Visitor Agreement.
I have had mine parked while on a trip for over 2 weeks, and it started right up. What your dealer told you was bunk. Have the bettery load tested to see if it can't hold a charge.
Whas up wit dat?
Time to rally the troops.
Easyrider300M
-m
In November, I had a whining noise on cold startup. It required the replacment of the engine belt. Everything was fine. Last weekend while filling the washer fluid I noticed the belt had been frayed, & was in danger of breaking. I took it in on friday to have it replaced again. This weekend, when I put my ported airbox back into the car, I noticed the belt is only half on the pully! So to avoid this I'm getting a belt, & putting it on myself. Now, anyone know the correct belt to put on?
On a side note, I have no emmsions in my state. I'm toying with the idea of cutting my cats off the car, & using stright pipe. Anyone think this might affect the car. I know there are 4 O2 sensors(2 on each cat) This is legal to do in MY STATE. Any muffler shop can do it. Any ideas?
As for removing the cats, it should help remove some of the restriction, and make the system louder, but it is something I probably woundn't do. If the car had a different transmission, I would probably do it though. What state do you live in again?
Racefan, you owe me a dozen Krispy Kremes for this information.
Easyrider300M-Part of the problem is the new TH software. It doesn't work nearly as well as the old software. I can't get it to act the same way twice! For example, I click on my favorites link for TH, and it takes me back 50 posts from where I left off. I have to click on "read subscriptions", then find where I left off before. If I want to post, I usually have to click "login" to get the post box to display. I post less because I know it's going to be a hassle getting the software to behave right.
Categorization-I for one HATE the boards that post messages in categories or separate threads. I like the long flowing format like we have here at TH. I have signed up for eGroups, but never read the posts anymore because the categorized posts are too scattered and in disarray. Some might like that and toat's fine with me. I personally don't like it and prefer not to participate if it's going to be formatted like that. There was a discussion a long time back about doing something like that off the TH site, but very few people had positive feelings about it. Most of TH's problems come from the crappy new software.
As for the transmission changes, I wanted to know if he could change the shift points and set it so that auto stick mode would shift a higher RPMs than it does now. He said this could be done too, All they would need is an hour to do all the changes.
As soon as I get my new wheels and tires, I will set an appointment with them.
Who here has the Eibach Kit ? Ive heard about problems with the Driveshaft and was wondering if anyone noticed anything... I want to drop the car a little for more stability at high speeds...
Keith
Let us know what happens.
That belt I was ranting about BROKE LAST NIGHT! Almost caused an accindent. I was going home doing about 80, changing lanes to exit, when all of a sudden I heard a POP. Lost my power steering, as I was changing lanes, almost hit 3 cars, & and almost didn't make the exit, & almost hit the gard rail. I still had control of the car, but the power went out of the power steering. So, I limped to the dealer, with the battery light on, & all the accessories off. Only to find out the dealers service dep. was closed. I had to leave it there. Unreal!
How many techs does it take to change a belt right?
Please take a look and let me know what you think!
KarenS
Owner's Club
New this week is a California walnut burl kit for the 2001 300M I/Luxury Group. This kit is not shown on the web site yet, but is available by specifying "Luxury Group match" in the order form comments box.
There is a 25% promotion in effect which brings the price to $216.00.
300michael - do you suppose I'd get better treatment from Pitre than Earnhardts? My car is in today for replacement of the window motors but I just received a phone call from them. Since they cannot duplicate the problem they will take no action.
I, too, am surprised you found a dealer willing to reprogram the chip. Let me know how things go. It didn't occur to me to have the dealer reporgram my tire size (but I'm within the 3%).
Igor
Im still going to try though...
Unfortunately I couldnt order the Eibach kit as it was no longer available... I did however order a H&R Sport Spring Kit (from Tirerack)... Lowers the Car 1.4" Front & 1.3" Rear...
They are a progressive Rate spring that is "Supposed" to maintain ride quality during normal driving...
The Eibach's are supposedly progressive as well. It doesn't matter. You will get a much stiffer ride. I'm not saying "don't do it", I just want you to know going in. You will get a stiffer ride, but you won't get any body roll in cornering and you won't get any nosedive under heavy braking. The car will handle like a much smaller car.
300michael:
I have had good luck with Earnhardts, until recently. They told me 2 days to replace the window motors and no loaner car. Then, when I took the car in, they refused to replace the motors because they couldn't get them to fail. ("Yes, we know about the TSBs for the bad regulators, but we're not allowed to fix them unless we see the failure.") What happens if they don't fail until 36,001 miles?
Igor
Before my 3/36K is up I am going to complane about the motors, transmission, and anything else I can think of, so that it is on the record. I too do not want any 36,001 issues comming up.
300michael, I called every 5* dealer within 100 miles of me, & none of them will reprogram the computer. Some said it voids the warranty, or they don't have equipment to do it, or they just do not do that. Told me to go to a performance shop. I guess your lucky
I spoke to JetChip today. Seems they were all set to start selling the modual on Feb 1st. They even updated the website for a little while. I saw it listed there for the 300M. However, yesterday, someone noticed that a little part of the instructions were wrong. They had the wire leads for power, & ground backwards. The power wire was marked ground, & the ground was marked power. They said 2 weeks. Maybe it's a cali thing. Does everything take 2 weeks there. I ordered something from there, & it took 2 weeks to get it. I have something on back order from cali, & it's 2 weeks. Weird???
Let us know how it goes when your get everything reprogrammed...
I dont have the PHP and always wished the car handled a little stiffer... Maybe just what the doctor ordered ...
How much did installation run you ? I want to make sure I get a fair price...
I have babied the car since day one and only have driven 4500 miles so far but it seems much older. The paint is chipping and coming off with numerous flaws and many areas are rough to the touch and no longer shine.
The engine idles and runs rough sometimes and makes loud whining noises. I normally use 89 octane gas and all maintenance has been done. The door seals are bad--it sounds like wind is coming through and when it rains it sounds like water is dripping in.
The dash now rattles and creaks endlessly, even on smooth roads, the headliner makes clicky noises, and the hole front of the car from the dash forward feel and sound like they are about to shake apart when I go over any bumps--along with more creaks and cracks.
Just today the seat started making funny sounds like the motor was on the verge of death even though its position is rarely changed.
I think my car is a lemon. No one else seems to ever have any problems with their M, regardless of year. How serious do the problems have to be to enact the Lemon Law? Will Chrysler buy back my piece of junk like I have heard VW and others do?
being fixed. And it has to be the same problem.
