Toyota Sienna Maintenance and Repair (2003 earlier)
1373840424372
  • gopackersgopackers Member Posts: 11
    see post 1948 above. Any suggestions?
  • smfransmfran Member Posts: 432
    This happens to our 2000 LE also. I have sprayed silicone which does seem to help somewhat. I would not use WD-40 as it can deteriorate plastic parts.
    I would also appreciate any other suggestions as the problem does re-occur.
  • sharks5sharks5 Member Posts: 4
    My wife just took our 2001 Sienna with 24,500 miles in for an oil change and to have the squeaking brakes checked. I haven't talked with the service manager yet, but I think the dealer is trying to pull a fast one. Here are the details:
    -Dealer found heat spots on rotors and resurfaced front rotors for $87.95.
    -Cleaned and adjusted rear brakes for $41.99 for labor.
    -Parts for brake work were only $3.21 which is ok.
    - Gave the dealer an unopened box with six Mobil 1 quarts of oil and none were returned.
    - She bought the oil filter, but it appears she was charged $13.45 for an LOF, but nothing for an oil filter.
    Should this work have been covered under warranty? The Limited Warranty book says that a maintenance expense of brake pads/linings are not covered, but does not mention rotors or adjusting brakes. The service manager said this is caused by stop and go driving.
    Any suggestions? Any advice would be greatly appreciated. I have had it up to my eyeballs with this particular dealer, but unfortunately they are the closest by about 30 minutes.
  • tony22rtony22r Member Posts: 45
    >-..resurfaced front rotors for $87.95.
    >$41.99 for labor.
    >which is ok.
    The charges you mention above sound about right for dealer performed brake service, in fact it's not too far from what Midas or Pep Boys would have charged.
    Stands for "Lube, Oil, & Filter". Well it's less than what Jiffy Lube would have charged, you should call the Service Dept and check what an 'LOF' normally sells for, then you'll know if they charged you correctly since you supplied the O/F, and they just did the L.
    >Should this work have been covered under >warranty?
    Hmm.. that's a tough one. They might have you under the stop & go driving and 24,500 miles. I guess it depends how much wrestling you wanna do with them to get your money back.
    Try calling the Toyota Complaint line, I *think* it's 800-331-4331.
    I had a Ford Windstar that would Warp the hell out of rotors every 15,000 miles, I *know* for damn sure it wasn't stop & go driving that did That! But that was just one of Many problems with that piece of junk.
    Oh man I fought with the dealership, Ford, Ford complaint dept, you name it. I got a "$2000 off coupon on my next purchase of a Ford vehicle"... i told 'em they could shove that coupon up their @##.
  • cliffy1cliffy1 Member Posts: 3,581
    Its a very tough call. Brake pads are not covered ever. Rotors on the other hand sometimes are. If they warped due to excessive use, or because you or the previous owner didn't replace the pads when it was needed, then no, they would not be covered. If they just warped (which the ones on two of my trucks have), they would.
  • arejohnarejohn Member Posts: 2
    Look at toyota services bulletins at alldata.com.
    There are several on Sienna sliding doors. Noise, sticking latches. etc.
    Rod
  • bobsmith3bobsmith3 Member Posts: 14
    Okay guys out there, give me some advice. Took my Sienna into Toyota for a 45K mile service, which was done for the sum of just under $100. It was recommended to me that I additionally have: fuel injection service ($99.95), Battery service ($18.95), Power steering service ($59.95), Fuel filter ($59.95), Coolant flush ($109.95) and Air filter ($18.95) I declined the recommended services, took the car home, installed a new air filter, cleaned off the battery terminals, and wondered about the necessity of the fuel injection, fuel filter, coolant flush and power steering service recommendations. I regularily use a "fuel injector cleaner" gasoline additive, every several tankfulls of gas. had a coolant flush done about 20K miles and 15 months ago. I routinely have the oil/filter changed at 3000 miles. (cheap insurance) On the "new" reminder window sticker for my next oil change, Toyota indicates that I'm good now for 5000 miles. Any helpful wisdom would be much appreciated.
    I don't know about all of that, but I can tell you that the fuel filter doesn't need done until 60K. If it needs replaced before that, it is a warranty issue. If you ask them about this, they will say that it is not defective and therefore not covered. They will further say it is a preventative thing. Your owner's maintenance guide should tell you the interval on this and all of the other things they suggested.
  • duckshooterduckshooter Member Posts: 156
    I recommend the coolant flush and fill every 20K miles. In addition to your oil, this is also good insurance. If you did it at 20K initially, it's due again.
