other.
This is a question for the mechanically knowledgeable. (One of whom I'm not)
If the STi comes out stateside, will it be possible to retrofit it's manual six for the five in a WRX?? Is this something worth doing? Cost/benefit?
I do a lot of weekday highway driving, and I'm wondering if an extra gear at the high end will help the engine loaf more efficiently/comfortably.
Any information on what such a change would do for a "spirited" driving style would also be appreciated. (My weekend job.
Thanks everyone for the great WRX messageboard!
As desirable as the 6-speed would be, I don't see how you could justify the cost/benefit ratio.
Bob
I can not say with ABSOLUTE certainty without first hand experience(yet), but from doing some research on the net and in print, power upgrades do SEEM to be relatively safe for the range I mentioned. Just to give you an idea, I have seen mention of Subaru Impeza turbo and high end upgrades with the possibility of yielding anywhere from 300-600hp. Obviously that level of power would require some extensive modifications, but it also means there are plenty of possibilities to make more power, even on the more conservative side.
The stock computer should be good for altering the timing and preventing detonation through the stock knock sensors, but we should also be able to alter the air/fuel mixture by other means if necessary. To my knowledge, the US WRX should use the same computer as the Japanese and Euro version which means it would contain timing maps for a wide range of knock prevention since it has the maps for the higher octane fuels there as well as ours. So, theoretically it would also be able to compensate for the higher boost level produced in those areas as well, if not even a bit more. This would likely require a "reset" of the ECU (by disconnecting the battery for a while), for it to properly compensate for any power upgrade changes. But ultimately a computer upgrade would be necessary for more extreme power levels.
Here are some good Subaru performance sites that I've found:
www.spomotorsports.com
www.rallispec.com
Dtech
Dtech
auto dimming mirror
security upgrade
air filtration system
wheel locks
speaker upgrade package
armrest extention
this bring the msrp to 25532 with Dest. and Delv.
The performance upgrades (shifter, gauge pack, etc.) are dealer installed options and I am not going to put any of those items on the cars until they are sold if the buyer wants them. Also, I sense the inventory will be tightening up. There are eleven dealers in my district and for March allocation which we had Friday (April delivery) we received only one WRX for stock and half the dealers in the district did not receive any! As I have said before, Subaru fills orders first and then allocates what is left to the dealers. This tells me that sold orders around the country are selling briskly.
People have bought automatic Miatas and put in 5 speeds. Without exception, though, they agree they should have just got a 5 speed to begin with.
Wait for the STi version, or live with the 5 speed. FWIW, the engine idled very quietly at the Philly Show.
-juice
I just got off the phone with the sales manager at the dealer and he told me that he has the confirmation for my order. I JUST made the April allocation.....WOOOHOOO!!! Ah...err....sorry...got a little carried away there, but can you blame me?..:)
Anyway, I should have it in 5-6 weeks so I'm REALLY excited!
I ordered mine as a WR Blue Sedan with the air filtration, security upgrade, and spoiler. I wasn't aware of the speaker/subwoofer upgrade when I ordered it or I may have considered it as well, but no big loss there. I can always add those or aftermarkets, but either way, the stock system should sound nice. It's actually lighter without and performance is my primary concern so....hehehe.
Dtech
Now I really do need some help here! Can someone tells me where I can get a WRX wagon $1000 below MSRP in the bay area?
thx!
http://www.vanbortelsubaru.com/tempfile.html
Seriously, I hope that this car will live up to all the praise it has received. I'm a little worried because all the praise that impressed me was for the foreign version of the WRX. Has anyone done proper tests on an American-spec car? I'm really waiting for a Road and Track test, because I trust their opinion the most.
For instance, I hope the American version doesn't get differently-tuned suspension. The Euro-spec version has the ability to oversteer even w/o lifting the throttle, which is a good thing. But I vaguely heard that the American version tends to understeer.
You guys with the first shipment will have to fill me in.
Dtech
