Visitor Agreement.
Anybody have experience or comments?
Easyrider300M
My dealer did the "Headlamp Welt" TSB awhile back and ever since the seam between the front of the hood and the front fascia seems way too big.
The dealer says it meets factory specs...That may or not be true...All I know is it "looks" larger than when I brought it in.
I'd like to play around and see if any adjustment can be made...
(I have a cable modem too, so let 'em rip!!)
tsokol5@comcast.net
Sorry, for the rant and rave, but What are they thinking (or not thinking, is the problem)?
I want to get rid of my Honda next year and was hoping for something good. I may have to keep it another year.
Note: Sometimes the car is not driven at all on the weekend, could this contribute?
Thanks Redvel
I would keep a journal for the car. and write down lenght of drive, tempiture, conditions (rain, snow, ect), how long the car sits before starting it again. To see if a pattern develops.
Have them change out the passengers door. and mention the blue smoke again.
The squeeky wheel gets the grease.
If you've been to the dealer for a complaint in the warranty period, it's documented in their file on your car. Typically, they'll honor a related claim after the warranty runs out. The service manager should be able to confirm/deny.
blue smoke = oil
black smoke = my wife's cooking
To date, warranty work:
Two window motors
One speed sensor
TSB work for rear door interior panels and stereo speakers.
All in all, a wonderful car, especially as I bought a first model year Chrysler! My fuel economy is now about 21 mpg using 87 mostly 40 miles/day commute. Not too bad. I'm looking forward to another (at least) eighteen months of trouble-free ownership. Two more payments and I own the Platinum bullet.
It is too bad Chryco didn't continue to evolve this fine automobile since inception. I still find it to be one of the best looking sedans on the market (does anyone really think a Caddy CTS is a better design than the M???), and a marvelous value in that MSRP is just a number in the window...! I've got a few luxuries (driver's seat ingress/egress slide: I love that! and memory settings for mirrors, e.g.)that the evil wife's Lexus RX300 doesn't have.
This car may not be the fastest to 60, pull the most .gs on the skidpad or stop the shortest. But, it does everything well! When you combine all the elements of performance, style, economy, utility and VALUE, I don't think there are a lot of ~$30k cars (not cars that START at $30k) that can touch it. Just MHO, of course.
To all that have had lesser 300M owner experiences than I (or most on this board), that is a shame, I feel for you. I hope that Chryco really knocks it out of the park with the next iteration. Good luck to all, continue to enjoy your Ms!
To celebrate this milestone, I think I'll take a road trip this weekend. Now, where should I go? Any thoughts, fastdriver??? ;-)
board...as far as the blue smoke issue, you might
have a problem with worn valve guides...this problem will not cause a problem with performance
and will not lead to more serious problems with the motor, if not repaired...to verify that the
motor is sound have a compression test and/or a
leakdown test done...if there's no loss of compression or any wide swing between the cylinders for compression...the motor is sound...
if you pull the plugs...the tip and the ground
conductor should be grayish white, but you will
probably see oil on the threads of the plugs..this
is the tip off that the guides are worn...jack g
door gaskets shrinking, imperfection in wood trim on dash, one window regulator, 2 door lock solenoids, one window switch, powersteering hose leak, seat movement (bad bolts), bad speaker.
I now have 34k on the dial and everything is running well now. Plan on keeping it at least another 3 years.
Laurasdada: suggestion for a place to go celebrate your trouble free M and warranty expiration: why not FOXWOODS where you can celebrate with free libations, tempting waitresses, nice atmosphere, and the excitement of making a donation to the Indians.
Easyrider300M
Anyway, with the traditional anti-Chrysler bias of its subscriber base (remember that those CR owner reliability surveys are ONLY from CR subcribers), CR's rating of the 300M as above average in reliability must mean it's truly outstanding. Based upon the experiences of several colleagues, I have a hard time believing the MB C-class is ONLY 5% below ave. This does not bode well for the new 300N (since it is reportedly to share many MB components).
Jon
I have two road trips planned for this summer. Next month I'll be driving to Dallas and back (2000+ miles) and the weekend of 9/1 I'll make a trip to Denver for the Grand Prix (1800+ miles). Question for Denver folks: How bad is traffic with the T-Rex construction? We'll probably be staying somewhere near DTC for the race and that project will probably affect our commute!
Denverm, re wheel weight: I agree with what you say about the physics of the thing. But keep in mind on this that the outside diameter of the *tire* remains unchanged; all we've done is move the mass a fraction of an inch from the center of rotation. If you think of how the mass of the wheel and tire is distributed along the radius, at most we've moved the mass 1/2". I suggest that, although the effect is real, it is not significant and may not even be measurable.