    I'd think everything else you listed you can do yourself. I just gotta wonder what you get for some of those other things they listed (battery service for 20 bucks? Fuel injection "service" for 100 bucks? Power steering? Ugh.
    Jeff
  • deepandeepan Member Posts: 342
    Looks like the Rear A/C is not working. Didnt notice this before as we always had the front one turned on. I am certain the van has two A/C units and not just a blower. Its a 2000 and under warranty and will take it in next week. Wonder if anyone has experieced this.
    It sounds like you did the right thing by refusing the additional services. You already take good care of your vehicle.
    We're probably will be inthe market for a minivan next year and the Sienna is on my shortlist alnog with the Honda, Dodge and Mazda offerings. I know about the sludge issue and am satisfied that Toyota has addressed this issue. Are there other "issues" or concerns with the Sienna?
  • pjksrpjksr Member Posts: 111
    Deepan: I'm sure you checked the obvious fuse, right?
    The rear A/C compressor is located on the passenger side, aft of the rear wheel. In the 2002, there is a grille on the inside of your vehicle in the general area; I think there may be a fuse behind this grille. (The power door motor is in there too.) If the rear A/C unit IS functioning, you'll get some water dripping from the condensation drain hole under the vehicle, too...
  • beer47beer47 Member Posts: 185
    I read somewhere on the Net that Toyota has addressed the sluge issue with some engine re-design for the 2002 model year. Can anyone confirm or deny such action? I think the article mentioned a PVC valve adjustment and larger ports. Cheers.
    >>The rear A/C compressor is located on the passenger side, aft of the rear wheel<<
    Hey neato, when I get home from work tonight I'm gonna have to go look at this!
    I always thought our Siennas had ONE A/C compressor with just a front & rear blower.
    pjksr... how did you find out about this? You crawl around underneath the chassis lookin for stuff like this? hehe.
    Yeah, I did crawl under there! But I have a Repair Manual that gives components' locations. I was most interested in locating the condensate drain (a rubber hose) to make sure I kept it clean.
    Now, not all Siennas have two A/C units. Be sure yours does before you look for it ;-).
    iirc, there was a running change in the crankcase ventilation system. Check the Sludge board linked in the left navigation bar - Mr. Shiftright has listed the "main" FAQ posts at the top of the discussion there.
    Steve
    thanks pjksr. i didnt know that the compressor was located in the back. i remember a grill in the back and i will chk it tonight. i didnt chk the fuse. is this located under the steering wheel or in the engine compartment. mine is a 2000 sienna and has rear a/c. i'm thinking if i have rear a/c then there should be two compressors. am i right.
    tony22r i think the heater is just a blower.
  • econtre1econtre1 Member Posts: 9
    for the longest time I have had crappy sound coming through the speakers while using the Video entertainment unit install by Toyota of Southeastern distributor. I thought this was the best I could get, until I heard the same setup on my brother's Sequoia. for the past month I have been going back and forward with Stadium Toyota in Tampa FL, who I purchase the vehicle from. First they replaced the VCR unit, then the radio, then the top video monitor. The system sound a whole lot better, but I still can not get a solid stereo(ST) signal on the radio display. in addition I now hear a high frequency pitch from the engine revolutions as I step on the gas and it goes down as I let off. The sound goes away if the radio is turned off and it does not appear to be a problem with regular FM stations or CD playing. Only while using the VES. I am very frustrated that I have to take the van in wait a week or two for a part, then wait some more for additional parts and still can not get satisfaction. The service manager is already involved and all I want is the problem fixed. Does any one out there in the Tampa bay area, having any problems with their signal strength or any other part of their Toyota installed VES. If your system is working fine, I would love to hear from you. You can email me at econtre1@tampabay.rr.com. Thanks in advance to this forum for making this exchange possible.
  • sypsyp Member Posts: 1
    Try this in a safe place.
    1. Put your Sienna in park, pull out the key. Feet off the brake.
    2. Now put your hand on the shifter and pull down like shifting into drive.
    3. My Sienna pops out of park and rolls freely.
    anyone repeat this besides me?
    thanks.
    Your shift lock is not functioning. Take it to the dealer. That should not happen... ever.
  • mheffmheff Member Posts: 1
    Recently I purchased a 2000 model with approx. 25,000 miles. When accelerating the transmission feels like it jerks into gear as it changes. Is this normal or what is wrong?
    Is this when the engine is cold. Once it warms up it should shift smoothly. Toyota transmissions are silky smooth. I have a 87 camry too and when it shifts you hardly notice it.
