Well, on a recent trip over Labor Day, my family and I (2 adults, 2 kids and luggage) went from Pittsburgh PA to Meadville PA near Lake Erie. For those of you who've never been to Pennsylvania, it's not the flattest land in the country. The trip I took didn't send me through the mountains of central PA, however, there were some hills and twists to contend with.
I figured, hey, this is gives me a good chance to see what the AVG MPG will be. So I gassed up the M with midgrade gas and was on my way. It took about 8 miles of stop and go driving before I hit the interstate, but once there, I averaged 75 mph. Usually going between 70 and 80 depending on traffic. During that time, I had my wife take a snapshot of the overhead computer.
http://public.fotki.com/videoman1/300m_mpg/mpg-reading.html
This was the highest reading I got about 3/4 through the trip. It's about a 2 hour drive of about 100 miles. When I got to my destination, I averaged 27.7 MPG which consisted of around 70% interstate and 30% country roads which I drove around 55 mph.
So the way I figure it, with my dual exhaust, Tornado Air, a flat highway, and keeping with the 65 mph speed limit it is very possible to get 30 MPG with a 300M. Maybe more once I change my intake to an Air Charger.
-vman
Toms99-Your spoiler is similar to the one on the red car in the picture, but not identical. The one in the photo rolls more into the fender line on the sides. The feet on your spoiler are a little further spaced apart and closer to the outer edges. Thanks for the headlight cover info.
Bobspc-Ditto on the headlight cover info.
http://www.sportwing.com/
Good luck!
Silver
I took some pics of the lens on my 99M
that I bought from Joe. I took some daytime
And night pics. the pics are ok. the cam I got
Stinks.its one of those free ones ) here is a
Link http://photos.yahoo.com/bc/brims300m/lst?.dir=/My+Photos&.view=t
got markers at pep boys ) APC brand...
the pin stripe a friend of mine Bob Coslett
he's in ca,
C
http://www.hrsprings.com/
Select APPLICATIONS, Then SUSPENSION, then choose CHRYSLER/DODGE. Don't go by the suggested retail, places like Tirerack.com and others carry them for about $270.
good choice (Avid t4's). You won't regret it!
easyrider300m...
I had the crack in the armrest -- it even started to make a noise when I rested my arm on it. You are right -- they replace the whole door panel!
sirharper...
I had my steering wheel replaced when it started chafing. However, the replacement wheel seemed much cheaper and didn't feel right. Feels a little better now or maybe I'm just used to it. I still regret replacing the original -- the chafing wasn't that bad...
on the 300m front dash and if so how hard? does it
come off with a clip or do I gotta go under dash...grits teeth....:))
the drl module from the dealer. all this mod does
instead of drl's on only at daytime. it keeps them
on all the time. or you can just have drl's only
for daytime. you should checkout the ez board under mods for this mod. theres a lot of good info
hope this helps
http://webhome.idirect.com/~mhicken/
Pick it up, turn it over, and shake.
There, "all clean again"
I'm confused about this query from sdmike: "Also, does the mod just keep the low beams from turning off when you turn on the highs, or something more sinister and complicated in play here?'
I've done no mods to my 2000's headlights, and my low beam bulbs stay on when I switch to high beam (which also lights the inner, high beam bulbs).
check these old mod posts
link.... http://pub88.ezboard.com/f300menthusiastsclubfrm2.showMessage?topicID=30.topic
bcm replacement for flickering light prob---hope it doesnt turn out to be the dimmer
seat bolts for shifting seat prob
seat heater replacement
antenna for overhead garage door opener
drivers armrest depression--possibly split under vinyl
discolored razorstar wheel--not sure if they will replace under warranty
door lock actuator-solenoid on drivers door (second one to break)
visor clip to replace broken clip
So I will be driving a dealer supplied Cheep for a couple of days---what a p o s--rattles,noisy engine--poor turn handling--yuk----whatdya want for nuttin---sure will be glad to get the M back--
I'll let ya know how it turns out.
EZ
Just tape up a butter knife and insert in the seam between the IP and front apron and pry the apron up all along. Then pull the apron rearward to release from the front clips. You'll find the module screwed to the IP extension with a 4 wire plug, 2 for the LED, 2 for the Cds cell (to sense sun load for A/C and control Auto headlights)
go on to reg power when in use. also I like this
mod because I can have my lows my fogs and my highs at lower power now. also since I did that
mod that 300M did for the hood on the fog lights
I get more side light now. and the side of my fogs
look like I got corning lights now.
another set to my clear third brake light too.
so they match my reverse lights when backing up...
