http://www.wheelskins.com/
http://www.autotoystore.com/WheelskinSolidCovers.html
nice find Rogor, got to get one for my Ram!!!
oh also found a product called forever black, that dyes the black plastic on the mirrors and at the bottom of the windshield, doesnt' wear off like the zaino or mothers back to black, this is the same stuff they use in the factories, have any of you 99 owners had problems with the black plastic fading??? i screwed up and zainoed these areas now it has a white hazy look to it, have tried everything to get the wax off and restore the deep black...
Since I am always thinking, I am considering taking out my side marker/turn signal lights and using the cavity for an air intake. I would then add a light to the "eye brow" for the side marker and turn signal lights. If you have seen the 300HemiC head lights up close and personal you will know what I am thinking of.
First, my dash now rattles and makes other funny noises over the smallest bumps in the road. Second, the rear driver's side door lock does not unlock when I use either the remote or the inside power button--it goes halfway up and stops--likes it's stuck or something? Third, the interior panels/parts make creaking noises going down the road. Fourth, I think the rear door seals are bad because I can hear wind coming through them and it sounds like the doors are leaking when it rains. Fifth, the engine now sounds like its whining every time I accelerate, the idle gets rougher everyday, and the car seems like it was about to stall once or twice. Finally, I now have a quarter-sized dent on the driver's door (not a Chrysler defect but still a bad thing).
I still like the car but I shouldn't be having the problems with it that I am.
link for those interested in joining the chat room is:
http://www.300mclub.org/chatroom2.htm
Beach: a guaranteed cure for most of your 300M problems: turn up the volume on the radio, it will cover most creaking and wind noises--or else buy a good set of ear plugs
a Mercedes its not, but the M is still a great car for the money--
here's a link:
http://www.properautocare.com/fb-1k.html
http://www.autotoystore.com/carcap.html
Good to 'hear' from you, race.
Glenn/drpixel
Is this common, anyone else notice, or should I make an appointment with the 5*?
Just kidding
Do you mean the rpm's will go up, but the car doesn't seem to go anywhere? They you slamm the gas, the car down shifts, then your going?
http://rekord-marine.com/fenders.htm
Did the Wheelskins have a reasonable color match for your interior?
Caveat Emptor! We all love our rides, and would like to improve them by installing after market products. This board has been a real education for me. Sorry the lessons are so expensive for some of you.
10k miles on the bullet and zero problems! Love it!
What you are describing sounds like the lock up function of your transmission. Once the overdrive kicks in the torque converter locks up for efficiency. If you press on the gas or even if you gently tap the brake with your foot on the gas the rpms will increase (not by much) while the lock up disengages the overdrive. Once you stop accelerating the trany will lock up the torque converter again.
BTW this happens on all cars with an automatic overdrive transmission.
I hope this helps
Ara
P.S. I love my M. The only problem I have with it is getting my wife to let me drive it.
I asked them if they had 300Ms with PHP in stock. They made big round eyes at me and said no. Never. THEIR customers are too old for that.
But on the other hand, I have seen them advertise in a newspaper lease deals for 300M - something like $299 per month with zero down. So if someone is in the area and does not need PHP, check them out. Their name is OC Taylor Chrysler.
If you want I'll give the guy I'm in contact with a call.
Fuzz-Like I've said before, NEVER underestimate the power of (super slick and slippery) Zaion!!! ;-)
Off-topic, but you just gotta smile when you read this! Welcome to Alabama!!http://www.al.com/news/huntsville/?Jan2001/24-e10422.html
http://abcnews.go.com/sections/wnt/WorldNewsTonight/wnt010125_daimlerchrysler_feature.html
BTW, did I tell you; the first KK store in the Seattle area will be right down the road from me in Issaquah, scheduled to open in June.
For your convenience, this discussion will also reside in that folder.
Hope to see you there soon!
KarenS
Owner's Club host
Hope that clears up any questions!
KarenS
Owner's Club Host
I went to the Cougar "Club" section on modifications, and it appears to just be a segment of >400 posts, just like this board. Maybe I'm not going to the part of the Cougar site that you think is great, but I didn't see anyplace where things are categorized . . . .
Its been a while since I've posted on this board. I was wondering who has had a performance upgrade to the chip or ECM? Who provided the upgrade? How satisfied with the upgrade are you?
I was in contact with So-Cal Speed and Jet Performance for many months with no luck.
Jeff
ca2stay, I have a meeting for Tuesday to talk to the service department to see about reprograming the ECM. I have been told it is reprogramable, so I am hopeing to do it, since I can't locate a reprogram unit for the newer Chryslers.