  • yamanyaman Member Posts: 113
    We have a 2000 and the transmission is very smooth
  • toocajun4utoocajun4u Member Posts: 26
    2002, about 2100 miles, and the transmission is not nearly as smooth (cold or warm) as I expected. Nothing horrible - but nowhere near as smooth as the '90 Corolla this van replaces, or the demo '02 Camry that I drove for a few days last week, or my dad's '01 Tundra. I definitely expected better.
    Besides the general roughness of upshifts, a disturbing trait is "jerkiness" - particularly noticeable when accelerating after a rolling idle. (i.e. slow down for a corner, then idle around the corner. When I press the accelerator after completing my turn, there is a definite jerk - as though there is too much slack in the transmission.)
    Any thoughts?
    BTW, thanks to all of you - your posts on this and the other Sienna boards were instrumental to my purchase decision.
    Many happy miles...Larry
  • cdingcding Member Posts: 27
    I have a problem similar to post #1908. So I will restate the problem here and appreciate anyone that comments:
    >It is a creak/rattle/noise - seems to be coming from the inside door handle of left sliding door. Sounds to me like something is loose and kind-of floating around in there.
    Well, the service department at Stadium Toyota in Tampa, FL has officially gave up on trying to fix my VES system. Now is on to phase two of Lemon Law procedures and calling Toyota to extend them the opportunity to fix the problems. What burns me about this whole issue is that these problems appear to be very trivial to me. VES installations on minivans and SUV's are dime a dozen out there. Why can't they fix my FM signal and filter the engine noise through the system I can't understand it. The saga continues...
  • john751john751 Member Posts: 5
    I just bought a 99 Sienna with 50K miles and found this gritty crust in the oil fill area of the valve cover. I was not aware of the sludge problem until I found this crust and started doing some research. I have read of others having this crust and not having sludge but I have not found an explanation for why it happens. I have all service records showing oil changes at 3K intervals. If anyone can shed some light on this subject, please do.
    John
    I wouldnt worry about it. Its probably on all the V6 engines made by toyota. The filler is bent 90 degress and some oil is left on this area which gets burnt over period. Of changes are done every 3k there shouldnt be an issue. If your engine does sludge up then you have an 8 yr unlimited KM warranty from toyota.
    John,
    First, don't worry about the "crust." As Deepan says, it is oil that remains in that area after a fill, and gets dirty and burned. In my experience though (10,000 miles, 2002 Sienna), the oil that I purposely let set in that spot has not gotten gritty (Chevron Supreme). What really matters is oil under the filler part!
    To ease your anxiety, if you're handy, it is easy to remove the cylinder head cover facing the front of the vehicle. You can then look at the camshafts, etc. for signs of gelling. At your mileage, you'll probably wish to replace the cylinder head cover gasket upon closing.
    Thanks for the info guys. I plan on buying a gasket and pulling the valve cover to see what lurks inside.
  • headers8headers8 Member Posts: 23
    Once in a while, I hear a very soft clunk/thud from under my 02 Sienna. It seems to come from somewhere under the front area, driver side, everytime the front wheel there goes into small ruts on the road. I probably just dont hear it, but maybe the passenger side has this sound too. But when both front wheels go through ruts at the same time, it seems I dont hear this sound.
    I am thinking this could be a ball joint or tied rod (f the van has these) problem...
    My van has already been serviced for oil change/inspection twice already, but dealer has not mentioned anything unusual.
    Has anybody else observed this sound?
  • teles4teles4 Member Posts: 2
    Recently I went to a Nissan dealer in Scottsdale, Arizona to buy a 2000 Toyota Sienna LE with 79K miles on it. The car price was listed $14,995( which is below the retail value suggested by Edmunds) and should be final. We went to the gas station to refill the tank. After that the van couldn't start. It has taken the dealership over 24 hours to get it to restart. and after all the dealer claimed it just needed a new battery. Do you believe in what he said? Is this something I should pursue?
    Teles
  • vvgvvg Member Posts: 10
    There were a couple of posts noting that the Sienna has two "compressors." Are you sure this is correct? I wouldn't be surprised if it had two evaporators - a radiator-like heat exchanger - in the passenger compartment, and one condenser up front (the heat exchanger in front of the radiator, usually. I have never heard of any passenger vehicle with two compressors, since they are engine driven.
  • armm753armm753 Member Posts: 1
    I need some assistance please.