Igor
PS. Just returned from my third long road trip of the summer. My '99 just turned over 60,000 miles.
PPS to Denverm: I think Denver drivers all got stupid lately (present company excepted, I'm sure). I had an absolutely terrifying drive up I-25 last Wednesday night.
by street glow or lite glow in my clear third brake lite. I think it will look pretty good. give me some input of what you think..? or
would it show enough red when you hit the brakes.
its just the low beams and DRL's lights. now
if I hit the high beams thats for lights at
full power plus the DRL's. I drive the freeway
daily and a lot of two lane highways too. and no
one has flashed me. I have had this mod for about
four months now.I think those hind lights are really bad when not aimed right. my lights don't
even compare..:)
Silver
take 2 more stars away from my dealer service dept:
they kept my car for 2 days for the 8 repairs noted below
seat heater not in stock yet
antenna for overhead univ remote not yet in stock
visor clip not yet in
wheel discoloration--sorry not covered
armrest indentation: sorry out of warranty not covered--
seat bolts for shifting seats--"please bring in the TSB again" they cant find the tsb on this--how come I can find it!--(3rd time I gave it to them)--supposed to have already been ordered
BCM---one they ordered is defective--will reorder part again--I think they use refurbished bcm's---
door lock solenoid---replaced it --all set
so of the 8 repairs requested , they completed one to my satisfaction in the 2 days they had my vehicle---please note that all the above parts were supposed to have been ordered 3 months ago--they never sent me a postcard to tell me parts were it---but they did make an appt to install the parts-after I called them 4 times asking if parts were in yet--5* star dealer? I dont think so!
My armrest was covered by warranty -- someone else had theirs replaced, too (a couple of years ago).
Sounds like a -3* dealer. Tell them others have had theirs replaced under warranty. If they won't do it, find another dealer!
Are you REALLY surprised? Seems to be SOP at most "5-STARS"!
This past weekend I was in Keene, NH. My friend has a 99 Platinum LHS, upgraded stereo and aluminum wheels that she inherited when her father passed away last year. The car has 29,700 miles. I had an opportunity to be a passenger in the car AND to drive it on Sunday.
On Saturday night, I was sitting in the backseat behind the driver. It was still light out. Headlights set on "A" and rheostat set at "max". All of a sudden, something caught my eye. The overhead display- directions and temp- starting flashing along with the odometer and the CD indicator light- NOTHING else was flashing. It was going from dim to real bright! I didn't say a thing because my friend's husband has NO patience with the "5-STARS" or this car, but just smiled to myself. Then, my friend's husband said to me- ever had this happen to you with the 300? I said no, but plenty of other people have had something similar. I told him to turn the dimmer switch to low and then back to the first notch. Blinking stopped! He said that it seems to happen when it's wet outside. I told him that it may return and that it could be the switch or the BCM! I know he was "thrilled" at the thought of ANOTHER visit to the "5-STAR". He's been there twice recently for something else, but I can't remember what right now. Supposedly, it was fixed twice, but it still doesn't work.
Sunday, I had the opportunity to drive the car. Thoughts of Christine came back to me in a FLASH! LOL... The steering wheel shimmied back and forth at about 60 MPH. The brakes shuddered when stopping and an annoying sound is coming from the rear. It sounds tire related, but is there constantly. I don't know how to explain it exactly. It's not a whine or a thump exactly, but something that should not be there.
I did get to check the left front tire and noticed the usual- WORNOUT on the outside edge. Never looked at the other front tire. I know that my friend's husband takes care of the car because he has plenty of time since he's retired. He just doesn't like spending it at the "5-STAR" while they are supposedly working on it.
One other thing that I noticed while I was sitting in the backseat is that the window switch didn't work. I'm sure that the lockout wasn't on because someone opened the other window. I didn't say a thing to him about this because he's never back there and rarely is anyone else. I don't think they'll have this car for long, so why aggravate him anymore.
How I don't miss ANY of this crap! ;-))
fastdriver
LOL....Nice try, but I KNOW it's not ME!! Those problems were there BEFORE I appeared on the scene. However, I can understand your "worry". ;-))
If I am possessed, I have not set off any alarms yet as I walk past/drive past any LH cars! At least not that I know about.
fastdriver
