Look for a black and white odometer style counter at the bottom of the home page. If it's there, you are seeing the "new" web site.
Thanks for your patience. We hope no one was inconvenienced during the transition.
Roger Waters, Prez
Mike Johnston
Hey, I was "slapped on the wrist" by Pat once for using the word "rice" in one of my posts. Thought it was silly, but have minded my manners since :-)
Just sit back, count to 10, drink a Molson, and say "Eh!" to the folks down here in the "lower 48"!!
I used gold to match the "3.5L" logo.
That engine paint on the lettering looks great. I wonder why the factory never did that? Post some details on what you did. I think I want to do mine in Platinum.
I then went to Wally Mart and got some simple gold touch-up paint. This time I just used the brush that came with the touch-up paint and tried to be as careful as possible. There were still a few minor drips that I simply scratched off with an exacto-blade tip after the paint dried.
19-001-01 MAR 01 Steering - Loose Feel/Clunking on Turns
http://www.discounttire.com/dtc/findTireDetail.do?step=details&index=2&productCodeIndex=43968
http://community.webshots.com/album/38170232wLNids
SDMike, what the heck are you waiting for. Go out there and just paint yours. We know you want to
Mike
Every MOPAR pic of the engine shows these chrome pieces, yet I have never seen an actual 300M/LHS with them!
Anyone know if they are actually available somewhere?
lonestarsled: Bought the kit from Stongard. I agree the price is steep, but getting a hood repainted is worse. The kit installed nicely but if you've never worked with this sort of stuff it would be best to practice first. The bumper is indeed the worst piece. It takes time and plenty of patience to work it. Because of the ground effects on the Special I ended up trimming the kit somewhat. But the end result turned out great.
They also provide phone support so I called them in advance and got some installation tips and tricks that helped.
Toms99: Those chrome parts are purely for advertising and show. If you want something like that you'd have to find a plating shop that could do it. Also there's a good chance the parts are non-functional because it is only a display piece. Think in terms of those cutaway engines you see at car shows.
sdmike2: Thanks for hosting lonestar's pics!
phases: Welcome back and thanks for defending our freedom!
I guess I'll try again some other day.
Get a firm foam paint pad and find a paint, like acrylic art paint, that is quite thick. Apply it evenly to the pad and then press down lightly on the letters and lift straight up. It should leave a nice, even, clean coat of paint on the top of the letters. After the paint drys, spray them with a coat of flat clear coat like Krylon.
1) Clean with a degreasing agent.
2) Paint the top of the letters white first to give the red a good base to go on to.
3) Wait a day before applying a second coat or take your M out for a good ride to cure the paint.
4) In between coats sand with a 400 grit paper to smooth it out.
You also need a steady hand and it's a lot easier to see what you doing if you have full sunlight
shining down on the covers when your applying it
Mike
The red wire enclosed in the vinyl wrap is the power wire to the Infinity Basslink (gee, doesn't everyone have one of these by now??)
The install was simple, but I ran into a couple of quirky problems. I'll post them later in case anyone else wnats to take the plunge!
Oh...BTW...Any fellow LHS lurkers here...this bolts right up, even though the LHS is not "officially" listed as one of the cars it is made for. If you think there are few aftermarket parts for the M, there are even less for the LHS. However 99% of the M stuff fits right into the LHS.