    I am the owner of a '99 Toyota Sienna that was purchased new on 5/17/99. In 1/01, I was transferred to work in Germany. On 5/27/02 with 42,254 miles on the powertrain, the transmission went out. After having it towed 6 hrs to my home to the local German dealership; I was told the transmission was gone. I was given two options by the dealership: 1) Pay up front $5,000.00 for repairs or 2) Have Toyota USA contact Toyota Germany for authorization to pay for all these repairs.
    5/02, contacted customer service 800-331-4331, given a case number and told to pay for these services up front; submit all of this info to Toyota Torrance CA for a board to review for "potential" reimbursement.
    7/02, contacted Toyota customer service again and they are still saying the same as what was told to me in 5/02.
    I've contacted my Congressman (I'm a US citizen, a Federal, Dept of Defense employee serving my country); Better Business Bureau, Federal Trade Commission and National Highway Transportation and Safey Commission for their assistance.
    The German dealership has replaced transmissions in two Siennas for Americans in this area. One was placed at no cost to the owner. I've spoken to him and he owns a 2000 Sienna and his transmission went out at 18,000. I'm still trying to locate the other owner.
    Toyota is stating that due to my vehicle being in a location other than USA or Canada; they don't have to honor my warranty.
    If someone has experienced the same problems with Toyota, please send me an email to ARMM753@hotmail.com.
    I really need your assistance.
    Youre correct. I was told at the dealership that it has only 1 compressor for sure and possibly two evaporators. also the rear a/c will not work without the front a/c switch pushed in (and fan speed set to anything otherthan off)
    It is correct that Toyota is not obligated to honor the warranty outside North America. This is actually stated in your original warranty book that came with the van. Your van's warranty is covered by Toyota Motor Sales, US and technically not Toyota itself. I know this is an odd distinction, but I believe it is a common practice in the automotive industry.
    Having said that, you will *probably* be able to get the work covered, due to your status. I don't know how to advise you as to how to go about this, but I know it is done with some regularity. I used to work at a dealership with a guy who's wife was stationed in Germany and he told me about the process involved in warranty claims. He said it was slow and frustrating, but customers did eventually get their repairs covered.
    the screw on child seat floor anchor (behind the 2nd row seat driver side) on my friends van broke cant remove the broken screw. Is there any way to get it out like drilling or something and hopefully not damage the van. or is there a way that another self piercing screw can be inserted.
  • asennap1asennap1 Member Posts: 1
    just got our sienna 7 months ago. dont think this is a typical AC smell problem. wondering if anyone else has seen this problem. There is a really mildewy strong smell inside the van. found where the problem is... if you take the drivers side floor mat hook out of its anchor hole.. there is lots of water in there. it is soaking into the carpet. also, on the passenger side if you take the floor mat up and push on the carpet you can hear water squishing around under the carpet. anyone else having this problem?? this to me is a SERIOUS problem in that after being in the van for 20 minutes our clothes actually keep the odor - its bad.
    taking it to my local toyota dealer tomorrow AM but i have a very bad feeling about this.
  • mrfong1mrfong1 Member Posts: 16
    I've noticed a slight decrease in performance in my 2000XLE's air conditioner. I figure it is simply a need for a recharge in compressor solvent. Has anyone used the kits available at auto parts stores to do this?
  • gopackgogopackgo Member Posts: 1
    Dear Packer fan (#1948),
    I had the same problem. I tried washing and re-lubing with lithium grease to no avail. I brought it in for a 35K service check and mentioned it to the technician. When I picked it up, the door opened like new. I called the dealership and got the fixer on the phone. The problem? Well, one of my kids spilled some 7-Up on the floor. It dried to a tacky, clear finish. So, if you managed to wrench the door open, you could see nothing. When you closed it and it sat for a while the "glue" set up again. A toast to the man, all around! (Even though he was a Bengals fan....)
    Thanks gopackgo. The door has been good all summer, I guess my kids just haven't spilled any sticky drinks in a while! If it happens again I will try a good cleaning and see if it helps.
  • jhuletjhulet Member Posts: 2
    My wife and I purchased our first minivan on July 24th, 2002, Last Wednesday. After our rather good experience with our 1994 Camry with 147,000+ miles on it, we really wanted a Sienna.
    We didn't want to invest $27,000 for a new Sienna so we searched for a nice used one. We found one at your local Toyota Dealership here in Traverse City, Michigan ( Traverse Motors, Inc.)