Igor
As for T-Rex, I really don't drive that section of I-25 very often, and never at rush hour. Conditions may well be very different in September, too. You might check the T-Rex web site: http://www.trexproject.com/ I'd say either try to avoid it or allocate extra time for the drive.
BTW, thanks for the CD - some great tunes, and an interesting mix.
http://public.fotki.com/Scotian/300m/exterior/exterior/mvc-003f.html
http://public.fotki.com/Scotian/300m/exterior/exterior/mvc-004f.html
Looks like your replacement trim didn't match the original color wise huh? I was pretty fortunate, I don't know why, but the color was a perfect match between the new and old. That was my biggest fear before they installed it.
Redevl -
Let me know if you want to see what the new rear trim looks like and I can take a picture for you. But Scotian's pics show the difference how they are pieced together.
I may end up replacing my other rear trim on my own dime eventually. Unfortunately some "nice" person in a SUV appears to have opened their door on the flat portion and left a nice little dent there. I tried to see if the dentless repair guy could fix it but he was unable to.
There's a product from http://www.bryndana.com/ that can fix or change the color of leather. I bought a can and will be testing it out on some scrap pieces to see what the quality and ease of use is. Hopefully it works as good as they and others who've used it says. The problem is, this type of mod cannot be reversed.
Also, I hope to be ordering my Joshua Tree interior trim this week. Now if I can only get a few days that it doesn't rain.
I regularly read this board and post occasionally, but as I'm sure is true for many, not much to post when all is well in M-land. BTW, I think the Boston area is fairly M populous. Here at work, about 1000 people on campus and at least 4 300Ms in the lot. I was the first, however. Quite the trendsetter.
Raining quite heavily here. Nice to see the water beading on my freshly waxed (polymered?) M.
Hasta manana, amigos.
Hey! How did I know that you prefer MS over FW? ;-)) I haven't been there myself lately. Guess it's safe now that they found the guy who robbed them of "some" chips! Turns out that a friend of mine knows this guy. He has a gambling problem. That's ended now.
Glad your car has held up well for you. Now that I have this car, I know how it feels to be problem free! Fourteen months and 14,500 miles and not a single problem. Just the luck of the draw I guess. Can't wait for some sunny weather and some free time to put on some Z. Last coat was over 2 months ago. Hasn't been washed in weeks either because of all this crazy rain. Thundering and lightning right now. Think it's coming your way! ;-))
Glad you're still here.
fastdriver
Glad you enjoyed the CD. You won't hear any of that stuff on the radio, particularly since you are in an area where one company pretty much rules the airwaves. (Okay, maybe KGNU plays some of that stuff, but that's about it!)
On the wheels, I haven't heard any real data comparing the weights of the various wheels. My 18x8 custom wheels weigh in at 24lbs each. Dubson's 20" wheels were 76lbs each. I would say 76lb wheels will cause a measurable difference, but I'm guessing the Special's wheels are more like mine than Dubson's.
Perhaps this is a question for wire2 or ottowkr. Can either of you guys provide weights for the wheels in question? Obsessed minds want to know!
Igor
Or it could be another ............... Nah, never mind.
fastdriver
I havent been to MS in over 2 years. Any improvements --shopping , restaurants, hotels, casinos... in the last couple of years? I was at FW about a month ago. Spend some time in the Racetrack Betting room and made my donation.
I hope you arent going to do a repeat of that gambler fanatic who thought the casino should give him his money back. You said and I quote "Actually, I plan to hit Mohegan Sun as I've accidently left more of my money there. I'm sure somebody has found it and will be willing to return it to me! "
By your quote, I hope you arent serious about doing that "hit."
I also have problems with Fotki, I thought it was just my computer, but it locks up my computer big time, and seems to take forever to clear.
NO! You said the "C" word! God forbid. ;-)) Two were enough to cross the border!
laurasdada-
LOL.. I can see the headlines now......."Out of stater attempts to recover his losses at MS"! ;-))
fastdriver
They must be doing SOMETHING right! They sell an awful lot of them. The quality can't be a figure of everyone's imaginations.
When you have problems with a car from day one, I don't think the "operator of the vehicle has a huge impact on the durability". The reliability has to be there in the first place before the durability can kick in!
fastdriver
I'm not sure about the tilt mirrors since my 1999 does not have them. The thought about turning either or both features off from the overhead console is highly likely if you have a 2001+ model.
