Beyond that, any vehicle with a roof rack will have more interior noise than one without it. Cross winds exaggerate this.
Does anyone have any stories of similar experiences and/or a permanent fix?
We need a little encouragement to continue to look at getting a Sienna.
1. I would think every new car company used semi pads I don't hear them squealing like a pig.
2. My Corolla requires new pads every 1 1/2 years. Something is wrong with that.
Very very disappointing to hear that the Sienna may have this same problems 6 years later in a different model. Any responces to this would be appreciated.
Engine Sludge? Somebody is up to something. There may be problems with engine sludge if a van is not maintained properly, but if you do change the oil at appropriate intervals (3-4K), the Sienna Engine (which, by the way is also used in the Camry and the Lexus, and is a beautiful[!!!] engine) will last for a long, long time.
This is a great and dependable minivan.
I have 3 Toyotas, and I change oil at 5K on 2 of them, and annually on the other, since we never go more than 6-7K a year in it. My pickup has 161K, the Camry 73K and the Sienna 20K. All are V-6 and none of them have sludge (or tranmission problems, for that matter).
In fact, I've never had a car develop sludge.
BTW, the Sienna, Camry, and Avalon are built at the Georgetown plant, which also assembles its own engines, V-6 and I-4. The Lexus uses the same design V-6 but it is not assembled in Georgetown.
On the other hand, my 1996 Plymouth Voyager will probably never develop a sludge problem as the oil leaks out completely every 500-750 miles or so.
Also, is there a pattern with what model year this problem has started? I bought the Sienna because of the reliability of the platform in the Camary / LX300 .
The magnitude of discussion on this issue is incredibly huge, compared to a really small number of reported incidents. How what is largely a war of words got that way is beyond me, but two things have become very clear---(1) There aren't very many actual sludge incidents being reported on the net, and (2) Absolutely no substantive evidence has been shown to support claims that Toyota engines are "prone" to sludge.
"A whole bunch of rhetoric, and nothing of much substance" about sums up progress to date!
Anyone concerned about the issue need not worry if they just use common sense about oil change intervals. It seems there are no concerns if a "severe" service schedule is adhered to--and most driving today falls into that category anyway. Call it 3K, or 5K, as long as it's recognized that oil doesn't last forever, there won't be a problem. And guess what, this advice applies to any make of engine!
Someone said that this issue is "More a problem of the mind than anything else". That seems to be true in more ways than one!
Regards,The Pilot.
Is this an official change of the Owner's Manual? Can they do this? I was told when I purchased my vehicle that extreme driving conditions warranting the 5,000 mile oil changes apply to people doing frequent stops and starts, such as a delivery person, or someone who pulls or carries heavy loads. Now, just owning a vehicle in Florida qualifies as extreme?
As well, what difference does it make to change a recommended service interval anyway? It might also mean the manufacturer or dealer is simply trying to do a better job of looking after your car. But that's just speculation--to suggest any motive whatsoever is just pure conjecture, isn't it!
Has anyone else experienced this, and did their dealer have a fix?
The solution.... Hold onto the edge (metal) of the door, or any where there is some steel/metal, while getting out of the van (prior to your posterior leaving the seat). The charge should then travel right through you without generating the "shock"
2. Here are other peoples complaints. The most dominant complaints on the Sienna are wheel vibrations, sliding door issues, and Engine Sludge. Of these only engine sludge requires an engine overhaul or cleaning. 3,000--5,000.
http://carreview.com/reviews/vans_minivans/product_225.shtml
3. My dealer's service deparatment recommends 3,000 mile changes and NO LONGER THAN 5,000. Stick to that schedule.
4. Make sure that you use only API certified oil of the recommended service level (usually SJ)
5. Never change oil youself during the warranty period. If you can't prove oil changes by documentation Toyota doesn't believe that they happenned.
4. Use good oil filters and change them at least every 3,000 miles. Check after each oil change to make sure that the new one is installed.
5. I personally only use synthetic on engines that may potentially have a sludging problem.
Unlike so many other things with Toyota, oil changes cannot be neglected or even stretched. Oil changes are cheap insurance.
driving from Portland to Minnesota. The Van drove
flawlessly with no problems at all. My back did
get a little sore after several hours of driving
so I had to add a little lower lumbar support to
solve this. The Van handled the mountain passes
with ease. The last time I drove this route we had our
93 MPV which had difficulty going over some the the passes.
I now have 25000 miles on the van with not one
problem, that is except for the Firestone tire
that had to be replaced after it separated internally and caused the Van to shake. Luckily the Van has a full size spare so we were
able to continue until our next stopover with a Firestone
dealer who replaced the tire.
It's frankly not a common issue, but a devistating one. Similar to the bad transmission issue. I'm going to service it every 30,000 miles.
Hopefully with the 2 I'll be able to easily get 200,000 miles out of my car without major engine or tranny problems.
Where is our moderator?
I loved the one response someone made to a sludge proponent, which exposes it for me-- if sludge exists, what is it? A steel and oil combination? Then why would the engine be ok if steel is coming off of it!
Mr_Shiftright "Engine Sludge?" Jul 6, 2001 3:30pm
Everyone, please take future sludge to the dedicated Engine Sludge? discussion. Thanks!
Steve
This concerns the poster's suggestion to visit the Carreview site and check out all the sludge reports for Siennas. So I did.
I counted a total of 92 posts. Only 14 mentioned sludge, and about half of those said it "Had concerns about it", as opposed actually reporting a problem. Most of the other posters said they liked their Siennas.
I'll post more info on this research in the proper Topic, so as not to abuse the privilege of this one last kick at the cat.
Thanks, The Pilot.
I have a 2001 Sienna XLE with 5000 miles on it. Last weekend, I noticed that the luggage compartment Light stopped working. Also I found that when I open the back door the back ceiling light did not light up. Also If I use the remote control and open the back door the van locked itself in a few seconds. This leads me to believe that the
security system thinks that the backup was not open (even it was), this explains why the ceiling light did not come out when the door was open. I was trying to locate the light switch like the one on the side door. I could not find one. Does anyone know where is the open/close door switch? I believe some how the switch is stuck at close position?
Thanks in advance.
Yuan
However, this hitch (part number 87638) allows the muffler to rattle up against it. I have an installation guide from their web site and noticed they have added 2 prongs from which to install the factory muffler hanger. Mentioned that the '01 has a slightly longer exhaust system that prior years. My hitch (built Feb 7/01) doesn't have those prongs. Question to anyone out there, have you installed this hitch with the prongs? Has it solved the rattle problem? Has it lowered the muffler? Has anyone installed a Drawtite or Reese hitch? Do those hitches have a muffler clearance issue?
Thanks;
INKY
I would recommend the Sienna to anyone and will probably get another one if we are still in the Van market when the time comes. Is it perfect? No but what vehicle is. Is it overpriced? Yes but what vehicle isn't.
So my question....
Are the torque convertors and sludging oil problems fixed in this model?
I own a 1985 Toyota Pickup and 2000 Toyota Echo that have no problems. I perform the maintenance on these vehicles and they have performed flawlessly. I was curious to owners of Sienna(s) and their history now in the 2001 and upcoming 2002 model years.
Thanks in advance!