    It was a 1999 Toyota Sienna in perfect cosmetic condition and ran and drove smooth as silk. It has 68,000 miles on it. We drove it off the lot last wednesday, July 24th, 2002. The next day the 25th, thurdsay we began to notice white/blue smoke on startup, not always the first of the day, but at different times during the course of the day. I called my salesman at first sight. His first thought and suggestion was moisture in the exhaust and was wondering if it was blue or just white. Its blue & white and a few times "plumed" out the exhause and over the van and down the windshield, viewed from the drivers seat! No it doesn't do it all the time, on all startups, but most. And its not as bad sometimes as others...it varies.
    Anyway...my salesman told me to give the service department a call and schedule an appointment to have it looked any anyway - to be safe. This was Thurday and it was going to take a week, until this coming thurday to get it in.
    IN HE MEAN TIME, I did some deeper research on the vehicle in general and thats were the ulcer started! I was jaw a gape finding all the talk about engine gelling/sludge, something I had never seen or heard of before, and surely never expected Toyota to roll something out the door with any major problems like this... I was in shock.
    So, I purchased the 1999 Sienna with 68,000 miles on it USED. I understand that I am the second owner per the title. I notified the Toyota dealership the second day of ownership to bring to light what the vehicle was doing... It is supposed to have a 30 day/3000 mile warranty from the dealership. I have no PAST HISTORY of maintence of oil changes......
    What do you all think they will tell me Thurday the 2nd of August when I bring the Sienna in to get checked out? =)
    Jason
    Traverse City, Mi
    If it is what you think it is, you should be able to get relief under what is called an SPA. It is my understanding that Toyota has been pretty generous when it comes to used car buyers. My guess is that your dealer will coordinate a claim with Toyota. If they don't contact Toyota yourself. Check the Toyota response topic to this issue for contact information.
    My Sienna recentlky got a scratch and visible ding on the passenger side sliding door. I think that if only I could get to the inside of the door, I could probably push the ding out.
    Does anybody know how to remove the sliding door back inside panel?
    I also retouched the scratch with the Toyota touch up paint pen. Is there a batter way to retouch it?
  • drseuss1drseuss1 Member Posts: 4
    I have a 2000 LE with a couple of sticky sliding doors. I noticed another poster said they belive it was liquid from a spilled childs drink. I would be dubious of this answer. This is what my dealer told me when I first brought it in. I have had this problem for three years and have learned to live with it. Nobody has posted on this board how to fix this problem, but a number of people have posted about the sticky sliding door problem.
    My vehicle is at the dealer as we speak. I told him/her that this is my number one priority to get this thing fixed. I have tried silicone spray, cleaning the door, other lubricants. Nothing works. The problem is much, much worse in the winter. I live in VA.
    The dealer knows all about the sticky latch problem and I suggested they change those. I figure I'm going to have to learn to live with this problem.
    For those researchers, the door only has the problem on the first open. Once I get it open I can open and close it at will.
    Which dealer is your van at?
    Hello Folks,
    Ok, after waiting two days in the dealership shop, the verdict was after all, sludge. They are going to "rebuild" the engine, not replace it. My van went in running great, just had blue smoke at startup, sometimes with or without a warm engine. They said it would take about a month to get the work done as there are currently 5 vehicles before me! The serviceman said that he was doing them on a first come first serve order. oh well... They told me to come back and pickup the van and drive it, just make sure you keep oil in it...
    I am wondering about what a "rebuilt" engine is? And what is thought about rebuilt engines? Whats the gig with a rebuilt engine? Better then before, like new? Is there usually a "break-in" period like a new engine? Is a "rebuilt" engine a good deal? Can I think of it as setting my odometer to Zero? Please throw some opinions at me!
    Jason
  • davemmdavemm Member Posts: 33
    As far as rebuilt engines, there are also re-manufactured engines. When I replaced my Jeeps engine, I went with a re-manufactured engine. A re-manufactured engine has more new parts, some even claim they are better than new.
    Do a search on remanufactured vs. rebuilt engines and you&#146;ll find some interesting facts.
    What they will do isn't exactly a rebuild but I guess it could be called that. The disassemble the engine down to its component parts. Most of the parts only need a cleaning. After they are cleaned, they are inspected. If they are damaged or out of spec in any way, they are replaced. You will also get the new valve cover which has a different part to reduce the chances of a recurrence. It is a VERY involved process. The end result will be equivalent to a new engine.
    So, you didn't have any problems getting this repair covered did you? That's good news.
  • chum05chum05 Member Posts: 4
    Has anyone else experienced "creaking" and a slight "rattling" from the sliding door on the drivers side? If so, is there a fix for it? The dealer claims not to hear it when we bring it in, but having just returned from a 1200 mile trip - I can attest to its existence!
